Coal_combustion_s_var_disp
int itemp2 [CS_COMBUSTION_COAL_MAX_CLASSES]
int irom2 [CS_COMBUSTION_COAL_MAX_CLASSES]
int idiam2 [CS_COMBUSTION_COAL_MAX_CLASSES]
int ix2 [CS_COMBUSTION_COAL_MAX_CLASSES]
int igmdch [CS_COMBUSTION_COAL_MAX_CLASSES]
int igmhet [CS_COMBUSTION_COAL_MAX_CLASSES]
int igmtr [CS_COMBUSTION_COAL_MAX_CLASSES]
int ighco2 [CS_COMBUSTION_COAL_MAX_CLASSES]
int ighh2o [CS_COMBUSTION_COAL_MAX_CLASSES]
int igmdv1 [CS_COMBUSTION_COAL_MAX_CLASSES]
int igmdv2 [CS_COMBUSTION_COAL_MAX_CLASSES]
int igmsec [CS_COMBUSTION_COAL_MAX_CLASSES]
int ibcarbone
int iboxygen
int ibhydrogen
◆ ibcarbone
int ibcarbone
used for bulk balance of carbon
◆ ibhydrogen
int ibhydrogen
used for bulk balance of hydrogen
◆ iboxygen
int iboxygen
used for bulk balance of oxygen
◆ idiam2
diameter of the particles of each class
◆ ighco2
id of field "het_ts_co2_p<class>"
◆ ighh2o
id of field "het_ts_h2o_p<class>"
◆ igmdch
disappearance rate of the reactive coal of each class
◆ igmdv1
mass transfer caused by the release of light volatiles of each class
◆ igmdv2
mass transfer caused by the release of heavy volatiles of each class
◆ igmhet
coke disappearance rate of the coke burnout of each class
◆ igmsec
id of field "dry_ts_p<class>"
◆ igmtr
implicit part of the exchanges to the gas by molecular distribution
◆ irom2
density of the particles of each class
◆ itemp2
temperature of the particles of each class
◆ ix2
solid mass fraction of each class
