Set of parameters to check the convergence (or the divergence) of an iterative process (tolerances or max. number of iterations) More...
#include <cs_param_types.h>
Data Fields | |
double | atol |
double | rtol |
double | dtol |
int | n_max_iter |
double atol |
Absolute tolerance under which the iterative process is stopped
double dtol |
Tolerance above which the iterative process is stated as "diverged". Not used if < 0
int n_max_iter |
Maximal number of iterations before stopping the iterative process
double rtol |
Relative tolerance under which the iterative process is stopped
