Here is a list of all variables with links to the structures/unions they belong to:
- i -
- i : cs_cdo_assembly_row_t
- i_dist : cs_cdo_quantities_t, cs_mesh_quantities_t
- i_f_face_factor : cs_mesh_quantities_t
- i_face_cells : cs_mesh_t
- i_face_center : cs_cdo_quantities_t
- i_face_cog : cs_mesh_quantities_t
- i_face_family : cs_mesh_t
- i_face_normal : cs_cdo_quantities_t, cs_mesh_quantities_t
- i_face_numbering : cs_mesh_t
- i_face_r_gen : cs_mesh_t
- i_face_surf : cs_cdo_quantities_t, cs_mesh_quantities_t
- i_face_u_normal : cs_cdo_quantities_t, cs_mesh_quantities_t
- i_face_vtx_connect_size : cs_mesh_t
- i_face_vtx_idx : cs_mesh_t
- i_face_vtx_lst : cs_mesh_t
- i_face_zone_id : cs_lagr_internal_condition_t
- i_les_balance : cs_les_balance_t
- i_quadrature : cs_rad_transfer_params_t
- iadded_mass : cs_lagr_time_scheme_t
- iash : cs_coal_model_t
- iautom : cs_boundary_condition_pm_info_t
- ibcarbone : cs_coal_model_t
- ibdtso : var_cal_opt, cs_equation_param_t
- ibhydrogen : cs_coal_model_t
- iboxygen : cs_coal_model_t
- ibrpr : cs_data_joule_effect_t
- ibrsec : cs_data_joule_effect_t
- ic_defs : cs_equation_param_t
- icalhy : cs_velocity_pressure_param_t
- iccvfg : cs_time_scheme_t
- icfgrp : cs_cf_model_t
- ich : cs_coal_model_t
- ichcor : cs_coal_model_t
- ichx1 : cs_coal_model_t
- ichx1c : cs_coal_model_t
- ichx2 : cs_coal_model_t
- ichx2c : cs_coal_model_t
- ick : cs_coal_model_t
- iclgst : cs_lagr_boundary_interactions_t
- iclkep : cs_turb_rans_model_t
- iclogh : cs_lagr_boundary_interactions_t
- iclogt : cs_lagr_boundary_interactions_t
- iclptr : cs_turb_rans_model_t
- iclsyr : cs_turb_rans_model_t
- iclt1d : cs_1d_wall_thermal_local_model_t
- icm : cs_join_param_t
- icnohc : cs_coal_model_t
- icnonh : cs_coal_model_t
- icnorb : cs_coal_model_t
- ico : cs_coal_model_t
- ico2 : cs_coal_model_t
- icodcl : cs_field_bc_coeffs_t
- iconsol : cs_lagr_consolidation_model_t
- iconv : var_cal_opt, cs_equation_param_t
- icorio : cs_physical_constants_t
- icoupl : var_cal_opt, cs_equation_param_t
- icp : cs_fluid_properties_t, cs_lagr_extra_module_t
- icv : cs_fluid_properties_t
- icvevm : cs_cavitation_parameters_t
- id : cs_equation_t, cs_property_t, cs_gwf_soil_t, cs_adv_field_t, cs_at_opt_interp_t, cs_boundary_zone_t, cs_cdo_system_block_t, cs_double_int_t, cs_field_t, cs_function_t, cs_gwf_tracer_decay_chain_t, cs_internal_coupling_t, cs_interpol_grid_t, cs_measures_set_t, cs_volume_zone_t, cs_zone_t
- id_eps : cs_atmo_imbrication_t
- id_nc : cs_atmo_imbrication_t
- id_qw : cs_atmo_imbrication_t
- id_theta : cs_atmo_imbrication_t
- id_tke : cs_atmo_imbrication_t
- id_u : cs_atmo_imbrication_t
- id_v : cs_atmo_imbrication_t
- idften : var_cal_opt, cs_equation_param_t
- idiam2 : cs_coal_model_t
- idiff : var_cal_opt, cs_equation_param_t
- idiffl : cs_lagr_model_t
- idifft : var_cal_opt, cs_equation_param_t
- idilat : cs_velocity_pressure_model_t
- idircl : var_cal_opt, cs_equation_param_t
- idirsm : cs_turb_rans_model_t
- idistu : cs_lagr_model_t
- idiver : cs_rad_transfer_params_t
- idpvar : cs_lagr_specific_physics_t
- idreca : cs_elec_option_t
- idries : cs_turb_les_model_t
- idrift : cs_coal_model_t, cs_vof_parameters_t
- ids : cs_adjacency_t, cs_cell_builder_t
- idstnt : cs_lagr_stat_options_t
- idtvar : cs_time_step_options_t
- idx : cs_adjacency_t
- ielcor : cs_elec_option_t
- ielecb : cs_data_joule_effect_t
- ielecc : cs_data_joule_effect_t
- ielect : cs_data_joule_effect_t
- iencra : cs_lagr_encrustation_t
- ientat : cs_coal_bc_inlet_t
- ientcp : cs_coal_bc_inlet_t
- ientfu : cs_combustion_bc_inlet_t
- ientgb : cs_combustion_bc_inlet_t, cs_combustion_gas_model_t
- ientgf : cs_combustion_bc_inlet_t, cs_combustion_gas_model_t
- ientox : cs_combustion_bc_inlet_t
- ieos : cs_cf_model_t
- ieqco2 : cs_coal_model_t
- ieqnox : cs_coal_model_t
- if1m : cs_coal_model_t
- if2m : cs_coal_model_t
- if2v : cs_cdo_connect_t
- if4m : cs_coal_model_t
- if5m : cs_coal_model_t
- if6m : cs_coal_model_t
- if7m : cs_coal_model_t
- if8m : cs_coal_model_t
- if9m : cs_coal_model_t
- ifgrno : cs_rad_transfer_params_t
- ifhcnc : cs_coal_model_t
- ifhcnd : cs_coal_model_t
- ifhcnr : cs_coal_model_t
- ifinfe : cs_rad_transfer_params_t
- iflow : cs_lagr_reentrained_model_t
- iflxmw : cs_space_disc_t
- ifnh3c : cs_coal_model_t
- ifnh3d : cs_coal_model_t
- ifnoch : cs_coal_model_t
- ifnohc : cs_coal_model_t
- ifnonh : cs_coal_model_t
- ifnoth : cs_coal_model_t
- ifpt1d : cs_1d_wall_thermal_t
- ifrefl : cs_rad_transfer_params_t
- ifs : cs_range_set_t
- ifvp2m : cs_coal_model_t
- ig_id : cs_at_opt_interp_t
- ighcn1 : cs_coal_model_t
- ighcn2 : cs_coal_model_t
- ighco2 : cs_coal_model_t
- ighh2o : cs_coal_model_t
- igmdch : cs_coal_model_t
- igmdv1 : cs_coal_model_t
- igmdv2 : cs_coal_model_t
- igmhet : cs_coal_model_t
- igmsec : cs_coal_model_t
- igmtr : cs_coal_model_t
- ignh31 : cs_coal_model_t
- ignh32 : cs_coal_model_t
- ignoth : cs_coal_model_t
- igprij : cs_velocity_pressure_param_t
- igpust : cs_velocity_pressure_param_t
- igrb : cs_coal_model_t
- igrdpp : cs_velocity_pressure_param_t
- igrhok : cs_turb_rans_model_t
- ih2 : cs_coal_model_t
- ih2o : cs_coal_model_t
- ih2s : cs_coal_model_t
- ihcn : cs_coal_model_t
- ihdepm : cs_lagr_boundary_interactions_t
- ihdepv : cs_lagr_boundary_interactions_t
- ihdiam : cs_lagr_boundary_interactions_t
- ihgas : cs_coal_model_t
- ihox : cs_coal_model_t
- ihsum : cs_lagr_boundary_interactions_t
- ihtco2 : cs_coal_model_t
- ihth2o : cs_coal_model_t
- ihy : cs_coal_model_t
- iic : cs_combustion_gas_model_t
- iicc : cs_turb_hybrid_model_t
- iico2 : cs_combustion_gas_model_t
- iifren : cs_velocity_pressure_param_t
- iilagr : cs_lagr_time_scheme_t
- iimpar : cs_rad_transfer_params_t
- iio2 : cs_combustion_gas_model_t
- ikecou : cs_turb_rans_model_t
- ikimid : cs_combustion_gas_model_t
- ikwcln : cs_turb_rans_model_t
- ilapoi : cs_lagr_time_scheme_t
- im : cs_cfd_sys_cplbc_t
- imbrication_flag : cs_atmo_imbrication_t
- imbrication_verbose : cs_atmo_imbrication_t
- imdnox : cs_coal_model_t
- imfsck : cs_rad_transfer_params_t
- imgrey : cs_rad_transfer_params_t
- imligr : var_cal_opt, cs_equation_param_t
- immel : cs_coal_model_t
- imoadf : cs_rad_transfer_params_t
- impale : cs_ale_data_t
- impvar : cs_lagr_specific_physics_t
- imrcfsk : cs_rad_transfer_params_t
- imrgra : var_cal_opt, cs_equation_param_t, cs_space_disc_t
- imvisf : var_cal_opt, cs_equation_param_t, cs_space_disc_t
- in2 : cs_coal_model_t
- inbr : cs_lagr_boundary_interactions_t
- inclg : cs_lagr_boundary_interactions_t
- inclgt : cs_lagr_boundary_interactions_t
- increment : cs_equation_builder_t
- incremental_algo : cs_equation_builder_t
- incremental_algo_cvg : cs_equation_param_t
- incremental_algo_type : cs_equation_param_t
- incremental_anderson_param : cs_equation_param_t
- incremental_relax_factor : cs_equation_param_t
- incremental_solve : cs_equation_system_param_t
- index : cs_halo_t
- index_id : cs_io_sec_header_t
- inf_radius : cs_measures_set_t
- info : cs_cdo_system_block_t
- info_mask : fvm_writer_format_t
- infrared_1D_profile : cs_atmo_option_t
- inh3 : cs_coal_model_t
- init_aero_with_lib : cs_atmo_chemistry_t
- init_context : cs_equation_t, cs_turbulence_t
- init_field_values : cs_equation_t
- init_func : fvm_writer_format_t
- init_gas_with_lib : cs_atmo_chemistry_t
- init_pressure : cs_navsto_system_t
- init_scheme_context : cs_navsto_system_t
- init_setup : cs_gwf_tracer_t
- init_sles : cs_saddle_solver_context_alu_t, cs_saddle_solver_context_gkb_t, cs_saddle_solver_context_simple_t, cs_saddle_solver_context_uzawa_cg_t
- init_sles_param : cs_param_saddle_context_alu_t, cs_param_saddle_context_gkb_t, cs_param_saddle_context_simple_t, cs_param_saddle_context_uzacg_t
- init_step : cs_equation_builder_t
- init_vals_defs : cs_ibm_object_t
- init_velocity : cs_navsto_system_t
- injection_frequency : cs_lagr_injection_set_t
- injection_profile_func : cs_lagr_injection_set_t
- injection_profile_input : cs_lagr_injection_set_t
- injection_set : cs_lagr_zone_data_t
- inlet_faces_ids : cs_ctwr_zone_t
- inmoxy : cs_coal_bc_inlet_t
- inner_potential_flux : cs_pressure_correction_cdo_t
- inp : cs_coal_model_t
- input : cs_xdef_analytic_context_t, cs_xdef_dof_context_t, cs_xdef_time_func_context_t
- input_zone_id : cs_cfd_sys_cplbc_t
- int_field_id : cs_adv_field_t
- integrate : cs_gwf_tracer_t
- interface_set : cs_cdo_system_dblock_t, cs_cdo_system_nblock_t, cs_cdo_system_ublock_t, cs_cdo_system_xblock_t
- interior_faces_group_name : cs_internal_coupling_t
- interlaced : cs_cdo_system_block_info_t
- interleaved : cs_measures_set_t
- interp_algo : cs_param_amg_boomer_t
- interp_type : cs_at_opt_interp_t
- interpol_field : cs_lagr_time_scheme_t
- interval_nt : cs_time_control_t
- interval_t : cs_time_control_t
- inv_kp : cs_solidification_binary_alloy_t
- inv_kpm1 : cs_solidification_binary_alloy_t
- inv_m : cs_gwf_soil_vgm_tpf_param_t
- inv_m22 : cs_saddle_solver_context_alu_t, cs_saddle_solver_context_gkb_t, cs_saddle_solver_context_simple_t, cs_saddle_solver_context_uzawa_cg_t
- inv_ml : cs_solidification_binary_alloy_t
- inv_pr_r : cs_gwf_soil_vgm_tpf_param_t
- inv_pty : cs_hodge_param_t
- invariant : cs_rotation_t
- io2 : cs_coal_model_t
- iochet : cs_coal_model_t
- ioetc2 : cs_coal_model_t
- ioetwt : cs_coal_model_t
- ionic_strength : cs_lagr_clogging_param_t, cs_lagr_dlvo_param_t, cs_lagr_roughness_param_t
- ipci : cs_coal_model_t
- ipgrno : cs_rad_transfer_params_t
- iphydr : cs_velocity_pressure_param_t
- iprcdo : cs_velocity_pressure_model_t
- iprco : cs_velocity_pressure_param_t
- ipredfl : cs_velocity_pressure_param_t
- iprefl : cs_rad_transfer_params_t
- ipthrm : cs_fluid_properties_t
- iptlro : cs_time_step_options_t
- ipucou : cs_velocity_pressure_param_t
- ir : cs_at_opt_interp_t
- ir_steps : cs_param_mumps_t
- irb : cs_coal_model_t
- irccor : cs_turb_rans_model_t
- ircflu : var_cal_opt, cs_equation_param_t
- irecmf : cs_velocity_pressure_param_t
- ireent : cs_lagr_reentrained_model_t
- irestrike : cs_elec_option_t
- irevmc : cs_velocity_pressure_param_t
- irijco : cs_turb_rans_model_t
- irijec : cs_turb_rans_model_t
- irijnu : cs_turb_rans_model_t
- irijrb : cs_turb_rans_model_t
- irom1 : cs_coal_model_t
- irom2 : cs_coal_model_t
- irovar : cs_fluid_properties_t
- is_connect : cs_interpol_grid_t
- is_cressman : cs_measures_set_t
- is_interpol : cs_measures_set_t
- is_iso : cs_property_data_t
- is_last_iter : cs_domain_t
- is_local : cs_time_step_t
- is_miscible : cs_gwf_tpf_t
- is_owner : cs_field_t, cs_xdef_array_context_t
- is_porous : cs_stl_mesh_t
- is_single : cs_param_mumps_t
- is_steady : cs_cdo_bc_face_t
- is_unity : cs_property_data_t
- is_up_to_date : cs_wall_distance_options_t
- is_variable : cs_time_step_t
- ischcv : var_cal_opt, cs_equation_param_t
- iscovc : cs_lagr_boundary_interactions_t
- ishield : cs_turb_hybrid_model_t
- isno2t : cs_time_scheme_t
- iso2 : cs_coal_model_t
- isoot : cs_combustion_gas_model_t
- isovol : cs_ibm_t
- isstpc : var_cal_opt, cs_equation_param_t
- istat : var_cal_opt, cs_equation_param_t
- istmpf : cs_time_scheme_t
- isto2t : cs_time_scheme_t
- isttio : cs_lagr_time_scheme_t
- isuila : cs_lagr_time_scheme_t
- isuist : cs_lagr_stat_options_t
- iswdyn : var_cal_opt, cs_equation_param_t
- itbrrb : cs_space_disc_t
- itemp2 : cs_coal_model_t
- iter : cs_solidification_binary_alloy_t
- itherm : cs_thermal_model_t
- ithvar : cs_cf_model_t
- itpcol : cs_velocity_pressure_param_t
- itpimp : cs_rad_transfer_params_t
- itpscl : cs_thermal_model_t
- itpt1d : cs_rad_transfer_params_t
- itpvar : cs_lagr_specific_physics_t
- itscvi : cs_cavitation_parameters_t
- iturb : cs_lagr_extra_module_t, cs_turb_model_t
- itycor : cs_turb_rans_model_t
- itytur : cs_lagr_extra_module_t, cs_turb_model_t
- iviscv : cs_fluid_properties_t
- ivisse : cs_velocity_pressure_model_t
- ivivar : cs_fluid_properties_t
- ivsuth : cs_fluid_properties_t
- iwalfs : cs_wall_functions_t
- iwallf : cs_wall_functions_t
- iwarni : var_cal_opt, cs_equation_param_t
- iwat : cs_coal_model_t
- iwgrec : var_cal_opt, cs_equation_param_t
- iwrp1t : cs_rad_transfer_params_t
- ix2 : cs_coal_model_t
- ixch : cs_coal_model_t
- ixck : cs_coal_model_t
- ixkabe : cs_elec_option_t
- ixwt : cs_coal_model_t
- ixyzp0 : cs_fluid_properties_t
- iy1ch : cs_coal_model_t
- iy2ch : cs_coal_model_t
- iyco2 : cs_coal_model_t
- iyhcn : cs_coal_model_t
- iym1 : cs_coal_model_t
- iynh3 : cs_coal_model_t
- iyno : cs_coal_model_t
- izfppp : cs_boundary_condition_pm_info_t
- izft1d : cs_1d_wall_thermal_t
- izreca : cs_elec_option_t
