7.2
cs_turbulence_model.h
1 #ifndef __CS_TURBULENCE_MODEL_H__
2 #define __CS_TURBULENCE_MODEL_H__
5  * Base turbulence model data.
31  * Local headers
34 #include "cs_defs.h"
41  * Macro definitions
45  * Type definitions
48 /*----------------------------------------------------------------------------
49  * turbulence models
50  *----------------------------------------------------------------------------*/
51
52 typedef enum {
53
70
72
73 /*----------------------------------------------------------------------------
74  * turbulence type of model
75  *----------------------------------------------------------------------------*/
76
77 enum {
78
83
84 };
85
87  * turbulence order of model
88  *----------------------------------------------------------------------------*/
89
90 enum {
91
95
96 };
97
98 /*----------------------------------------------------------------------------
99  * hybrid models
100  *----------------------------------------------------------------------------*/
101
102 enum {
103
108
109 };
110
111 /* turbulence model general options descriptor */
112 /*---------------------------------------------*/
113
114 typedef struct {
115
116  int iturb; /* turbulence model
117  CS_TURB_NONE: no turbulence model (laminar flow)
118  CS_TURB_MIXING_LENGTH: mixing length model
119  CS_TURB_K_EPSILON: standard k-epsilon model
120  CS_TURB_K_EPSILON_LIN_PROD: k-epsilon model with
121  Linear Production (LP) correction
122  CS_TURB_K_EPSILON_LS: Launder-Sharma low Re
123  k-epsilon model
124  CS_TURB_K_EPSILON_QUAD: Baglietto et al. low Re
125  k epsilon model
126  CS_TURB_RIJ_EPSILON_LRR: Rij-epsilon (LRR)
127  CS_TURB_RIJ_EPSILON_SSG: Rij-epsilon (SSG)
128  CS_TURB_RIJ_EPSILON_EBRSM: Rij-epsilon (EBRSM)
129  CS_TURB_LES_SMAGO_CONST: LES
130  (constant Smagorinsky model)
131  CS_TURB_LES_SMAGO_DYN: LES ("classical" dynamic
132  Smagorisky model)
133  CS_TURB_LES_WALE: LES (WALE)
134  CS_TURB_V2F_PHI: v2f phi-model
135  CS_TURB_V2F_BL_V2K: v2f BL-v2-k
136  CS_TURB_K_OMEGA: k-omega SST
137  CS_TURB_SPALART_ALLMARAS: Spalart-Allmaras model */
138  int itytur; /* class of turbulence model (integer value
139  iturb/10) */
140  int hybrid_turb; /* Type of Hybrid Turbulence Model
141  - CS_HYBRID_NONE: No model
142  - CS_HYBRID_DES: Detached Eddy Simulation
143  - CS_HYBRID_DDES: Delayed Detached Eddy
144  Simulation
145  - CS_HYBRID_SAM: Scale Adaptive Model */
146  int type; /* Type of turbulence modelling:
147  - CS_TURB_NONE: No model
148  - CS_TURB_RANS: RANS modelling
149  - CS_TURB_LES: LES modelling
150  - CS_TURB_HYBRID: RANS -- LES modelling */
151  int order; /* Order of the turbulence model:
152  - CS_TURB_ALGEBRAIC: 0th order algebraik model
153  - CS_TURB_FIRST_ORDER: 1st order Eddy Viscosity
154  type models
155  - CS_TURB_SECOND_ORDER: 2nd order Differential
156  Reynolds Stress type models */
158
159 /* Reference values for turbulence structure and associated pointer */
160 /*------------------------------------------------------------------*/
161
162 typedef struct {
163
164  double almax; /* characteristic macroscopic length of the
165  domain */
166  double uref; /* characteristic flow velocity */
167
169
170 /* RANS turbulence model descriptor */
171 /*----------------------------------*/
172
173 typedef struct {
174
175  int irccor; /* activation of rotation/curvature correction for
176  an eddy viscosity turbulence models
177  - 0: false
178  - 1: true */
179  int itycor; /* type of rotation/curvature correction for an
180  eddy viscosity turbulence models
181  - 1: Cazalbou correction (default when irccor=1
182  and itytur=2 or 5)
183  - 2: Spalart-Shur correction (default when
184  irccor=1 and iturb=60 or 70) */
185  int idirsm; /* turbulent diffusion model for second moment
186  closure
187  - 0: scalar diffusivity (Shir model)
188  - 1: tensorial diffusivity (Daly and Harlow
189  model, default model) */
190  int iclkep; /* clipping of k and epsilon
191  - 0: absolute value clipping
192  - 1: coupled clipping based on physical
193  relationships */
194  int igrhok; /* take (2/3 rho grad k) in the momentum
195  equation
196  - 1: true
197  - 0: false (default) */
198  int igrake; /* buoyant term in k-epsilon
199  - 1: true (default if rho is variable)
200  - 0: false */
201  int igrari; /* buoyant term in Rij-epsilon
202  - 1: true (default if rho is variable)
203  - 0: false */
204  int ikecou; /* partially coupled version of
205  k-epsilon (only for iturb=20)
206  - 1: true (default)
207  - 0: false */
208  int reinit_turb; /* Advanced re-init for EBRSM and k-omega models
209  - 1: true (default)
210  - 0: false */
211  int irijco; /* coupled solving of Rij
212  - 1: true
213  - 0: false (default) */
214  int irijnu; /* pseudo eddy viscosity in the matrix of momentum
215  equation to partially implicit div( rho R )
216  - 1: true
217  - 0: false (default) */
218  int irijrb; /* accurate treatment of R at the boundary (see
219  \ref condli)
220  - 1: true
221  - 0: false (default) */
222  int irijec; /* wall echo term of R
223  - 1: true
224  - 0: false (default) */
225  int idifre; /* whole treatment of the diagonal part of the
226  diffusion tensor of R and epsilon
227  - 1: true (default)
228  - 0: simplified treatment */
229  int iclsyr; /* partial implicitation of symmetry BCs of R
230  - 1: true (default)
231  - 0: false */
232  int iclptr; /* partial implicitation of wall BCs of R
233  - 1: true
234  - 0: false (default) */
235  double xlomlg; /* mixing length */
236
238
239 /* LES turbulence model descriptor */
240 /*---------------------------------*/
241
242 typedef struct {
243
244  int idries; /* Van Driest smoothing at the wall (only for
245  itytur=4)
246  - 1: true
247  - 0: false */
248
250
251 /*============================================================================
252  * Static global variables
253  *============================================================================*/
254
255 /* Pointer to main turbulence model descriptor structure */
256
257 extern const cs_turb_model_t *cs_glob_turb_model;
258
259 /* Pointer to reference values for turbulence descriptor structure */
260
262
263 /* Pointer to RANS turbulence model descriptor structure */
264
266
267 /* Pointer to LES turbulence model descriptor structure */
268
270
271 /* Constant for turbulence models */
272
273 extern const double cs_turb_xkappa;
274 extern const double cs_turb_vdriest;
275 extern const double cs_turb_cstlog;
276 extern const double cs_turb_cstlog_rough;
277 extern double cs_turb_cstlog_alpha;
278 extern const double cs_turb_apow;
279 extern const double cs_turb_bpow;
280 extern double cs_turb_dpow;
281 extern double cs_turb_cmu;
282 extern double cs_turb_cmu025;
283 extern double cs_turb_ce1;
284 extern double cs_turb_ce2;
285 extern double cs_turb_ce4;
286 extern double cs_turb_crij1;
287 extern double cs_turb_crij2;
288 extern double cs_turb_crij3;
289 extern const double cs_turb_crijp1;
290 extern const double cs_turb_crijp2;
291 extern const double cs_turb_cssge2;
292 extern const double cs_turb_cssgs1;
293 extern const double cs_turb_cssgs2;
294 extern const double cs_turb_cssgr1;
295 extern const double cs_turb_cssgr2;
296 extern const double cs_turb_cssgr3;
297 extern const double cs_turb_cssgr4;
298 extern const double cs_turb_cssgr5;
299 extern const double cs_turb_cebms1;
300 extern const double cs_turb_cebms2;
301 extern const double cs_turb_cebmr1, cebmr2, cebmr3, cebmr4, cebmr5;
302 extern double cs_turb_csrij;
303 extern const double cs_turb_cebme2;
304 extern const double cs_turb_cebmmu;
305 extern const double cs_turb_xcl;
306 extern const double cs_turb_xa1;
307 extern const double cs_turb_xct;
308 extern const double cs_turb_xceta;
309 extern const double cs_turb_cpale1;
310 extern const double cs_turb_cpale2;
311 extern const double cs_turb_cpale3;
312 extern const double cs_turb_cpale4;
313 extern const double cs_turb_cpalc1;
314 extern const double cs_turb_cpalc2;
315 extern const double cs_turb_cpalct;
316 extern const double cs_turb_cpalcl;
317 extern const double cs_turb_cpalet;
318 extern const double cs_turb_ckwsk1;
319 extern const double cs_turb_ckwsk2;
320 extern const double cs_turb_ckwsw1;
321 extern const double cs_turb_ckwsw2;
322 extern const double cs_turb_ckwbt1;
323 extern const double cs_turb_ckwbt2;
324 extern double cs_turb_ckwgm1;
325 extern double cs_turb_ckwgm2;
326 extern const double cs_turb_ckwa1;
327 extern const double cs_turb_ckwc1;
328 extern double cs_turb_cddes;
329 extern const double cs_turb_csas;
330 extern const double cs_turb_csas_eta2;
331 extern const double cs_turb_cnl1;
332 extern const double cs_turb_cnl2;
333 extern const double cs_turb_cnl3;
334 extern const double cs_turb_cnl4;
335 extern const double cs_turb_cnl5;
336 extern const double cs_turb_csab1;
337 extern const double cs_turb_csab2;
338 extern const double cs_turb_csasig;
339 extern const double cs_turb_csav1;
340 extern double cs_turb_csaw1;
341 extern const double cs_turb_csaw2;
342 extern const double cs_turb_csaw3;
343 extern const double cs_turb_cssr1;
344 extern const double cs_turb_cssr2;
345 extern const double cs_turb_cssr3;
346 extern const double cs_turb_ccaze2;
347 extern const double cs_turb_ccazsc;
348 extern const double cs_turb_ccaza;
349 extern const double cs_turb_ccazb;
350 extern const double cs_turb_ccazc;
351 extern const double cs_turb_ccazd;
352 extern const double cs_turb_xlesfl;
353 extern const double cs_turb_ales;
354 extern const double cs_turb_bles;
355 extern double cs_turb_csmago;
356 extern double cs_turb_xlesfd;
357 extern double cs_turb_csmago_max;
358 extern double cs_turb_csmago_min;
359 extern double cs_turb_cdries;
360 extern const double cs_turb_cv2fa1;
361 extern const double cs_turb_cv2fe2;
362 extern const double cs_turb_cv2fc1;
363 extern const double cs_turb_cv2fc2;
364 extern const double cs_turb_cv2fct;
365 extern const double cs_turb_cv2fcl;
366 extern const double cs_turb_cv2fet;
367 extern double cs_turb_cwale;
368 extern const double cs_turb_xiafm;
369 extern const double cs_turb_etaafm;
370 extern const double cs_turb_c1trit;
371 extern const double cs_turb_c2trit;
372 extern const double cs_turb_c3trit;
373 extern const double cs_turb_c4trit;
374 extern const double cs_turb_cthafm;
375 extern const double cs_turb_cthdfm;
376
377 /*=============================================================================
378  * Public function prototypes
379  *============================================================================*/
380
381 /*----------------------------------------------------------------------------
382  * Initialize turbulence model structures
383  *----------------------------------------------------------------------------*/
384
385 void
386 cs_turb_model_init(void);
387
388 /*----------------------------------------------------------------------------
389  * Set type and order of the turbulence model
390  *----------------------------------------------------------------------------*/
391
392 void
394
395 /*----------------------------------------------------------------------------
396  * Set global pointer to turbulence model structure
397  *----------------------------------------------------------------------------*/
398
399 void
401
402 /*----------------------------------------------------------------------------
403  * Provide write access to turbulence model structure
404  *----------------------------------------------------------------------------*/
405
408
409 /*----------------------------------------------------------------------------
410  * Compute turbulence model constants,
411  * some of which may depend on the model choice.
412  *----------------------------------------------------------------------------*/
413
414 void
416
417 /*----------------------------------------------------------------------------
418  * Provide access to cs_glob_turb_ref_values
419  *
420  * needed to initialize structure with GUI
421  *----------------------------------------------------------------------------*/
422
425
426 /*----------------------------------------------------------------------------
427  * Provide access to cs_glob_turb_rans_model
428  *
429  * needed to initialize structure with GUI
430  *----------------------------------------------------------------------------*/
431
434
435 /*----------------------------------------------------------------------------
436  * Provide access to cs_glob_turb_les_model
437  *
438  * needed to initialize structure with GUI
439  *----------------------------------------------------------------------------*/
440
443
444 /*----------------------------------------------------------------------------*
445  * Print the turbulence model parameters to setup.log.
446  *----------------------------------------------------------------------------*/
447
448 void
450
451 /*----------------------------------------------------------------------------*
452  * Print the turbulent constants to setup.log.
453  *----------------------------------------------------------------------------*/
454
455 void
457
458 /*----------------------------------------------------------------------------*
459  * Clip turbulent fluxes
460  *----------------------------------------------------------------------------*/
461
462 void
463 cs_clip_turbulent_fluxes(int flux_id,
464  int ivartt);
465
466 /*----------------------------------------------------------------------------*/
467
469
470 #endif /* __CS_TURBULENCE_MODEL_H__ */
Definition: cs_turbulence_model.c:729
Definition: cs_turbulence_model.c:637
Definition: cs_turbulence_model.c:407
Definition: cs_turbulence_model.c:574
int itytur
Definition: cs_turbulence_model.h:138
Definition: cs_turbulence_model.c:643
const cs_turb_rans_model_t * cs_glob_turb_rans_model
Definition: cs_turbulence_model.c:564
Definition: cs_turbulence_model.c:920
Definition: cs_turbulence_model.c:550
Definition: cs_turbulence_model.h:54
Definition: cs_turbulence_model.h:105
Definition: cs_turbulence_model.c:918
Definition: cs_turbulence_model.c:538
void cs_turb_constants_log_setup(void)
Definition: cs_turbulence_model.c:1857
Definition: cs_turbulence_model.c:678
const double cebmr5
Definition: cstphy.f90:446
Definition: cs_turbulence_model.h:79
Definition: cs_turbulence_model.c:613
double xlomlg
Definition: cs_turbulence_model.h:235
Definition: cs_turbulence_model.c:952
Definition: cs_turbulence_model.h:68
Definition: cs_turbulence_model.c:704
int irijec
Definition: cs_turbulence_model.h:222
Definition: cs_turbulence_model.c:789
Definition: cs_turbulence_model.c:508
Definition: cs_turbulence_model.c:882
int order
Definition: cs_turbulence_model.h:151
cs_turb_les_model_t * cs_get_glob_turb_les_model(void)
Provide access to cs_glob_turb_les_model.
Definition: cs_turbulence_model.c:1546
Definition: cs_turbulence_model.h:104
Definition: cs_turbulence_model.c:764
Turbulence model general options descriptor.
Definition: cs_turbulence_model.h:114
int idries
Definition: cs_turbulence_model.h:244
int irijrb
Definition: cs_turbulence_model.h:218
Definition: cs_turbulence_model.c:485
Definition: cs_turbulence_model.c:808
double almax
Definition: cs_turbulence_model.h:164
Definition: cs_turbulence_model.h:82
Definition: cs_turbulence_model.h:107
Definition: cs_turbulence_model.c:479
Definition: cs_turbulence_model.h:94
Definition: cs_turbulence_model.c:759
const double cebmr2
Definition: cs_turbulence_model.h:57
Definition: cs_turbulence_model.c:592
int igrari
Definition: cs_turbulence_model.h:201
int irccor
Definition: cs_turbulence_model.h:175
Definition: cs_turbulence_model.c:631
int itycor
Definition: cs_turbulence_model.h:179
Definition: cs_turbulence_model.c:544
int igrake
Definition: cs_turbulence_model.h:198
Definition: cs_turbulence_model.c:932
const cs_turb_les_model_t * cs_glob_turb_les_model
Definition: cs_turbulence_model.h:162
void cs_set_glob_turb_model(void)
Set global pointer to turbulence model structure.
Definition: cs_turbulence_model.c:1436
Definition: cs_turbulence_model.c:500
Definition: cs_turbulence_model.h:81
Definition: cs_turbulence_model.c:870
Definition: cs_turbulence_model.c:610
Definition: cs_turbulence_model.c:698
Definition: cs_turbulence_model.c:921
Definition: cs_turbulence_model.c:598
int irijnu
Definition: cs_turbulence_model.h:214
Definition: cs_turbulence_model.c:432
Definition: cs_turbulence_model.h:56
int reinit_turb
Definition: cs_turbulence_model.h:208
int iclptr
Definition: cs_turbulence_model.h:232
Definition: cs_turbulence_model.c:601
double cs_turb_ce2
Definition: cs_turbulence_model.c:464
void cs_turb_model_log_setup(void)
Definition: cs_turbulence_model.c:1558
Definition: cs_turbulence_model.c:927
Definition: cs_turbulence_model.c:586
Definition: cs_turbulence_model.c:580
Definition: cs_turbulence_model.c:685
Definition: cs_turbulence_model.c:448
Definition: cs_turbulence_model.c:562
Definition: cs_turbulence_model.c:888
Definition: cs_turbulence_model.h:59
Definition: cs_turbulence_model.c:851
Definition: cs_turbulence_model.h:64
int type
Definition: cs_turbulence_model.h:146
Definition: cs_turbulence_model.c:876
void cs_set_type_order_turbulence_model(void)
Initialize type and order members of turbulence model structure.
Definition: cs_turbulence_model.c:1378
Definition: cs_turbulence_model.h:67
Definition: cs_turbulence_model.c:799
Definition: cs_turbulence_model.c:491
const double cebmr3
Definition: cs_turbulence_model.c:942
void cs_turb_model_init(void)
Initialize turbulence model structures.
Definition: cs_turbulence_model.c:1364
Definition: cs_turbulence_model.c:817
double cs_turb_ce4
Definition: cs_turbulence_model.c:473
Definition: cs_turbulence_model.h:62
RANS turbulence model descriptor.
Definition: cs_turbulence_model.h:173
Definition: cs_turbulence_model.h:65
Definition: cs_turbulence_model.h:69
void cs_turb_compute_constants(void)
Compute turbulence model constants, some of which may depend on the model choice. ...
Definition: cs_turbulence_model.c:1451
const cs_turb_ref_values_t * cs_glob_turb_ref_values
Definition: cs_turbulence_model.h:80
Definition: cs_turbulence_model.c:744
Definition: cs_turbulence_model.c:900
Definition: cs_turbulence_model.c:520
cs_turb_model_type_t
Definition: cs_turbulence_model.h:52
Definition: cs_turbulence_model.c:912
Definition: cs_turbulence_model.c:894
double cs_turb_ce1
Definition: cs_turbulence_model.c:456
Definition: cs_turbulence_model.c:418
Definition: cs_turbulence_model.c:387
Definition: cs_turbulence_model.c:841
Definition: cs_turbulence_model.c:667
Definition: cs_turbulence_model.h:63
Definition: cs_turbulence_model.c:719
Definition: cs_turbulence_model.c:714
Definition: cs_turbulence_model.c:784
Definition: cs_turbulence_model.c:769
int ikecou
Definition: cs_turbulence_model.h:204
Definition: cs_turbulence_model.h:61
Definition: cs_turbulence_model.c:556
Definition: cs_turbulence_model.c:779
Definition: cs_turbulence_model.c:655
Definition: cs_turbulence_model.c:616
cs_turb_ref_values_t * cs_get_glob_turb_ref_values(void)
Provide access to cs_glob_turb_ref_values.
Definition: cs_turbulence_model.c:1518
int idifre
Definition: cs_turbulence_model.h:225
int iturb
Definition: cs_turbulence_model.h:116
Definition: cs_turbulence_model.c:625
Definition: cs_turbulence_model.c:619
LES turbulence model descriptor.
Definition: cs_turbulence_model.h:242
const double cebmr4
Definition: cs_turbulence_model.c:396
Definition: cs_turbulence_model.c:595
int hybrid_turb
Definition: cs_turbulence_model.h:140
Definition: cs_turbulence_model.c:962
cs_turb_model_t * cs_get_glob_turb_model(void)
Provide write access to turbulence model structure.
Definition: cs_turbulence_model.c:1422
Definition: cs_turbulence_model.c:919
Definition: cs_turbulence_model.c:724
Definition: cs_turbulence_model.h:60
Definition: cs_turbulence_model.c:957
Definition: cs_turbulence_model.h:93
Definition: cs_turbulence_model.c:526
int iclsyr
Definition: cs_turbulence_model.h:229
Definition: cs_turbulence_model.c:577
Definition: cs_turbulence_model.c:861
int iclkep
Definition: cs_turbulence_model.h:190
Definition: cs_turbulence_model.c:906
Definition: cs_turbulence_model.c:831
Definition: cs_turbulence_model.c:649
Definition: cs_turbulence_model.h:66
Definition: cs_turbulence_model.c:583
const cs_turb_model_t * cs_glob_turb_model
Definition: cs_turbulence_model.c:947
double uref
Definition: cs_turbulence_model.h:166
Definition: cs_turbulence_model.c:709
Definition: cs_turbulence_model.c:532
Definition: cs_turbulence_model.c:937
int igrhok
Definition: cs_turbulence_model.h:194
double cs_turb_cmu
Definition: cs_turbulence_model.c:445
Definition: cs_turbulence_model.c:774
Definition: cs_turbulence_model.c:734
Definition: cs_turbulence_model.c:922
void cs_clip_turbulent_fluxes(int flux_id, int ivartt)
Clipping for the turbulence flux vector.
Definition: cs_turbulence_model.c:2059
cs_turb_rans_model_t * cs_get_glob_turb_rans_model(void)
Provide access to cs_glob_turb_rans_model.
Definition: cs_turbulence_model.c:1532
int idirsm
Definition: cs_turbulence_model.h:185
Definition: cs_turbulence_model.c:692
Definition: cs_turbulence_model.c:514
double cs_turb_dpow
Definition: cs_turbulence_model.c:438
int irijco
Definition: cs_turbulence_model.h:211
Definition: cs_turbulence_model.c:607
Definition: cs_turbulence_model.h:58
Definition: cs_turbulence_model.c:739
Definition: cs_turbulence_model.h:106
Definition: cs_turbulence_model.c:749
Definition: cs_turbulence_model.h:92
Definition: cs_turbulence_model.c:435
Definition: cs_turbulence_model.h:55
Definition: cs_turbulence_model.c:559
Definition: cs_turbulence_model.c:589
Definition: cs_turbulence_model.c:429
Definition: cs_turbulence_model.c:967
Definition: cs_turbulence_model.c:754
Definition: cs_turbulence_model.c:604
