cs_equation_system_t Struct Reference
Main structure to handle a set of coupled equations. More...
#include <cs_equation_system.h>
Collaboration diagram for cs_equation_system_t:
Data Fields
Metadata
cs_equation_system_param_tparam
cs_timer_counter_t timer
int timer_id
Structure of the system of equations
cs_cdo_system_helper_tsystem_helper
void * context
Diagonal block (equations)
int n_equations
cs_equation_t ** equations
Crossed terms
The setting of each block relies on the cs_equation_param_t structure. The cs_equation_param_t structures related to the diagonal blocks are shared with the cs_equation_t structures in the "equations" member and thus not owned by the current structure. The extra-diagonal blocks dealing with the crossed terms (i.e. the coupling between variables) are owned by this structure.
By default, there is no crossed term (i.e. params[1] = nullptr)
The same rationale applies to builder structures and scheme context structures. All these structures are contained in the structure cs_equation_core_t to avoid manipulating void ** structures
cs_equation_core_t ** block_factories
Pointer to functions
cs_equation_system_define_tdefine
cs_equation_system_free_tfree
cs_equation_system_solve_tsolve_system
cs_equation_system_solve_tsolve_steady_state_system
Field Documentation
◆ block_factories
cs_equation_core_t** block_factories
Matrix of cs_equation_core_t structures. The size of the matrix is n_equations (stored as an array of size n_equations^2). These structures enable to build and solve the system of equations.
◆ context
void* context
pointer to a structure cast on-the-fly which depends on the numerical scheme
◆ define
Initialize builder and scheme context structures. Pointer of function given by the prototype cs_equation_system_init_structures_t
◆ equations
cs_equation_t** equations
Array of pointer to the equations constituting the coupled system. These equations correspond to the each row and the cs_equation_param_t associated to an equation corresponds to the setting of the diagonal block.
◆ free
Free builder and scheme context structures. Pointer of function given by the prototype cs_equation_system_free_context_t
◆ n_equations
int n_equations
Number of coupled equations (> 1) composing the system
◆ param
Set of parameters to specify the settings of the system of equations
◆ solve_steady_state_system
cs_equation_system_solve_t* solve_steady_state_system
Solve the system of equations (steady-state case). Pointer of function given by the generic prototype cs_equation_system_solve_t
◆ solve_system
Solve the system of equations (unsteady case). Pointer of function given by the generic prototype cs_equation_system_solve_t
◆ system_helper
cs_cdo_system_helper_t* system_helper
Set of structures to define the system of equations (rhs, matrix or matrices, range sets, interface sets, etc.)
◆ timer
Cumulated elapsed time
◆ timer_id
int timer_id
Id of the timer statistics
