#include <cs_lagr.h>
Collaboration diagram for cs_lagr_time_scheme_t:Data Fields | |
| int | iilagr |
| int | isttio |
| int | isuila |
| int | t_order |
| int | extended_t_scheme |
| int | interpol_field |
| int | ilapoi |
| int | iadded_mass |
| cs_real_t | added_mass_const |
Time and coupling scheme for the Lagrangian module
| cs_real_t added_mass_const |
Added-mass constant (
| int extended_t_scheme |
Extended exponential scheme taking into account the gradient of T_lag (0 off, 1 on)
| int iadded_mass |
activation (=1) or not (=0) of the added-mass term.
and
with
. Then
with
| int iilagr |
Lagrangian module status.
| int ilapoi |
activation (=1) or not (=0) of the solution of a Poisson's equation for the correction of the particle instantaneous velocities (in order to obtain a null divergence). this option is not validated and reserved to the development team. Do not change the default value
| int interpol_field |
activation (=1) or not (=0) P1 interpolation of velocity and Lagragian time at the location of the particle
| int isttio |
| int isuila |
activation (=1) or not (=0) of a Lagrangian calculation restart. The calculation restart file read when this option is activated only contains the data related to the particles; the global calculation must also be a restart calculation
| int t_order |
trajectory algorithm order in time
