Here is a list of all variables with links to the structures/unions they belong to:
- n -
- n : cs_gwf_soil_vgm_tpf_param_t, cs_gwf_soil_vgm_spf_param_t
- n1_dofs_by_elt : cs_saddle_solver_t
- n1_elts : cs_saddle_solver_t
- n1_scatter_dofs : cs_saddle_solver_t
- n2_dofs_by_elt : cs_saddle_solver_t
- n2_elts : cs_saddle_solver_t
- n2_scatter_dofs : cs_saddle_solver_t
- n_agg_levels : cs_param_amg_boomer_t, cs_param_amg_gamg_t
- n_agg_paths : cs_param_amg_boomer_t
- n_algo_iter : cs_iter_algo_aac_t, cs_iter_algo_default_t
- n_atomic_species : cs_coal_model_t, cs_combustion_gas_model_t
- n_aux : cs_sles_pc_poly_t
- n_b_cells : cs_mesh_t
- n_b_definitions : cs_property_t
- n_b_faces : cs_cdo_bc_face_t, cs_cdo_quantities_t, cs_mesh_t
- n_b_faces_all : cs_mesh_t
- n_bc_defs : cs_equation_param_t
- n_bc_faces : cs_cell_sys_t
- n_bdy_flux_defs : cs_adv_field_t
- n_blocks : cs_cdo_system_helper_t
- n_boundaries : cs_boundary_t
- n_boundary_stats : cs_lagr_dim_t
- n_boussinesq_terms : cs_navsto_param_t
- n_boxes : fvm_box_set_t, cs_join_stats_t
- n_buoyant_scal : cs_velocity_pressure_model_t
- n_c_domains : cs_halo_t
- n_calls : cs_join_stats_t, cs_saddle_solver_t
- n_cells : cs_cdocb_scaleq_t, cs_ctwr_zone_t, fvm_nodal_t, cs_cdo_connect_t, cs_cdo_quantities_t, cs_mesh_t, cs_solid_selection_t, cs_volume_zone_t
- n_cells_with_ghosts : cs_cdo_connect_t, cs_mesh_t
- n_circulation_faces : cs_cdo_bc_face_t
- n_classes_per_coal : cs_coal_model_t
- n_coals : cs_coal_model_t
- n_col_blocks : cs_cdo_system_helper_t, cs_sdm_block_t
- n_cols : cs_sdm_t, cs_cdo_assembly_row_t, cs_sles_pc_poly_t
- n_cpl_bcs : cs_sys_cpl_t
- n_cpl_phases : cs_sys_cpl_t
- n_cw_dofs : cs_cdo_assembly_t
- n_definitions : cs_property_t
- n_deg_elts : cs_basis_func_t
- n_dir : cs_iter_algo_aac_t
- n_dirac : cs_libby_williams_params_t
- n_distant : cs_internal_coupling_t
- n_dofs : cs_cdocb_scaleq_t, cs_cdoeb_vecteq_t, cs_cdofb_vecteq_t, cs_cdovb_vecteq_t, cs_macfb_vecteq_t, cs_cell_sys_t, cs_macfb_builder_t
- n_domains : cs_mesh_t
- n_doms : fvm_nodal_t
- n_down_iter : cs_param_amg_boomer_t, cs_param_amg_gamg_t, cs_param_amg_hmg_t, cs_param_amg_inhouse_t
- n_ec : cs_cell_mesh_t
- n_edges : fvm_nodal_t, cs_cdo_connect_t, cs_cdo_quantities_t
- n_ef : cs_face_mesh_light_t, cs_face_mesh_t
- n_elements : cs_cdo_system_block_info_t, fvm_nodal_section_t
- n_elts : cs_adjacency_t, cs_cfd2sys_intersection_t, cs_enforcement_param_t, cs_halo_t, cs_iter_algo_aac_t, cs_medcoupling_mesh_t, cs_range_set_t, cs_zone_t
- n_enforcements : cs_equation_param_t
- n_equations : cs_equation_system_t
- n_events : cs_lagr_event_set_t
- n_events_max : cs_lagr_event_set_t
- n_face_basis : cs_hho_builder_t
- n_faces : cs_cdocb_scaleq_t, cs_cdofb_vecteq_t, cs_macfb_vecteq_t, fvm_nodal_t, cs_boundary_zone_t, cs_cdo_connect_t, cs_cdo_quantities_t, cs_mesh_extrude_vectors_t, cs_stl_mesh_t, fvm_nodal_section_t
- n_failed_part : cs_lagr_particle_set_t
- n_families : cs_mesh_t
- n_fc : cs_cell_mesh_t, cs_macfb_builder_t
- n_format_writers : fvm_writer_t
- n_g_b_faces : cs_mesh_t
- n_g_b_faces_all : cs_mesh_t
- n_g_boxes : fvm_box_set_t
- n_g_cells : cs_cdo_quantities_t, cs_mesh_t, cs_solid_selection_t, cs_solidification_t
- n_g_cumulative_failed : cs_lagr_particle_counter_t
- n_g_cumulative_total : cs_lagr_particle_counter_t
- n_g_deposited : cs_lagr_particle_counter_t
- n_g_edges : cs_cdo_connect_t, cs_cdo_quantities_t
- n_g_elts : cs_zone_t
- n_g_exit : cs_lagr_particle_counter_t
- n_g_face_connect_size : cs_mesh_builder_t
- n_g_faces : cs_cdo_quantities_t, cs_mesh_builder_t
- n_g_failed : cs_lagr_particle_counter_t
- n_g_fouling : cs_lagr_particle_counter_t
- n_g_free_faces : cs_mesh_t
- n_g_i_c_faces : cs_mesh_t
- n_g_i_faces : cs_mesh_t
- n_g_merged : cs_lagr_particle_counter_t
- n_g_new : cs_lagr_particle_counter_t
- n_g_per_face_couples : cs_mesh_builder_t
- n_g_resuspended : cs_lagr_particle_counter_t
- n_g_total : cs_lagr_particle_counter_t
- n_g_vertices : cs_cdo_quantities_t, cs_mesh_t
- n_gas : cs_data_elec_t
- n_gas_el_comp : cs_coal_model_t, cs_combustion_gas_model_t
- n_gas_fl : cs_combustion_gas_model_t
- n_gas_species : cs_coal_model_t, cs_combustion_gas_model_t
- n_ghost_cells : cs_mesh_t
- n_gpts_tetra : cs_basis_func_t
- n_gpts_tria : cs_basis_func_t
- n_groups : cs_mesh_t, cs_numbering_t
- n_headers : cs_porosity_from_scan_opt_t
- n_hmg_dir_faces : cs_cdo_bc_face_t
- n_hmg_neu_faces : cs_cdo_bc_face_t
- n_i_faces : cs_cdo_quantities_t, cs_mesh_t
- n_ic_defs : cs_equation_param_t
- n_init_perio : cs_mesh_t
- n_inject : cs_lagr_injection_set_t
- n_injection_sets : cs_lagr_zone_data_t
- n_inlet_faces : cs_ctwr_zone_t
- n_inner_iter : cs_iter_algo_aac_t, cs_iter_algo_default_t
- n_it : cs_solving_info_t
- n_iter_max : cs_saddle_solver_t, cs_solidification_binary_alloy_t, cs_solidification_stefan_t
- n_iter_mean : cs_turb_hybrid_model_t
- n_iter_min : cs_saddle_solver_t
- n_iter_tot : cs_saddle_solver_t
- n_layer : cs_atmo_chemistry_t
- n_layers : cs_mesh_extrude_face_info_t, cs_mesh_extrude_vectors_t
- n_leaf_boxes : cs_join_stats_t
- n_leaves : cs_join_stats_t
- n_list_elts : cs_xdef_array_context_t
- n_local : cs_internal_coupling_t
- n_local_elts : cs_halo_t
- n_location_vals : cs_io_sec_header_t
- n_log_data : cs_at_opt_interp_t
- n_matrices : cs_cdo_system_nblock_t
- n_max_blocks_by_col : cs_sdm_block_t
- n_max_blocks_by_row : cs_sdm_block_t
- n_max_classes : cs_lagr_agglomeration_model_t
- n_max_cols : cs_sdm_t
- n_max_dir : cs_iter_algo_param_aac_t
- n_max_dofs : cs_macfb_builder_t
- n_max_ebyc : cs_cdo_connect_t, cs_cell_mesh_t
- n_max_equiv_breaks : cs_join_param_t
- n_max_face_basis : cs_hho_builder_t
- n_max_family_items : cs_mesh_t
- n_max_fbyc : cs_cdo_connect_t, cs_cell_mesh_t
- n_max_iter : cs_param_convergence_t
- n_max_outer_iter : cs_navsto_param_t
- n_max_rows : cs_sdm_t
- n_max_v2ec : cs_cdo_connect_t
- n_max_v2fc : cs_cdo_connect_t
- n_max_vbyc : cs_cdo_connect_t, cs_cell_mesh_t
- n_max_vbyf : cs_cdo_connect_t, cs_face_mesh_light_t, cs_face_mesh_t
- n_meshes : cs_stl_mesh_info_t
- n_nhmg_dir_faces : cs_cdo_bc_face_t
- n_nhmg_neu_faces : cs_cdo_bc_face_t
- n_no_adj_halo_elts : cs_numbering_t
- n_no_adj_halo_groups : cs_numbering_t
- n_objects : cs_ibm_t
- n_outlet_cells : cs_ctwr_zone_t
- n_outlet_faces : cs_ctwr_zone_t
- n_part_dep : cs_lagr_particle_set_t
- n_part_fou : cs_lagr_particle_set_t
- n_part_merged : cs_lagr_particle_set_t
- n_part_new : cs_lagr_particle_set_t
- n_part_out : cs_lagr_particle_set_t
- n_part_resusp : cs_lagr_particle_set_t
- n_particles : cs_lagr_particle_set_t
- n_particles_max : cs_lagr_particle_set_t
- n_per_face_couples : cs_mesh_builder_t
- n_perio : cs_mesh_builder_t
- n_phases : cs_lagr_extra_module_t
- n_point : cs_data_elec_t
- n_pressure_bc_defs : cs_navsto_param_t
- n_pressure_ic_defs : cs_navsto_param_t
- n_ranks : cs_block_dist_info_t, fvm_to_histogram_writer_t
- n_reaction_terms : cs_equation_param_t
- n_reactions : cs_atmo_chemistry_t, cs_coal_model_t, cs_combustion_gas_model_t
- n_recv_fields : cs_cfd_sys_cplbc_t
- n_recv_vals : cs_sys_cpl_t
- n_related_properties : cs_property_t
- n_robin_faces : cs_cdo_bc_face_t
- n_rotations : cs_halo_t
- n_row_blocks : cs_sdm_block_t
- n_rows : cs_sdm_t, cs_sles_pc_poly_t
- n_sections : fvm_nodal_t
- n_seeds : cs_stl_mesh_t
- n_send_elts : cs_halo_t
- n_send_fields : cs_cfd_sys_cplbc_t
- n_send_vals : cs_sys_cpl_t
- n_size : cs_atmo_chemistry_t
- n_sliding_faces : cs_cdo_bc_face_t
- n_smooth_agg : cs_param_amg_gamg_t
- n_source_terms : cs_equation_param_t
- n_species : cs_atmo_chemistry_t, cs_gas_mix_t
- n_species_profiles : cs_atmo_chemistry_t
- n_species_solved : cs_gas_mix_t
- n_stat_classes : cs_lagr_model_t
- n_std_send_blocks : cs_halo_t
- n_stored_directions : cs_param_saddle_context_block_krylov_t
- n_structures : cs_inflow_sem_t
- n_sub : fvm_to_histogram_writer_t
- n_sys_elts : cs_cfd_sys_cplbc_t
- n_tab_points : cs_coal_model_t, cs_combustion_gas_model_t
- n_temperature_layers : cs_lagr_model_t
- n_th_leaves : cs_join_stats_t
- n_threads : cs_numbering_t
- n_time_vals : cs_field_t, cs_lagr_attribute_map_t
- n_tracers : cs_gwf_tracer_decay_chain_t
- n_transforms : cs_halo_t, cs_mesh_t
- n_up_iter : cs_param_amg_boomer_t, cs_param_amg_gamg_t, cs_param_amg_hmg_t, cs_param_amg_inhouse_t
- n_user_variables : cs_lagr_model_t
- n_vals : cs_io_sec_header_t
- n_vc : cs_cell_mesh_t
- n_velocity_bc_defs : cs_navsto_param_t
- n_velocity_ic_defs : cs_navsto_param_t
- n_version_strings_func : fvm_writer_format_t
- n_vertices : fvm_nodal_t, cs_cdo_connect_t, cs_cdo_quantities_t, cs_mesh_extrude_vectors_t, cs_mesh_t
- n_vf : cs_face_mesh_light_t, cs_face_mesh_t
- n_volume_mass_injections : cs_equation_param_t
- n_volume_zones : cs_internal_coupling_t
- n_vtx : cs_medcoupling_mesh_t
- n_z_profiles : cs_atmo_chemistry_t
- n_zones : cs_lagr_zone_data_t
- name : cs_ctwr_zone_t, cs_property_t, cs_tree_node_t, fvm_nodal_t, fvm_writer_t, cs_adv_field_t, cs_at_opt_interp_t, cs_boundary_zone_t, cs_equation_param_t, cs_equation_system_param_t, cs_field_t, cs_function_t, cs_gui_boundary_meg_context_t, cs_gwf_tracer_decay_chain_t, cs_ibm_object_t, cs_interpol_grid_t, cs_measures_set_t, cs_meg_xdef_input_t, cs_param_saddle_t, cs_param_sles_t, cs_stl_mesh_t, cs_volume_zone_t, cs_zone_t, fvm_to_ensight_case_file_info_t, fvm_to_histogram_writer_t, fvm_writer_format_t
- nb_cut_cells : cs_ibm_t
- nb_cut_faces : cs_ibm_t
- nb_measures : cs_measures_set_t
- nb_measures_max : cs_measures_set_t
- nb_points : cs_interpol_grid_t
- nb_sources : cs_porosity_from_scan_opt_t
- nb_times : cs_at_opt_interp_t
- nbelec : cs_data_joule_effect_t
- nbmaxt : cs_atmo_option_t
- nbmetd : cs_atmo_option_t
- nbmetm : cs_atmo_option_t
- nbmett : cs_atmo_option_t
- nbprec : cs_lagr_precipitation_model_t
- nbrclas : cs_lagr_precipitation_model_t
- nbtrf : cs_data_joule_effect_t
- nch : cs_coal_model_t
- ncharb : cs_lagr_extra_module_t
- ncharm : cs_lagr_extra_module_t
- ncharm2 : cs_lagr_const_dim_t
- nck : cs_coal_model_t
- nclacp : cs_coal_model_t
- ndircl : var_cal_opt, cs_equation_param_t
- ndirec : cs_rad_transfer_params_t
- ndirs : cs_rad_transfer_params_t
- ndlaim : cs_lagr_const_dim_t
- ndrop_met : cs_atmo_option_t
- need_compute : cs_wall_distance_options_t
- need_eigen : cs_property_data_t
- need_flexible : cs_param_sles_t
- need_tensor : cs_property_data_t
- needs_tesselation_func : fvm_writer_format_t
- neu_values : cs_cell_sys_t
- new_to_old : cs_medcoupling_mesh_t
- next : cs_tree_node_t, fvm_writer_section_t
- nfpt1d : cs_1d_wall_thermal_t
- nfpt1t : cs_1d_wall_thermal_t
- nhmg_dir_ids : cs_cdo_bc_face_t
- nhmg_neu_ids : cs_cdo_bc_face_t
- nki : cs_combustion_gas_model_t
- nl_algo : cs_gwf_tpf_t, cs_solidification_voller_t
- nl_algo_type : cs_gwf_tpf_t, cs_navsto_param_t, cs_solidification_voller_t
- nl_algo_verbosity : cs_gwf_tpf_t
- nl_cvg_param : cs_gwf_tpf_t, cs_navsto_param_t
- nlayer : cs_lagr_const_dim_t
- nlibvar : cs_combustion_gas_model_t
- nmxt1d : cs_1d_wall_thermal_t
- nombrd : cs_lagr_boundary_interactions_t
- nor : cs_lagr_time_step_t
- normalization : cs_iter_algo_aac_t, cs_iter_algo_default_t
- noxyd : cs_coal_model_t
- npencr : cs_lagr_encrustation_t
- npm : cs_combustion_gas_model_t
- npoc : cs_coal_model_t
- nppt1d : cs_1d_wall_thermal_local_model_t
- npstf : cs_lagr_boundary_interactions_t
- npstft : cs_lagr_boundary_interactions_t
- npts : cs_lagr_source_terms_t
- nrphas : cs_rad_transfer_params_t
- nsec : cs_timer_counter_t, cs_timer_t
- nsolid : cs_coal_model_t
- nstist : cs_lagr_stat_options_t
- nstits : cs_lagr_source_terms_t
- nswrgr : var_cal_opt, cs_equation_param_t
- nswrsm : var_cal_opt, cs_equation_param_t
- nt : fvm_to_histogram_writer_t
- nt_cur : cs_time_step_t
- nt_ini : cs_time_step_t
- nt_max : cs_time_step_t
- nt_prev : cs_time_step_t
- nt_step_profiles : cs_atmo_chemistry_t
- ntdcla : cs_elec_option_t
- nterup : cs_velocity_pressure_param_t
- ntfref : cs_data_joule_effect_t
- ntxerr : cs_lagr_source_terms_t
- nucleation_model : cs_atmo_option_t
- num : cs_ctwr_zone_t, cs_join_param_t
- num_dom : fvm_nodal_t
- num_shift : fvm_writer_section_t
- numeric : cs_thermal_system_t
- nusbrd : cs_lagr_const_dim_t
- nwsgg : cs_rad_transfer_params_t
- nxr : cs_combustion_gas_model_t
- nzm : cs_combustion_gas_model_t
- nzvar : cs_combustion_gas_model_t
