cs_face_mesh_t Struct Reference
Set of local quantities and connectivities related to a mesh face Structure used to get a better memory locality. Map existing structure into a more compact one dedicated to a face. Arrays are allocated to n_max_vbyf (= n_max_ebyf). Face-wise numbering is based on the f2e connectivity. More...
#include <cs_cdo_local.h>
Collaboration diagram for cs_face_mesh_t:
Data Fields
short int n_max_vbyf
cs_lnum_t c_id
cs_real_3_t xc
cs_lnum_t f_id
short int f_sgn
cs_quant_t face
cs_nvec3_t dedge
double pvol
double hfc
short int n_vf
cs_lnum_tv_ids
double * xv
double * wvf
short int n_ef
cs_lnum_te_ids
cs_quant_tedge
double * tef
short int * e2v_ids
Field Documentation
◆ c_id
cs_lnum_t c_id
id of related cell
◆ dedge
cs_nvec3_t dedge
its dual edge quantities (length and unit vector)
◆ e2v_ids
short int* e2v_ids
face-wise edge -> vertices connectivity
◆ e_ids
cs_lnum_t* e_ids
edge ids (in the mesh or cellwise numbering)
◆ edge
cs_quant_t* edge
edge quantities (xe, length and unit vector)
◆ f_id
cs_lnum_t f_id
local mesh face id
◆ f_sgn
short int f_sgn
incidence number between f and c
◆ face
cs_quant_t face
face quantities (xf, area and unit normal)
◆ hfc
double hfc
height of the pyramid of base f and apex x_c
◆ n_ef
short int n_ef
local number of edges in on this face (= n_vf)
◆ n_max_vbyf
= n_max_ebyf
◆ n_vf
short int n_vf
local number of vertices on this face
◆ pvol
double pvol
volume of the pyramid of base f and apex x_c
◆ tef
double* tef
area of the triangle of base e and apex xf
◆ v_ids
cs_lnum_t* v_ids
vertex ids (in the mesh or cellwise numbering)
◆ wvf
double* wvf
weight related to each vertex
◆ xc
pointer to the coordinates of the cell center
◆ xv
double* xv
local vertex coordinates (copy)
