#include <cs_lagr.h>
Collaboration diagram for cs_lagr_injection_set_t:Particle injection parameters for a given zone and particle set
| int aggregat_class_id |
aggregate class id
| cs_real_t aggregat_fractal_dim |
aggregate fractal dimension
| cs_real_t angular_vel[3] |
particle angular velocity (if shape model is activated
| int cluster |
statistical cluster id
| int coal_number |
particle coal number (if physical_model =2)
| cs_real_t cp |
particle specific heat
| cs_real_t density |
particle density
| cs_real_t diameter |
particle diameter
| cs_real_t diameter_variance |
particle diameter variance
| cs_real_t emissivity |
particle emissivity
| cs_real_t euler[4] |
particle four Euler parameters (if shape model is activated
| cs_real_t flow_rate |
flow rate
| cs_real_t fouling_index |
fouling index
| int injection_frequency |
injection frequency (if =< 0, only at first iteration)
| cs_lagr_injection_profile_compute_t* injection_profile_func |
optional injection profile computation function, or NULL
| void* injection_profile_input |
optional injection profile input data, or NULL
| int location_id |
associated mesh location id
| cs_gnum_t n_inject |
number of particles injected at a time for this class and zone
| cs_real_t orientation[3] |
particle orintation for spheroids
| cs_real_t radii[3] |
particle radii for ellispoids
| int set_id |
associated set id
| cs_real_t shape |
particle shape for spheroids (if shape model is activated
| cs_real_t shape_param[4] |
particle shape parameters for ellispoids (alpha_0, beta_0, gamma_0, chi _0) in Brenner 1964 (if shape model is activated
| cs_real_t stat_weight |
particle statitistical weight
| cs_real_t temperature |
particle temperature
| int temperature_profile |
temperature condition type:
| cs_real_t velocity[3] |
particle velocity components
| cs_real_t velocity_magnitude |
particle velocity magnitude
| int velocity_profile |
velocity condition type:
| int zone_id |
associated zone id
