1 #ifndef __CS_PROPERTY_H__ 2 #define __CS_PROPERTY_H__ 51 #define CS_PROPERTY_MASS_DENSITY "mass_density" 61 #define CS_PROPERTY_POST_FOURIER (1 << 0) 75 #define CS_PROPERTY_ISO (1 << 0) 81 #define CS_PROPERTY_ORTHO (1 << 1) 88 #define CS_PROPERTY_ANISO (1 << 2) 94 #define CS_PROPERTY_ANISO_SYM (1 << 3) 100 #define CS_PROPERTY_BY_PRODUCT (1 << 4) 109 #define CS_PROPERTY_SUBCELL_DEFINITION (1 << 5) 349 static inline const char *
int id
Definition: cs_property.h:148
void cs_property_log_setup(void)
Print a summary of the settings for all defined cs_property_t structures.
Definition: cs_property.c:2466
Definition: cs_property.h:81
#define restrict
Definition: cs_defs.h:142
cs_property_t * cs_property_add(const char *name, cs_property_type_t type)
Create and initialize a new property structure.
Definition: cs_property.c:724
cs_property_t * cs_property_by_name(const char *name)
Find the related property definition from its name.
Definition: cs_property.c:856
short int * def_ids
Definition: cs_property.h:168
cs_real_t eigen_ratio
Definition: cs_property.h:208
#define CS_FLAG_STATE_UNIFORM
Definition: cs_flag.h:103
cs_flag_t state_flag
Definition: cs_property.h:149
cs_property_t * cs_property_subcell_add(const char *name, cs_property_type_t type)
Create and initialize a new property structure with an evaluation which can be called on a sub-partit...
Definition: cs_property.c:771
static int cs_property_get_dim(const cs_property_t *pty)
Retrieve the dimension of the property.
Definition: cs_property.h:388
cs_real_t eigen_max
Definition: cs_property.h:207
Definition: cs_field.h:125
cs_xdef_t * cs_property_def_aniso_by_value(cs_property_t *pty, const char *zname, cs_real_t tens[3][3])
Define an anisotropic cs_property_t structure by value for entities related to a volume zone...
Definition: cs_property.c:1391
bool is_iso
Definition: cs_property.h:203
Structure storing the evaluation of a property and its related data.
Definition: cs_property.h:199
char *restrict name
Definition: cs_property.h:147
cs_flag_t process_flag
Definition: cs_property.h:150
void cs_property_init_sharing(const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect)
Definition: cs_property.c:691
cs_real_t ref_value
Definition: cs_property.h:158
cs_real_t value
Definition: cs_property.h:212
cs_xdef_cw_eval_t ** get_eval_at_cell_cw
Definition: cs_property.h:182
void cs_property_destroy_all(void)
Free all cs_property_t structures and the array storing all the structures.
Definition: cs_property.c:951
cs_xdef_t * cs_property_def_ortho_by_value(cs_property_t *pty, const char *zname, double val[])
Define an orthotropic cs_property_t structure by value for entities related to a volume zone...
Definition: cs_property.c:1340
static cs_property_type_t cs_property_get_type(const cs_property_t *pty)
Retrieve the type of a property.
Definition: cs_property.h:369
Definition: cs_property.h:94
void cs_property_finalize_setup(void)
Last stage of the definition of a property based on several definitions (i.e. definition by subdomain...
Definition: cs_property.c:993
void cs_property_set_reference_value(cs_property_t *pty, double refval)
Set the reference value associated to a cs_property_t structure This is a real number even whatever t...
Definition: cs_property.c:934
void cs_property_def_by_field(cs_property_t *pty, cs_field_t *field)
Define a cs_property_t structure thanks to a field structure.
Definition: cs_property.c:1753
Definition: cs_property.h:151
cs_xdef_eval_t ** get_eval_at_cell
Definition: cs_property.h:177
Definition: cs_defs.h:322
Definition: cs_cdo_quantities.h:132
Definition: cs_property.h:75
Definition: cs_property.h:128
bool need_eigen
Definition: cs_property.h:206
cs_xdef_t * cs_property_def_iso_by_value(cs_property_t *pty, const char *zname, double val)
Define an isotropic cs_property_t structure by value for entities related to a volume zone...
Definition: cs_property.c:1284
cs_xdef_t * cs_property_def_by_func(cs_property_t *pty, const char *zname, void *context, cs_xdef_eval_t *get_eval_at_cell, cs_xdef_cw_eval_t *get_eval_at_cell_cw)
Define a cs_property_t structure thanks to law depending on one scalar variable in a subdomain attach...
Definition: cs_property.c:1630
Definition: cs_property.h:109
void() cs_xdef_eval_t(cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval)
Function pointer for evaluating a quantity defined through a descriptor (cs_xdef_t structure) ...
Definition: cs_xdef_eval.h:66
Definition: cs_property.h:145
const cs_property_t ** related_properties
Definition: cs_property.h:188
cs_xdef_t * cs_property_def_aniso_sym_by_value(cs_property_t *pty, const char *zname, cs_real_t symtens[6])
Definition: cs_property.c:1451
cs_real_t cs_property_value_in_cell(const cs_cell_mesh_t *cm, const cs_property_t *pty, cs_real_t t_eval)
Compute the value of a property at the cell center Version using a cs_cell_mesh_t structure...
Definition: cs_property.c:2229
cs_xdef_t ** defs
Definition: cs_property.h:163
void cs_property_iso_get_cell_values(cs_real_t t_eval, const cs_property_t *pty, int *pty_stride, cs_real_t **p_pty_vals)
Evaluate the value of the property at each cell. Store the evaluation in the given array...
Definition: cs_property.c:1815
void cs_property_data_init(bool need_tensor, bool need_eigen, const cs_property_t *property, cs_property_data_t *data)
Initialize a cs_property_data_t structure. If property is NULL then one considers that this is a unit...
Definition: cs_property.c:1163
#define CS_FLAG_STATE_STEADY
Definition: cs_flag.h:106
static const char * cs_property_get_name(const cs_property_t *pty)
Retrieve the name of a property.
Definition: cs_property.h:350
static bool cs_property_is_steady(const cs_property_t *pty)
returns true if the property is steady, otherwise false
Definition: cs_property.h:261
cs_real_t cs_property_get_cell_value(cs_lnum_t c_id, cs_real_t t_eval, const cs_property_t *pty)
Compute the value of a property at the cell center.
Definition: cs_property.c:2136
void cs_property_eval_at_cells(cs_real_t t_eval, const cs_property_t *pty, cs_real_t *array)
Definition: cs_property.c:1863
Definition: cs_xdef.h:154
cs_xdef_t * cs_property_def_by_time_func(cs_property_t *pty, const char *zname, cs_time_func_t *func, void *input)
Define a cs_property_t structure thanks to an analytic function in a subdomain attached to the mesh l...
Definition: cs_property.c:1504
void() cs_xdef_cw_eval_t(const cs_cell_mesh_t *cm, cs_real_t time_eval, void *input, cs_real_t *eval)
Function pointer for evaluating a quantity defined through a descriptor (cs_xdef_t structure) by a ce...
Definition: cs_xdef_cw_eval.h:70
void cs_property_c2v_values(const cs_cell_mesh_t *cm, const cs_property_t *pty, cs_real_t t_eval, cs_real_t *eval)
Compute the values of an isotropic property in each portion of dual cell in a (primal) cell...
Definition: cs_property.c:2274
bool need_tensor
Definition: cs_property.h:210
void cs_property_set_option(cs_property_t *pty, cs_property_key_t key)
Set optional parameters related to a cs_property_t structure.
Definition: cs_property.c:903
cs_xdef_t * cs_property_def_by_analytic(cs_property_t *pty, const char *zname, cs_analytic_func_t *func, void *input)
Definition: cs_property.c:1580
Definition: cs_defs.h:316
int n_definitions
Definition: cs_property.h:162
void cs_property_get_cell_tensor(cs_lnum_t c_id, cs_real_t t_eval, const cs_property_t *pty, bool do_inversion, cs_real_t tensor[3][3])
Compute the value of the tensor attached to a property at the cell center.
Definition: cs_property.c:2095
cs_property_data_t cs_property_data_define(bool need_tensor, bool need_eigen, const cs_property_t *property)
Define a cs_property_data_t structure (not a pointer to this structure). If property is NULL then one...
Definition: cs_property.c:1106
void cs_property_get_fourier(const cs_property_t *pty, cs_real_t t_eval, double dt, cs_real_t fourier[])
Compute the Fourier number in each cell.
Definition: cs_property.c:2400
int n_related_properties
Definition: cs_property.h:187
unsigned short int cs_flag_t
Definition: cs_defs.h:324
cs_property_t * cs_property_by_id(int id)
Find the related property definition from its id.
Definition: cs_property.c:883
void() cs_time_func_t(double time, void *input, cs_real_t *retval)
Function which defines the evolution of a quantity according to the current time and any structure gi...
Definition: cs_param_types.h:172
bool is_unity
Definition: cs_property.h:204
const cs_property_t * property
Definition: cs_property.h:201
Definition: cs_property.h:129
static bool cs_property_is_constant(const cs_property_t *pty)
returns true if the property is steady and uniform, otherwise false
Definition: cs_property.h:235
void cs_property_tensor_in_cell(const cs_cell_mesh_t *cm, const cs_property_t *pty, cs_real_t t_eval, bool do_inversion, cs_real_t tensor[3][3])
Compute the value of the tensor attached to a property at the cell center Version using a cs_cell_mes...
Definition: cs_property.c:2186
cs_property_t * cs_property_add_as_product(const char *name, const cs_property_t *pty_a, const cs_property_t *pty_b)
Define a cs_property_t structure thanks to the product of two properties The type is infered from tha...
Definition: cs_property.c:794
Definition: cs_property.h:88
static bool cs_property_is_subcell(const cs_property_t *pty)
returns true if the property is allowed to be evaluated on a sub-partition of a cell ...
Definition: cs_property.h:328
cs_flag_t cs_property_type_t
Definition: cs_property.h:117
static bool cs_property_is_isotropic(const cs_property_t *pty)
returns true if the property is isotropic, otherwise false
Definition: cs_property.h:305
cs_xdef_t * cs_property_def_constant_value(cs_property_t *pty, double val)
Define a single uniform and steady isotropic definition for the given cs_property_t structure...
Definition: cs_property.c:1225
cs_property_key_t
List of available keys for setting options on a property.
Definition: cs_property.h:126
static bool cs_property_is_uniform(const cs_property_t *pty)
returns true if the property is uniform, otherwise false
Definition: cs_property.h:283
int cs_property_get_n_properties(void)
Retrieve the number of properties.
Definition: cs_property.c:707
cs_xdef_t * cs_property_def_by_array(cs_property_t *pty, cs_flag_t loc, cs_real_t *array, bool is_owner, const cs_lnum_t *index, const cs_lnum_t *ids)
Define a cs_property_t structure thanks to an array of values.
Definition: cs_property.c:1677
