cs_coal_bc_inlet_t Struct Reference
Inlet definition for pulverized coal combustion. More...
#include <cs_coal_boundary_conditions.h>
Collaboration diagram for cs_coal_bc_inlet_t:
Data Fields
const cs_zone_tzone
int ientat
int ientcp
int inmoxy
cs_real_t qimpcp [CS_COMBUSTION_MAX_COALS]
cs_real_t timpcp [CS_COMBUSTION_MAX_COALS]
cs_real_t distch [CS_COMBUSTION_MAX_COALS][CS_COMBUSTION_MAX_CLASSES_PER_COAL]
cs_real_t t_air
cs_coal_bc_inlet_state_tstate
Prescribed air mass flow definition.
Using such a definition allows prescribing the air mass flow and letting the code determine the total (air + coal) mass flow.
Only used if activated by call to cs_coal_boundary_conditions_inlet_set_air_mass_flow_rate_by_value or cs_coal_boundary_conditions_inlet_set_air_mass_flow_rate_by_func.
cs_real_t qm_air
cs_eval_at_location_tqm_air_func
void * qm_air_input
Field Documentation
◆ distch
Coal class mass distribution ratio (in percentage)
◆ ientat
int ientat
Air indicator
◆ ientcp
int ientcp
Cp indicator
◆ inmoxy
int inmoxy
Number of oxydants
◆ qimpcp
Coal mass flow per coal
◆ qm_air
cs_real_t qm_air
Air mass flow rate, if prescribed
◆ qm_air_func
cs_eval_at_location_t* qm_air_func
Associated global air mass flow evaluation function, or NULL
◆ qm_air_input
void* qm_air_input
Associated function input if needed, or NULL
◆ state
◆ t_air
cs_real_t t_air
Air temperature (in K)
◆ timpcp
Coal temperature (in K) per coal
◆ zone
const cs_zone_t* zone
Pointer to associated zone
