1 #ifndef __CS_FIELD_POINTER_H__ 2 #define __CS_FIELD_POINTER_H__ 47 #define CS_ENUMF_(e) CS_FIELD_POINTER_ ## e 51 #define CS_F_(e) cs_glob_field_pointers[CS_FIELD_POINTER_ ## e].f 53 #define CS_FI_(e, i) cs_glob_field_pointers[CS_FIELD_POINTER_ ## e].p[i] 347 const int species_f_id[]);
Definition: cs_field_pointer.h:241
Definition: cs_field_pointer.h:164
Definition: cs_field_pointer.h:196
Definition: cs_field_pointer.h:224
Definition: cs_field_pointer.h:165
Definition: cs_field_pointer.h:160
Definition: cs_field_pointer.h:175
Definition: cs_field_pointer.h:204
void cs_field_pointer_map_base(void)
Map base fields to enumerated pointers.
Definition: cs_field_pointer.c:277
Definition: cs_field_pointer.h:192
Definition: cs_field_pointer.h:104
Definition: cs_field_pointer.h:150
Definition: cs_field_pointer.h:169
Definition: cs_field_pointer.h:139
Definition: cs_field_pointer.h:166
Definition: cs_field_pointer.h:243
Definition: cs_field.h:125
Definition: cs_field_pointer.h:172
Definition: cs_field_pointer.h:106
Definition: cs_field_pointer.h:143
Definition: cs_field_pointer.h:77
void cs_field_pointer_ensure_init(void)
Ensure field pointer array is initialized.
Definition: cs_field_pointer.c:173
Definition: cs_field_pointer.h:229
void cs_field_pointer_destroy_all(void)
Free all field pointer data.
Definition: cs_field_pointer.c:186
Definition: cs_field_pointer.h:227
Definition: cs_field_pointer.h:215
Definition: cs_field_pointer.h:202
Definition: cs_field_pointer.h:151
Definition: cs_field_pointer.h:161
Definition: cs_field_pointer.h:84
Definition: cs_field_pointer.h:237
Definition: cs_field_pointer.h:124
Definition: cs_field_pointer.h:216
Definition: cs_field_pointer.h:228
Definition: cs_field_pointer.h:73
Macro used for scoping of field pointer enums.
Definition: cs_field_pointer.h:47
Definition: cs_field_pointer.h:179
Definition: cs_field_pointer.h:133
Definition: cs_field_pointer.h:162
Definition: cs_field_pointer.h:230
Definition: cs_field_pointer.h:231
cs_field_t * f
Definition: cs_field_pointer.h:260
void cs_field_pointer_map_boundary(void)
Map some boundary fields to enumerated pointers.
Definition: cs_field_pointer.c:347
Definition: cs_field_pointer.h:214
Definition: cs_field_pointer.h:126
Definition: cs_field_pointer.h:145
void cs_field_pointer_map_gas_mix(void)
Map base fields to enumerated pointers for gas mix model.
Definition: cs_field_pointer.c:497
Definition: cs_field_pointer.h:67
Definition: cs_field_pointer.h:178
Definition: cs_field_pointer.h:100
void cs_field_pointer_map_compressible(void)
Map base fields to enumerated pointers for compressible model.
Definition: cs_field_pointer.c:460
Definition: cs_field_pointer.h:136
Definition: cs_field_pointer.h:212
Definition: cs_field_pointer.h:217
Definition: cs_field_pointer.h:200
Definition: cs_field_pointer.h:239
Definition: cs_field_pointer.h:223
Definition: cs_field_pointer.h:142
Definition: cs_field_pointer.h:154
Definition: cs_field_pointer.h:153
Definition: cs_field_pointer.h:234
void cs_field_pointer_map_coal_combustion(int n_coals, int n_classes)
Map base fields to enumerated pointers for coal combustion.
Definition: cs_field_pointer.c:393
Definition: cs_field_pointer.h:109
Definition: cs_field_pointer.h:177
Definition: cs_field_pointer.h:159
Definition: cs_field_pointer.h:188
Definition: cs_field_pointer.h:107
Definition: cs_field_pointer.h:253
void cs_field_pointer_map_groundwater(void)
Map base fields to enumerated pointers for groundwater flows.
Definition: cs_field_pointer.c:544
Definition: cs_field_pointer.h:206
Definition: cs_field_pointer.h:95
cs_field_t ** p
Definition: cs_field_pointer.h:261
struct cs_field_pointer_array_t * cs_glob_field_pointers
Definition: cs_field_pointer.c:130
Definition: cs_field_pointer.h:128
Definition: cs_field_pointer.h:115
Definition: cs_field_pointer.h:201
Definition: cs_field_pointer.h:176
Definition: cs_field_pointer.h:218
Definition: cs_field_pointer.h:222
Definition: cs_field_pointer.h:203
Definition: cs_field_pointer.h:123
Definition: cs_field_pointer.h:210
Definition: cs_field_pointer.h:209
Definition: cs_field_pointer.h:167
void cs_field_pointer_map_indexed(cs_field_pointer_id_t e, int index, cs_field_t *f)
Map a field to an (enumerated pointer, index) couple.
Definition: cs_field_pointer.c:232
Definition: cs_field_pointer.h:152
void cs_field_pointer_map(cs_field_pointer_id_t e, cs_field_t *f)
Map a simple field to an enumerated pointer.
Definition: cs_field_pointer.c:210
Definition: cs_field_pointer.h:91
Definition: cs_field_pointer.h:185
Definition: cs_field_pointer.h:141
Definition: cs_field_pointer.h:93
Definition: cs_field_pointer.h:226
Definition: cs_field_pointer.h:249
Definition: cs_field_pointer.h:89
Definition: cs_field_pointer.h:221
Definition: cs_field_pointer.h:190
Definition: cs_field_pointer.h:238
Definition: cs_field_pointer.h:81
Definition: cs_field_pointer.h:120
Definition: cs_field_pointer.h:225
Definition: cs_field_pointer.h:194
Definition: cs_field_pointer.h:111
Definition: cs_field_pointer.h:101
Definition: cs_field_pointer.h:94
Definition: cs_field_pointer.h:182
Definition: cs_field_pointer.h:213
Definition: cs_field_pointer.h:219
Definition: cs_field_pointer.h:233
Definition: cs_field_pointer.h:181
Definition: cs_field_pointer.h:199
Definition: cs_field_pointer.h:144
Definition: cs_field_pointer.h:183
Definition: cs_field_pointer.h:170
Definition: cs_field_pointer.h:156
Definition: cs_field_pointer.h:235
Definition: cs_field_pointer.h:232
Definition: cs_field_pointer.h:137
Definition: cs_field_pointer.h:80
Definition: cs_field_pointer.h:246
Definition: cs_field_pointer.h:186
Definition: cs_field_pointer.h:259
Definition: cs_field_pointer.h:146
Definition: cs_field_pointer.h:75
Definition: cs_field_pointer.h:205
Definition: cs_field_pointer.h:131
Definition: cs_field_pointer.h:163
Definition: cs_field_pointer.h:157
Definition: cs_field_pointer.h:147
Definition: cs_field_pointer.h:121
Definition: cs_field_pointer.h:148
Definition: cs_field_pointer.h:135
Definition: cs_field_pointer.h:149
Definition: cs_field_pointer.h:189
Definition: cs_field_pointer.h:211
Definition: cs_field_pointer.h:191
Definition: cs_field_pointer.h:103
Definition: cs_field_pointer.h:129
Definition: cs_field_pointer.h:61
Definition: cs_field_pointer.h:125
Definition: cs_field_pointer.h:240
Definition: cs_field_pointer.h:88
Definition: cs_field_pointer.h:155
Definition: cs_field_pointer.h:187
Definition: cs_field_pointer.h:110
Definition: cs_field_pointer.h:71
Definition: cs_field_pointer.h:168
Definition: cs_field_pointer.h:220
Definition: cs_field_pointer.h:119
Definition: cs_field_pointer.h:242
Definition: cs_field_pointer.h:173
void cs_field_pointer_map_atmospheric(int n_chem_species, const int species_f_id[])
Map base fields to enumerated pointers for atmospheric models.
Definition: cs_field_pointer.c:366
Definition: cs_field_pointer.h:86
Definition: cs_field_pointer.h:132
Definition: cs_field_pointer.h:140
Definition: cs_field_pointer.h:76
Definition: cs_field_pointer.h:236
Definition: cs_field_pointer.h:184
void cs_field_pointer_map_gas_combustion(void)
Map base fields to enumerated pointers for gas combustion.
Definition: cs_field_pointer.c:510
Definition: cs_field_pointer.h:117
