cs_cell_mesh_t Struct Reference
Set of local quantities and connectivities related to a mesh cell. More...
#include <cs_cdo_local.h>
Collaboration diagram for cs_cell_mesh_t:
Data Fields
cs_eflag_t flag
fvm_element_t type
short int n_max_vbyc
short int n_max_ebyc
short int n_max_fbyc
cs_lnum_t c_id
cs_real_3_t xc
double vol_c
double diam_c
short int n_vc
cs_lnum_tv_ids
double * xv
double * wvc
short int n_ec
cs_lnum_te_ids
cs_quant_tedge
cs_nvec3_tdface
cs_real_tpvol_e
short int n_fc
cs_lnum_t bface_shift
cs_lnum_tf_ids
short int * f_sgn
double * f_diam
double * hfc
cs_quant_tface
cs_nvec3_tdedge
cs_real_tpvol_f
short int * e2v_ids
short int * e2v_sgn
short int * f2v_idx
short int * f2v_ids
short int * f2e_idx
short int * f2e_ids
short int * f2e_sgn
double * tef
short int * e2f_ids
cs_nvec3_tsefc
This is a key structure for all cellwise processes. This structure belongs to one thread and only. This structure used allows one to get a better memory locality. It maps the existing global mesh and other related structures into a more compact one dedicated to a cell. Arrays are allocated to the max number of related entities (e.g. n_max_vbyc or to n_max_ebyc). The cell-wise numbering is based on the c2v, c2e and c2f connectivity.
Field Documentation
◆ bface_shift
shift to get the boundary face numbering
◆ c_id
cs_lnum_t c_id
id of related cell
◆ dedge
cs_nvec3_t* dedge
dual edge quantities (length + unit vector)
◆ dface
cs_nvec3_t* dface
dual face quantities (area and unit normal)
◆ diam_c
double diam_c
diameter of the current cell
◆ e2f_ids
short int* e2f_ids
cell-wise edge -> faces connectivity
◆ e2v_ids
short int* e2v_ids
cell-wise edge->vertices connectivity
◆ e2v_sgn
short int* e2v_sgn
cell-wise edge->vertices orientation (-1 or +1)
◆ e_ids
cs_lnum_t* e_ids
edge ids on this rank
◆ edge
cs_quant_t* edge
edge quantities (xe, length and unit vector)
◆ f2e_ids
short int* f2e_ids
cellwise face->edges ids (size 2*n_max_ebyc)
◆ f2e_idx
short int* f2e_idx
cellwise face->edges connectivity (size n_fc+1)
◆ f2e_sgn
short int* f2e_sgn
cellwise face->edges orientation (-1 or +1)
◆ f2v_ids
short int* f2v_ids
size 2*n_max_ebyc
◆ f2v_idx
short int* f2v_idx
size n_fc + 1
◆ f_diam
double* f_diam
diameters of local faces
◆ f_ids
cs_lnum_t* f_ids
face ids on this rank
◆ f_sgn
short int* f_sgn
incidence number between f and c
◆ face
cs_quant_t* face
face quantities (xf, area and unit normal)
◆ flag
cs_eflag_t flag
indicate which quantities have to be computed
◆ hfc
double* hfc
height of the pyramid of basis f and apex c
◆ n_ec
short int n_ec
number of edges in a cell
◆ n_fc
short int n_fc
number of faces in a cell
◆ n_max_ebyc
◆ n_max_fbyc
◆ n_max_vbyc
◆ n_vc
short int n_vc
number of vertices in a cell
◆ pvol_e
cs_real_t* pvol_e
volume associated to an edge in the cell
◆ pvol_f
cs_real_t* pvol_f
volume associated to a face in the cell
◆ sefc
cs_nvec3_t* sefc
portion of dual faces (2 triangles by edge)
◆ tef
double* tef
area of the triangle of base |e| and apex xf
◆ type
type of element related to this cell
◆ v_ids
cs_lnum_t* v_ids
vertex ids on this rank
◆ vol_c
double vol_c
volume of the current cell
◆ wvc
double* wvc
weight |dualvol(v) cap vol_c|/|vol_c|, size: n_vc
◆ xc
coordinates of the cell center
◆ xv
double* xv
local vertex coordinates (copy)
