#include "base/cs_defs.h"#include <assert.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include <math.h>#include "bft/bft_error.h"#include "bft/bft_printf.h"#include "base/cs_assert.h"#include "base/cs_field.h"#include "base/cs_field_default.h"#include "base/cs_field_pointer.h"#include "base/cs_function.h"#include "alge/cs_gradient.h"#include "base/cs_log.h"#include "base/cs_log_iteration.h"#include "base/cs_math.h"#include "base/cs_mem.h"#include "mesh/cs_mesh.h"#include "base/cs_parall.h"#include "mesh/cs_mesh_location.h"#include "base/cs_time_step.h"#include "base/cs_wall_functions.h"#include "turb/cs_turbulence_model.h"Functions | |
| void | cs_turbulence_init_models (void) |
| Initialize additional turbulence model members of turbulence model and RANS model structure. | |
| cs_turb_model_t * | cs_get_glob_turb_model (void) |
| Provide write access to turbulence model structure. | |
| void | cs_set_glob_turb_model (void) |
| Set global pointer to turbulence model structure. | |
| void | cs_turb_compute_constants (int phase_id) |
| Compute turbulence model constants, some of which may depend on the model choice. | |
| cs_turb_ref_values_t * | cs_get_glob_turb_ref_values (void) |
| Provide access to cs_glob_turb_ref_values. | |
| cs_turb_rans_model_t * | cs_get_glob_turb_rans_model (void) |
| Provide access to cs_glob_turb_rans_model. | |
| cs_turb_les_model_t * | cs_get_glob_turb_les_model (void) |
| Provide access to cs_glob_turb_les_model. | |
| cs_turb_hybrid_model_t * | cs_get_glob_turb_hybrid_model (void) |
| Provide access to cs_glob_turb_hybrid_model. | |
| const char * | cs_turbulence_model_name (cs_turb_model_type_t id) |
| Return name string associated with a turbulence model value. | |
| void | cs_turb_model_log_setup (void) |
| Print the turbulence model parameters to setup.log. | |
| void | cs_turb_constants_log_setup (void) |
| Print the turbulent constants to setup.log. | |
| void | cs_turb_init_ref_quantities (void) |
| Compute characteristic length for turbulence if not already done. | |
| void | cs_clip_turbulent_fluxes (int flux_id, int variance_id) |
| Clipping for the turbulence flux vector. | |
| void | cs_turbulence_function_k (int location_id, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, void *input, void *vals) |
| Return or estimate the value of the turbulent kinetic energy over specified elements. | |
| void | cs_turbulence_function_eps (int location_id, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, void *input, void *vals) |
| Return or estimate the value of the turbulent dissipation over specified elements. | |
| void | cs_turbulence_function_rij (int location_id, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, void *input, void *vals) |
| Return or estimate the value of the Reynolds stresses over specified elements. | |
| double | cs_turb_xkappa = 0.42 |
| double | cs_turb_vdriest = 25.6 |
| double | cs_turb_cstlog = 5.2 |
| double | cs_turb_cstlog_rough = 8.5 |
| double | cs_turb_cstlog_alpha |
| double | cs_turb_apow = 8.3 |
| double | cs_turb_bpow = 1.0/7.0 |
| double | cs_turb_dpow = -1. |
| double | cs_turb_cmu = 0.09 |
| double | cs_turb_ce1 = 1.44 |
| double | cs_turb_ce2 = 1.92 |
| double | cs_turb_ce3 = 2.02 |
| double | cs_turb_ce4 = 1.20 |
| double | cs_turb_crij_eps = 1. |
| double | cs_turb_crij1 = 1.80 |
| double | cs_turb_crij2 = 0.60 |
| double | cs_turb_crij_c0 = 3.5 |
| double | cs_turb_crij_ct = 1. |
| double | cs_turb_crij3 = 0.55 |
| double | cs_turb_crijp1 = 0.50 |
| double | cs_turb_crijp2 = 0.30 |
| double | cs_turb_cssgs1 = 1.70 |
| double | cs_turb_cssgs2 = -1.05 |
| double | cs_turb_cssgr1 = 0.90 |
| double | cs_turb_cssgr2 = 0.80 |
| double | cs_turb_cssgr3 = 0.65 |
| double | cs_turb_cssgr4 = 0.625 |
| double | cs_turb_cssgr5 = 0.20 |
| double | cs_turb_cebms1 = 1.70 |
| double | cs_turb_cebms2 = 0. |
| double | cs_turb_cebmr1 = 0.90 |
| double | cs_turb_cebmr2 = 0.80 |
| double | cs_turb_cebmr3 = 0.65 |
| double | cs_turb_cebmr4 = 0.625 |
| double | cs_turb_cebmr5 = 0.20 |
| double | cs_turb_csrij |
| double | cs_turb_cebmmu = 0.22 |
| double | cs_turb_xcl = 0.122 |
| double | cs_turb_xa1 = 0.1 |
| double | cs_turb_xct = 6.0 |
| double | cs_turb_xceta = 80.0 |
| double | cs_turb_cpale1 = 1.44 |
| double | cs_turb_cpale2 = 1.83 |
| double | cs_turb_cpale3 = 2.3 |
| double | cs_turb_cpale4 = 0.4 |
| double | cs_turb_cpalc1 = 1.7 |
| double | cs_turb_cpalc2 = 0.9 |
| double | cs_turb_cpalct = 4.0 |
| double | cs_turb_cpalcl = 0.164 |
| double | cs_turb_cpalet = 75.0 |
| double | cs_turb_ckwsk1 = 1.0/0.85 |
| double | cs_turb_ckwsk2 = 1.0 |
| double | cs_turb_ckwsw1 = 2.0 |
| double | cs_turb_ckwsw2 = 1.0/0.856 |
| double | cs_turb_ckwbt1 = 0.075 |
| double | cs_turb_ckwbt2 = 0.0828 |
| double | cs_turb_ckwgm1 = -1. |
| double | cs_turb_ckwgm2 = -1. |
| double | cs_turb_ckwa1 = 0.31 |
| double | cs_turb_ckwc1 = 10.0 |
| double | cs_turb_cddes = 0.65 |
| double | cs_turb_csas = 0.11 |
| double | cs_turb_csas_eta2 = 3.51 |
| double | cs_turb_chtles_bt0 = 0.48 |
| double | cs_turb_csab1 = 0.1355 |
| double | cs_turb_csab2 = 0.622 |
| double | cs_turb_csasig = 2.0/3.0 |
| double | cs_turb_csav1 = 7.1 |
| double | cs_turb_csaw1 = -1. |
| double | cs_turb_csaw2 = 0.3 |
| double | cs_turb_csaw3 = 2.0 |
| double | cs_turb_cssr1 = 1.0 |
| double | cs_turb_cssr2 = 2.0 |
| double | cs_turb_cssr3 = 1.0 |
| double | cs_turb_ccaze2 = 1.83 |
| double | cs_turb_ccazsc = 0.119 |
| double | cs_turb_ccaza = 4.3 |
| double | cs_turb_ccazb = 5.130 |
| double | cs_turb_ccazc = 0.453 |
| double | cs_turb_ccazd = 0.682 |
| double | cs_turb_xlesfl = 2.0 |
| double | cs_turb_ales = 1.0 |
| double | cs_turb_bles = 1.0/3.0 |
| double | cs_turb_csmago = 0.065 |
| double | cs_turb_xlesfd = 1.5 |
| double | cs_turb_csmago_max = -1. |
| double | cs_turb_csmago_min = 0. |
| double | cs_turb_cdries = 26.0 |
| double | cs_turb_cv2fa1 = 0.05 |
| double | cs_turb_cv2fe2 = 1.85 |
| double | cs_turb_cv2fc1 = 1.4 |
| double | cs_turb_cv2fc2 = 0.3 |
| double | cs_turb_cv2fct = 6.0 |
| double | cs_turb_cv2fcl = 0.25 |
| double | cs_turb_cv2fet = 110.0 |
| double | cs_turb_cnl1 = 0.8 |
| double | cs_turb_cnl2 = 11. |
| double | cs_turb_cnl3 = 4.5 |
| double | cs_turb_cnl4 = 1e3 |
| double | cs_turb_cnl5 = 1. |
| double | cs_turb_cwale = 0.25 |
| double | cs_turb_xiafm = 0.7 |
| double | cs_turb_etaafm = 0.4 |
| double | cs_turb_c1trit = 4.15 |
| double | cs_turb_c2trit = 0.55 |
| double | cs_turb_c3trit = 0.5 |
| double | cs_turb_c4trit = 0. |
| double | cs_turb_cthafm = 0.236 |
| double | cs_turb_cthdfm = 0.31 |
| double | cs_turb_cthebdfm = 0.22 |
| double | cs_turb_xclt = 0.305 |
Base turbulence model data.
| void cs_clip_turbulent_fluxes | ( | int | flux_id, |
| int | variance_id ) |
| [in] | flux_id | turbulent flux index |
| [in] | variance_id | scalar variance index |
| cs_turb_hybrid_model_t * cs_get_glob_turb_hybrid_model | ( | void | ) |
needed to initialize structure with GUI
| cs_turb_les_model_t * cs_get_glob_turb_les_model | ( | void | ) |
| cs_turb_model_t * cs_get_glob_turb_model | ( | void | ) |
| cs_turb_rans_model_t * cs_get_glob_turb_rans_model | ( | void | ) |
| cs_turb_ref_values_t * cs_get_glob_turb_ref_values | ( | void | ) |
| void cs_set_glob_turb_model | ( | void | ) |
This global pointer provides a read-only access to the structure.
| void cs_turb_compute_constants | ( | int | phase_id | ) |
| [in] | phase_id | turbulent phase id (-1 for single phase flow) |
| void cs_turb_constants_log_setup | ( | void | ) |
| void cs_turb_init_ref_quantities | ( | void | ) |
| void cs_turb_model_log_setup | ( | void | ) |
| void cs_turbulence_function_eps | ( | int | location_id, |
| cs_lnum_t | n_elts, | ||
| void * | input, | ||
| void * | vals ) |
Returned values are zero for turbulence models other than RANS.
This function matches the cs_eval_at_location_t function profile.
| [in] | location_id | base associated mesh location id |
| [in] | n_elts | number of associated elements |
| [in] | elt_ids | ids of associated elements, or nullptr if no filtering is required |
| [in,out] | input | ignored |
| [in,out] | vals | pointer to output values (size: n_elts*dimension) |
| void cs_turbulence_function_k | ( | int | location_id, |
| void * | vals ) |
| void cs_turbulence_function_rij | ( | int | location_id, |
| void * | vals ) |
| void cs_turbulence_init_models | ( | void | ) |
| const char * cs_turbulence_model_name | ( | cs_turb_model_type_t | id | ) |
| [in] | id | model type |
| double cs_turb_ales = 1.0 |
Constant used to define, for each cell
Useful if and only if model = 40 or 41.
| double cs_turb_apow = 8.3 |
Werner and Wengle coefficient
| double cs_turb_bles = 1.0/3.0 |
| double cs_turb_bpow = 1.0/7.0 |
| double cs_turb_c1trit = 4.15 |
Coefficient of turbulent DFM flow model.
| double cs_turb_c2trit = 0.55 |
| double cs_turb_c3trit = 0.5 |
| double cs_turb_c4trit = 0. |
| double cs_turb_ccaza = 4.3 |
Constants of the Cazalbou rotation/curvature correction.
| double cs_turb_ccazb = 5.130 |
| double cs_turb_ccazc = 0.453 |
| double cs_turb_ccazd = 0.682 |
| double cs_turb_ccaze2 = 1.83 |
| double cs_turb_ccazsc = 0.119 |
| double cs_turb_cddes = 0.65 |
Constant
| double cs_turb_cdries = 26.0 |
Van Driest constant appearing in the van Driest damping function applied to the Smagorinsky constant:
| double cs_turb_ce1 = 1.44 |
Constant
| double cs_turb_ce2 = 1.92 |
Constant
| double cs_turb_ce3 = 2.02 |
Constant
| double cs_turb_ce4 = 1.20 |
Coefficient of interfacial coefficient in k-eps, used in Lagrange treatment.
Constant
| double cs_turb_cebmmu = 0.22 |
Constant of the Rij-epsilon EBRSM.
| double cs_turb_cebmr1 = 0.90 |
| double cs_turb_cebmr2 = 0.80 |
| double cs_turb_cebmr3 = 0.65 |
| double cs_turb_cebmr4 = 0.625 |
| double cs_turb_cebmr5 = 0.20 |
| double cs_turb_cebms1 = 1.70 |
| double cs_turb_cebms2 = 0. |
| double cs_turb_chtles_bt0 = 0.48 |
Constant
| double cs_turb_ckwa1 = 0.31 |
Specific constant of k-omega SST. Constant
| double cs_turb_ckwbt1 = 0.075 |
Constant
| double cs_turb_ckwbt2 = 0.0828 |
Constant
| double cs_turb_ckwc1 = 10.0 |
Constant
| double cs_turb_ckwgm1 = -1. |
| double cs_turb_ckwgm2 = -1. |
| double cs_turb_ckwsk1 = 1.0/0.85 |
Constant
| double cs_turb_ckwsk2 = 1.0 |
Constant
| double cs_turb_ckwsw1 = 2.0 |
Constant
| double cs_turb_ckwsw2 = 1.0/0.856 |
Constant
| double cs_turb_cmu = 0.09 |
Constant
| double cs_turb_cnl1 = 0.8 |
Constants for the Baglietto et al. quadratic k-epsilon model. Useful if and only if model = CS_TURB_K_EPSILON_QUAD
| double cs_turb_cnl2 = 11. |
| double cs_turb_cnl3 = 4.5 |
| double cs_turb_cnl4 = 1e3 |
| double cs_turb_cnl5 = 1. |
| double cs_turb_cpalc1 = 1.7 |
Specific constant of v2f "BL-v2k" (or phi-alpha).
| double cs_turb_cpalc2 = 0.9 |
| double cs_turb_cpalcl = 0.164 |
| double cs_turb_cpalct = 4.0 |
| double cs_turb_cpale1 = 1.44 |
| double cs_turb_cpale2 = 1.83 |
| double cs_turb_cpale3 = 2.3 |
| double cs_turb_cpale4 = 0.4 |
| double cs_turb_cpalet = 75.0 |
| double cs_turb_crij1 = 1.80 |
Constant
| double cs_turb_crij2 = 0.60 |
Constant
| double cs_turb_crij3 = 0.55 |
Constant
| double cs_turb_crij_c0 = 3.5 |
Rotta constant
| double cs_turb_crij_ct = 1. |
Monin constant
| double cs_turb_crij_eps = 1. |
Coefficient of in front of dissipation term in Rij models Default value is 1, can be used to unplung dissipation source term.
| double cs_turb_crijp1 = 0.50 |
Constant
| double cs_turb_crijp2 = 0.30 |
Constant
| double cs_turb_csab1 = 0.1355 |
Specific constant of Spalart-Allmaras.
| double cs_turb_csab2 = 0.622 |
| double cs_turb_csas = 0.11 |
Constant
| double cs_turb_csas_eta2 = 3.51 |
constant
| double cs_turb_csasig = 2.0/3.0 |
| double cs_turb_csav1 = 7.1 |
| double cs_turb_csaw1 = -1. |
| double cs_turb_csaw2 = 0.3 |
| double cs_turb_csaw3 = 2.0 |
| double cs_turb_csmago = 0.065 |
Smagorinsky constant used in the Smagorinsky model for LES. The sub-grid scale viscosity is calculated by
Useful if and only if model = 40.
| double cs_turb_csmago_max = -1. |
Maximum allowed value for the variable
Useful if and only if model = 41.
| double cs_turb_csmago_min = 0. |
Minimum allowed value for the variable
| double cs_turb_csrij |
Constant
| double cs_turb_cssgr1 = 0.90 |
Constant
| double cs_turb_cssgr2 = 0.80 |
Constant
| double cs_turb_cssgr3 = 0.65 |
Constant
| double cs_turb_cssgr4 = 0.625 |
constant
| double cs_turb_cssgr5 = 0.20 |
Constant
| double cs_turb_cssgs1 = 1.70 |
Constant
| double cs_turb_cssgs2 = -1.05 |
Constant
| double cs_turb_cssr1 = 1.0 |
Constant of the Spalart-Shur rotation/curvature correction.
| double cs_turb_cssr2 = 2.0 |
| double cs_turb_cssr3 = 1.0 |
| double cs_turb_cstlog = 5.2 |
Constant of logarithmic smooth law function:
Constant of the logarithmic wall function. Useful if and only if model != CS_TURB_NONE (mixing length,
| double cs_turb_cstlog_alpha |
Constant
| double cs_turb_cstlog_rough = 8.5 |
Constant of logarithmic rough law function:
| double cs_turb_cthafm = 0.236 |
Constant of GGDH and AFM on the thermal scalar.
| double cs_turb_cthdfm = 0.31 |
| double cs_turb_cthebdfm = 0.22 |
| double cs_turb_cv2fa1 = 0.05 |
Constant
| double cs_turb_cv2fc1 = 1.4 |
Constant
| double cs_turb_cv2fc2 = 0.3 |
Constant
| double cs_turb_cv2fcl = 0.25 |
Constant
| double cs_turb_cv2fct = 6.0 |
Constant
| double cs_turb_cv2fe2 = 1.85 |
Constant
| double cs_turb_cv2fet = 110.0 |
Constant
| double cs_turb_cwale = 0.25 |
Constant of the WALE LES method.
| double cs_turb_dpow = -1. |
| double cs_turb_etaafm = 0.4 |
Coefficient of turbulent AFM flow model.
| double cs_turb_vdriest = 25.6 |
Van Driest constant. (= 25.6)
Useful if and only if cs_glob_wall_functions::iwallf = CS_WALL_F_2SCALES_VDRIEST. (Two scales log law at the wall using Van Driest mixing length expression).
| double cs_turb_xa1 = 0.1 |
Constant in the expression of Ce1' for the Rij-epsilon EBRSM.
| double cs_turb_xceta = 80.0 |
| double cs_turb_xcl = 0.122 |
| double cs_turb_xclt = 0.305 |
constant of EB-AFM and EB-DFM (0.122*2.5, See F. Dehoux thesis)
| double cs_turb_xct = 6.0 |
| double cs_turb_xiafm = 0.7 |
| double cs_turb_xkappa = 0.42 |
Karman constant. (= 0.42)
Useful if and only if model != CS_TURB_NONE. (mixing length,
| double cs_turb_xlesfd = 1.5 |
Ratio between explicit and explicit filter width for a dynamic model. Constant used to define, for each cell
| double cs_turb_xlesfl = 2.0 |
Constant used in the definition of LES filtering diameter:
