cs_gwf_soil_t Struct Reference
Main structure to handle a soil in the groundwater flow module: its definition, the way to update its related properties. More...
#include <cs_gwf_soil.h>
Collaboration diagram for cs_gwf_soil_t:
Data Fields
Metadata
int id
int zone_id
cs_gwf_model_type_t hydraulic_model
void * hydraulic_context
Soil features (whatever is the soil model)
double bulk_density
double porosity
int abs_permeability_dim
double abs_permeability [3][3]
Soil modelling
cs_gwf_soil_model_t model
void * model_param
Function pointers
cs_gwf_soil_update_tupdate_properties
cs_gwf_soil_free_param_tfree_model_param
Store a set of parameters and pointers describing a soil and its related hydraulic model (this hydraulic model is shared with the main structure cs_gwf_t)
Field Documentation
◆ abs_permeability
double abs_permeability[3][3]
Value of the intrisic permeability in the soil when all the porous media is filled with water (= saturated permeability)
◆ abs_permeability_dim
=1 if isotropic or =3 if orthotropic or =9 if anisotropic
◆ bulk_density
double bulk_density
Value of the mass density of the soil
◆ free_model_param
cs_gwf_soil_free_param_t* free_model_param
Pointer to a function which free the param structure if needed. May be set to null if there is nothing to free inside the param structure.
◆ hydraulic_context
void* hydraulic_context
Structure cast on-the-fly. This structure contains parameters, arrays, properties and fields describing the hydraulic state. It depends on the type of hydraulic model which is considered.
◆ hydraulic_model
Type of model use in the groundwater flow module to describe the hydraulic (see cs_gwf_model_type_t for more details)
◆ id
int id
id associated to a soil. Position in the array of soils.
◆ model
Type of model describing the hydraulic behaviour of a soil (cf. cs_gwf_soil_model_t for more details)
◆ model_param
void* model_param
Pointer to a structure cast on-the-fly (it depends on the type of soil model). This structure contains the set of parameters describing a soil. Can be set to null in the case of a saturated single-phase model.
◆ porosity
double porosity
Max. portion of volume in a soil where the liquid (or the gas) can be. In a single-phase saturated model this corresponds to the saturated moisture or the max. liquid saturation.
◆ update_properties
cs_gwf_soil_update_t* update_properties
Pointer to a function which manages the update of the properties describing the porous media or used in associated equations (diffusion terms for instance). These functions depend on the model of soil and the type of model used in the groundwater flow module. May be set to null if there is no need to update soil properties.
◆ zone_id
int zone_id
id related to a volumic cs_zone_t structure (based on cells)
