Turbulence model general options descriptor.
More...
#include <cs_turbulence_model.h>
Members of this turbulence model are publicly accessible, to allow for concise syntax, as it is expected to be used in many places.
◆ [union]
◆ high_low_re
Order of the turbulence model:
- CS_TURB_ALGEBRAIC: 0th order algebraik model
- CS_TURB_FIRST_ORDER: 1st order Eddy Viscosity type models
- CS_TURB_SECOND_ORDER: 2nd order Differential Reynolds Stress type models
◆ hybrid_turb
Type of hybrid turbulence model
- 0: No model
- 1: Detached Eddy Simulation
- 2: Delayed Detached Eddy Simulation
- 3: Scale Adaptive Model (Menter et al.)
- 4. Hybrid Temporal LES
◆ iturb
turbulence model
- CS_TURB_NONE: no turbulence model (laminar flow)
- CS_TURB_MIXING_LENGTH: mixing length model
- CS_TURB_K_EPSILON: standard k-epsilon model
- CS_TURB_K_EPSILON_LIN_PROD: k-epsilon model with Linear Production (LP) correction
- CS_TURB_K_EPSILON_LS: Launder-Sharma low Re k-epsilon model
- CS_TURB_K_EPSILON_QUAD: Baglietto et al. low Re k epsilon model
- CS_TURB_RIJ_EPSILON_LRR: Rij-epsilon (LRR)
- CS_TURB_RIJ_EPSILON_SSG: Rij-epsilon (SSG)
- CS_TURB_RIJ_EPSILON_EBRSM: Rij-epsilon (EBRSM)
- CS_TURB_LES_SMAGO_CONST: LES (constant Smagorinsky model)
- CS_TURB_LES_SMAGO_DYN: LES ("classical" dynamic Smagorisky model)
- CS_TURB_LES_WALE: LES (WALE)
- CS_TURB_V2F_PHI: v2f phi-model
- CS_TURB_V2F_BL_V2K: v2f BL-v2-k
- CS_TURB_K_OMEGA: k-omega SST
- CS_TURB_SPALART_ALLMARAS: Spalart-Allmaras model
◆ itytur
class of turbulence model (integer value model/10, deprecated)
◆ model
◆ order
Type of turbulence modelling:
◆ type
Type of Hybrid Turbulence Model
