#include <cs_combustion_gas.h>
Gas combustion model parameters structure
| double cebu |
Eddy-break-up constant (EBU)
| cs_field_t* ckabs |
| double ckabsg[CS_COMBUSTION_GAS_MAX_GLOBAL_SPECIES] |
absorption coefficient of global species
mass fraction conversion coefficients from global species to elementary species
| double coeff_therm[7][2][5] |
Burke-Schumann parameters
mole fraction conversion coefficients from global species to elementary species
| cs_field_t* coyfp |
| double cp_gas_g[CS_COMBUSTION_GAS_MAX_TABULATION_POINTS][CS_COMBUSTION_GAS_MAX_GLOBAL_SPECIES] |
cpgasg[j][i] is the massic calorific capacity (J/kg/K) of the i-th global species at temperature
| char* data_file_name |
| double eh_gas_g[CS_COMBUSTION_GAS_MAX_TABULATION_POINTS][CS_COMBUSTION_GAS_MAX_GLOBAL_SPECIES] |
massic enthalpy (J/kg) of the i-th global secies at temperature th(j)
| cs_real_t* flamelet_library_p |
pointer to flamelet library
| char flamelet_species_name[CS_COMBUSTION_GAS_MAX_GLOBAL_SPECIES][13] |
flamelet species names
| cs_field_t* fm |
| cs_field_t* fp2m |
| double frmel |
constant mixture fraction (EBU only)
| double fs[CS_COMBUSTION_GAS_MAX_GLOBAL_REACTIONS] |
mixing rate at the stoichiometry
| cs_field_t* fsm |
| cs_field_t* fsqm |
| double hinfue |
input mass enthalpy for fuel
| double hinoxy |
input mass enthalpy for the oxidant
| cs_field_t* hrr |
| int ientgb |
burned gas indicator (EBU and LW only)
| int ientgf |
fresh gas indicator (EBU and LW only)
| int iic |
use NIST-JANAF tables for enthalpy/temperature conversion rank of C in gas composition (base 1)
| int iico2 |
rank of CO2 in gas composition (base 1)
| int iio2 |
rank of O2 in gas composition (base 1)
| int ikimid |
Index (1-based) for flamelet on middle branch
| int isoot |
soot production modeling flag
| double lsp_fuel |
laminar smoke point length
Libby Williams parameters
| int mode_fp2m |
Mixture fraction variance computation mode:
| int n_atomic_species |
number of atomic species
| int n_gas_el_comp |
number of elementary gas components
| int n_gas_fl |
Steady flamelet model parameters number of species in flamelet library YFUE YOXY YCO2 YH2O YCO YH2
| int n_gas_species |
number of global species
| int n_reactions |
number of global reactions in gas phase
| int n_tab_points |
number of tabulation points
| int nki |
number of flamelets (strain rate)
| int nlibvar |
number of variables in library
| cs_field_t* npm |
| int nxr |
discretization of enthalpy defect
| int nzm |
discretization of mixture fraction
| int nzvar |
discretization of variance
| cs_field_t* omgc |
| double oxyco2[CS_COMBUSTION_GAS_MAX_OXYDANTS] |
composition of CO2 oxidants
| double oxyh2o[CS_COMBUSTION_GAS_MAX_OXYDANTS] |
composition of H2O oxidants
| double oxyn2[CS_COMBUSTION_GAS_MAX_OXYDANTS] |
composition of N2 oxidants
| double pcigas |
combustible reaction enthalpy (Lower Calorific Value)
| cs_field_t* pvm |
| cs_field_t* recvr |
| double rosoot |
soot density
| double srrom |
sub-relaxation coefficient for the density:
| cs_field_t* t2m |
| cs_field_t* t3m |
| cs_field_t* t4m |
| double tgf |
fresh gas temperature (EBU and LW only)
| double th[CS_COMBUSTION_GAS_MAX_TABULATION_POINTS] |
temperature in K
| double tinfue |
input temperature for fuel en K
| double tinoxy |
input temperature for oxydant
| cs_field_t* totki |
combustion model type
| bool use_janaf |
| double wmolat[CS_COMBUSTION_GAS_MAX_ATOMIC_SPECIES] |
molar mass of atomic species
| double wmole[CS_COMBUSTION_GAS_MAX_ELEMENTARY_COMPONENTS] |
molar mass of an elementary gas component
| double wmolg[CS_COMBUSTION_GAS_MAX_GLOBAL_SPECIES] |
molar mass of global species
| double xco2 |
molar coefficient of CO2
| double xh2o |
molar coefficient of H2O
| cs_field_t* xr |
| double xsoot |
soot fraction production (isoot = 0)
| cs_field_t* yfm |
| cs_field_t* yfp2m |
| cs_field_t* ygfm |
