#include "cs_cdo_connect.h"#include "cs_cdo_local.h"#include "cs_cdo_quantities.h"#include "cs_mesh.h"#include "cs_quadrature.h"#include "cs_xdef.h"
Include dependency graph for cs_xdef_cw_eval.h:Go to the source code of this file.
Macros | |
| typedef void() | cs_xdef_cw_eval_t(const cs_cell_mesh_t *cm, cs_real_t time_eval, void *input, cs_real_t *eval) |
| Function pointer for evaluating a quantity defined through a descriptor (cs_xdef_t structure) by a cellwise process (usage of a cs_cell_mesh_t structure) More... | |
| typedef void() | cs_xdef_cw_eval_xyz_t(const cs_cell_mesh_t *cm, cs_lnum_t n_points, const cs_real_t *xyz, cs_real_t time_eval, void *input, cs_real_t *eval) |
| Function pointer for evaluating a quantity at several locations in a cell defined through a descriptor (cs_xdef_t structure). The algorithm may use a cs_cell_mesh_t structure. More... | |
| typedef void() | cs_xdef_cw_eval_int_t(const cs_cell_mesh_t *cm, cs_real_t time_eval, void *input, cs_quadrature_type_t qtype, cs_real_t *eval) |
| Function pointer for evaluating a quantity defined through a descriptor (cs_xdef_t structure) by a cellwise process (usage of a cs_cell_mesh_t structure) which is hinged on integrals. More... | |
| typedef void() | cs_xdef_cw_eval_face_t(const cs_cell_mesh_t *cm, short int f, cs_real_t time_eval, void *input, cs_quadrature_type_t qtype, cs_real_t *eval) |
| static void | cs_xdef_cw_eval_scalar_by_val (const cs_cell_mesh_t *cm, cs_real_t time_eval, void *input, cs_real_t *eval) |
| Evaluate a scalar-valued quantity by a cellwise process. More... | |
| static void | cs_xdef_cw_eval_vector_by_val (const cs_cell_mesh_t *cm, cs_real_t time_eval, void *input, cs_real_t *eval) |
| Evaluate a vector-valued quantity by a cellwise process. More... | |
| static void | cs_xdef_cw_eval_symtens_by_val (const cs_cell_mesh_t *cm, cs_real_t time_eval, void *input, cs_real_t *eval) |
| Evaluate a tensor-valued quantity with a symmetric storage by a cellwise process. More... | |
| static void | cs_xdef_cw_eval_tensor_by_val (const cs_cell_mesh_t *cm, cs_real_t time_eval, void *input, cs_real_t *eval) |
| Evaluate a tensor-valued quantity by a cellwise process. More... | |
| static void | cs_xdef_cw_eval_vector_at_xyz_by_val (const cs_cell_mesh_t *cm, cs_lnum_t n_points, const cs_real_t *xyz, cs_real_t time_eval, void *input, cs_real_t *eval) |
| Function pointer for evaluating a quantity defined by analytic function at a precise location inside a cell Use of a cs_cell_mesh_t structure. More... | |
| static void | cs_xdef_cw_eval_flux_by_vector_val (const cs_cell_mesh_t *cm, short int f, cs_real_t time_eval, void *input, cs_real_t *eval) |
| Function pointer for evaluating the normal flux of a quantity defined by a vector-valued flux for the face f Use of a cs_cell_mesh_t structure. More... | |
| static void | cs_xdef_cw_eval_flux_by_tensor_val (const cs_cell_mesh_t *cm, short int f, cs_real_t time_eval, void *input, cs_real_t *eval) |
| Function pointer for evaluating the normal flux of a quantity defined by values. Use of a cs_cell_mesh_t structure. More... | |
| static void | cs_xdef_cw_eval_scalar_face_avg_by_value (const cs_cell_mesh_t *cm, short int f, cs_real_t t_eval, void *input, cs_quadrature_type_t qtype, cs_real_t *eval) |
| Function pointer for evaluating the average on a face of a scalar function defined through a descriptor (cs_xdef_t structure) by a cellwise process (usage of a cs_cell_mesh_t structure) More... | |
| static void | cs_xdef_cw_eval_scalar_face_avg_by_array (const cs_cell_mesh_t *cm, short int f, cs_real_t t_eval, void *input, cs_quadrature_type_t qtype, cs_real_t *eval) |
| Function pointer for evaluating the average on a face of a vector function defined through a descriptor (cs_xdef_t structure) by a cellwise process (usage of a cs_cell_mesh_t structure) More... | |
| static void | cs_xdef_cw_eval_face_drhm_by_analytic (const cs_cell_mesh_t *cm, short int f, cs_real_t t_eval, void *input, cs_quadrature_type_t qtype, cs_real_t *eval) |
| Function pointer for evaluating at the center of the face a scalar function defined through a descriptor (cs_xdef_t structure) by a cellwise process (usage of a cs_cell_mesh_t structure) Since it's only an evaluation, the functions works for any dimension (assuming that the function is well defined) More... | |
| static void | cs_xdef_cw_eval_vector_face_avg_by_value (const cs_cell_mesh_t *cm, short int f, cs_real_t t_eval, void *input, cs_quadrature_type_t qtype, cs_real_t *eval) |
| static void | cs_xdef_cw_eval_vector_face_avg_by_array (const cs_cell_mesh_t *cm, short int f, cs_real_t t_eval, void *input, cs_quadrature_type_t qtype, cs_real_t *eval) |
| static void | cs_xdef_cw_eval_tensor_face_avg_by_value (const cs_cell_mesh_t *cm, short int f, cs_real_t t_eval, void *input, cs_quadrature_type_t qtype, cs_real_t *eval) |
| Function pointer for evaluating the average on a face of a tensor function defined through a descriptor (cs_xdef_t structure) by a cellwise process (usage of a cs_cell_mesh_t structure) More... | |
| static void | cs_xdef_cw_eval_tensor_face_avg_by_array (const cs_cell_mesh_t *cm, short int f, cs_real_t t_eval, void *input, cs_quadrature_type_t qtype, cs_real_t *eval) |
| void | cs_xdef_cw_eval_f_int_by_analytic (const cs_cell_mesh_t *cm, double t_eval, short int f, cs_analytic_func_t *ana, void *input, cs_quadrature_tria_integral_t *qfunc, cs_real_t *eval) |
| Integrate an analytic function over a face. More... | |
| void | cs_xdef_cw_eval_c_int_by_analytic (const cs_cell_mesh_t *cm, double t_eval, cs_analytic_func_t *ana, void *input, cs_quadrature_tetra_integral_t *qfunc, cs_real_t *eval) |
| Integrate an analytic function over a cell. More... | |
| void | cs_xdef_cw_eval_fc_int_by_analytic (const cs_cell_mesh_t *cm, cs_real_t t_eval, cs_analytic_func_t *ana, void *input, const short int dim, cs_quadrature_tetra_integral_t *q_tet, cs_quadrature_tria_integral_t *q_tri, cs_real_t *c_int, cs_real_t *f_int) |
| Routine to integrate an analytic function over a cell and its faces. More... | |
| void | cs_xdef_cw_eval_scalar_face_avg_by_analytic (const cs_cell_mesh_t *cm, short int f, cs_real_t time_eval, void *input, cs_quadrature_type_t qtype, cs_real_t *eval) |
| void | cs_xdef_cw_eval_vector_face_avg_by_analytic (const cs_cell_mesh_t *cm, short int f, cs_real_t t_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval) |
| void | cs_xdef_cw_eval_tensor_face_avg_by_analytic (const cs_cell_mesh_t *cm, short int f, cs_real_t t_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval) |
| void | cs_xdef_cw_eval_scalar_avg_by_analytic (const cs_cell_mesh_t *cm, cs_real_t t_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval) |
| Function pointer for evaluating a quantity defined through a descriptor (cs_xdef_t structure) by a cellwise process (usage of a cs_cell_mesh_t structure). This evaluation hinges on the computation of integrals. More... | |
| void | cs_xdef_cw_eval_vector_avg_by_analytic (const cs_cell_mesh_t *cm, cs_real_t t_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval) |
| Function pointer for evaluating a quantity defined through a descriptor (cs_xdef_t structure) by a cellwise process (usage of a cs_cell_mesh_t structure). This evaluation hinges on the computation of integrals Vector-valued case. More... | |
| void | cs_xdef_cw_eval_tensor_avg_by_analytic (const cs_cell_mesh_t *cm, cs_real_t t_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval) |
| Function pointer for evaluating a quantity defined through a descriptor (cs_xdef_t structure) by a cellwise process (usage of a cs_cell_mesh_t structure). This evaluation hinges on the computation of integrals Tensor-valued case. More... | |
| void | cs_xdef_cw_eval_by_time_func (const cs_cell_mesh_t *cm, cs_real_t time_eval, void *context, cs_real_t *eval) |
| Evaluate a quantity by a cellwise process using a definition by time function. More... | |
| void | cs_xdef_cw_eval_by_analytic (const cs_cell_mesh_t *cm, cs_real_t time_eval, void *context, cs_real_t *eval) |
| Evaluate a quantity at the cell center defined using an analytic function by a cellwise process (usage of a cs_cell_mesh_t structure) More... | |
| void | cs_xdef_cw_eval_by_array (const cs_cell_mesh_t *cm, cs_real_t time_eval, void *context, cs_real_t *eval) |
| Evaluate a quantity at cells defined by an array. Array is assumed to be interlaced. Variation using a cs_cell_mesh_t structure. More... | |
| void | cs_xdef_cw_eval_by_field (const cs_cell_mesh_t *cm, cs_real_t time_eval, void *context, cs_real_t *eval) |
| Evaluate a quantity inside a cell defined using a field Variation using a cs_cell_mesh_t structure. More... | |
| void | cs_xdef_cw_eval_at_xyz_by_analytic (const cs_cell_mesh_t *cm, cs_lnum_t n_points, const cs_real_t *xyz, cs_real_t time_eval, void *context, cs_real_t *eval) |
| Function pointer for evaluating a quantity defined by analytic function at a precise location (x, y, z) inside a cell Use of a cs_cell_mesh_t structure. More... | |
| void | cs_xdef_cw_eval_vector_at_xyz_by_array (const cs_cell_mesh_t *cm, cs_lnum_t n_points, const cs_real_t *xyz, cs_real_t time_eval, void *context, cs_real_t *eval) |
| Function pointer for evaluating a quantity defined by analytic function at a precise location inside a cell Use of a cs_cell_mesh_t structure. Vector-valued case. More... | |
| void | cs_xdef_cw_eval_vector_at_xyz_by_field (const cs_cell_mesh_t *cm, cs_lnum_t n_points, const cs_real_t *xyz, cs_real_t time_eval, void *context, cs_real_t *eval) |
| Function pointer for evaluating a quantity defined by a field at a precise location inside a cell Use of a cs_cell_mesh_t structure. Vector-valued case. More... | |
| void | cs_xdef_cw_eval_flux_v_by_scalar_val (const cs_cell_mesh_t *cm, short int f, cs_real_t time_eval, void *context, cs_real_t *eval) |
| Function pointer for evaluating the normal flux defined by scalar-valued quantities. The normal flux is then added to each portion of face related to a vertex. Use of a cs_cell_mesh_t structure. More... | |
| void | cs_xdef_cw_eval_flux_v_by_vector_val (const cs_cell_mesh_t *cm, short int f, cs_real_t time_eval, void *context, cs_real_t *eval) |
| Function pointer for evaluating the normal flux defined by vector-valued quantities. The normal flux is then added to each portion of face related to a vertex. Use of a cs_cell_mesh_t structure. More... | |
| void | cs_xdef_cw_eval_flux_v_by_scalar_analytic (const cs_cell_mesh_t *cm, short int f, cs_real_t time_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval) |
| Function pointer for evaluating the normal flux defined by a scalar-valued quantities and relying on an analytic function. The normal flux is then added to each portion of face related to a vertex. Use of a cs_cell_mesh_t structure. More... | |
| void | cs_xdef_cw_eval_flux_v_by_vector_analytic (const cs_cell_mesh_t *cm, short int f, cs_real_t time_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval) |
| Function pointer for evaluating the normal flux defined by a vector-valued quantities and relying on an analytic function. The normal flux is then added to each portion of face related to a vertex. Use of a cs_cell_mesh_t structure. More... | |
| void | cs_xdef_cw_eval_flux_by_scalar_analytic (const cs_cell_mesh_t *cm, short int f, cs_real_t time_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval) |
| Function pointer for evaluating the normal flux of a quantity defined by analytic function (scalar-valued) at the face f. Use of a cs_cell_mesh_t structure. More... | |
| void | cs_xdef_cw_eval_flux_by_vector_analytic (const cs_cell_mesh_t *cm, short int f, cs_real_t time_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval) |
| Function pointer for evaluating the (scalar-valued) normal flux of a quantity defined by an analytic function. Use of a cs_cell_mesh_t structure. More... | |
| void | cs_xdef_cw_eval_vector_flux_by_analytic (const cs_cell_mesh_t *cm, short int f, cs_real_t time_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval) |
| Function pointer for evaluating the normal vector-valued flux of a quantity defined by analytic function for the face f Use of a cs_cell_mesh_t structure. Case of a vector-valued quantities. More... | |
| void | cs_xdef_cw_eval_scal_avg_reduction_by_analytic (const cs_cell_mesh_t *cm, cs_real_t t_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval) |
| Function pointer for evaluating the reduction by averages of a analytic function by a cellwise process (usage of a cs_cell_mesh_t structure). This evaluation hinges on the computation of integrals (faces first, then cell) Scalar-valued case. More... | |
| void | cs_xdef_cw_eval_vect_avg_reduction_by_analytic (const cs_cell_mesh_t *cm, cs_real_t t_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval) |
| Function pointer for evaluating the reduction by averages of a analytic function by a cellwise process (usage of a cs_cell_mesh_t structure). This evaluation hinges on the computation of integrals (faces first, then cell) Vector-valued case. More... | |
| typedef void() cs_xdef_cw_eval_face_t(const cs_cell_mesh_t *cm, short int f, cs_real_t time_eval, void *input, cs_quadrature_type_t qtype, cs_real_t *eval) |
| [in] | f | local face id |
| [in] | qtype | quadrature type |
| [in] | input | pointer to an input structure |
| [out] | eval | result of the evaluation |
| typedef void() cs_xdef_cw_eval_int_t(const cs_cell_mesh_t *cm, cs_real_t time_eval, void *input, cs_quadrature_type_t qtype, cs_real_t *eval) |
| typedef void() cs_xdef_cw_eval_t(const cs_cell_mesh_t *cm, cs_real_t time_eval, void *input, cs_real_t *eval) |
| [in] | input | NULL or pointer to an input structure |
| typedef void() cs_xdef_cw_eval_xyz_t(const cs_cell_mesh_t *cm, cs_lnum_t n_points, const cs_real_t *xyz, cs_real_t time_eval, void *input, cs_real_t *eval) |
| [in] | n_points | number of points where to compute the evaluation |
| [in] | xyz | where to compute the evaluation |
| void cs_xdef_cw_eval_at_xyz_by_analytic | ( | const cs_cell_mesh_t * | cm, |
| cs_lnum_t | n_points, | ||
| const cs_real_t * | xyz, | ||
| cs_real_t | time_eval, | ||
| void * | context, | ||
| cs_real_t * | eval | ||
| [in] | context | pointer to a context structure |
| [in,out] | eval | result of the evaluation |
| void cs_xdef_cw_eval_by_analytic | ( | const cs_cell_mesh_t * | cm, |
| [in,out] | eval | result of the evaluation at cell center |
| void cs_xdef_cw_eval_by_array | ( | const cs_cell_mesh_t * | cm, |
| void cs_xdef_cw_eval_by_field | ( | const cs_cell_mesh_t * | cm, |
| [in,out] | eval | value of the property at the cell center |
| void cs_xdef_cw_eval_by_time_func | ( | const cs_cell_mesh_t * | cm, |
| void cs_xdef_cw_eval_c_int_by_analytic | ( | const cs_cell_mesh_t * | cm, |
| double | t_eval, | ||
| cs_analytic_func_t * | ana, | ||
| void * | input, | ||
| cs_quadrature_tetra_integral_t * | qfunc, | ||
| [in] | t_eval | time at which the function is evaluated |
| [in] | ana | analytic function to integrate |
| [in] | qfunc | quadrature function to use |
| void cs_xdef_cw_eval_f_int_by_analytic | ( | const cs_cell_mesh_t * | cm, |
| short int | f, | ||
| cs_quadrature_tria_integral_t * | qfunc, | ||
| [in] | f | face id in the local cell numbering |
DOXYGEN_SHOULD_SKIP_THIS
inlinestatic |
| [in] | t_eval | physical time at which one evaluates the term |
| [in] | qtype | level of quadrature to use |
| void cs_xdef_cw_eval_fc_int_by_analytic | ( | const cs_cell_mesh_t * | cm, |
| cs_real_t | t_eval, | ||
| const short int | dim, | ||
| cs_quadrature_tetra_integral_t * | q_tet, | ||
| cs_quadrature_tria_integral_t * | q_tri, | ||
| cs_real_t * | c_int, | ||
| cs_real_t * | f_int | ||
| [in] | dim | dimension of the function |
| [in] | q_tet | quadrature function to use on tetrahedra |
| [in] | q_tri | quadrature function to use on triangles |
| [out] | c_int | result of the evaluation on the cell |
| [out] | f_int | result of the evaluation on the faces |
| void cs_xdef_cw_eval_flux_by_scalar_analytic | ( | const cs_cell_mesh_t * | cm, |
| short int | f, | ||
| cs_quadrature_type_t | qtype, | ||
| [in,out] | eval | array of values at DoFs |
inlinestatic |
| [in,out] | eval | result of the evaluation (set inside) |
| void cs_xdef_cw_eval_flux_by_vector_analytic | ( | const cs_cell_mesh_t * | cm, |
| short int | f, | ||
| [in,out] | eval | array of evaluations at DoFs |
inlinestatic |
| [in,out] | eval | result of the evaluation (a scalar) |
| void cs_xdef_cw_eval_flux_v_by_scalar_analytic | ( | const cs_cell_mesh_t * | cm, |
| short int | f, | ||
| [in,out] | eval | array of Neumann fluxes at DoFs |
| void cs_xdef_cw_eval_flux_v_by_scalar_val | ( | const cs_cell_mesh_t * | cm, |
| short int | f, | ||
| void cs_xdef_cw_eval_flux_v_by_vector_analytic | ( | const cs_cell_mesh_t * | cm, |
| short int | f, | ||
| void cs_xdef_cw_eval_flux_v_by_vector_val | ( | const cs_cell_mesh_t * | cm, |
| short int | f, | ||
| void cs_xdef_cw_eval_scal_avg_reduction_by_analytic | ( | const cs_cell_mesh_t * | cm, |
| void cs_xdef_cw_eval_scalar_avg_by_analytic | ( | const cs_cell_mesh_t * | cm, |
inlinestatic |
| void cs_xdef_cw_eval_scalar_face_avg_by_analytic | ( | const cs_cell_mesh_t * | cm, |
| short int | f, | ||
inlinestatic |
inlinestatic |
inlinestatic |
| void cs_xdef_cw_eval_tensor_avg_by_analytic | ( | const cs_cell_mesh_t * | cm, |
inlinestatic |
| void cs_xdef_cw_eval_tensor_face_avg_by_analytic | ( | const cs_cell_mesh_t * | cm, |
| short int | f, | ||
inlinestatic |
inlinestatic |
| void cs_xdef_cw_eval_vect_avg_reduction_by_analytic | ( | const cs_cell_mesh_t * | cm, |
| void cs_xdef_cw_eval_vector_at_xyz_by_array | ( | const cs_cell_mesh_t * | cm, |
| void cs_xdef_cw_eval_vector_at_xyz_by_field | ( | const cs_cell_mesh_t * | cm, |
inlinestatic |
| void cs_xdef_cw_eval_vector_avg_by_analytic | ( | const cs_cell_mesh_t * | cm, |
inlinestatic |
| void cs_xdef_cw_eval_vector_face_avg_by_analytic | ( | const cs_cell_mesh_t * | cm, |
| short int | f, | ||
inlinestatic |
inlinestatic |
| void cs_xdef_cw_eval_vector_flux_by_analytic | ( | const cs_cell_mesh_t * | cm, |
| short int | f, | ||
