#include <ple_locator.h>#include "fvm_nodal.h"#include "fvm_writer.h"#include "cs_base.h"#include "cs_field.h"#include "cs_math.h"#include "cs_mesh_location.h"
Include dependency graph for cs_boundary_conditions.h:Go to the source code of this file.
| void | cs_boundary_conditions_error (const int *bc_type, const char *type_name) |
| Handling of boundary condition definition errors and associated output. More... | |
| ple_locator_t * | cs_boundary_conditions_map (cs_mesh_location_type_t location_type, cs_lnum_t n_location_elts, cs_lnum_t n_faces, const cs_lnum_t *location_elts, const cs_lnum_t *faces, cs_real_3_t *coord_shift, int coord_stride, double tolerance) |
| Locate shifted boundary face coordinates on possibly filtered cells or boundary faces for later interpolation. More... | |
| void | cs_boundary_conditions_mapped_set (const cs_field_t *f, ple_locator_t *locator, cs_mesh_location_type_t location_type, int normalize, int interpolate, cs_lnum_t n_faces, const cs_lnum_t *faces, cs_real_t *balance_w, int nvar, cs_real_t rcodcl[]) |
| Set mapped boundary conditions for a given field and mapping locator. More... | |
| int | cs_boundary_conditions_add_map (int bc_location_id, int source_location_id, cs_real_t coord_shift[3], double tolerance) |
| Add location of locate shifted boundary face coordinates on cells or boundary faces for automatic interpolation. More... | |
| void | cs_boundary_conditions_create (void) |
| Create the legacy boundary conditions face type and face zone arrays. More... | |
| void | cs_boundary_conditions_free (void) |
| Free the boundary conditions face type and face zone arrays. More... | |
| static void | cs_boundary_conditions_set_neumann_scalar (cs_real_t *a, cs_real_t *af, cs_real_t *b, cs_real_t *bf, cs_real_t qimp, cs_real_t hint) |
| Set Neumann BC for a scalar for a given face. More... | |
| static void | cs_boundary_conditions_set_neumann_vector (cs_real_t a[3], cs_real_t af[3], cs_real_t b[3][3], cs_real_t bf[3][3], const cs_real_t qimpv[3], cs_real_t hint) |
| static void | cs_boundary_conditions_set_dirichlet_scalar (cs_real_t *a, cs_real_t *af, cs_real_t *b, cs_real_t *bf, cs_real_t pimp, cs_real_t hint, cs_real_t hext) |
| Set Dirichlet BC for a scalar for a given face. More... | |
| static void | cs_boundary_conditions_set_dirichlet_vector (cs_real_3_t a, cs_real_3_t af, cs_real_33_t b, cs_real_33_t bf, cs_real_3_t pimpv, cs_real_t hint, cs_real_3_t hextv) |
| Set Dirichlet BC for a vector for a given face. More... | |
| void | cs_boundary_conditions_set_convective_outlet_scalar (cs_real_t *coefa, cs_real_t *cofaf, cs_real_t *coefb, cs_real_t *cofbf, cs_real_t pimp, cs_real_t cfl, cs_real_t hint) |
| Set convective oulet boundary condition for a scalar. More... | |
| static void | cs_boundary_conditions_set_dirichlet_vector_aniso (cs_real_3_t a, cs_real_3_t af, cs_real_33_t b, cs_real_33_t bf, cs_real_3_t pimpv, cs_real_6_t hintt, cs_real_3_t hextv) |
| Set Dirichlet BC for a vector for a given face with left anisotropic diffusion. More... | |
| void | cs_boundary_conditions_compute (int nvar, int itypfb[], int icodcl[], double rcodcl[]) |
| Update per variable boundary condition codes. More... | |
| void | cs_boundary_conditions_complete (int nvar, int itypfb[], int icodcl[], double rcodcl[]) |
| Automatic adjustments for boundary condition codes. More... | |
| const int * | cs_glob_bc_type |
| const int * | cs_glob_bc_face_zone |
| int cs_boundary_conditions_add_map | ( | int | bc_location_id, |
| int | source_location_id, | ||
| cs_real_t | coord_shift[3], | ||
| double | tolerance | ||
| [in] | bc_location_id | id of selected boundary mesh location; currently restricted to subsets of boundary faces (i.e. boundary zone location ids). |
| [in] | source_location_id | id of selected location mesh location (usually CS_MESH_LOCATION_CELLS but can be a more restricted cell or boundary face zone location location id). |
| [in] | coord_shift | coordinates shift relative to selected boundary faces |
| [in] | tolerance | relative tolerance for point location. |
| void cs_boundary_conditions_complete | ( | int | nvar, |
| int | itypfb[], | ||
| int | icodcl[], | ||
| double | rcodcl[] | ||
| [in] | nvar | number of variables requiring BC's |
| [in] | itypfb | type of boundary for each face |
| [in,out] | icodcl | boundary condition codes |
| [in,out] | rcodcl | boundary condition values |
| void cs_boundary_conditions_compute | ( | int | nvar, |
| void cs_boundary_conditions_create | ( | void | ) |
| void cs_boundary_conditions_error | ( | const int * | bc_flag, |
| const char * | type_name | ||
| [in] | bc_flag | array of BC type ids |
| [in] | type_name | name of attribute in error, or NULL |
| void cs_boundary_conditions_free | ( | void | ) |
| ple_locator_t* cs_boundary_conditions_map | ( | cs_mesh_location_type_t | location_type, |
| cs_lnum_t | n_location_elts, | ||
| cs_lnum_t | n_faces, | ||
| const cs_lnum_t * | location_elts, | ||
| const cs_lnum_t * | faces, | ||
| cs_real_3_t * | coord_shift, | ||
| int | coord_stride, | ||
| [in] | location_type | matching values location (CS_MESH_LOCATION_CELLS or CS_MESH_LOCATION_BOUNDARY_FACES) |
| [in] | n_location_elts | number of selected location elements |
| [in] | n_faces | number of selected boundary faces |
| [in] | location_elts | list of selected location elements (0 to n-1), or NULL if no indirection is needed |
| [in] | faces | list of selected boundary faces (0 to n-1), or NULL if no indirection is needed |
| [in] | coord_shift | array of coordinates shift relative to selected boundary faces |
| [in] | coord_stride | access stride in coord_shift: 0 for uniform shift, 1 for "per face" shift. |
| void cs_boundary_conditions_mapped_set | ( | const cs_field_t * | f, |
| ple_locator_t * | locator, | ||
| cs_mesh_location_type_t | location_type, | ||
| int | normalize, | ||
| int | interpolate, | ||
| cs_real_t * | balance_w, | ||
| int | nvar, | ||
| cs_real_t | rcodcl[] | ||
| [in] | f | field whose boundary conditions are set |
| [in] | locator | associated mapping locator, as returned by cs_boundary_conditions_map. |
| [in] | normalize | normalization option: 0: values are simply mapped 1: values are mapped, then multiplied by a constant factor so that their surface integral on selected faces is preserved (relative to the input values) 2: as 1, but with a boundary-defined weight, defined by balance_w 3: as 1, but with a cell-defined weight, defined by balance_w |
| [in] | interpolate | interpolation option: 0: values are simply based on matching cell or face center values 1: values are based on matching cell or face center values, corrected by gradient interpolation |
| [in] | balance_w | optional balance weight, or NULL |
| void cs_boundary_conditions_set_convective_outlet_scalar | ( | cs_real_t * | coefa, |
| cs_real_t * | cofaf, | ||
| cs_real_t * | coefb, | ||
| cs_real_t * | cofbf, | ||
| cs_real_t | pimp, | ||
| cs_real_t | cfl, | ||
| cs_real_t | hint | ||
Parameters:
| [out] | coefa | explicit BC coefficient for gradients |
| [out] | cofaf | explicit BC coefficient for diffusive flux |
| [out] | coefb | implicit BC coefficient for gradients |
| [out] | cofbf | implicit BC coefficient for diffusive flux |
| [in] | pimp | Flux value to impose |
| [in] | cfl | Local Courant number used to convect |
| [in] | hint | Internal exchange coefficient |
inlinestatic |
| [out] | a | explicit BC coefficient for gradients |
| [out] | af | explicit BC coefficient for diffusive flux |
| [out] | b | implicit BC coefficient for gradients |
| [out] | bf | implicit BC coefficient for diffusive flux |
| [in] | pimp | dirichlet value to impose |
| [in] | hint | internal exchange coefficient |
| [in] | hext | external exchange coefficient (assumed infinite/ignored if < 0) |
inlinestatic |
| [in] | pimpv | dirichlet value to impose |
| [in] | hextv | external exchange coefficient (assumed infinite/ignored if < 0) |
inlinestatic |
| [in] | hintt | internal exchange coefficient |
inlinestatic |
| [in] | qimp | flux value to impose |
inlinestatic |
| [in] | qimpv | flux value to impose |
| const int* cs_glob_bc_face_zone |
boundary zone number associated with each boundary face (specific physical models)
| const int* cs_glob_bc_type |
Boundary condition type (code) associated with each boundary face
