251 if (fabs(h1_info.
coef - h2_info.
coef) > 0)
Definition: cs_hodge.h:86
bool cs_hodge_vpcd_voro_get(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Build a local Hodge operator for a given cell using VORONOI algo. Hodge op. from primal vertices to d...
Definition: cs_hodge.c:3453
void cs_hodge_compute_wbs_surfacic(const cs_face_mesh_t *fm, cs_sdm_t *hf)
Compute the hodge operator related to a face (i.e. a mass matrix with unity property) using a Whitney...
Definition: cs_hodge.c:4763
bool cs_hodge_edfp_cost_get_opt(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Build a local Hodge operator for a given cell using the COST algo. Hodge op. from dual edges to prima...
Definition: cs_hodge.c:4250
bool cs_hodge_fb_cost_get_stiffness(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Build a local stiffness matrix using the generic COST algo. The computed matrix is stored in cb->loc ...
Definition: cs_hodge.c:1888
bool cs_hodge_vb_ocs2_get_aniso_stiffness(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Build a local stiffness matrix using the Orthogonal Consistent/Sub-Stabilization decomposition (OCS2)...
Definition: cs_hodge.c:2349
bool inv_pty
Inversion of the property evaluation or not.
Definition: cs_hodge.h:156
Definition: cs_hodge.h:83
bool cs_hodge_vb_cost_get_aniso_stiffness(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Definition: cs_hodge.c:2161
bool cs_hodge_vcb_voro_get(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Build a local Hodge operator for a given cell using the Voronoi algo. This leads to a diagonal operat...
Definition: cs_hodge.c:3105
cs_hodge_type_t type
Definition: cs_hodge.h:165
static bool cs_hodge_param_is_similar(const cs_hodge_param_t h1_info, const cs_hodge_param_t h2_info)
Check if two sets of parameters related to how build a discrete Hodge operator are similar...
Definition: cs_hodge.h:242
cs_hodge_compute_t * cs_hodge_get_func(const char *calling_func, const cs_hodge_param_t hp)
Retrieve a function pointer to compute a discrete Hodge operator.
Definition: cs_hodge.c:1438
Structure storing the evaluation of a property and its related data.
Definition: cs_property.h:199
bool cs_hodge_epfd_cost_get(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Build a local Hodge operator for a given cell using the COST algo. Hodge op. from primal edges to dua...
Definition: cs_hodge.c:3597
bool cs_hodge_epfd_ocs2_get(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Build a local Hodge operator for a given cell using the Orthogonal Consistent/Sub-Stabilization decom...
Definition: cs_hodge.c:3775
bool cs_hodge_vb_wbs_get_stiffness(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Build a local stiffness matrix using the generic WBS algo. WBS standing for Whitney Barycentric Subdi...
Definition: cs_hodge.c:2730
void cs_hodge_free(cs_hodge_t **p_hodge)
Free a cs_hodge_t structure.
Definition: cs_hodge.c:1379
Definition: cs_hodge.h:89
bool cs_hodge_vb_cost_get_iso_stiffness(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Definition: cs_hodge.c:2098
bool cs_hodge_fb_voro_get_stiffness(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Build a local stiffness matrix using the Voronoi algorithm The computed matrix is stored in cb->loc a...
Definition: cs_hodge.c:2029
bool cs_hodge_vb_voro_get_stiffness(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Definition: cs_hodge.c:2623
bool cs_hodge_epfd_bubble_get(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Build a local Hodge operator for a given cell using the COST algo. with a bubble stabilization. The discrete Hodge operator is stored in hodge->matrix Hodge op. from primal edges to dual faces. This function is specific for vertex-based schemes.
Definition: cs_hodge.c:3689
void cs_hodge_set_property_value_cw(const cs_cell_mesh_t *cm, const cs_real_t t_eval, const cs_flag_t c_flag, cs_hodge_t *hodge)
Set the property value (scalar- or tensor-valued) related to a discrete Hodge operator inside a cell ...
Definition: cs_hodge.c:1807
cs_hodge_t ** cs_hodge_init_context(const cs_cdo_connect_t *connect, const cs_property_t *property, const cs_hodge_param_t *hp, bool need_tensor, bool need_eigen)
Create and initialize an array of pointers to a cs_hodge_t structures. This array is of size the numb...
Definition: cs_hodge.c:1340
Definition: cs_hodge.h:144
bool cs_hodge_fped_voro_get(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Build a local Hodge operator for a given cell using VORONOI algo. Hodge op. from primal faces to dual...
Definition: cs_hodge.c:3832
Definition: cs_hodge.h:186
Definition: cs_defs.h:322
Definition: cs_cdo_quantities.h:132
double coef
Scaling coefficient value.
Definition: cs_hodge.h:168
bool cs_hodge_vcb_wbs_get(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Build a local Hodge operator for a given cell using the WBS algo. This function is specific for verte...
Definition: cs_hodge.c:3185
cs_hodge_algo_t cs_hodge_set_mass_algo(const char *eqname, cs_hodge_algo_t reac_algo, cs_hodge_algo_t time_algo, cs_hodge_algo_t srct_algo)
Check the consistency of the settings between terms related to a mass matrix and define the common al...
Definition: cs_hodge.c:1580
bool cs_hodge_vb_bubble_get_iso_stiffness(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Build a local stiffness matrix using the generic Bubble algo. The computed matrix is stored in cb->lo...
Definition: cs_hodge.c:2223
Definition: cs_field_pointer.h:128
void cs_hodge_free_context(cs_hodge_t ***p_hodges)
Free a set of cs_hodge_t structures.
Definition: cs_hodge.c:1405
Definition: cs_hodge.h:137
Definition: cs_hodge.h:91
bool cs_hodge_fped_bubble_get(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Build a local Hodge operator for a given cell using the Bubble algo. Hodge op. from primal faces to d...
Definition: cs_hodge.c:3999
bool cs_hodge_edfp_bubble_get(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Build a local Hodge operator for a given cell using the Bubble algo. Hodge op. from dual edges to pri...
Definition: cs_hodge.c:4336
cs_hodge_type_t
Type of discrete Hodge operators.
Definition: cs_hodge.h:81
bool cs_hodge_fb_get(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Build a local Hodge operator on a given cell which is equivalent of a mass matrix. It relies on a CO+ST algo. and is specific to CDO-Fb schemes. The discrete Hodge operator is stored in hodge->matrix.
Definition: cs_hodge.c:3019
Definition: cs_hodge.h:138
void cs_hodge_set_property_value(const cs_lnum_t c_id, const cs_real_t t_eval, const cs_flag_t c_flag, cs_hodge_t *hodge)
Definition: cs_hodge.c:1725
bool cs_hodge_vcb_get_stiffness(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Definition: cs_hodge.c:2867
cs_hodge_algo_t
Type of algorithm to build a discrete Hodge operator.
Definition: cs_hodge.h:135
Definition: cs_cdo_local.h:60
Definition: cs_hodge.h:140
Definition: cs_hodge.h:141
cs_hodge_t * cs_hodge_create(const cs_cdo_connect_t *connect, const cs_property_t *property, const cs_hodge_param_t *hp, bool need_tensor, bool need_eigen)
Create and initialize a pointer to a cs_hodge_t structure.
Definition: cs_hodge.c:1276
bool cs_hodge_fb_bubble_get_stiffness(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Build a local stiffness matrix using the generic COST algo. with the usage of bubble stabilization...
Definition: cs_hodge.c:1959
Definition: cs_defs.h:316
const cs_hodge_param_t * param
Definition: cs_hodge.h:188
bool cs_hodge_fped_cost_get(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Build a local Hodge operator for a given cell using the COST algo. Hodge op. from primal faces to dua...
Definition: cs_hodge.c:3908
void cs_hodge_circulation_from_flux(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t t_eval, const cs_hodge_param_t hodgep, const cs_property_t *pty, const cs_real_t flux[], cs_real_t circul[])
Compute cellwise a discrete hodge operator in order to define a circulation array from a flux array...
Definition: cs_hodge.c:4652
cs_property_data_t * pty_data
Data evaluation.
Definition: cs_hodge.h:190
cs_sdm_t * matrix
Definition: cs_hodge.h:198
Definition: cs_hodge.h:142
unsigned short int cs_flag_t
Definition: cs_defs.h:324
bool cs_hodge_vb_bubble_get_aniso_stiffness(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Definition: cs_hodge.c:2285
Definition: cs_hodge.h:88
Definition: cs_hodge.h:139
void cs_hodge_matvec(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_hodge_param_t hodgep, const cs_property_t *pty, const cs_real_t in_vals[], cs_real_t t_eval, cs_real_t result[])
Compute cellwise a discrete hodge operator and multiple it with a vector.
Definition: cs_hodge.c:4422
bool cs_hodge_edfp_voro_get(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Build a local Hodge operator for a given cell using VORONOI algo. Hodge op. from dual edges to primal...
Definition: cs_hodge.c:4085
bool cs_hodge_vb_cost_get_stiffness(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Definition: cs_hodge.c:2398
Set of local quantities and connectivities related to a mesh face Structure used to get a better memo...
Definition: cs_cdo_local.h:279
bool() cs_hodge_compute_t(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Build a discrete Hodge operator or a related operator (such as the stiffmess matrix) for a given cell...
Definition: cs_hodge.h:221
cs_hodge_algo_t algo
Definition: cs_hodge.h:166
Definition: cs_hodge.h:85
Definition: cs_hodge.h:84
bool cs_hodge_vpcd_wbs_get(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Build a local Hodge operator for a given cell using WBS algo. Hodge op. from primal vertices to dual ...
Definition: cs_hodge.c:3324
void cs_hodge_param_log(const char *prefix, const cs_property_t *property, const cs_hodge_param_t hp)
Output the settings related to a cs_hodge_param_t structure.
Definition: cs_hodge.c:1660
bool cs_hodge_edfp_cost_get(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Definition: cs_hodge.c:4161
Structure storing all metadata/parameters related to the usage of a discrete Hodge operator...
Definition: cs_hodge.h:154
bool cs_hodge_epfd_voro_get(const cs_cell_mesh_t *cm, cs_hodge_t *hodge, cs_cell_builder_t *cb)
Build a local Hodge operator for a given cell using VORONOI algo. Hodge op. from primal edges to dual...
Definition: cs_hodge.c:3515
void cs_hodge_copy_parameters(const cs_hodge_param_t *h_ref, cs_hodge_param_t *h_cpy)
Copy the set of parameters associated to a discrete Hodge operator to another one.
Definition: cs_hodge.c:1699
Definition: cs_hodge.h:87
