1354 cs_real_t **p_cs_glob_lagr_source_terms);
int temperature_profile
Definition: cs_lagr.h:587
const cs_lagr_particle_counter_t * cs_glob_lagr_particle_counter
Definition: cs_lagr.h:726
int itsli
Definition: cs_lagr.h:660
Definition: cs_lagr.h:149
cs_lagr_zone_data_t * cs_lagr_get_boundary_conditions(void)
Return pointer to the main boundary conditions structure.
Definition: cs_lagr.c:1668
cs_gnum_t n_g_exit
Definition: cs_lagr.h:361
Definition: cs_lagr.h:157
cs_real_t csthpp
Definition: cs_lagr.h:491
cs_real_t fouling_index
Definition: cs_lagr.h:622
unsigned long cs_gnum_t
global mesh entity number
Definition: cs_defs.h:301
Definition: cs_lagr.h:404
Definition: cs_lagr.h:141
int ilapoi
Definition: cs_lagr.h:235
Definition: cs_lagr.h:532
cs_real_t * visref
Definition: cs_lagr.h:783
int coal_number
Definition: cs_lagr.h:589
int set_id
Definition: cs_lagr.h:563
cs_real_t slope_consol
Definition: cs_lagr.h:536
cs_real_t * enc2
Definition: cs_lagr.h:773
cs_real_t w_merged
Definition: cs_lagr.h:388
Definition: cs_lagr.h:105
cs_real_t phi_p
Definition: cs_lagr.h:806
cs_real_t cp
Definition: cs_lagr.h:624
cs_lagr_boundary_interactions_t * cs_get_lagr_boundary_interactions(void)
Definition: cs_lagr.c:1765
Definition: cs_lagr.h:1004
int iclogh
Definition: cs_lagr.h:873
cs_real_t temperature
Definition: cs_lagr.h:601
cs_real_t * enc1
Definition: cs_lagr.h:771
void cs_lagr_injection_set_default(cs_lagr_injection_set_t *zis)
Initialize injection set data structure fields to defaults.
Definition: cs_lagr.c:1336
Definition: cs_lagr.h:544
int io2
Definition: cs_lagr.h:1007
cs_lagr_module_status_t
Definition: cs_lagr.h:122
int npstf
Definition: cs_lagr.h:840
int deposition
Definition: cs_lagr.h:299
Definition: cs_field.h:125
cs_lagr_physico_chemical_t * cs_get_lagr_physico_chemical(void)
Definition: cs_lagr.c:1606
cs_real_t * e2ch
Definition: cs_lagr.h:1026
cs_real_t rayasp
Definition: cs_lagr.h:459
cs_real_t w_exit
Definition: cs_lagr.h:385
cs_real_t added_mass_const
Definition: cs_lagr.h:255
int itsco
Definition: cs_lagr.h:685
int ncharm2
Definition: cs_lagr.h:164
int nstits
Definition: cs_lagr.h:703
void cs_lagr_add_fields(void)
Create additional fields needed by the Lagrangien model.
Definition: cs_lagr.c:1236
cs_lagr_encrustation_t * cs_get_lagr_encrustation(void)
Definition: cs_lagr.c:1594
int clogging
Definition: cs_lagr.h:313
Definition: cs_lagr.h:467
cs_lagr_injection_set_t ** injection_set
Definition: cs_lagr.h:735
cs_real_t * thcdch
Definition: cs_lagr.h:1035
cs_real_t cppart
Definition: cs_lagr.h:438
cs_lnum_t iconsol
Definition: cs_lagr.h:534
cs_lagr_agglomeration_model_t * cs_get_lagr_agglomeration_model(void)
Definition: cs_lagr.c:1546
int fouling
Definition: cs_lagr.h:325
int ngazem
Definition: cs_lagr.h:1017
char * elt_type
Definition: cs_lagr.h:738
int iclgst
Definition: cs_lagr.h:858
cs_real_t denasp
Definition: cs_lagr.h:457
int ihdepm
Definition: cs_lagr.h:879
int n_zones
Definition: cs_lagr.h:730
const cs_lagr_zone_data_t * cs_glob_lagr_boundary_conditions
Definition: cs_lagr.h:637
int n_user_variables
Definition: cs_lagr.h:337
int iencra
Definition: cs_lagr.h:764
int ireent
Definition: cs_lagr.h:449
cs_lagr_consolidation_model_t * cs_get_lagr_consolidation_model(void)
Definition: cs_lagr.c:1558
int itsfp4
Definition: cs_lagr.h:688
cs_real_t * rho0ch
Definition: cs_lagr.h:1032
cs_real_t * a2ch
Definition: cs_lagr.h:1025
int isuila
Definition: cs_lagr.h:217
int itsti
Definition: cs_lagr.h:673
char ** nombrd
Definition: cs_lagr.h:904
cs_real_t aggregat_fractal_dim
Definition: cs_lagr.h:596
Definition: cs_lagr.h:135
Definition: cs_lagr.h:262
int nusbrd
Definition: cs_lagr.h:159
int isttio
Definition: cs_lagr.h:210
cs_lagr_particle_counter_t * cs_lagr_get_particle_counter(void)
Get read/write pointer to global particle counter.
Definition: cs_lagr.c:1409
int location_id
Definition: cs_lagr.h:564
cs_real_t * wmolat
Definition: cs_lagr.h:1015
int location_id
Definition: cs_lagr.h:728
int idistu
Definition: cs_lagr.h:289
Definition: cs_lagr.h:123
cs_real_t * st_val
Definition: cs_lagr.h:719
int nlayer
Definition: cs_lagr.h:165
Definition: cs_lagr.h:499
cs_gnum_t n_g_merged
Definition: cs_lagr.h:364
Definition: cs_defs.h:322
cs_real_t min_stat_weight
Definition: cs_lagr.h:511
cs_real_t jamlim
Definition: cs_lagr.h:489
int dlvo
Definition: cs_lagr.h:301
cs_real_t lambda_vdw
Definition: cs_lagr.h:800
cs_real_t espasg
Definition: cs_lagr.h:456
cs_lagr_injection_profile_compute_t * injection_profile_func
Definition: cs_lagr.h:573
cs_real_t * xashch
Definition: cs_lagr.h:1034
Definition: cs_lagr.h:126
int idpvar
Definition: cs_lagr.h:416
int ihdiam
Definition: cs_lagr.h:885
void * injection_profile_input
Definition: cs_lagr.h:576
cs_lagr_coal_comb_t * cs_glob_lagr_coal_comb
cs_real_t stat_weight
Definition: cs_lagr.h:626
cs_real_t prefth
Definition: cs_lagr.h:1011
int t_order
Definition: cs_lagr.h:220
cs_lagr_bc_type
Definition: cs_lagr.h:83
cs_gnum_t n_inject
Definition: cs_lagr.h:566
cs_real_t * tprenc
Definition: cs_lagr.h:778
cs_real_t flow_rate
Definition: cs_lagr.h:628
cs_real_t ttclag
Definition: cs_lagr.h:553
int n_boundary_stats
Definition: cs_lagr.h:175
cs_real_t valen
Definition: cs_lagr.h:812
int ntersl
Definition: cs_lagr.h:174
cs_lagr_physico_chemical_t * cs_glob_lagr_physico_chemical
int iadded_mass
Definition: cs_lagr.h:252
Definition: cs_lagr.h:831
cs_real_t vmax
Definition: cs_lagr.h:713
int n_temperature_layers
Definition: cs_lagr.h:275
int ncharm
Definition: cs_lagr.h:1021
int inbr
Definition: cs_lagr.h:861
int nor
Definition: cs_lagr.h:547
cs_real_33_t * cs_glob_lagr_b_face_proj
cs_lagr_zone_data_t * cs_lagr_get_volume_conditions(void)
Return pointer to the main volume conditions structure.
Definition: cs_lagr.c:1692
int cluster
Definition: cs_lagr.h:593
int ltsdyn
Definition: cs_lagr.h:642
int * itsmv2
Definition: cs_lagr.h:682
int npstft
Definition: cs_lagr.h:848
int iatc
Definition: cs_lagr.h:1010
cs_real_t shape
Definition: cs_lagr.h:606
cs_lagr_reentrained_model_t * cs_get_lagr_reentrained_model(void)
Provide access to cs_lagr_reentrained_model_t.
Definition: cs_lagr.c:1497
int ih2o
Definition: cs_lagr.h:1006
cs_lagr_consolidation_model_t * cs_glob_lagr_consolidation_model
int roughness
Definition: cs_lagr.h:305
void cs_lagr_finalize_zone_conditions(void)
Finalize the global boundary and volume condition structures.
Definition: cs_lagr.c:1716
Definition: cs_lagr.h:750
int iscovc
Definition: cs_lagr.h:876
Definition: cs_lagr.h:104
cs_lagr_specific_physics_t * cs_get_lagr_specific_physics(void)
Provide access to cs_lagr_specific_physics_t.
Definition: cs_lagr.c:1483
int itste
Definition: cs_lagr.h:669
int * itsmv1
Definition: cs_lagr.h:679
int extended_t_scheme
Definition: cs_lagr.h:224
cs_lnum_t n_max_classes
Definition: cs_lagr.h:510
cs_real_t base_diameter
Definition: cs_lagr.h:514
cs_real_t w_total
Definition: cs_lagr.h:379
int itske
Definition: cs_lagr.h:665
cs_real_t diameter
Definition: cs_lagr.h:472
cs_real_t * a1ch
Definition: cs_lagr.h:1022
int ltsmas
Definition: cs_lagr.h:648
cs_gnum_t n_g_cumulative_failed
Definition: cs_lagr.h:352
cs_real_t * ehetch
Definition: cs_lagr.h:1031
cs_real_t * solub
Definition: cs_lagr.h:478
cs_gnum_t n_g_resuspended
Definition: cs_lagr.h:373
integer, dimension(:), pointer, save itypfb
Definition: pointe.f90:100
cs_real_t * e1ch
Definition: cs_lagr.h:1024
cs_real_t w_new
Definition: cs_lagr.h:382
int * iym1
Definition: cs_lagr.h:1019
Definition: cs_lagr.h:560
int agglomeration
Definition: cs_lagr.h:329
int iclogt
Definition: cs_lagr.h:870
int npts
Definition: cs_lagr.h:706
cs_real_t trefth
Definition: cs_lagr.h:1012
int ntxerr
Definition: cs_lagr.h:710
cs_lagr_shape_model_t * cs_glob_lagr_shape_model
cs_lagr_agglomeration_model_t * cs_glob_lagr_agglomeration_model
Definition: cs_lagr.h:487
cs_gnum_t n_g_fouling
Definition: cs_lagr.h:370
int ltsthe
Definition: cs_lagr.h:656
int interpol_field
Definition: cs_lagr.h:228
cs_real_t * xwatch
Definition: cs_lagr.h:1033
const cs_lagr_zone_data_t * cs_glob_lagr_volume_conditions
cs_real_t velocity_magnitude
Definition: cs_lagr.h:598
Definition: cs_lagr.h:125
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:335
cs_real_t w_resuspended
Definition: cs_lagr.h:397
Definition: cs_lagr.h:124
Definition: cs_lagr.h:521
cs_lagr_specific_physics_t * cs_glob_lagr_specific_physics
cs_lagr_time_scheme_t * cs_glob_lagr_time_scheme
cs_real_t cstham
Definition: cs_lagr.h:796
Definition: cs_lagr.h:822
cs_lagr_internal_condition_t * cs_glob_lagr_internal_conditions
int consolidation
Definition: cs_lagr.h:322
cs_lagr_fragmentation_model_t * cs_glob_lagr_fragmentation_model
cs_real_t * cp2ch
Definition: cs_lagr.h:1029
int injection_frequency
Definition: cs_lagr.h:569
int * nbprec
Definition: cs_lagr.h:476
int zone_id
Definition: cs_lagr.h:562
int velocity_profile
Definition: cs_lagr.h:582
Definition: cs_lagr.h:151
cs_gnum_t n_g_failed
Definition: cs_lagr.h:376
cs_lagr_model_t * cs_glob_lagr_model
cs_real_t * y2ch
Definition: cs_lagr.h:1028
int ihdepv
Definition: cs_lagr.h:882
int ndlaim
Definition: cs_lagr.h:162
int * i_face_zone_id
Definition: cs_lagr.h:752
int modcpl
Definition: cs_lagr.h:283
cs_real_t force_consol
Definition: cs_lagr.h:537
Definition: cs_defs.h:316
int * zone_type
Definition: cs_lagr.h:731
cs_lagr_clogging_model_t * cs_glob_lagr_clogging_model
void() cs_lagr_injection_profile_compute_t(int zone_id, int location_id, const void *input, cs_lnum_t n_elts, const cs_lnum_t elt_ids[], cs_real_t profile[])
Function pointer for computation of particle injection profile.
void cs_lagr_solve_time_step(const int itypfb[], const cs_real_t *dt)
Definition: cs_lagr.c:1858
cs_real_t dtp
Definition: cs_lagr.h:550
int physical_model
Definition: cs_lagr.h:274
cs_real_t tstatp
Definition: cs_lagr.h:896
cs_real_t epseau
Definition: cs_lagr.h:803
int cs_glob_lagr_log_frequency_n
const cs_lagr_const_dim_t * cs_glob_lagr_const_dim
int aggregat_class_id
Definition: cs_lagr.h:595
Definition: cs_lagr.h:344
int nbrclas
Definition: cs_lagr.h:470
cs_real_t * wmole
Definition: cs_lagr.h:1018
int iilagr
Definition: cs_lagr.h:196
int iflow
Definition: cs_lagr.h:453
cs_lagr_clogging_model_t * cs_get_lagr_clogging_model(void)
Definition: cs_lagr.c:1522
int precipitation
Definition: cs_lagr.h:324
int has_part_impact_nbr
Definition: cs_lagr.h:853
cs_lagr_boundary_interactions_t * cs_glob_lagr_boundary_interactions
int itpvar
Definition: cs_lagr.h:411
cs_lagr_source_terms_t * cs_get_lagr_source_terms(void)
Definition: cs_lagr.c:1582
int ico
Definition: cs_lagr.h:1008
cs_real_t tpart
Definition: cs_lagr.h:429
Definition: cs_lagr.h:150
cs_gnum_t n_g_total
Definition: cs_lagr.h:355
cs_real_t mporos
Definition: cs_lagr.h:490
cs_real_t rate_consol
Definition: cs_lagr.h:535
int inclgt
Definition: cs_lagr.h:867
cs_real_t * ahetch
Definition: cs_lagr.h:1030
Definition: cs_lagr.h:508
cs_real_t * h02ch
Definition: cs_lagr.h:1023
cs_lagr_particle_counter_t * cs_lagr_update_particle_counter(void)
Update global particle counter.
Definition: cs_lagr.c:1426
cs_real_t rho
Definition: cs_lagr.h:474
cs_real_t dnpenc
Definition: cs_lagr.h:786
cs_gnum_t n_g_cumulative_total
Definition: cs_lagr.h:348
cs_lagr_brownian_t * cs_glob_lagr_brownian
cs_real_t * y1ch
Definition: cs_lagr.h:1027
int resuspension
Definition: cs_lagr.h:309
cs_lagr_precipitation_model_t * cs_glob_lagr_precipitation_model
int ihsum
Definition: cs_lagr.h:888
cs_lagr_dim_t * cs_glob_lagr_dim
cs_real_t cs_real_33_t[3][3]
Definition: cs_defs.h:342
cs_real_t diameter
Definition: cs_lagr.h:603
cs_lagr_extra_module_t * cs_get_lagr_extra_module(void)
Definition: cs_lagr.c:1776
cs_lagr_brownian_t * cs_get_lagr_brownian(void)
Definition: cs_lagr.c:1618
Definition: cs_lagr.h:524
int * n_injection_sets
Definition: cs_lagr.h:733
int inclg
Definition: cs_lagr.h:864
cs_real_t fion
Definition: cs_lagr.h:815
int idiffl
Definition: cs_lagr.h:295
cs_real_t diameter_variance
Definition: cs_lagr.h:604
cs_lagr_time_step_t * cs_glob_lagr_time_step
cs_lagr_source_terms_t * cs_glob_lagr_source_terms
Definition: cs_lagr.h:759
cs_real_t w_deposited
Definition: cs_lagr.h:391
Definition: cs_lagr.h:138
void cs_lagr_init_c_arrays(int dim_cs_glob_lagr_source_terms[2], cs_real_t **p_cs_glob_lagr_source_terms)
Definition: cs_lagr.c:1126
cs_real_t w_fouling
Definition: cs_lagr.h:394
cs_lagr_extra_module_t * cs_glob_lagr_extra_module
cs_real_t * particle_flow_rate
Definition: cs_lagr.h:741
int n_stat_classes
Definition: cs_lagr.h:335
cs_lagr_module_shape_t
Definition: cs_lagr.h:132
cs_real_t diam_mean
Definition: cs_lagr.h:492
cs_real_t modyeq
Definition: cs_lagr.h:458
cs_real_t density
Definition: cs_lagr.h:620
cs_lagr_encrustation_t * cs_glob_lagr_encrustation
cs_real_t param_chmb
Definition: cs_lagr.h:501
cs_lagr_precipitation_model_t * cs_get_lagr_precipitation_model(void)
Provide access to cs_lagr_precipitation_model_t.
Definition: cs_lagr.c:1510
cs_lagr_time_step_t * cs_get_lagr_time_step(void)
Definition: cs_lagr.c:1570
cs_gnum_t n_g_deposited
Definition: cs_lagr.h:367
int impvar
Definition: cs_lagr.h:421
cs_real_t phi_s
Definition: cs_lagr.h:809
void cs_lagr_finalize(void)
Definition: cs_lagr.c:1161
Definition: cs_lagr.h:793
int itsmas
Definition: cs_lagr.h:676
cs_real_t emissivity
Definition: cs_lagr.h:630
cs_lagr_internal_condition_t * cs_lagr_get_internal_conditions(void)
Return pointer to the main internal conditions structure.
Definition: cs_lagr.c:1634
int lamvbr
Definition: cs_lagr.h:824
cs_lagr_reentrained_model_t * cs_glob_lagr_reentrained_model
cs_real_t rayasg
Definition: cs_lagr.h:460
cs_lagr_shape_model_t * cs_get_lagr_shape_model(void)
Definition: cs_lagr.c:1534
cs_gnum_t n_g_new
Definition: cs_lagr.h:358
cs_real_t max_stat_weight
Definition: cs_lagr.h:512
Definition: cs_lagr.h:445
cs_real_t scalar_kernel
Definition: cs_lagr.h:513
int npencr
Definition: cs_lagr.h:767
int shape
Definition: cs_lagr.h:318
cs_real_t tmamax
Definition: cs_lagr.h:716
void cs_lagr_finalize_internal_cond(void)
Definition: cs_lagr.c:1747
int fragmentation
Definition: cs_lagr.h:333
cs_real_t * mp_diss
Definition: cs_lagr.h:480
cs_lagr_injection_set_t * cs_lagr_get_injection_set(cs_lagr_zone_data_t *zone_data, int zone_id, int set_id)
Provide access to injection set structure.
Definition: cs_lagr.c:1309
Definition: cs_lagr.h:523
Definition: cs_lagr.h:182
int natom
Definition: cs_lagr.h:1014
void cs_lagr_solve_initialize(const cs_real_t *dt)
Definition: cs_lagr.c:1791
Definition: cs_lagr.h:172
