cs_1d_wall_thermal_local_model_t Struct Reference
#include <cs_1d_wall_thermal.h>
Collaboration diagram for cs_1d_wall_thermal_local_model_t:
Data Fields
int nppt1d
int iclt1d
cs_real_t eppt1d
cs_real_t rgpt1d
cs_real_t tept1d
cs_real_t hept1d
cs_real_t fept1d
cs_real_t xlmbt1
cs_real_t rcpt1d
cs_real_t dtpt1d
cs_real_tz
cs_real_tt
1D wall thermal module parameters and variables for each coupled face.
Field Documentation
◆ dtpt1d
cs_real_t dtpt1d
Physical time step associated with the solved 1D equation of the pseudo wall (which can be different from the time step of the calculation).
◆ eppt1d
cs_real_t eppt1d
Thickness of the 1D wall for the nfpt1d boundary faces which are coupled with a 1D wall thermal module.
◆ fept1d
cs_real_t fept1d
External heat flux in the pseudo wall under the flux conditions (in $W.m^{-2}$, negative value for energy entering the wall).
◆ hept1d
cs_real_t hept1d
External coefficient of transfer in the pseudo wall under Dirichlet conditions, (in $W.m^{-2}.K$).
◆ iclt1d
int iclt1d
Boundary condition type at the external (pseudo) wall:
  • 1: Dirichlet,
  • 2: Flux condition.
◆ nppt1d
int nppt1d
Number of discretisation cells in the 1D wall for the nfpt1d boundary faces which are coupled with a 1D wall thermal module.
◆ rcpt1d
cs_real_t rcpt1d
Volumetric heat capacity rho C_p of the wall uniform in thickness ( $J.m^{-3}.K^{-1}$).
◆ rgpt1d
cs_real_t rgpt1d
Geometry of the pseudo wall mesh (refined as a fluid if rgt1d is smaller than 1.
◆ t
Temperature at each point of discretization.
◆ tept1d
cs_real_t tept1d
External temperature of the pseudo wall in the Dirichlet case.
◆ xlmbt1
cs_real_t xlmbt1
Thermal diffusivity.
◆ z
Discretization points coordinates.
