7.2
cs_boundary_conditions.h
1 #ifndef __CS_BOUNDARY_CONDITIONS_H__
2 #define __CS_BOUNDARY_CONDITIONS_H__
5  * Boundary condition handling.
35  * Local headers
38 #include <ple_locator.h>
40 #include "fvm_nodal.h"
41 #include "fvm_writer.h"
43 #include "cs_base.h"
44 #include "cs_field.h"
45 #include "cs_math.h"
46 #include "cs_mesh_location.h"
48 /*----------------------------------------------------------------------------*/
49
51
53  * Macro definitions
55
56 /*============================================================================
57  * Local type definitions
59
60 /*=============================================================================
61  * Global variables
62  *============================================================================*/
63
66 extern const int *cs_glob_bc_type;
67
71 extern const int *cs_glob_bc_face_zone;
72
73 /*============================================================================
74  * Public function prototypes
75  *============================================================================*/
76
77 /*----------------------------------------------------------------------------
78  * Handling of boundary condition definition errors and associated output.
79  *
80  * This function checks for errors, and simply returns if no error is
81  * encountered. In case of error, it outputs helpful information so as to
82  * make it easier to locate the matching faces.
83  *
84  * For each boundary face, bc_type defines the boundary condition type.
85  * As a convention here, zero values correspond to undefined types,
86  * positive values to defined types (with no error), and negative values
87  * to defined types with inconsistent or incompatible values, the
88  * absolute value indicating the original boundary condition type.
89  *
90  * An optional label may be used if the error is related to another
91  * attribute than the boundary type, for appropriate error reporting.
92  *
93  * parameters:
94  * bc_flag <-- array of BC type ids
95  * type_name <-- name of attribute in error, or NULL
96  *----------------------------------------------------------------------------*/
97
98 void
99 cs_boundary_conditions_error(const int *bc_type,
100  const char *type_name);
101
102 /*----------------------------------------------------------------------------
103  * Locate shifted boundary face coordinates on possibly filtered
104  * cells or boundary faces for later interpolation.
105  *
106  * parameters:
107  * location_type <-- matching values location (CS_MESH_LOCATION_CELLS
108  * or CS_MESH_LOCATION_BOUNDARY_FACES)
109  * n_location_elts <-- number of selected location elements
110  * n_faces <-- number of selected boundary faces
111  * location_elts <-- list of selected location elements (0 to n-1),
112  * or NULL if no indirection is needed
113  * faces <-- list of selected boundary faces (0 to n-1),
114  * or NULL if no indirection is needed
115  * coord_shift <-- array of coordinates shift relative to selected
116  * boundary faces
117  * coord_stride <-- access stride in coord_shift: 0 for uniform
118  * shift, 1 for "per face" shift.
119  * tolerance <-- relative tolerance for point location.
120  *
121  * returns:
122  * associated locator structure
123  *----------------------------------------------------------------------------*/
124
125 ple_locator_t *
127  cs_lnum_t n_location_elts,
128  cs_lnum_t n_faces,
129  const cs_lnum_t *location_elts,
130  const cs_lnum_t *faces,
131  cs_real_3_t *coord_shift,
132  int coord_stride,
133  double tolerance);
134
135 /*----------------------------------------------------------------------------
136  * Set mapped boundary conditions for a given field and mapping locator.
137  *
138  * parameters:
139  * field <-- field whose boundary conditions are set
140  * locator <-- associated mapping locator, as returned
141  * by cs_boundary_conditions_map().
142  * location_type <-- matching values location (CS_MESH_LOCATION_CELLS or
143  * CS_MESH_LOCATION_BOUNDARY_FACES)
144  * normalize <-- normalization option:
145  * 0: values are simply mapped
146  * 1: values are mapped, then multiplied
147  * by a constant factor so that their
148  * surface integral on selected faces
149  * is preserved (relative to the
150  * input values)
151  * 2: as 1, but with a boundary-defined
152  * weight, defined by balance_w
153  * 3: as 1, but with a cell-defined
154  * weight, defined by balance_w
155  * interpolate <-- interpolation option:
156  * 0: values are simply based on matching
157  * cell or face center values
158  * 1: values are based on matching cell
159  * or face center values, corrected
160  * by gradient interpolation
161  * n_faces <-- number of selected boundary faces
162  * faces <-- list of selected boundary faces (0 to n-1),
163  * or NULL if no indirection is needed
164  * balance_w <-- optional balance weight, or NULL
165  * nvar <-- number of variables requiring BC's
166  * rcodcl <-> boundary condition values
167  *----------------------------------------------------------------------------*/
168
169 void
171  ple_locator_t *locator,
172  cs_mesh_location_type_t location_type,
173  int normalize,
174  int interpolate,
175  cs_lnum_t n_faces,
176  const cs_lnum_t *faces,
177  cs_real_t *balance_w,
178  int nvar,
179  cs_real_t rcodcl[]);
180
181 /*----------------------------------------------------------------------------*/
205 /*----------------------------------------------------------------------------*/
206
207 int
208 cs_boundary_conditions_add_map(int bc_location_id,
209  int source_location_id,
210  cs_real_t coord_shift[3],
211  double tolerance);
212
213 /*----------------------------------------------------------------------------
214  * Create the boundary conditions face type and face zone arrays
215  *----------------------------------------------------------------------------*/
216
217 void
219
220 /*----------------------------------------------------------------------------
221  * Free the boundary conditions face type and face zone arrays.
222  *
223  * This also frees boundary condition mappings which may have been defined.
224  *----------------------------------------------------------------------------*/
225
226 void
228
229 /*----------------------------------------------------------------------------*/
240 /*----------------------------------------------------------------------------*/
241
242 inline static void
244  cs_real_t *af,
245  cs_real_t *b,
246  cs_real_t *bf,
247  cs_real_t qimp,
248  cs_real_t hint)
249 {
250  /* Gradient BCs */
251  *a = -qimp/hint;
252  *b = 1.;
253
254  /* Flux BCs */
255  *af = qimp;
256  *bf = 0.;
257 }
258
259 /*----------------------------------------------------------------------------*/
270 /*----------------------------------------------------------------------------*/
271
272 inline static void
274  cs_real_t af[3],
275  cs_real_t b[3][3],
276  cs_real_t bf[3][3],
277  const cs_real_t qimpv[3],
278  cs_real_t hint)
279 {
280  /* Gradient BCs */
281
282  for (size_t i = 0; i < 3; i++) {
283  a[i] = -qimpv[i] / fmax(hint, 1.e-300);
284  }
285
286  b[0][0] = 1., b[0][1] = 0., b[0][2] = 0.;
287  b[1][0] = 0., b[1][1] = 1., b[1][2] = 0.;
288  b[2][0] = 0., b[2][1] = 0., b[2][2] = 1.;
289
290  /* Flux BCs */
291
292  for (size_t i = 0; i < 3; i++) {
293  af[i] = qimpv[i];
294
295  for (size_t j = 0; j < 3; j++)
296  bf[i][j] = 0;
297  }
298 }
299
300 /*----------------------------------------------------------------------------*/
313 /*----------------------------------------------------------------------------*/
314
315 inline static void
317  cs_real_t *af,
318  cs_real_t *b,
319  cs_real_t *bf,
320  cs_real_t pimp,
321  cs_real_t hint,
322  cs_real_t hext)
323 {
324  if (hext < 0.) {
325
326  /* Gradient BCs */
327  *a = pimp;
328  *b = 0.;
329
330  /* Flux BCs */
331  *af = -hint*pimp;
332  *bf = hint;
333
334  }
335  else {
336
337  /* Gradient BCs */
338  *a = hext*pimp/(hint + hext);
339  *b = hint /(hint + hext);
340
341  /* Flux BCs */
342  cs_real_t heq = hint*hext/(hint + hext);
343  *af = -heq*pimp;
344  *bf = heq;
345
346  }
347 }
348
349 /*----------------------------------------------------------------------------*/
362 /*----------------------------------------------------------------------------*/
363
364 inline static void
366  cs_real_3_t af,
367  cs_real_33_t b,
368  cs_real_33_t bf,
369  cs_real_3_t pimpv,
370  cs_real_t hint,
371  cs_real_3_t hextv)
372 {
373  for (int isou = 0 ; isou < 3; isou++) {
374  if (fabs(hextv[isou]) > 0.5*cs_math_infinite_r) {
375
376  /* Gradient BCs */
377  a[isou] = pimpv[isou];
378  for (int jsou = 0 ; jsou < 3 ; jsou++)
379  b[isou][jsou] = 0.;
380
381  /* Flux BCs */
382  af[isou] = -hint*pimpv[isou];
383  for (int jsou = 0; jsou < 3; jsou++) {
384  if (jsou == isou)
385  bf[isou][jsou] = hint;
386  else
387  bf[isou][jsou] = 0.;
388  }
389  } else {
390
391  cs_real_t heq = hint*hextv[isou]/(hint + hextv[isou]);
392
393  /* Gradient BCs */
394  a[isou] = hextv[isou]*pimpv[isou]/(hint + hextv[isou]);
395  for (int jsou = 0 ; jsou < 3 ; jsou++) {
396  if (jsou == isou)
397  b[isou][jsou] = hint/(hint + hextv[isou]);
398  else
399  b[isou][jsou] = 0.;
400  }
401
402  /* Flux BCs */
403  af[isou] = -heq*pimpv[isou];
404  for (int jsou = 0 ; jsou < 3 ; jsou++) {
405  if (jsou == isou)
406  bf[isou][jsou] = heq;
407  else
408  bf[isou][jsou] = 0.;
409  }
410  }
411  }
412 }
413
414 /*----------------------------------------------------------------------------*/
427 /*----------------------------------------------------------------------------*/
428
429 void
431  cs_real_t *cofaf,
432  cs_real_t *coefb,
433  cs_real_t *cofbf,
434  cs_real_t pimp,
435  cs_real_t cfl,
436  cs_real_t hint);
437
438 /*----------------------------------------------------------------------------*/
452 /*----------------------------------------------------------------------------*/
453
454 inline static void
456  cs_real_3_t af,
457  cs_real_33_t b,
458  cs_real_33_t bf,
459  cs_real_3_t pimpv,
460  cs_real_6_t hintt,
461  cs_real_3_t hextv)
462 {
463  for (int isou = 0 ; isou < 3 ; isou++) {
464  if (fabs(hextv[isou]) > 0.5*cs_math_infinite_r) {
465
466  /* Gradient BCs */
467  a[isou] = pimpv[isou];
468  for (int jsou = 0 ; jsou < 3 ; jsou++)
469  b[isou][jsou] = 0.;
470
471  } else {
472
473  cs_exit(1);
474
475  }
476  }
477
478  /* Flux BCs */
479  cs_math_sym_33_3_product(hintt, pimpv, af);
480  for (int isou = 0 ; isou < 3 ; isou++)
481  af[isou] = -af[isou];
482
483  bf[0][0] = hintt[0];
484  bf[1][1] = hintt[1];
485  bf[2][2] = hintt[2];
486  bf[0][1] = hintt[3];
487  bf[1][0] = hintt[3];
488  bf[1][2] = hintt[4];
489  bf[2][1] = hintt[4];
490  bf[0][2] = hintt[5];
491  bf[2][0] = hintt[5];
492 }
493
494 /*----------------------------------------------------------------------------*/
503 /*----------------------------------------------------------------------------*/
504
505 void
507  int itypfb[],
508  int icodcl[],
509  double rcodcl[]);
510
511 /*----------------------------------------------------------------------------*/
524 /*----------------------------------------------------------------------------*/
525
526 void
528  int itypfb[],
529  int icodcl[],
530  double rcodcl[]);
531
532 /*----------------------------------------------------------------------------*/
533
535
536 #endif /* __CS_BOUNDARY_CONDITIONS_H__ */
cs_real_t cs_real_6_t[6]
Definition: cs_defs.h:337
static void cs_boundary_conditions_set_neumann_vector(cs_real_t a[3], cs_real_t af[3], cs_real_t b[3][3], cs_real_t bf[3][3], const cs_real_t qimpv[3], cs_real_t hint)
Set Neumann BC for a scalar for a given face.
Definition: cs_boundary_conditions.h:273
Definition: cs_field.h:125
Definition: cs_mesh_location.h:60
void cs_boundary_conditions_free(void)
Definition: cs_boundary_conditions.c:1332
void cs_exit(int status)
Definition: cs_base.c:1498
void cs_boundary_conditions_create(void)
Create the legacy boundary conditions face type and face zone arrays.
Definition: cs_boundary_conditions.c:1292
void cs_boundary_conditions_mapped_set(const cs_field_t *f, ple_locator_t *locator, cs_mesh_location_type_t location_type, int normalize, int interpolate, cs_lnum_t n_faces, const cs_lnum_t *faces, cs_real_t *balance_w, int nvar, cs_real_t rcodcl[])
Definition: cs_boundary_conditions.c:1047
const int * cs_glob_bc_face_zone
Definition: cs_defs.h:322
static void cs_boundary_conditions_set_dirichlet_scalar(cs_real_t *a, cs_real_t *af, cs_real_t *b, cs_real_t *bf, cs_real_t pimp, cs_real_t hint, cs_real_t hext)
Set Dirichlet BC for a scalar for a given face.
Definition: cs_boundary_conditions.h:316
void cs_boundary_conditions_set_convective_outlet_scalar(cs_real_t *coefa, cs_real_t *cofaf, cs_real_t *coefb, cs_real_t *cofbf, cs_real_t pimp, cs_real_t cfl, cs_real_t hint)
Set convective oulet boundary condition for a scalar.
Definition: cs_boundary_conditions.c:1359
double precision, save a
void cs_boundary_conditions_compute(int nvar, int itypfb[], int icodcl[], double rcodcl[])
Update per variable boundary condition codes.
Definition: cs_boundary_conditions.c:1388
integer, dimension(:), pointer, save itypfb
Definition: pointe.f90:100
integer, save nvar
number of solved variables (must be lower than nvarmx)
Definition: dimens.f90:42
double precision, save fmax
Definition: coincl.f90:180
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:335
static void cs_boundary_conditions_set_dirichlet_vector(cs_real_3_t a, cs_real_3_t af, cs_real_33_t b, cs_real_33_t bf, cs_real_3_t pimpv, cs_real_t hint, cs_real_3_t hextv)
Set Dirichlet BC for a vector for a given face.
Definition: cs_boundary_conditions.h:365
Definition: cs_defs.h:316
static void cs_boundary_conditions_set_dirichlet_vector_aniso(cs_real_3_t a, cs_real_3_t af, cs_real_33_t b, cs_real_33_t bf, cs_real_3_t pimpv, cs_real_6_t hintt, cs_real_3_t hextv)
Set Dirichlet BC for a vector for a given face with left anisotropic diffusion.
Definition: cs_boundary_conditions.h:455
double precision, dimension(nozppm), save qimp
Definition: coincl.f90:155
cs_real_t cs_real_33_t[3][3]
Definition: cs_defs.h:342
void cs_boundary_conditions_complete(int nvar, int itypfb[], int icodcl[], double rcodcl[])
Automatic adjustments for boundary condition codes.
Definition: cs_boundary_conditions.c:1570
static void cs_math_sym_33_3_product(const cs_real_t m[6], const cs_real_t v[3], cs_real_t mv[restrict 3])
Compute the product of a symmetric matrix of 3x3 real values by a vector of 3 real values...
Definition: cs_math.h:618
void cs_boundary_conditions_error(const int *bc_type, const char *type_name)
Definition: cs_boundary_conditions.c:825
static void cs_boundary_conditions_set_neumann_scalar(cs_real_t *a, cs_real_t *af, cs_real_t *b, cs_real_t *bf, cs_real_t qimp, cs_real_t hint)
Definition: cs_boundary_conditions.h:243
int cs_boundary_conditions_add_map(int bc_location_id, int source_location_id, cs_real_t coord_shift[3], double tolerance)
Add location of locate shifted boundary face coordinates on cells or boundary faces for automatic int...
Definition: cs_boundary_conditions.c:1259
const cs_real_t cs_math_infinite_r
ple_locator_t * cs_boundary_conditions_map(cs_mesh_location_type_t location_type, cs_lnum_t n_location_elts, cs_lnum_t n_faces, const cs_lnum_t *location_elts, const cs_lnum_t *faces, cs_real_3_t *coord_shift, int coord_stride, double tolerance)
Locate shifted boundary face coordinates on possibly filtered cells or boundary faces for later inter...
Definition: cs_boundary_conditions.c:879
const int * cs_glob_bc_type
double precision, save b
