7.2
cs_lagr_clogging.h
1 #ifndef __CS_LAGR_CLOGGING_H__
2 #define __CS_LAGR_CLOGGING_H__
5  * Clogging modeling.
31  * Local headers
34 #include "cs_defs.h"
35 #include "cs_lagr_particle.h"
36
38
42  * Type definitions
45 typedef struct {
46
55
61
63
64 /*============================================================================
65  * Public function definitions
66  *============================================================================*/
67
68 /*----------------------------------------------------------------------------
69  * Clogging initialization.
70  *
71  * - Retrieve various parameters for storing in global structure.
72  * - Compute and store the Debye screening length
73  *----------------------------------------------------------------------------*/
74
75 void
76 cloginit(const cs_real_t *water_permit,
77  const cs_real_t *ionic_strength,
78  const cs_real_t *jamming_limit,
79  const cs_real_t *min_porosity,
80  const cs_real_t *diam_mean,
81  const cs_real_t temperature[],
82  const cs_real_t *valen,
83  const cs_real_t *phi_p,
84  const cs_real_t *phi_s,
85  const cs_real_t *cstham,
86  const cs_real_t *csthpp,
87  const cs_real_t *lambda_vdw
88  );
89
90 /*----------------------------------------------------------------------------
91  * Clogging finalization.
92  *
93  * Deallocate the arrays storing temperature and Debye length.
94  *----------------------------------------------------------------------------*/
95
96 void
98
99 /*----------------------------------------------------------------------------
100  * Clogging:
101  *
102  * - Compute the number of deposited particles in contact with the depositing
103  * particle
104  * - Re-compute the energy barrier if this number is greater than zero
105  *
106  * parameters:
107  * particle <-- pointer to particle data
108  * attr_map <-- pointer to attribute map
109  * iel <-- id of cell where the particle is
110  * face_area <-- area of face
111  * energy_barrier <-> energy barrier
112  * surface_coverage <-> surface coverage
113  * limit <-> jamming limit
114  * mporos <-> minimum porosity
115  *
116  * returns:
117  * number of deposited particles in contact with the depositing particle
118  *----------------------------------------------------------------------------*/
119
120 int
121 cs_lagr_clogging_barrier(const void *particle,
122  const cs_lagr_attribute_map_t *attr_map,
123  cs_lnum_t iel,
124  cs_real_t *energy_barrier,
125  cs_real_t *surface_coverage,
126  cs_real_t *limit,
127  cs_real_t *mporos);
128
129 /*----------------------------------------------------------------------------*/
130
132
133 #endif /* __CS_LAGR_CLOGGING_H__ */
134
void cs_lagr_clogging_finalize(void)
Definition: cs_lagr_clogging.c:194
cs_real_t min_porosity
Definition: cs_lagr_clogging.h:50
void cloginit(const cs_real_t *water_permit, const cs_real_t *ionic_strength, const cs_real_t *jamming_limit, const cs_real_t *min_porosity, const cs_real_t *diam_mean, const cs_real_t temperature[], const cs_real_t *valen, const cs_real_t *phi_p, const cs_real_t *phi_s, const cs_real_t *cstham, const cs_real_t *csthpp, const cs_real_t *lambda_vdw)
Definition: cs_lagr_clogging.c:113
cs_real_t valen
Definition: cs_lagr_clogging.h:52
cs_real_t lambda_vdw
Definition: cs_lagr_clogging.h:60
int cs_lagr_clogging_barrier(const void *particle, const cs_lagr_attribute_map_t *attr_map, cs_lnum_t iel, cs_real_t *energy_barrier, cs_real_t *surface_coverage, cs_real_t *limit, cs_real_t *mporos)
Definition: cs_lagr_clogging.c:221
cs_real_t jamming_limit
Definition: cs_lagr_clogging.h:49
Definition: cs_defs.h:322
cs_real_t ionic_strength
Definition: cs_lagr_clogging.h:48
cs_real_t phi_s
Definition: cs_lagr_clogging.h:54
cs_real_t water_permit
Definition: cs_lagr_clogging.h:47
cs_real_t cstham
Definition: cs_lagr_clogging.h:58
Definition: cs_lagr_clogging.h:45
cs_real_t csthpp
Definition: cs_lagr_clogging.h:59
Definition: cs_defs.h:316
cs_real_t diam_mean
Definition: cs_lagr_clogging.h:51
cs_real_t * temperature
Definition: cs_lagr_clogging.h:56
cs_real_t * debye_length
Definition: cs_lagr_clogging.h:57
Definition: cs_lagr_particle.h:188
cs_real_t phi_p
Definition: cs_lagr_clogging.h:53
