7.2
cs_cdo_local.h
1 #ifndef __CS_CDO_LOCAL_H__
2 #define __CS_CDO_LOCAL_H__
5  * Functions to handle low-level functions related to CDO local quantities:
6  * - local matrices (stored in dense format),
7  * - local quantities related to a cell.
8  *============================================================================*/
9
10 /*
11  This file is part of code_saturne, a general-purpose CFD tool.
13  Copyright (C) 1998-2022 EDF S.A.
14
15  This program is free software; you can redistribute it and/or modify it under
16  the terms of the GNU General Public License as published by the Free Software
17  Foundation; either version 2 of the License, or (at your option) any later
18  version.
19
20  This program is distributed in the hope that it will be useful, but WITHOUT
21  ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS
22  FOR A PARTICULAR PURPOSE. See the GNU General Public License for more
23  details.
24
25  You should have received a copy of the GNU General Public License along with
26  this program; if not, write to the Free Software Foundation, Inc., 51 Franklin
27  Street, Fifth Floor, Boston, MA 02110-1301, USA.
28 */
31  * Local headers
34 #include "cs_cdo_connect.h"
35 #include "cs_cdo_quantities.h"
36 #include "cs_flag.h"
37 #include "cs_param_cdo.h"
38 #include "cs_sdm.h"
45  * Macro definitions
49  * Type definitions
51
60 typedef struct {
61
81
107  double gpty_val;
108  double tpty_val;
109  double rpty_vals[CS_CDO_N_MAX_REACTIONS];
110  double rpty_val;
111
112  double *adv_fluxes;
128  int *ids;
129  double *values;
132  cs_sdm_t *loc;
133  cs_sdm_t *aux;
134
140
147 typedef struct {
148
151  int n_dofs;
155  cs_sdm_t *mat;
156  double *rhs;
157  double *source;
158  double *val_n;
159  double *val_nm1;
166  short int n_bc_faces;
167  short int *_f_ids;
172  double *dir_values;
175  double *neu_values;
177  bool has_robin;
178  double *rob_values;
180  bool has_sliding;
182  bool has_internal_enforcement; /*<! At least one DoF enforced */
189 } cs_cell_sys_t;
190
203 typedef struct {
204
208  /* Sizes used to allocate buffers */
209
210  short int n_max_vbyc;
211  short int n_max_ebyc;
212  short int n_max_fbyc;
213
214  /* Cell information */
215
218  double vol_c;
219  double diam_c;
221  /* Vertex information */
222
223  short int n_vc;
225  double *xv;
226  double *wvc;
228  /* Edge information */
229
230  short int n_ec;
236  /* Face information */
237
238  short int n_fc;
241  short int *f_sgn;
242  double *f_diam;
243  double *hfc;
248  /* Local e2v connectivity: size 2*n_ec (allocated to 2*n_max_ebyc) */
249
250  short int *e2v_ids;
251  short int *e2v_sgn;
253  /* Local f2v connectivity: size = 2*n_max_ebyc */
254
255  short int *f2v_idx;
256  short int *f2v_ids;
258  /* Local f2e connectivity: size = 2*n_max_ebyc */
259  short int *f2e_idx;
260  short int *f2e_ids;
261  short int *f2e_sgn;
262  double *tef;
264  /* Local e2f connectivity: size 2*n_ec (allocated to 2*n_max_ebyc) */
265
266  short int *e2f_ids;
270
279 typedef struct {
280
281  short int n_max_vbyf;
286  /* Face information */
287
289  short int f_sgn;
292  double pvol;
293  double hfc;
295  /* Vertex information */
296
297  short int n_vf;
299  double *xv;
300  double *wvf;
302  /* Edge information */
303
304  short int n_ef;
307  double *tef;
309  /* Local e2v connectivity: size 2*n_ec (allocated to 2*n_max_ebyf) */
310
311  short int *e2v_ids;
314
315 /*
316  A cs_face_mesh_light_t structure is close to a cs_face_mesh_t structure
317  There are less members to be buildt quicker.
318  Such structure is always associated to a cs_cell_mesh_t structure
319 */
320
321 typedef struct {
322
323  short int n_max_vbyf; /* Max number of vertices belonging to a face
324  (= n_max_ebyf) */
325
326  cs_lnum_t c_id; /* id of related cell in the mesh numbering */
327  short int f; /* id of the face in the cell mesh numbering */
328
329  /* Vertex information */
330
331  short int n_vf; /* local number of vertices on this face */
332  short int *v_ids; /* vertex ids in the cellwise numbering */
333  double *wvf; /* weights related to each vertex */
334
335  /* Edge information */
336
337  short int n_ef; /* local number of edges on this face (= n_vf) */
338  short int *e_ids; /* edge ids in the cellwise numbering */
339  double *tef; /* area of the triangle of base e and apex xf */
340
342
343 /*============================================================================
344  * Global variables
345  *============================================================================*/
346
347 /* Auxiliary buffers for extra-operations related to local problems. These
348  * buffers are also used for computing quantities related to a cs_cell_mesh_t
349  * (there are as many buffers as threads since a call to these buffers can be
350  * inside an OpenMP directive */
351
352 extern int cs_cdo_local_d_buffer_size;
353 extern double **cs_cdo_local_d_buffer;
354
355 /* Pointer of pointers to global structures */
356
360
361 /*============================================================================
362  * Static inline function prototypes
363  *============================================================================*/
364
365 /*----------------------------------------------------------------------------*/
371 /*----------------------------------------------------------------------------*/
372
373 static inline int
375 {
377 }
378
379 /*----------------------------------------------------------------------------*/
388 /*----------------------------------------------------------------------------*/
389
390 static inline double *
392 {
393  assert(thr_id > -1 && thr_id < cs_glob_n_threads);
394  return cs_cdo_local_d_buffer[thr_id];
395 }
396
397 /*----------------------------------------------------------------------------*/
405 /*----------------------------------------------------------------------------*/
406
407 static inline bool
409 {
413  return true;
414  else
415  return false;
416 }
417
418 /*----------------------------------------------------------------------------*/
428 /*----------------------------------------------------------------------------*/
429
430 static inline short int
432  const cs_cell_mesh_t *const cm)
433 {
434  if (cm == NULL)
435  return -1;
436  for (short int v = 0; v < cm->n_vc; v++)
437  if (cm->v_ids[v] == v_id)
438  return v;
439  return -1;
440 }
441
442 /*----------------------------------------------------------------------------*/
452 /*----------------------------------------------------------------------------*/
453
454 static inline short int
456  const cs_cell_mesh_t *const cm)
457 {
458  if (cm == NULL)
459  return -1;
460  for (short int e = 0; e < cm->n_ec; e++)
461  if (cm->e_ids[e] == e_id)
462  return e;
463  return -1;
464 }
465
466 /*----------------------------------------------------------------------------*/
476 /*----------------------------------------------------------------------------*/
477
478 static inline short int
480  const cs_cell_mesh_t *const cm)
481 {
482  if (cm == NULL)
483  return -1;
484  for (short int f = 0; f < cm->n_fc; f++)
485  if (cm->f_ids[f] == f_id)
486  return f;
487  return -1;
488 }
489
490 /*----------------------------------------------------------------------------*/
499 /*----------------------------------------------------------------------------*/
500
501 static inline void
503  const cs_cell_mesh_t *cm,
504  short int *n_vf,
505  short int *v_ids)
506 {
507  /* Reset */
508
509  *n_vf = 0;
510  for (short int v = 0; v < cm->n_vc; v++) v_ids[v] = -1;
511
512  /* Tag vertices belonging to the current face f */
513
514  for (short int i = cm->f2e_idx[f]; i < cm->f2e_idx[f+1]; i++) {
515
516  const int shift_e = 2*cm->f2e_ids[i];
517  v_ids[cm->e2v_ids[shift_e]] = 1;
518  v_ids[cm->e2v_ids[shift_e+1]] = 1;
519
520  } /* Loop on face edges */
521
522  for (short int v = 0; v < cm->n_vc; v++) {
523  if (v_ids[v] > 0)
524  v_ids[*n_vf] = v, *n_vf += 1;
525  }
526 }
527
528 /*----------------------------------------------------------------------------*/
539 /*----------------------------------------------------------------------------*/
540
541 static inline void
542 cs_cell_mesh_get_next_3_vertices(const short int *f2e_ids,
543  const short int *e2v_ids,
544  short int *v0,
545  short int *v1,
546  short int *v2)
547 {
548  const short int e0 = f2e_ids[0];
549  const short int e1 = f2e_ids[1];
550  const short int tmp = e2v_ids[2*e1];
551
552  *v0 = e2v_ids[2*e0];
553  *v1 = e2v_ids[2*e0+1];
554  *v2 = ((tmp != *v0) && (tmp != *v1)) ? tmp : e2v_ids[2*e1+1];
555 }
556
557 /*----------------------------------------------------------------------------*/
566 /*----------------------------------------------------------------------------*/
567
568 static inline bool
570  const short int f)
571 {
572  if (cm->f_ids[f] - cm->bface_shift > -1)
573  return true;
574  else
575  return false;
576 }
577
578 /*============================================================================
579  * Public function prototypes
580  *============================================================================*/
581
582 /*----------------------------------------------------------------------------*/
589 /*----------------------------------------------------------------------------*/
590
591 void
593
594 /*----------------------------------------------------------------------------*/
599 /*----------------------------------------------------------------------------*/
600
601 void
603
604 /*----------------------------------------------------------------------------*/
616 /*----------------------------------------------------------------------------*/
617
619 cs_cell_sys_create(int n_max_dofbyc,
620  int n_max_fbyc,
621  int n_blocks,
622  int *block_sizes);
623
624 /*----------------------------------------------------------------------------*/
632 /*----------------------------------------------------------------------------*/
633
634 void
635 cs_cell_sys_reset(int n_fbyc,
636  cs_cell_sys_t *csys);
637
638 /*----------------------------------------------------------------------------*/
644 /*----------------------------------------------------------------------------*/
645
646 void
648
649 /*----------------------------------------------------------------------------*/
656 /*----------------------------------------------------------------------------*/
657
658 void
659 cs_cell_sys_dump(const char msg[],
660  const cs_cell_sys_t *csys);
661
662 /*----------------------------------------------------------------------------*/
668 /*----------------------------------------------------------------------------*/
669
672
673 /*----------------------------------------------------------------------------*/
679 /*----------------------------------------------------------------------------*/
680
681 void
683
684 /*----------------------------------------------------------------------------*/
692 /*----------------------------------------------------------------------------*/
693
695 cs_cell_mesh_create(const cs_cdo_connect_t *connect);
696
697 /*----------------------------------------------------------------------------*/
705 /*----------------------------------------------------------------------------*/
706
708 cs_cdo_local_get_cell_mesh(int mesh_id);
709
710 /*----------------------------------------------------------------------------*/
716 /*----------------------------------------------------------------------------*/
717
718 void
720
721 /*----------------------------------------------------------------------------*/
727 /*----------------------------------------------------------------------------*/
728
729 void
731
732 /*----------------------------------------------------------------------------*/
738 /*----------------------------------------------------------------------------*/
739
740 void
742
743 /*----------------------------------------------------------------------------*/
754 /*----------------------------------------------------------------------------*/
755
756 void
758  cs_eflag_t build_flag,
759  const cs_cdo_connect_t *connect,
760  const cs_cdo_quantities_t *quant,
761  cs_cell_mesh_t *cm);
762
763 /*----------------------------------------------------------------------------*/
771 /*----------------------------------------------------------------------------*/
772
774 cs_face_mesh_create(short int n_max_vbyf);
775
776 /*----------------------------------------------------------------------------*/
784 /*----------------------------------------------------------------------------*/
785
787 cs_cdo_local_get_face_mesh(int mesh_id);
788
789 /*----------------------------------------------------------------------------*/
795 /*----------------------------------------------------------------------------*/
796
797 void
799
800 /*----------------------------------------------------------------------------*/
810 /*----------------------------------------------------------------------------*/
811
812 void
814  cs_lnum_t f_id,
815  const cs_cdo_connect_t *connect,
816  const cs_cdo_quantities_t *quant,
817  cs_face_mesh_t *fm);
818
819 /*----------------------------------------------------------------------------*/
829 /*----------------------------------------------------------------------------*/
830
831 void
833  short int f,
834  cs_face_mesh_t *fm);
835
836 /*----------------------------------------------------------------------------*/
845 /*----------------------------------------------------------------------------*/
846
848 cs_face_mesh_light_create(short int n_max_vbyf,
849  short int n_max_vbyc);
850
851 /*----------------------------------------------------------------------------*/
860 /*----------------------------------------------------------------------------*/
861
864
865 /*----------------------------------------------------------------------------*/
871 /*----------------------------------------------------------------------------*/
872
873 void
875
876 /*----------------------------------------------------------------------------*/
885 /*----------------------------------------------------------------------------*/
886
887 void
889  short int f,
891
892 /*----------------------------------------------------------------------------*/
893
895
896 #endif /* __CS_CDO_LOCAL_H__ */
cs_lnum_t * e_ids
Definition: cs_cdo_local.h:305
cs_face_mesh_t * cs_face_mesh_create(short int n_max_vbyf)
Allocate a cs_face_mesh_t structure.
Definition: cs_cdo_local.c:1471
bool * dof_is_forced
Definition: cs_cdo_local.h:183
#define CS_FLAG_BOUNDARY_CELL_BY_EDGE
(= 4) boundary cell with at least one border edge
Definition: cs_flag.h:64
Definition: cs_cdo_local.c:86
void cs_cdo_local_initialize(const cs_cdo_connect_t *connect)
Allocate global structures used for build system with a cellwise or facewise process.
Definition: cs_cdo_local.c:130
bool has_dirichlet
Definition: cs_cdo_local.h:171
short int * e2f_ids
Definition: cs_cdo_local.h:266
double * tef
Definition: cs_cdo_local.h:262
bool has_sliding
Definition: cs_cdo_local.h:180
double vol_c
Definition: cs_cdo_local.h:218
void cs_cell_mesh_free(cs_cell_mesh_t **p_cm)
Free a cs_cell_mesh_t structure.
Definition: cs_cdo_local.c:870
cs_cell_builder_t * cs_cell_builder_create(void)
Allocate cs_cell_builder_t structure.
Definition: cs_cdo_local.c:503
cs_lnum_t * f_ids
Definition: cs_cdo_local.h:240
static bool cs_cell_has_boundary_elements(const cs_cell_builder_t *const cb)
Check if at least one entity of the cell belongs to the boundary.
Definition: cs_cdo_local.h:408
int cs_glob_n_threads
Definition: cs_defs.c:172
cs_lnum_t f_id
Definition: cs_cdo_local.h:288
static void cs_cell_mesh_get_f2v(short int f, const cs_cell_mesh_t *cm, short int *n_vf, short int *v_ids)
Retrieve the list of vertices attached to a face.
Definition: cs_cdo_local.h:502
cs_face_mesh_light_t * cs_face_mesh_light_create(short int n_max_vbyf, short int n_max_vbyc)
Allocate a cs_face_mesh_light_t structure.
Definition: cs_cdo_local.c:1848
double tpty_val
Definition: cs_cdo_local.h:108
cs_real_t t_bc_eval
Definition: cs_cdo_local.h:79
short int * v_ids
Definition: cs_cdo_local.h:332
double * wvc
Definition: cs_cdo_local.h:226
cs_sdm_t * loc
Definition: cs_cdo_local.h:132
Definition: cs_cdo_local.h:281
cs_lnum_t * bf_ids
Definition: cs_cdo_local.h:168
double * tef
Definition: cs_cdo_local.h:307
double * source
Definition: cs_cdo_local.h:157
void cs_cell_sys_reset(int n_fbyc, cs_cell_sys_t *csys)
Reset all members related to BC and some other ones in a cs_cell_sys_t structure. ...
Definition: cs_cdo_local.c:368
Definition: cs_cdo_local.h:182
cs_real_t * pvol_e
Definition: cs_cdo_local.h:234
cs_lnum_t * dof_ids
Definition: cs_cdo_local.h:152
Definition: cs_cdo_local.h:210
double * rob_values
Definition: cs_cdo_local.h:178
double * dir_values
Definition: cs_cdo_local.h:172
short int * e2v_sgn
Definition: cs_cdo_local.h:251
double * tef
Definition: cs_cdo_local.h:339
cs_nvec3_t * dface
Definition: cs_cdo_local.h:233
void cs_cdo_local_finalize(void)
Free global structures related to cs_cell_mesh_t and cs_face_mesh_t structures.
Definition: cs_cdo_local.c:189
double * val_n
Definition: cs_cdo_local.h:158
cs_lnum_t c_id
Definition: cs_cdo_local.h:326
double * hfc
Definition: cs_cdo_local.h:243
short int n_vf
Definition: cs_cdo_local.h:297
void cs_cell_builder_free(cs_cell_builder_t **p_cb)
Free a cs_cell_builder_t structure.
Definition: cs_cdo_local.c:544
short int * f2e_ids
Definition: cs_cdo_local.h:260
cs_sdm_t * mat
Definition: cs_cdo_local.h:155
static short int cs_cell_mesh_get_v(const cs_lnum_t v_id, const cs_cell_mesh_t *const cm)
Retrieve the vertex id in the cellwise numbering associated to the given vertex id in the mesh number...
Definition: cs_cdo_local.h:431
cs_flag_t * dof_flag
Definition: cs_cdo_local.h:153
cs_lnum_t * v_ids
Definition: cs_cdo_local.h:298
double * xv
Definition: cs_cdo_local.h:225
short int n_ef
Definition: cs_cdo_local.h:304
cs_face_mesh_light_t * cs_cdo_local_get_face_mesh_light(int mesh_id)
Get a pointer to a cs_face_mesh_light_t structure corresponding to mesh id.
Definition: cs_cdo_local.c:1886
cs_nvec3_t * sefc
Definition: cs_cdo_local.h:267
Definition: cs_defs.h:322
Definition: cs_cdo_quantities.h:132
cs_nvec3_t dedge
Definition: cs_cdo_local.h:291
Definition: cs_defs.h:368
Definition: cs_cdo_local.h:211
cs_lnum_t * v_ids
Definition: cs_cdo_local.h:224
int n_dofs
Definition: cs_cdo_local.h:151
void cs_face_mesh_light_free(cs_face_mesh_light_t **p_fm)
Free a cs_face_mesh_light_t structure.
Definition: cs_cdo_local.c:1903
Definition: cs_cdo_local.h:321
short int * f_sgn
Definition: cs_cdo_local.h:241
short int * f2v_ids
Definition: cs_cdo_local.h:256
double * wvf
Definition: cs_cdo_local.h:300
double pvol
Definition: cs_cdo_local.h:292
double gpty_val
Definition: cs_cdo_local.h:107
double * rhs
Definition: cs_cdo_local.h:156
double * val_nm1
Definition: cs_cdo_local.h:159
double precision, dimension(:,:,:), allocatable v
Definition: atimbr.f90:114
double rpty_val
Definition: cs_cdo_local.h:110
cs_sdm_t * aux
Definition: cs_cdo_local.h:133
double diam_c
Definition: cs_cdo_local.h:219
Definition: cs_field_pointer.h:128
cs_lnum_t c_id
Definition: cs_cdo_local.h:149
fvm_element_t
Definition: fvm_defs.h:48
fvm_element_t type
Definition: cs_cdo_local.h:206
cs_lnum_t c_id
Definition: cs_cdo_local.h:216
void cs_face_mesh_light_build(const cs_cell_mesh_t *cm, short int f, cs_face_mesh_light_t *fm)
Define a cs_face_mesh_light_t structure starting from a cs_cell_mesh_t structure. ...
Definition: cs_cdo_local.c:1931
cs_cell_mesh_t * cs_cdo_local_get_cell_mesh(int mesh_id)
Get a pointer to a cs_cell_mesh_t structure corresponding to mesh id.
Definition: cs_cdo_local.c:652
cs_eflag_t flag
Definition: cs_cdo_local.h:205
Definition: cs_cdo_local.h:212
void cs_face_mesh_build_from_cell_mesh(const cs_cell_mesh_t *cm, short int f, cs_face_mesh_t *fm)
Define a cs_face_mesh_t structure for a given cell from a cs_cell_mesh_t structure. v_ids and e_ids are defined in the cell numbering given by cm.
Definition: cs_cdo_local.c:1720
cs_flag_t * bf_flag
Definition: cs_cdo_local.h:169
short int n_fc
Definition: cs_cdo_local.h:238
short int f_sgn
Definition: cs_cdo_local.h:289
cs_face_mesh_t * cs_cdo_local_get_face_mesh(int mesh_id)
Get a pointer to a cs_face_mesh_t structure corresponding to mesh id.
Definition: cs_cdo_local.c:1518
double hfc
Definition: cs_cdo_local.h:293
cs_lnum_t bface_shift
Definition: cs_cdo_local.h:239
cs_lnum_t * e_ids
Definition: cs_cdo_local.h:231
void cs_cell_mesh_build(cs_lnum_t c_id, cs_eflag_t build_flag, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_cell_mesh_t *cm)
Define a cs_cell_mesh_t structure for a given cell id. According to the requested level...
Definition: cs_cdo_local.c:926
cs_real_t t_pty_eval
Definition: cs_cdo_local.h:78
cs_real_t t_st_eval
Definition: cs_cdo_local.h:80
static double * cs_cdo_local_get_d_buffer(int thr_id)
Retrieve the buffer associated to the current thread. If there is no openMP then one should give 0 as...
Definition: cs_cdo_local.h:391
cs_nvec3_t * dedge
Definition: cs_cdo_local.h:245
short int n_vf
Definition: cs_cdo_local.h:331
cs_quant_t * edge
Definition: cs_cdo_local.h:306
double * f_diam
Definition: cs_cdo_local.h:242
static bool cs_cell_mesh_is_boundary_face(const cs_cell_mesh_t *cm, const short int f)
Is the face a boundary one ?
Definition: cs_cdo_local.h:569
cs_cell_mesh_t ** cs_cdo_local_cell_meshes
Definition: cs_cdo_local.c:91
short int * e2v_ids
Definition: cs_cdo_local.h:311
short int * f2v_idx
Definition: cs_cdo_local.h:255
double * neu_values
Definition: cs_cdo_local.h:175
Definition: cs_cdo_local.h:60
int * ids
Definition: cs_cdo_local.h:128
cs_quant_t * face
Definition: cs_cdo_local.h:244
cs_face_mesh_light_t ** cs_cdo_local_face_meshes_light
Definition: cs_cdo_local.c:93
double ** cs_cdo_local_d_buffer
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:335
bool has_robin
Definition: cs_cdo_local.h:177
static short int cs_cell_mesh_get_e(const cs_lnum_t e_id, const cs_cell_mesh_t *const cm)
Retrieve the edge id in the cellwise numbering associated to the given edge id in the mesh numbering...
Definition: cs_cdo_local.h:455
cs_quant_t face
Definition: cs_cdo_local.h:290
short int * _f_ids
Definition: cs_cdo_local.h:167
void cs_cell_sys_free(cs_cell_sys_t **p_csys)
Free a cs_cell_sys_t structure.
Definition: cs_cdo_local.c:408
cs_real_3_t xc
Definition: cs_cdo_local.h:217
short int * e_ids
Definition: cs_cdo_local.h:338
#define CS_CDO_N_MAX_REACTIONS
Definition: cs_param_cdo.h:74
cs_flag_t cell_flag
Definition: cs_cdo_local.h:82
Definition: cs_defs.h:316
short int n_vc
Definition: cs_cdo_local.h:223
#define CS_FLAG_BOUNDARY_CELL_BY_VERTEX
(= 2) boundary cell with at least one border vertex
Definition: cs_flag.h:63
cs_real_3_t xc
Definition: cs_cdo_local.h:284
short int f
Definition: cs_cdo_local.h:327
void cs_cell_mesh_reset(cs_cell_mesh_t *cm)
Initialize to invalid values a cs_cell_mesh_t structure.
Definition: cs_cdo_local.c:676
static int cs_cdo_local_get_d_buffer_size(void)
Retrieve the size of the auxiliary buffer of double.
Definition: cs_cdo_local.h:374
short int * e2v_ids
Definition: cs_cdo_local.h:250
cs_cell_sys_t * cs_cell_sys_create(int n_max_dofbyc, int n_max_fbyc, int n_blocks, int *block_sizes)
Allocate a cs_cell_sys_t structure.
Definition: cs_cdo_local.c:240
unsigned short int cs_flag_t
Definition: cs_defs.h:324
Definition: cs_cdo_local.h:166
double * wvf
Definition: cs_cdo_local.h:333
cs_cell_mesh_t * cs_cell_mesh_create(const cs_cdo_connect_t *connect)
Allocate and initialize a cs_cell_mesh_t structure.
Definition: cs_cdo_local.c:574
short int n_ef
Definition: cs_cdo_local.h:337
double precision, dimension(ncharm), save e1
Definition: cpincl.f90:233
short int n_ec
Definition: cs_cdo_local.h:230
static short int cs_cell_mesh_get_f(const cs_lnum_t f_id, const cs_cell_mesh_t *const cm)
Retrieve the face id in the cellwise numbering associated to the given face id in the mesh numbering...
Definition: cs_cdo_local.h:479
unsigned int cs_eflag_t
Definition: cs_flag.h:187
double * values
Definition: cs_cdo_local.h:129
Set of local quantities and connectivities related to a mesh face Structure used to get a better memo...
Definition: cs_cdo_local.h:279
static void cs_cell_mesh_get_next_3_vertices(const short int *f2e_ids, const short int *e2v_ids, short int *v0, short int *v1, short int *v2)
Get the next three vertices in a row from a face to edge connectivity and a edge to vertex connectivi...
Definition: cs_cdo_local.h:542
void cs_face_mesh_build(cs_lnum_t c_id, cs_lnum_t f_id, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_face_mesh_t *fm)
Define a cs_face_mesh_t structure for a given face/cell id.
Definition: cs_cdo_local.c:1568
cs_real_3_t * vectors
Definition: cs_cdo_local.h:130
short int * f2e_idx
Definition: cs_cdo_local.h:259
Definition: cs_cdo_local.h:323
cs_face_mesh_t ** cs_cdo_local_face_meshes
void cs_cell_sys_dump(const char msg[], const cs_cell_sys_t *csys)
Dump a local system for debugging purpose.
Definition: cs_cdo_local.c:448
double * adv_fluxes
Definition: cs_cdo_local.h:112
short int * f2e_sgn
Definition: cs_cdo_local.h:261
cs_real_t * pvol_f
Definition: cs_cdo_local.h:246
cs_lnum_t c_id
Definition: cs_cdo_local.h:283
void cs_cell_mesh_dump(const cs_cell_mesh_t *cm)
Dump a cs_cell_mesh_t structure.
Definition: cs_cdo_local.c:752
double * xv
Definition: cs_cdo_local.h:299
cs_quant_t * edge
Definition: cs_cdo_local.h:232
void cs_face_mesh_free(cs_face_mesh_t **p_fm)
Free a cs_face_mesh_t structure.
Definition: cs_cdo_local.c:1535
bool has_nhmg_neumann
Definition: cs_cdo_local.h:174
#define CS_FLAG_BOUNDARY_CELL_BY_FACE
(= 1) boundary cell with at least one border face
Definition: cs_flag.h:62
