#include "cs_field.h"#include "cs_flag.h"#include "cs_param_types.h"#include "cs_xdef.h"#include "cs_xdef_cw_eval.h"#include "cs_xdef_eval.h"
Include dependency graph for cs_property.h:Go to the source code of this file.
| struct | cs_property_t |
| struct | cs_property_data_t |
| Structure storing the evaluation of a property and its related data. More... | |
Macros | |
| #define | CS_PROPERTY_MASS_DENSITY "mass_density" |
| #define | CS_PROPERTY_POST_FOURIER (1 << 0) |
| #define | CS_PROPERTY_ISO (1 << 0) |
| #define | CS_PROPERTY_ORTHO (1 << 1) |
| #define | CS_PROPERTY_ANISO (1 << 2) |
| #define | CS_PROPERTY_ANISO_SYM (1 << 3) |
| #define | CS_PROPERTY_BY_PRODUCT (1 << 4) |
| #define | CS_PROPERTY_SUBCELL_DEFINITION (1 << 5) |
| typedef cs_flag_t | cs_property_type_t |
Enumerations | |
| enum | cs_property_key_t { CS_PTYKEY_POST_FOURIER, CS_PTYKEY_N_KEYS } |
| List of available keys for setting options on a property. More... | |
| static bool | cs_property_is_constant (const cs_property_t *pty) |
| returns true if the property is steady and uniform, otherwise false More... | |
| static bool | cs_property_is_steady (const cs_property_t *pty) |
| returns true if the property is steady, otherwise false More... | |
| static bool | cs_property_is_uniform (const cs_property_t *pty) |
| returns true if the property is uniform, otherwise false More... | |
| static bool | cs_property_is_isotropic (const cs_property_t *pty) |
| returns true if the property is isotropic, otherwise false More... | |
| static bool | cs_property_is_subcell (const cs_property_t *pty) |
| returns true if the property is allowed to be evaluated on a sub-partition of a cell More... | |
| static const char * | cs_property_get_name (const cs_property_t *pty) |
| Retrieve the name of a property. More... | |
| static cs_property_type_t | cs_property_get_type (const cs_property_t *pty) |
| Retrieve the type of a property. More... | |
| static int | cs_property_get_dim (const cs_property_t *pty) |
| Retrieve the dimension of the property. More... | |
| void | cs_property_init_sharing (const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect) |
| int | cs_property_get_n_properties (void) |
| Retrieve the number of properties. More... | |
| cs_property_t * | cs_property_add (const char *name, cs_property_type_t type) |
| Create and initialize a new property structure. More... | |
| cs_property_t * | cs_property_subcell_add (const char *name, cs_property_type_t type) |
| Create and initialize a new property structure with an evaluation which can be called on a sub-partition of a cell. This kind of property is not available for all numerical scheme. By default, only one evaluation is performed in each cell. More... | |
| cs_property_t * | cs_property_add_as_product (const char *name, const cs_property_t *pty_a, const cs_property_t *pty_b) |
| Define a cs_property_t structure thanks to the product of two properties The type is infered from that of the related properties The value of the property is given as: value_ab = value_a * value_b. More... | |
| cs_property_t * | cs_property_by_name (const char *name) |
| Find the related property definition from its name. More... | |
| cs_property_t * | cs_property_by_id (int id) |
| Find the related property definition from its id. More... | |
| void | cs_property_set_option (cs_property_t *pty, cs_property_key_t key) |
| Set optional parameters related to a cs_property_t structure. More... | |
| void | cs_property_set_reference_value (cs_property_t *pty, double refval) |
| Set the reference value associated to a cs_property_t structure This is a real number even whatever the type of property is. More... | |
| void | cs_property_destroy_all (void) |
| Free all cs_property_t structures and the array storing all the structures. More... | |
| void | cs_property_finalize_setup (void) |
| Last stage of the definition of a property based on several definitions (i.e. definition by subdomains) More... | |
| cs_property_data_t | cs_property_data_define (bool need_tensor, bool need_eigen, const cs_property_t *property) |
| Define a cs_property_data_t structure (not a pointer to this structure). If property is NULL then one considers that this is a unitary property. More... | |
| void | cs_property_data_init (bool need_tensor, bool need_eigen, const cs_property_t *property, cs_property_data_t *data) |
| Initialize a cs_property_data_t structure. If property is NULL then one considers that this is a unitary property. More... | |
| cs_xdef_t * | cs_property_def_constant_value (cs_property_t *pty, double val) |
| Define a single uniform and steady isotropic definition for the given cs_property_t structure. This is a specialized variant of cs_property_def_iso_by_value since several assumptions are satisfied. More... | |
| cs_xdef_t * | cs_property_def_iso_by_value (cs_property_t *pty, const char *zname, double val) |
| Define an isotropic cs_property_t structure by value for entities related to a volume zone. More... | |
| cs_xdef_t * | cs_property_def_ortho_by_value (cs_property_t *pty, const char *zname, double val[]) |
| Define an orthotropic cs_property_t structure by value for entities related to a volume zone. More... | |
| cs_xdef_t * | cs_property_def_aniso_by_value (cs_property_t *pty, const char *zname, cs_real_t tens[3][3]) |
| Define an anisotropic cs_property_t structure by value for entities related to a volume zone. More... | |
| cs_xdef_t * | cs_property_def_aniso_sym_by_value (cs_property_t *pty, const char *zname, cs_real_t symtens[6]) |
| cs_xdef_t * | cs_property_def_by_time_func (cs_property_t *pty, const char *zname, cs_time_func_t *func, void *input) |
| Define a cs_property_t structure thanks to an analytic function in a subdomain attached to the mesh location named ml_name. More... | |
| cs_xdef_t * | cs_property_def_by_analytic (cs_property_t *pty, const char *zname, cs_analytic_func_t *func, void *input) |
| cs_xdef_t * | cs_property_def_by_func (cs_property_t *pty, const char *zname, void *context, cs_xdef_eval_t *get_eval_at_cell, cs_xdef_cw_eval_t *get_eval_at_cell_cw) |
| Define a cs_property_t structure thanks to law depending on one scalar variable in a subdomain attached to the mesh location named ml_name. More... | |
| cs_xdef_t * | cs_property_def_by_array (cs_property_t *pty, cs_flag_t loc, cs_real_t *array, bool is_owner, const cs_lnum_t *index, const cs_lnum_t *ids) |
| Define a cs_property_t structure thanks to an array of values. More... | |
| void | cs_property_def_by_field (cs_property_t *pty, cs_field_t *field) |
| Define a cs_property_t structure thanks to a field structure. More... | |
| void | cs_property_iso_get_cell_values (cs_real_t t_eval, const cs_property_t *pty, int *pty_stride, cs_real_t **p_pty_vals) |
| Evaluate the value of the property at each cell. Store the evaluation in the given array. More... | |
| void | cs_property_eval_at_cells (cs_real_t t_eval, const cs_property_t *pty, cs_real_t *array) |
| void | cs_property_get_cell_tensor (cs_lnum_t c_id, cs_real_t t_eval, const cs_property_t *pty, bool do_inversion, cs_real_t tensor[3][3]) |
| Compute the value of the tensor attached to a property at the cell center. More... | |
| cs_real_t | cs_property_get_cell_value (cs_lnum_t c_id, cs_real_t t_eval, const cs_property_t *pty) |
| Compute the value of a property at the cell center. More... | |
| void | cs_property_tensor_in_cell (const cs_cell_mesh_t *cm, const cs_property_t *pty, cs_real_t t_eval, bool do_inversion, cs_real_t tensor[3][3]) |
| Compute the value of the tensor attached to a property at the cell center Version using a cs_cell_mesh_t structure. More... | |
| cs_real_t | cs_property_value_in_cell (const cs_cell_mesh_t *cm, const cs_property_t *pty, cs_real_t t_eval) |
| Compute the value of a property at the cell center Version using a cs_cell_mesh_t structure. More... | |
| void | cs_property_c2v_values (const cs_cell_mesh_t *cm, const cs_property_t *pty, cs_real_t t_eval, cs_real_t *eval) |
| Compute the values of an isotropic property in each portion of dual cell in a (primal) cell. This relies on the c2v connectivity. More... | |
| void | cs_property_get_fourier (const cs_property_t *pty, cs_real_t t_eval, double dt, cs_real_t fourier[]) |
| Compute the Fourier number in each cell. More... | |
| void | cs_property_log_setup (void) |
| Print a summary of the settings for all defined cs_property_t structures. More... | |
| #define CS_PROPERTY_MASS_DENSITY "mass_density" |
| typedef cs_flag_t cs_property_type_t |
| enum cs_property_key_t |
| cs_property_t* cs_property_add | ( | const char * | name, |
| cs_property_type_t | type | ||
| [in] | name | name of the property |
| [in] | type | type of property |
| cs_property_t* cs_property_add_as_product | ( | const char * | name, |
| const cs_property_t * | pty_a, | ||
| const cs_property_t * | pty_b | ||
| [in] | pty_a | pointer to a cs_property_t structure |
| [in] | pty_b | pointer to a cs_property_t structure |
| cs_property_t* cs_property_by_id | ( | int | id | ) |
| [in] | id | id of the property to find |
| cs_property_t* cs_property_by_name | ( | const char * | name | ) |
| [in] | name | name of the property to find |
| void cs_property_c2v_values | ( | const cs_cell_mesh_t * | cm, |
| const cs_property_t * | pty, | ||
| cs_real_t | t_eval, | ||
| cs_real_t * | eval | ||
| [in] | pty | pointer to a cs_property_t structure |
| [in] | t_eval | physical time at which one evaluates the term |
| [in,out] | eval | array of values storing the evaluation |
| cs_property_data_t cs_property_data_define | ( | bool | need_tensor, |
| bool | need_eigen, | ||
| const cs_property_t * | property | ||
| [in] | need_tensor | true if one needs a tensor-valued evaluation |
| [in] | need_eigen | true if one needs an evaluation of eigen values |
| [in] | property | pointer to the cs_property_t structure |
| void cs_property_data_init | ( | bool | need_tensor, |
| const cs_property_t * | property, | ||
| cs_property_data_t * | data | ||
| [in,out] | data | structure to initialize (already allocated) |
| cs_xdef_t* cs_property_def_aniso_by_value | ( | cs_property_t * | pty, |
| const char * | zname, | ||
| cs_real_t | tens[3][3] | ||
| [in,out] | pty | pointer to a cs_property_t structure |
| [in] | zname | name of the associated zone (if NULL or "" all cells are considered) |
| [in] | tens | values to set (3x3 tensor) |
| cs_xdef_t* cs_property_def_aniso_sym_by_value | ( | cs_property_t * | pty, |
| cs_real_t | symtens[6] | ||
| [in] | symtens | values to set (6 values – symmetric storage) |
| cs_xdef_t* cs_property_def_by_analytic | ( | cs_property_t * | pty, |
| void * | input | ||
| [in] | func | pointer to a cs_analytic_func_t function |
| cs_xdef_t* cs_property_def_by_array | ( | cs_property_t * | pty, |
| cs_flag_t | loc, | ||
| cs_real_t * | array, | ||
| bool | is_owner, | ||
| const cs_lnum_t * | index, | ||
| const cs_lnum_t * | ids | ||
| [in] | is_owner | transfer the lifecycle to the cs_xdef_t structure (true or false) |
| [in] | index | optional pointer to an array of index values |
| [in] | ids | optional pointer to a list of entity ids |
| void cs_property_def_by_field | ( | cs_property_t * | pty, |
| cs_field_t * | field | ||
| cs_xdef_t* cs_property_def_by_func | ( | cs_property_t * | pty, |
| void * | context, | ||
| cs_xdef_eval_t * | get_eval_at_cell, | ||
| cs_xdef_cw_eval_t * | get_eval_at_cell_cw | ||
| [in] | context | pointer to a structure (may be NULL) |
| [in] | get_eval_at_cell | pointer to a function |
| [in] | get_eval_at_cell_cw | pointer to a function |
| cs_xdef_t* cs_property_def_by_time_func | ( | cs_property_t * | pty, |
| cs_time_func_t * | func, | ||
| void * | input | ||
| cs_xdef_t* cs_property_def_constant_value | ( | cs_property_t * | pty, |
| double | val | ||
| [in] | val | value to set |
| cs_xdef_t* cs_property_def_iso_by_value | ( | cs_property_t * | pty, |
| double | val | ||
| cs_xdef_t* cs_property_def_ortho_by_value | ( | cs_property_t * | pty, |
| double | val[] | ||
| [in] | val | values to set (vector of size 3) |
| void cs_property_destroy_all | ( | void | ) |
| void cs_property_eval_at_cells | ( | cs_real_t | t_eval, |
| cs_real_t * | array | ||
| [in,out] | array | pointer to an array of values (must be allocated) |
| void cs_property_finalize_setup | ( | void | ) |
| void cs_property_get_cell_tensor | ( | cs_lnum_t | c_id, |
| bool | do_inversion, | ||
| cs_real_t | tensor[3][3] | ||
| [in] | c_id | id of the current cell |
| [in] | do_inversion | true or false |
| [in,out] | tensor | 3x3 matrix |
| cs_real_t cs_property_get_cell_value | ( | cs_lnum_t | c_id, |
| const cs_property_t * | pty | ||
inlinestatic |
| [in] | pty | pointer to a property |
| void cs_property_get_fourier | ( | const cs_property_t * | pty, |
| double | dt, | ||
| cs_real_t | fourier[] | ||
| [in] | pty | pointer to the diffusive property struct. |
| [in] | dt | value of the current time step |
| [in,out] | fourier | pointer to an array storing Fourier numbers |
| int cs_property_get_n_properties | ( | void | ) |
inlinestatic |
inlinestatic |
| void cs_property_init_sharing | ( | const cs_cdo_quantities_t * | quant, |
inlinestatic |
| [in] | pty | pointer to a property to test |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
| void cs_property_iso_get_cell_values | ( | cs_real_t | t_eval, |
| int * | pty_stride, | ||
| cs_real_t ** | p_pty_vals | ||
| [out] | pty_stride | = 0 if uniform, =1 otherwise |
| [in,out] | pty_vals | pointer to an array of values. Allocated if not The size of the allocation depends on the value of the pty_stride |
| void cs_property_log_setup | ( | void | ) |
| void cs_property_set_option | ( | cs_property_t * | pty, |
| cs_property_key_t | key | ||
| [in] | key | key related to a setting option |
| void cs_property_set_reference_value | ( | cs_property_t * | pty, |
| double | refval | ||
| [in] | refval | value to set |
| cs_property_t* cs_property_subcell_add | ( | const char * | name, |
| void cs_property_tensor_in_cell | ( | const cs_cell_mesh_t * | cm, |
| cs_real_t cs_property_value_in_cell | ( | const cs_cell_mesh_t * | cm, |
| cs_real_t | t_eval | ||
