Indicates the type of wall function used for the velocity boundary conditions on a frictional wall.
CS_WALL_F_DISABLED: no wall functions
CS_WALL_F_1SCALE_POWER: one scale of friction velocities (power law)
CS_WALL_F_1SCALE_LOG: one scale of friction velocities (log law)
CS_WALL_F_2SCALES_LOG: two scales of friction velocities (log law)
CS_WALL_F_SCALABLE_2SCALES_LOG: two scales of friction velocities (log law) (scalable wall functions)
CS_WALL_F_2SCALES_VDRIEST: two scales of friction velocities (mixing length based on V. Driest analysis)
CS_WALL_F_2SCALES_SMOOTH_ROUGH: wall function unifying rough and smooth friction regimes
CS_WALL_F_2SCALES_CONTINUOUS: All for low Reynolds models iwallf is initialised to CS_WALL_F_1SCALE_LOG for model = 10, 40, 41 or 70 (mixing length, LES and Spalart Allmaras). iwallf is initialised to CS_WALL_F_DISABLED for model = 0, 32, 50 or 51 iwallf is initialised to CS_WALL_F_2SCALES_LOG for model = 20, 21, 30, 31 or 60 ( , LRR, SSG and SST models).
The v2f model (model=50) is not designed to use wall functions (the mesh must be low Reynolds).
The value iwallf = CS_WALL_F_2SCALES_LOG is not compatible with model=0, 10, 40 or 41 (laminar, mixing length and LES).
Concerning the and models, the two-scales model is usually at least as satisfactory as the one-scale model.
The scalable wall function allows to virtually shift the wall when necessary in order to be always in a logarithmic layer. It is used to make up for the problems related to the use of High-Reynolds models on very refined meshes.
Useful if model is different from 50.
ypluli depends on the chosen wall function: it is initialized to 10.88 for the scalable wall function (iwallf=CS_WALL_F_SCALABLE_2SCALES_LOG), otherwise it is initialized to . In LES, ypluli is taken by default to be 10.88. Always useful.
