#include <cs_iter_algo.h>
Data Fields | |
cs_sles_convergence_state_t | cvg_status |
double | normalization |
double | tol |
double | prev_res |
double | res |
double | res0 |
int | n_algo_iter |
int | n_inner_iter |
int | last_inner_iter |
cs_sles_convergence_state_t cvg_status |
Converged, iterating or diverged status
int last_inner_iter |
Last number of iterations for the inner solver
int n_algo_iter |
Current number of iterations for the algorithm
int n_inner_iter |
Curent cumulated number of inner iterations (sum over the outer iterations)
double normalization |
Value of the normalization for the relative tolerance.
The stopping criterion is such that res < rtol * normalization. By default, the normalization is set to 1.
double prev_res |
Value of the previous residual achieved during the iterative process
double res |
Value of the residual for the iterative algorithm
double res0 |
Value of the first residual of the iterative process. This is used for detecting the divergence of the algorithm.
double tol |
Tolerance computed as tol = max(atol, normalization*rtol) where atol and rtol are respectively the absolute and relative tolerance associated to the algorithm
