7.2
cs_lagr_particle.h
1 #ifndef __CS_LAGR_PARTICLE_H__
2 #define __CS_LAGR_PARTICLE_H__
5  * Lagrangian module particle model
30 #include "cs_defs.h"
32 #include "assert.h"
34 /*----------------------------------------------------------------------------*/
38 /*=============================================================================
39  * Macro definitions
40  *============================================================================*/
42 /*=============================================================================
43  * Macro definitions
45
51 #define CS_LAGR_PART_TO_DELETE (1 << 0)
52
54 #define CS_LAGR_PART_FIXED (1 << 1)
55
57 #define CS_LAGR_PART_DEPOSITED (1 << 2)
58
60 #define CS_LAGR_PART_ROLLING (1 << 3)
61
63 #define CS_LAGR_PART_IMPOSED_MOTION (1 << 4)
64
68 #define CS_LAGR_PART_DEPOSITION_FLAGS \
69  ( CS_LAGR_PART_TO_DELETE | CS_LAGR_PART_FIXED | CS_LAGR_PART_DEPOSITED \
70  | CS_LAGR_PART_ROLLING | CS_LAGR_PART_IMPOSED_MOTION)
71
72 /*============================================================================
73  * Type definitions
74  *============================================================================*/
75
77 /* ------------------------------- */
78
79 typedef enum {
80
98
104  /* Arrays for 2nd order scheme */
105
106  CS_LAGR_TURB_STATE_1, /* turbulence characteristics of first pass */
107  CS_LAGR_PRED_VELOCITY, /* 1st step prediction for particle velocity */
108  CS_LAGR_PRED_VELOCITY_SEEN, /* 1st step prediction for relative velocity */
109  CS_LAGR_V_GAUSS, /* 1st step Gaussian variable */
110  CS_LAGR_BR_GAUSS, /* 1st step Brownian motion Gaussian variable */
111
112  /* Non-spherical particles submodel additoinal parameters */
113
122  /* Deposition submodel additional parameters */
123
129
130  /* Resuspension model additional parameters */
131
137
138  /* Clogging model additional parameters */
139
144
145  /* Thermal model additional parameters */
146
150
151  /* Coal combustion additional parameters */
152
156
159
162
163  /* Radiative model additional parameters */
164
166
167  /* Statistical class */
168
170
171  /* Agglomeration/fragmentation model parameters */
174
175  /* User attributes */
176
178
179  /* End of attributes */
180
182
184
186 /* ------------------------------------- */
187
188 typedef struct {
189
190  size_t extents; /* size (in bytes) of particle
191  structure */
192  size_t lb; /* size (in bytes) of lower
193  bounds of particle data
194  (work area before) */
195
196  int n_time_vals; /* number of time values
197  handled */
198
199  size_t size[CS_LAGR_N_ATTRIBUTES]; /* size (in bytes) of
200  attributes in particle
201  structure for a given
202  time value */
203  cs_datatype_t datatype[CS_LAGR_N_ATTRIBUTES]; /* datatype of associated
204  attributes */
205  int (*count)[CS_LAGR_N_ATTRIBUTES]; /* number of values for each
206  attribute, per associated
207  time_id */
208  ptrdiff_t (*displ)[CS_LAGR_N_ATTRIBUTES]; /* displacement (in bytes) of
209  attributes in particle data,
210  per associated time_id*/
211
212  ptrdiff_t *source_term_displ; /* displacement (in bytes) of
213  source term values
214  for second-order scheme,
215  or NULL */
216
218
219 /* Particle set */
220 /* ------------ */
221
222 typedef struct {
223
224  cs_lnum_t n_particles; /* number of particle in domain */
227  cs_lnum_t n_part_merged; /* number of merged particles */
232
241
243
246  unsigned char *p_buffer;
249
250 /*=============================================================================
251  * Global variables
252  *============================================================================*/
253
256 extern const char *cs_lagr_attribute_name[];
257
261
262 /*============================================================================
263  * Public function prototypes for Fortran API
264  *============================================================================*/
265
266 /*============================================================================
267  * Public function prototypes
268  *============================================================================*/
269
270 /*----------------------------------------------------------------------------*/
274 /*----------------------------------------------------------------------------*/
275
276 void
278
279 /*----------------------------------------------------------------------------*/
285 /*----------------------------------------------------------------------------*/
286
289
290 /*----------------------------------------------------------------------------*/
294 /*----------------------------------------------------------------------------*/
295
296 void
298
299 /*----------------------------------------------------------------------------*/
303 /*----------------------------------------------------------------------------*/
304
305 void
307
308 /*----------------------------------------------------------------------------*/
317 /*----------------------------------------------------------------------------*/
318
319 void
321  cs_lnum_t src);
322
323 /*----------------------------------------------------------------------------*/
342 /*----------------------------------------------------------------------------*/
343
344 void
346  int time_id,
347  cs_lagr_attribute_t attr,
348  size_t *extents,
349  size_t *size,
350  ptrdiff_t *displ,
351  cs_datatype_t *datatype,
352  int *count);
353
354 /*----------------------------------------------------------------------------*/
367 /*----------------------------------------------------------------------------*/
368
369 int
371  cs_lagr_attribute_t attr,
372  cs_datatype_t datatype,
373  int stride,
374  int component_id);
375
376 /*----------------------------------------------------------------------------*/
384 /*----------------------------------------------------------------------------*/
385
386 void
388
389 /*----------------------------------------------------------------------------
390  * Return pointer to the main cs_lagr_particle_set_t structure.
391  *
392  * returns:
393  * pointer to current particle set, or NULL
394  *----------------------------------------------------------------------------*/
395
398
399 /*----------------------------------------------------------------------------*/
409 /*----------------------------------------------------------------------------*/
410
411 inline static void *
413  cs_lnum_t particle_id,
414  cs_lagr_attribute_t attr)
415 {
416  assert(particle_set->p_am->count[0][attr] > 0);
417
418  return (unsigned char *)particle_set->p_buffer
419  + particle_set->p_am->extents*particle_id
420  + particle_set->p_am->displ[0][attr];
421 }
422
423 /*----------------------------------------------------------------------------*/
434 /*----------------------------------------------------------------------------*/
435
436 inline static const void *
438  cs_lnum_t particle_id,
439  cs_lagr_attribute_t attr)
440 {
441  assert(particle_set->p_am->count[0][attr] > 0);
442
443  return particle_set->p_buffer
444  + particle_set->p_am->extents*particle_id
445  + particle_set->p_am->displ[0][attr];
446 }
447
448 /*----------------------------------------------------------------------------*/
460 /*----------------------------------------------------------------------------*/
461
462 inline static void *
464  cs_lnum_t particle_id,
465  int time_id,
466  cs_lagr_attribute_t attr)
467 {
468  assert(particle_set->p_am->count[time_id][attr] > 0);
469
470  return particle_set->p_buffer
471  + particle_set->p_am->extents*particle_id
472  + particle_set->p_am->displ[time_id][attr];
473 }
474
475 /*----------------------------------------------------------------------------*/
487 /*----------------------------------------------------------------------------*/
488
489 inline static const void *
491  cs_lnum_t particle_id,
492  int time_id,
493  cs_lagr_attribute_t attr)
494 {
495  assert(particle_set->p_am->count[time_id][attr] > 0);
496
497  return particle_set->p_buffer
498  + particle_set->p_am->extents*particle_id
499  + particle_set->p_am->displ[time_id][attr];
500 }
501
502 /*----------------------------------------------------------------------------*/
512 /*----------------------------------------------------------------------------*/
513
514 inline static int
516  cs_lnum_t particle_id,
517  int mask)
518 {
519  int flag
520  = *((const cs_lnum_t *)( particle_set->p_buffer
521  + particle_set->p_am->extents*particle_id
522  + particle_set->p_am->displ[0][CS_LAGR_P_FLAG]));
523
524  return (flag & mask);
525 }
526
527 /*----------------------------------------------------------------------------*/
535 /*----------------------------------------------------------------------------*/
536
537 inline static void
539  cs_lnum_t particle_id,
540  int mask)
541 {
542  int flag
543  = *((const cs_lnum_t *)( particle_set->p_buffer
544  + particle_set->p_am->extents*particle_id
545  + particle_set->p_am->displ[0][CS_LAGR_P_FLAG]));
546
547  flag = flag | mask;
548
549  *((cs_lnum_t *)( particle_set->p_buffer
550  + particle_set->p_am->extents*particle_id
551  + particle_set->p_am->displ[0][CS_LAGR_P_FLAG])) = flag;
552 }
553
554 /*----------------------------------------------------------------------------*/
562 /*----------------------------------------------------------------------------*/
563
564 inline static void
566  cs_lnum_t particle_id,
567  int mask)
568 {
569  int flag
570  = *((const cs_lnum_t *)( particle_set->p_buffer
571  + particle_set->p_am->extents*particle_id
572  + particle_set->p_am->displ[0][CS_LAGR_P_FLAG]));
573
574  flag = (flag | mask) - mask;
575
576  *((cs_lnum_t *)( particle_set->p_buffer
577  + particle_set->p_am->extents*particle_id
578  + particle_set->p_am->displ[0][CS_LAGR_P_FLAG])) = flag;
579 }
580
581 /*----------------------------------------------------------------------------*/
591 /*----------------------------------------------------------------------------*/
592
593 inline static cs_lnum_t
595  cs_lnum_t particle_id,
596  cs_lagr_attribute_t attr)
597 {
598  assert(particle_set->p_am->count[0][attr] > 0);
599
600  return *((const cs_lnum_t *)( particle_set->p_buffer
601  + particle_set->p_am->extents*particle_id
602  + particle_set->p_am->displ[0][attr]));
603 }
604
605 /*----------------------------------------------------------------------------*/
617 /*----------------------------------------------------------------------------*/
618
619 inline static cs_lnum_t
621  cs_lnum_t particle_id,
622  int time_id,
623  cs_lagr_attribute_t attr)
624 {
625  assert(particle_set->p_am->count[time_id][attr] > 0);
626
627  return *((const cs_lnum_t *)( particle_set->p_buffer
628  + particle_set->p_am->extents*particle_id
629  + particle_set->p_am->displ[time_id][attr]));
630 }
631
632 /*----------------------------------------------------------------------------*/
641 /*----------------------------------------------------------------------------*/
642
643 inline static void
645  cs_lnum_t particle_id,
646  cs_lagr_attribute_t attr,
647  cs_lnum_t value)
648 {
649  assert(particle_set->p_am->count[0][attr] > 0);
650
651  *((cs_lnum_t *)( particle_set->p_buffer
652  + particle_set->p_am->extents*particle_id
653  + particle_set->p_am->displ[0][attr])) = value;
654 }
655
656 /*----------------------------------------------------------------------------*/
667 /*----------------------------------------------------------------------------*/
668
669 inline static void
671  cs_lnum_t particle_id,
672  int time_id,
673  cs_lagr_attribute_t attr,
674  cs_lnum_t value)
675 {
676  assert(particle_set->p_am->count[time_id][attr] > 0);
677
678  *((cs_lnum_t *)( particle_set->p_buffer
679  + particle_set->p_am->extents*particle_id
680  + particle_set->p_am->displ[time_id][attr])) = value;
681 }
682
683 /*----------------------------------------------------------------------------*/
693 /*----------------------------------------------------------------------------*/
694
695 inline static cs_gnum_t
697  cs_lnum_t particle_id,
698  cs_lagr_attribute_t attr)
699 {
700  assert(particle_set->p_am->count[0][attr] > 0);
701
702  return *((const cs_gnum_t *)( particle_set->p_buffer
703  + particle_set->p_am->extents*particle_id
704  + particle_set->p_am->displ[0][attr]));
705 }
706
707 /*----------------------------------------------------------------------------*/
719 /*----------------------------------------------------------------------------*/
720
721 inline static cs_gnum_t
723  cs_lnum_t particle_id,
724  int time_id,
725  cs_lagr_attribute_t attr)
726 {
727  assert(particle_set->p_am->count[time_id][attr] > 0);
728
729  return *((const cs_gnum_t *)( particle_set->p_buffer
730  + particle_set->p_am->extents*particle_id
731  + particle_set->p_am->displ[time_id][attr]));
732 }
733
734 /*----------------------------------------------------------------------------*/
743 /*----------------------------------------------------------------------------*/
744
745 inline static void
747  cs_lnum_t particle_id,
748  cs_lagr_attribute_t attr,
749  cs_gnum_t value)
750 {
751  assert(particle_set->p_am->count[0][attr] > 0);
752
753  *((cs_gnum_t *)( particle_set->p_buffer
754  + particle_set->p_am->extents*particle_id
755  + particle_set->p_am->displ[0][attr])) = value;
756 }
757
758 /*----------------------------------------------------------------------------*/
769 /*----------------------------------------------------------------------------*/
770
771 inline static void
773  cs_lnum_t particle_id,
774  int time_id,
775  cs_lagr_attribute_t attr,
776  cs_gnum_t value)
777 {
778  assert(particle_set->p_am->count[time_id][attr] > 0);
779
780  *((cs_gnum_t *)( particle_set->p_buffer
781  + particle_set->p_am->extents*particle_id
782  + particle_set->p_am->displ[time_id][attr])) = value;
783 }
784
785 /*----------------------------------------------------------------------------*/
795 /*----------------------------------------------------------------------------*/
796
797 inline static cs_real_t
799  cs_lnum_t particle_id,
800  cs_lagr_attribute_t attr)
801 {
802  assert(particle_set->p_am->count[0][attr] > 0);
803
804  return *((const cs_real_t *)( particle_set->p_buffer
805  + particle_set->p_am->extents*particle_id
806  + particle_set->p_am->displ[0][attr]));
807 }
808
809 /*----------------------------------------------------------------------------*/
821 /*----------------------------------------------------------------------------*/
822
823 inline static cs_real_t
825  cs_lnum_t particle_id,
826  int time_id,
827  cs_lagr_attribute_t attr)
828 {
829  assert(particle_set->p_am->count[time_id][attr] > 0);
830
831  return *((const cs_real_t *)( particle_set->p_buffer
832  + particle_set->p_am->extents*particle_id
833  + particle_set->p_am->displ[time_id][attr]));
834 }
835
836 /*----------------------------------------------------------------------------*/
845 /*----------------------------------------------------------------------------*/
846
847 inline static void
849  cs_lnum_t particle_id,
850  cs_lagr_attribute_t attr,
851  cs_real_t value)
852 {
853  assert(particle_set->p_am->count[0][attr] > 0);
854
855  *((cs_real_t *)( particle_set->p_buffer
856  + particle_set->p_am->extents*particle_id
857  + particle_set->p_am->displ[0][attr])) = value;
858 }
859
860 /*----------------------------------------------------------------------------*/
871 /*----------------------------------------------------------------------------*/
872
873 inline static void
875  cs_lnum_t particle_id,
876  int time_id,
877  cs_lagr_attribute_t attr,
878  cs_real_t value)
879 {
880  assert(particle_set->p_am->count[time_id][attr] > 0);
881
882  *((cs_real_t *)( particle_set->p_buffer
883  + particle_set->p_am->extents*particle_id
884  + particle_set->p_am->displ[time_id][attr])) = value;
885 }
886
887 /*----------------------------------------------------------------------------*/
898 /*----------------------------------------------------------------------------*/
899
900 inline static cs_real_t *
902  cs_lnum_t particle_id,
903  cs_lagr_attribute_t attr)
904 {
905  assert(particle_set->p_am->source_term_displ != NULL);
906  assert(particle_set->p_am->source_term_displ[attr] >= 0);
907
908  return (cs_real_t *)( (unsigned char *)particle_set->p_buffer
909  + particle_set->p_am->extents*particle_id
910  + particle_set->p_am->source_term_displ[attr]);
911 }
912
913 /*----------------------------------------------------------------------------*/
924 /*----------------------------------------------------------------------------*/
925
926 inline static const cs_real_t *
928  cs_lnum_t particle_id,
929  cs_lagr_attribute_t attr)
930 {
931  assert(particle_set->p_am->source_term_displ != NULL);
932  assert(particle_set->p_am->source_term_displ[attr] >= 0);
933
934  return (const cs_real_t *)( (unsigned char *)particle_set->p_buffer
935  + particle_set->p_am->extents*particle_id
936  + particle_set->p_am->source_term_displ[attr]);
937 }
938
939 /*----------------------------------------------------------------------------*/
949 /*----------------------------------------------------------------------------*/
950
951 inline static void *
952 cs_lagr_particle_attr(void *particle,
953  const cs_lagr_attribute_map_t *attr_map,
954  cs_lagr_attribute_t attr)
955 {
956  assert(attr_map->count[0][attr] > 0);
957
958  return (unsigned char *)particle + attr_map->displ[0][attr];
959 }
960
961 /*----------------------------------------------------------------------------*/
971 /*----------------------------------------------------------------------------*/
972
973 inline static const void *
974 cs_lagr_particle_attr_const(const void *particle,
975  const cs_lagr_attribute_map_t *attr_map,
976  cs_lagr_attribute_t attr)
977 {
978  assert(attr_map->count[0][attr] > 0);
979
980  return (const unsigned char *)particle + attr_map->displ[0][attr];
981 }
982
983 /*----------------------------------------------------------------------------*/
994 /*----------------------------------------------------------------------------*/
995
996 inline static void *
997 cs_lagr_particle_attr_n(void *particle,
998  const cs_lagr_attribute_map_t *attr_map,
999  int time_id,
1000  cs_lagr_attribute_t attr)
1001 {
1002  assert(attr_map->count[time_id][attr] > 0);
1003
1004  return (unsigned char *)particle + attr_map->displ[time_id][attr];
1005 }
1006
1007 /*----------------------------------------------------------------------------*/
1018 /*----------------------------------------------------------------------------*/
1019
1020 inline static const void *
1021 cs_lagr_particle_attr_n_const(const void *particle,
1022  const cs_lagr_attribute_map_t *attr_map,
1023  int time_id,
1024  cs_lagr_attribute_t attr)
1025 {
1026  assert(attr_map->count[time_id][attr] > 0);
1027
1028  return (const unsigned char *)particle
1029  + attr_map->displ[time_id][attr];
1030 }
1031
1032 /*----------------------------------------------------------------------------*/
1042 /*----------------------------------------------------------------------------*/
1043
1044 inline static cs_lnum_t
1045 cs_lagr_particle_get_lnum(const void *particle,
1046  const cs_lagr_attribute_map_t *attr_map,
1047  cs_lagr_attribute_t attr)
1048 {
1049  assert(attr_map->count[0][attr] > 0);
1050
1051  return *((const cs_lnum_t *)( (const unsigned char *)particle
1052  + attr_map->displ[0][attr]));
1053 }
1054
1055 /*----------------------------------------------------------------------------*/
1067 /*----------------------------------------------------------------------------*/
1068
1069 inline static cs_lnum_t
1070 cs_lagr_particle_get_lnum_n(const void *particle,
1071  const cs_lagr_attribute_map_t *attr_map,
1072  int time_id,
1073  cs_lagr_attribute_t attr)
1074 {
1075  assert(attr_map->count[time_id][attr] > 0);
1076
1077  return *((const cs_lnum_t *)( (const unsigned char *)particle
1078  + attr_map->displ[time_id][attr]));
1079 }
1080
1081 /*----------------------------------------------------------------------------*/
1090  /*----------------------------------------------------------------------------*/
1091
1092 inline static void
1094  const cs_lagr_attribute_map_t *attr_map,
1095  cs_lagr_attribute_t attr,
1096  cs_lnum_t value)
1097 {
1098  assert(attr_map->count[0][attr] > 0);
1099
1100  *((cs_lnum_t *)((unsigned char *)particle + attr_map->displ[0][attr]))
1101  = value;
1102 }
1103
1104 /*----------------------------------------------------------------------------*/
1115  /*----------------------------------------------------------------------------*/
1116
1117 inline static void
1119  const cs_lagr_attribute_map_t *attr_map,
1120  int time_id,
1121  cs_lagr_attribute_t attr,
1122  cs_lnum_t value)
1123 {
1124  assert(attr_map->count[time_id][attr] > 0);
1125
1126  *((cs_lnum_t *)( (unsigned char *)particle
1127  + attr_map->displ[time_id][attr])) = value;
1128 }
1129
1130 /*----------------------------------------------------------------------------*/
1140 /*----------------------------------------------------------------------------*/
1141
1142 inline static cs_gnum_t
1143 cs_lagr_particle_get_gnum(const void *particle,
1144  const cs_lagr_attribute_map_t *attr_map,
1145  cs_lagr_attribute_t attr)
1146 {
1147  assert(attr_map->count[0][attr] > 0);
1148
1149  return *((const cs_gnum_t *)( (const unsigned char *)particle
1150  + attr_map->displ[0][attr]));
1151 }
1152
1153 /*----------------------------------------------------------------------------*/
1165 /*----------------------------------------------------------------------------*/
1166
1167 inline static cs_gnum_t
1168 cs_lagr_particle_get_gnum_n(const void *particle,
1169  const cs_lagr_attribute_map_t *attr_map,
1170  int time_id,
1171  cs_lagr_attribute_t attr)
1172 {
1173  assert(attr_map->count[time_id][attr] > 0);
1174
1175  return *((const cs_gnum_t *)( (const unsigned char *)particle
1176  + attr_map->displ[time_id][attr]));
1177 }
1178
1179 /*----------------------------------------------------------------------------*/
1188  /*----------------------------------------------------------------------------*/
1189
1190 inline static void
1192  const cs_lagr_attribute_map_t *attr_map,
1193  cs_lagr_attribute_t attr,
1194  cs_gnum_t value)
1195 {
1196  assert(attr_map->count[0][attr] > 0);
1197
1198  *((cs_gnum_t *)((unsigned char *)particle + attr_map->displ[0][attr]))
1199  = value;
1200 }
1201
1202 /*----------------------------------------------------------------------------*/
1213  /*----------------------------------------------------------------------------*/
1214
1215 inline static void
1217  const cs_lagr_attribute_map_t *attr_map,
1218  int time_id,
1219  cs_lagr_attribute_t attr,
1220  cs_gnum_t value)
1221 {
1222  assert(attr_map->count[time_id][attr] > 0);
1223
1224  *((cs_gnum_t *)( (unsigned char *)particle
1225  + attr_map->displ[time_id][attr])) = value;
1226 }
1227
1228 /*----------------------------------------------------------------------------*/
1238 /*----------------------------------------------------------------------------*/
1239
1240 inline static cs_real_t
1241 cs_lagr_particle_get_real(const void *particle,
1242  const cs_lagr_attribute_map_t *attr_map,
1243  cs_lagr_attribute_t attr)
1244 {
1245  assert(attr_map->count[0][attr] > 0);
1246
1247  return *((const cs_real_t *)( (const unsigned char *)particle
1248  + attr_map->displ[0][attr]));
1249 }
1250
1251 /*----------------------------------------------------------------------------*/
1263 /*----------------------------------------------------------------------------*/
1264
1265 inline static cs_real_t
1266 cs_lagr_particle_get_real_n(const void *particle,
1267  const cs_lagr_attribute_map_t *attr_map,
1268  int time_id,
1269  cs_lagr_attribute_t attr)
1270 {
1271  assert(attr_map->count[time_id][attr] > 0);
1272
1273  return *((const cs_real_t *)( (const unsigned char *)particle
1274  + attr_map->displ[time_id][attr]));
1275 }
1276
1277 /*----------------------------------------------------------------------------*/
1286  /*----------------------------------------------------------------------------*/
1287
1288 inline static void
1290  const cs_lagr_attribute_map_t *attr_map,
1291  cs_lagr_attribute_t attr,
1292  cs_real_t value)
1293 {
1294  assert(attr_map->count[0][attr] > 0);
1295
1296  *((cs_real_t *)((unsigned char *)particle + attr_map->displ[0][attr]))
1297  = value;
1298 }
1299
1300 /*----------------------------------------------------------------------------*/
1311  /*----------------------------------------------------------------------------*/
1312
1313 inline static void
1315  const cs_lagr_attribute_map_t *attr_map,
1316  int time_id,
1317  cs_lagr_attribute_t attr,
1318  cs_real_t value)
1319 {
1320  assert(attr_map->count[time_id][attr] > 0);
1321
1322  *((cs_real_t *)( (unsigned char *)particle
1323  + attr_map->displ[time_id][attr])) = value;
1324 }
1325
1326 /*----------------------------------------------------------------------------*/
1336 /*----------------------------------------------------------------------------*/
1337
1338 inline static cs_real_t *
1340  const cs_lagr_attribute_map_t *attr_map,
1341  cs_lagr_attribute_t attr)
1342 {
1343  assert(attr_map->source_term_displ != NULL);
1344  assert(attr_map->source_term_displ[attr] >= 0);
1345
1346  return (cs_real_t *)( (unsigned char *)particle
1347  + attr_map->source_term_displ[attr]);
1348 }
1349
1350 /*----------------------------------------------------------------------------*/
1360 /*----------------------------------------------------------------------------*/
1361
1362 inline static const cs_real_t *
1364  const cs_lagr_attribute_map_t *attr_map,
1365  cs_lagr_attribute_t attr)
1366 {
1367  assert(attr_map->source_term_displ != NULL);
1368  assert(attr_map->source_term_displ[attr] >= 0);
1369
1370  return (const cs_real_t *)( (unsigned char *)particle
1371  + attr_map->source_term_displ[attr]);
1372 }
1373
1374 /*----------------------------------------------------------------------------
1375  * Resize particle set buffers if needed.
1376  *
1377  * parameters:
1378  * n_particles <-- minumum number of particles required
1379  *
1380  *
1381  * returns:
1382  * 1 if resizing was required, 0 otherwise
1383  *----------------------------------------------------------------------------*/
1384
1385 int
1386 cs_lagr_particle_set_resize(cs_lnum_t n_min_particles);
1387
1388 /*----------------------------------------------------------------------------
1389  * Set reallocation factor for particle sets.
1390  *
1391  * This factor determines the multiplier used for reallocations when
1392  * the particle set's buffers are too small to handle the new number of
1393  * particles.
1394  *
1395  * parameters:
1396  * f <-- reallocation size multiplier
1397  *----------------------------------------------------------------------------*/
1398
1399 void
1401
1402 /*----------------------------------------------------------------------------*/
1411 /*----------------------------------------------------------------------------*/
1412
1413 unsigned long long
1415
1416 /*----------------------------------------------------------------------------*/
1425 /*----------------------------------------------------------------------------*/
1426
1427 void
1428 cs_lagr_set_n_g_particles_max(unsigned long long n_g_particles_max);
1429
1430 /*----------------------------------------------------------------------------*/
1437 /*----------------------------------------------------------------------------*/
1438
1439 void
1441  cs_lnum_t particle_id);
1442
1443 /*----------------------------------------------------------------------------*/
1449 /*----------------------------------------------------------------------------*/
1450
1451 void
1453
1454 /*----------------------------------------------------------------------------*/
1460 /*----------------------------------------------------------------------------*/
1461
1462 void
1463 cs_lagr_set_n_user_variables(int n_user_variables);
1464
1465 /*----------------------------------------------------------------------------*/
1466
1468
1469 #endif /* __CS_LAGR_PARTICLE_H__ */
Definition: cs_lagr_particle.h:117
static cs_gnum_t cs_lagr_particle_get_gnum(const void *particle, const cs_lagr_attribute_map_t *attr_map, cs_lagr_attribute_t attr)
Get attribute value of type cs_gnum_t of a given particle in a set.
Definition: cs_lagr_particle.h:1143
Definition: cs_lagr_particle.h:97
cs_lnum_t n_part_out
Definition: cs_lagr_particle.h:226
static void * cs_lagr_particles_attr_n(cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, int time_id, cs_lagr_attribute_t attr)
Get pointer to attribute data of a given particle in a set at a given time.
Definition: cs_lagr_particle.h:463
void cs_lagr_particle_finalize(void)
Destroy main particle set and map if they exist.
Definition: cs_lagr_particle.c:980
static cs_real_t * cs_lagr_particle_source_term(void *particle, const cs_lagr_attribute_map_t *attr_map, cs_lagr_attribute_t attr)
Get pointer to 2nd order scheme attribute source terms of a particle.
Definition: cs_lagr_particle.h:1339
cs_datatype_t
Definition: cs_defs.h:275
static cs_lnum_t cs_lagr_particles_get_lnum_n(const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, int time_id, cs_lagr_attribute_t attr)
Get attribute value of type cs_lnum_t of a given particle in a set at a given time.
Definition: cs_lagr_particle.h:620
unsigned long cs_gnum_t
global mesh entity number
Definition: cs_defs.h:301
Definition: cs_lagr_particle.h:132
cs_lagr_particle_set_t * cs_glob_lagr_particle_set
static const cs_real_t * cs_lagr_particle_source_term_const(void *particle, const cs_lagr_attribute_map_t *attr_map, cs_lagr_attribute_t attr)
Definition: cs_lagr_particle.h:1363
cs_lnum_t n_part_fou
Definition: cs_lagr_particle.h:229
static void cs_lagr_particle_set_real_n(void *particle, const cs_lagr_attribute_map_t *attr_map, int time_id, cs_lagr_attribute_t attr, cs_real_t value)
Set attribute value of type cs_real_t of a given particle at a given time.
Definition: cs_lagr_particle.h:1314
static void * cs_lagr_particle_attr_n(void *particle, const cs_lagr_attribute_map_t *attr_map, int time_id, cs_lagr_attribute_t attr)
Get pointer to attribute data of a particle at a given time.
Definition: cs_lagr_particle.h:997
static void cs_lagr_particle_set_lnum_n(void *particle, const cs_lagr_attribute_map_t *attr_map, int time_id, cs_lagr_attribute_t attr, cs_lnum_t value)
Set attribute value of type cs_lnum_t of a given particle at a given time.
Definition: cs_lagr_particle.h:1118
static cs_real_t cs_lagr_particles_get_real_n(const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, int time_id, cs_lagr_attribute_t attr)
Get attribute value of type cs_real_t of a given particle in a set at a given time.
Definition: cs_lagr_particle.h:824
void cs_lagr_particle_attr_initialize(void)
Define particle map based on defined options.
Definition: cs_lagr_particle.c:661
Definition: cs_lagr_particle.h:172
Definition: cs_lagr_particle.h:140
Definition: cs_lagr_particle.h:169
ptrdiff_t * source_term_displ
Definition: cs_lagr_particle.h:212
static cs_lnum_t cs_lagr_particle_get_lnum(const void *particle, const cs_lagr_attribute_map_t *attr_map, cs_lagr_attribute_t attr)
Get attribute value of type cs_lnum_t of a given particle in a set.
Definition: cs_lagr_particle.h:1045
static const void * cs_lagr_particle_attr_const(const void *particle, const cs_lagr_attribute_map_t *attr_map, cs_lagr_attribute_t attr)
Get const pointer to current attribute data of a particle.
Definition: cs_lagr_particle.h:974
Definition: cs_lagr_particle.h:142
Definition: cs_lagr_particle.h:158
cs_lnum_t n_part_resusp
Definition: cs_lagr_particle.h:230
static const void * cs_lagr_particles_attr_const(const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, cs_lagr_attribute_t attr)
Get const pointer to current attribute data of a given particle in a set.
Definition: cs_lagr_particle.h:437
static cs_gnum_t cs_lagr_particle_get_gnum_n(const void *particle, const cs_lagr_attribute_map_t *attr_map, int time_id, cs_lagr_attribute_t attr)
Get attribute value of type cs_gnum_t of a given particle at a given time.
Definition: cs_lagr_particle.h:1168
Definition: cs_lagr_particle.h:100
static cs_real_t cs_lagr_particles_get_real(const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, cs_lagr_attribute_t attr)
Get attribute value of type cs_real_t of a given particle in a set.
Definition: cs_lagr_particle.h:798
Definition: cs_lagr_particle.h:155
cs_real_t weight_new
Definition: cs_lagr_particle.h:234
Definition: cs_lagr_particle.h:222
static cs_real_t * cs_lagr_particles_source_terms(cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, cs_lagr_attribute_t attr)
Get pointer to 2nd order scheme source terms for an attribute of a given particle in a set...
Definition: cs_lagr_particle.h:901
cs_lagr_attribute_t
static void cs_lagr_particles_set_real(cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, cs_lagr_attribute_t attr, cs_real_t value)
Set attribute value of type cs_real_t of a given particle in a set.
Definition: cs_lagr_particle.h:848
Definition: cs_lagr_particle.h:120
cs_real_t weight_resusp
Definition: cs_lagr_particle.h:239
void cs_lagr_particles_current_to_previous(cs_lagr_particle_set_t *particles, cs_lnum_t particle_id)
Copy current attributes to previous attributes.
Definition: cs_lagr_particle.c:1254
Definition: cs_lagr_particle.h:108
cs_lagr_particle_set_t * cs_lagr_get_particle_set(void)
Definition: cs_lagr_particle.c:1153
cs_real_t weight_fou
Definition: cs_lagr_particle.h:238
Definition: cs_lagr_particle.h:165
int cs_lagr_particle_set_resize(cs_lnum_t n_min_particles)
Definition: cs_lagr_particle.c:1173
const cs_lagr_attribute_map_t * p_am
Definition: cs_lagr_particle.h:244
static void cs_lagr_particles_set_gnum_n(cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, int time_id, cs_lagr_attribute_t attr, cs_gnum_t value)
Set attribute value of type cs_gnum_t of a given particle in a set at a given time.
Definition: cs_lagr_particle.h:772
cs_real_t weight_failed
Definition: cs_lagr_particle.h:240
static cs_gnum_t cs_lagr_particles_get_gnum(const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, cs_lagr_attribute_t attr)
Definition: cs_lagr_particle.h:696
Definition: cs_lagr_particle.h:96
Definition: cs_lagr_particle.h:86
cs_real_t weight_dep
Definition: cs_lagr_particle.h:237
static void cs_lagr_particle_set_gnum_n(void *particle, const cs_lagr_attribute_map_t *attr_map, int time_id, cs_lagr_attribute_t attr, cs_gnum_t value)
Set attribute value of type cs_gnum_t of a given particle at a given time.
Definition: cs_lagr_particle.h:1216
Definition: cs_defs.h:322
Definition: cs_lagr_particle.h:127
unsigned char * p_buffer
Definition: cs_lagr_particle.h:246
static void cs_lagr_particles_set_lnum_n(cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, int time_id, cs_lagr_attribute_t attr, cs_lnum_t value)
Set attribute value of type cs_lnum_t of a given particle in a set at a given time.
Definition: cs_lagr_particle.h:670
Definition: cs_lagr_particle.h:83
void cs_lagr_set_reallocation_factor(double f)
Definition: cs_lagr_particle.c:1204
static int cs_lagr_particles_get_flag(const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, int mask)
Get flag value with a selected mask for a given particle in a set.
Definition: cs_lagr_particle.h:515
ptrdiff_t(* displ)[CS_LAGR_N_ATTRIBUTES]
Definition: cs_lagr_particle.h:208
static const void * cs_lagr_particle_attr_n_const(const void *particle, const cs_lagr_attribute_map_t *attr_map, int time_id, cs_lagr_attribute_t attr)
Get const pointer to attribute data of a particle at a given time.
Definition: cs_lagr_particle.h:1021
Definition: cs_lagr_particle.h:125
cs_real_t weight_out
Definition: cs_lagr_particle.h:235
Definition: cs_lagr_particle.h:148
static void * cs_lagr_particle_attr(void *particle, const cs_lagr_attribute_map_t *attr_map, cs_lagr_attribute_t attr)
Get pointer to current attribute data of a particle.
Definition: cs_lagr_particle.h:952
Definition: cs_lagr_particle.h:94
const char * cs_lagr_attribute_name[]
void cs_lagr_particle_attr_in_range(int attr)
Check if a particle attribute is in a valid range.
Definition: cs_lagr_particle.c:1136
Definition: cs_lagr_particle.h:227
static void cs_lagr_particles_set_real_n(cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, int time_id, cs_lagr_attribute_t attr, cs_real_t value)
Set attribute value of type cs_real_t of a given particle in a set at a given time.
Definition: cs_lagr_particle.h:874
cs_lnum_t n_part_dep
Definition: cs_lagr_particle.h:228
cs_lnum_t n_particles_max
Definition: cs_lagr_particle.h:242
Definition: cs_lagr_particle.h:107
void cs_lagr_set_n_user_variables(int n_user_variables)
Set number of user particle variables.
Definition: cs_lagr_particle.c:1309
Definition: cs_lagr_particle.h:153
static void cs_lagr_particles_set_gnum(cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, cs_lagr_attribute_t attr, cs_gnum_t value)
Set attribute value of type cs_gnum_t of a given particle in a set.
Definition: cs_lagr_particle.h:746
Definition: cs_lagr_particle.h:149
Definition: cs_lagr_particle.h:128
static const void * cs_lagr_particles_attr_n_const(const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, int time_id, cs_lagr_attribute_t attr)
Get const pointer to attribute data of a given particle in a set at a given time. ...
Definition: cs_lagr_particle.h:490
Definition: cs_lagr_particle.h:161
Definition: cs_lagr_particle.h:109
static void cs_lagr_particles_set_flag(const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, int mask)
Set flag value with a selected mask for a given particle in a set.
Definition: cs_lagr_particle.h:538
static cs_real_t cs_lagr_particle_get_real_n(const void *particle, const cs_lagr_attribute_map_t *attr_map, int time_id, cs_lagr_attribute_t attr)
Get attribute value of type cs_real_t of a given particle at a given time.
Definition: cs_lagr_particle.h:1266
Definition: cs_lagr_particle.h:119
Definition: cs_lagr_particle.h:91
cs_lnum_t n_part_new
Definition: cs_lagr_particle.h:225
Definition: cs_lagr_particle.h:224
Definition: cs_lagr_particle.h:115
cs_lnum_t n_failed_part
Definition: cs_lagr_particle.h:231
Definition: cs_lagr_particle.h:160
static void cs_lagr_particles_set_lnum(cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, cs_lagr_attribute_t attr, cs_lnum_t value)
Set attribute value of type cs_lnum_t of a given particle in a set.
Definition: cs_lagr_particle.h:644
Definition: cs_lagr_particle.h:118
void cs_lagr_particle_set_create(void)
Definition: cs_lagr_particle.c:963
static void * cs_lagr_particles_attr(cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, cs_lagr_attribute_t attr)
Get pointer to a current attribute of a given particle in a set.
Definition: cs_lagr_particle.h:412
static void cs_lagr_particle_set_real(void *particle, const cs_lagr_attribute_map_t *attr_map, cs_lagr_attribute_t attr, cs_real_t value)
Set attribute value of type cs_real_t of a given particle.
Definition: cs_lagr_particle.h:1289
int cs_lagr_check_attr_query(const cs_lagr_particle_set_t *particles, cs_lagr_attribute_t attr, cs_datatype_t datatype, int stride, int component_id)
Check that query for a given particle attribute is valid.
Definition: cs_lagr_particle.c:1071
Definition: cs_lagr_particle.h:135
Definition: cs_lagr_particle.h:93
static const cs_real_t * cs_lagr_particles_source_terms_const(cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, cs_lagr_attribute_t attr)
Get const pointer to 2nd order scheme source terms an attribute of a given particle in a set...
Definition: cs_lagr_particle.h:927
unsigned long long cs_lagr_get_n_g_particles_max(void)
Get global maximum number of particles.
Definition: cs_lagr_particle.c:1222
Definition: cs_lagr_particle.h:157
Definition: cs_defs.h:316
static cs_real_t cs_lagr_particle_get_real(const void *particle, const cs_lagr_attribute_map_t *attr_map, cs_lagr_attribute_t attr)
Definition: cs_lagr_particle.h:1241
static cs_gnum_t cs_lagr_particles_get_gnum_n(const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, int time_id, cs_lagr_attribute_t attr)
Get attribute value of type cs_gnum_t of a given particle in a set at a given time.
Definition: cs_lagr_particle.h:722
int n_time_vals
Definition: cs_lagr_particle.h:196
Definition: cs_lagr_particle.h:110
Definition: cs_lagr_particle.h:143
size_t lb
Definition: cs_lagr_particle.h:192
size_t extents
Definition: cs_lagr_particle.h:190
Definition: cs_lagr_particle.h:147
Definition: cs_lagr_particle.h:81
Definition: cs_lagr_particle.h:154
const cs_lagr_attribute_map_t * cs_lagr_particle_get_attr_map(void)
Return const pointer to the main particle attribute map structure.
Definition: cs_lagr_particle.c:950
void cs_lagr_set_n_g_particles_max(unsigned long long n_g_particles_max)
Set global maximum number of particles.
Definition: cs_lagr_particle.c:1239
cs_real_t weight
Definition: cs_lagr_particle.h:233
cs_real_t weight_merged
Definition: cs_lagr_particle.h:236
void cs_lagr_part_copy(cs_lnum_t dest, cs_lnum_t src)
Copy attributes from one particle to another.
Definition: cs_lagr_particle.c:999
Definition: cs_lagr_particle.h:177
static cs_lnum_t cs_lagr_particles_get_lnum(const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, cs_lagr_attribute_t attr)
Definition: cs_lagr_particle.h:594
void cs_lagr_particle_set_dump(const cs_lagr_particle_set_t *particles)
Dump a cs_lagr_particle_set_t structure.
Definition: cs_lagr_particle.c:1281
Definition: cs_lagr_particle.h:188
static cs_lnum_t cs_lagr_particle_get_lnum_n(const void *particle, const cs_lagr_attribute_map_t *attr_map, int time_id, cs_lagr_attribute_t attr)
Get attribute value of type cs_lnum_t of a given particle at a given time.
Definition: cs_lagr_particle.h:1070
static void cs_lagr_particles_unset_flag(const cs_lagr_particle_set_t *particle_set, cs_lnum_t particle_id, int mask)
Unset flag value with a selected mask for a given particle in a set.
Definition: cs_lagr_particle.h:565
void cs_lagr_get_attr_info(const cs_lagr_particle_set_t *particles, int time_id, cs_lagr_attribute_t attr, size_t *extents, size_t *size, ptrdiff_t *displ, cs_datatype_t *datatype, int *count)
Get data extents for a given particle attribute.
Definition: cs_lagr_particle.c:1034
Definition: cs_lagr_particle.h:173
Definition: cs_lagr_particle.h:134
static void cs_lagr_particle_set_lnum(void *particle, const cs_lagr_attribute_map_t *attr_map, cs_lagr_attribute_t attr, cs_lnum_t value)
Set attribute value of type cs_lnum_t of a given particle.
Definition: cs_lagr_particle.h:1093
Definition: cs_lagr_particle.h:106
static void cs_lagr_particle_set_gnum(void *particle, const cs_lagr_attribute_map_t *attr_map, cs_lagr_attribute_t attr, cs_gnum_t value)
Set attribute value of type cs_gnum_t of a given particle.
Definition: cs_lagr_particle.h:1191
Definition: cs_lagr_particle.h:88
int(* count)[CS_LAGR_N_ATTRIBUTES]
Definition: cs_lagr_particle.h:205
Definition: cs_lagr_particle.h:141
Definition: cs_lagr_particle.h:181
