#include "cs_defs.h"#include <assert.h>#include <errno.h>#include <ctype.h>#include <stdio.h>#include <stdarg.h>#include <stdlib.h>#include <string.h>#include <math.h>#include <float.h>#include "bft_mem.h"#include "bft_error.h"#include "bft_printf.h"#include "cs_atmo_profile_std.h"#include "cs_base.h"#include "cs_boundary_conditions.h"#include "cs_boundary_zone.h"#include "cs_domain.h"#include "cs_field.h"#include "cs_field_default.h"#include "cs_field_pointer.h"#include "cs_halo.h"#include "cs_log.h"#include "cs_math.h"#include "cs_mesh.h"#include "cs_mesh_location.h"#include "cs_mesh_quantities.h"#include "cs_parall.h"#include "cs_equation_iterative_solve.h"#include "cs_physical_constants.h"#include "cs_physical_model.h"#include "cs_prototypes.h"#include "cs_thermal_model.h"#include "cs_turbulence_model.h"#include "cs_volume_zone.h"#include "cs_balance.h"#include "cs_blas.h"#include "cs_convection_diffusion.h"#include "cs_parameters.h"#include "cs_porous_model.h"#include "cs_timer.h"#include "cs_matrix_building.h"#include "cs_sles.h"#include "cs_sles_default.h"#include "cs_face_viscosity.h"#include "cs_divergence.h"#include "cs_velocity_pressure.h"#include "cs_atmo.h"#include "cs_atmo_aerosol.h"
Include dependency graph for cs_atmo.c:Functions | |
| void | cs_atmo_init_meteo_profiles (void) |
| Initialize meteo profiles if no meteo file is given. More... | |
| void | cs_atmo_compute_meteo_profiles (void) |
| Compute meteo profiles if no meteo file is given. More... | |
| void | cs_atmo_z_ground_compute (void) |
| Compute the ground elevation. More... | |
| void | cs_atmo_hydrostatic_profiles_compute (void) |
| Compute hydrostatic profiles of density and pressure. More... | |
| void | cs_atmo_set_meteo_file_name (const char *file_name) |
| This function set the file name of the meteo file. More... | |
| void | cs_atmo_set_chem_conc_file_name (const char *file_name) |
| This function set the file name of the chemistry file. More... | |
| void | cs_atmo_set_aero_conc_file_name (const char *file_name) |
| This function set the file name of the aerosol file. More... | |
| void | cs_atmo_chemistry_set_spack_file_name (const char *file_name) |
| This function set the file name of the SPACK file. More... | |
| void | cs_atmo_chemistry_set_aerosol_file_name (const char *file_name) |
| This function sets the file name to initialize the aerosol library. More... | |
| void | cs_atmo_declare_chem_from_spack (void) |
| This function declares additional transported variables for atmospheric module for the chemistry defined from SPACK. More... | |
| void | cs_atmo_compute_solar_angles (cs_real_t latitude, cs_real_t longitude, cs_real_t squant, cs_real_t utc, int sea_id, cs_real_t *albedo, cs_real_t *muzero, cs_real_t *omega, cs_real_t *fo) |
| 1D Radiative scheme - Solar data + zenithal angle) More... | |
| void | cs_atmo_log_setup (void) |
| Print the atmospheric module options to setup.log. More... | |
| void | cs_atmo_chemistry_log_setup (void) |
| Print the atmospheric chemistry options to setup.log. More... | |
| void | cs_atmo_aerosol_log_setup (void) |
| Print the atmospheric aerosols options to setup.log. More... | |
| void | cs_atmo_finalize (void) |
| Deallocate arrays for atmo module. More... | |
| void cs_atmo_aerosol_log_setup | ( | void | ) |
| void cs_atmo_chemistry_log_setup | ( | void | ) |
| void cs_atmo_chemistry_set_aerosol_file_name | ( | const char * | file_name | ) |
| [in] | file_name | name of the file. |
| void cs_atmo_chemistry_set_spack_file_name | ( | const char * | file_name | ) |
| void cs_atmo_compute_meteo_profiles | ( | void | ) |
| void cs_atmo_compute_solar_angles | ( | cs_real_t | latitude, |
| cs_real_t | longitude, | ||
| cs_real_t | squant, | ||
| cs_real_t | utc, | ||
| int | sea_id, | ||
| cs_real_t * | albedo, | ||
| cs_real_t * | muzero, | ||
| cs_real_t * | omega, | ||
| cs_real_t * | fo | ||
Compute:
| [in] | latitude | latitude |
| [in] | longitude | longitude |
| [in] | squant | start day in the year |
| [in] | utc | Universal time (hour) |
| [in] | sea_id | sea index |
| [out] | albedo | albedo |
| [out] | muzero | cosin of zenithal angle |
| [out] | omega | solar azimut angle |
| [out] | fo | solar constant |
| void cs_atmo_declare_chem_from_spack | ( | void | ) |
This function declare additional transported variables for atmospheric module for the chemistry defined from SPACK.
| void cs_atmo_finalize | ( | void | ) |
| void cs_atmo_hydrostatic_profiles_compute | ( | void | ) |
This function solves the following transport equation on
where
is the gravity field and
is the potential temperature.
The boundary conditions on
read:
and Neumann elsewhere.
| void cs_atmo_init_meteo_profiles | ( | void | ) |
| void cs_atmo_log_setup | ( | void | ) |
| void cs_atmo_set_aero_conc_file_name | ( | const char * | file_name | ) |
This function set the file name of the aerosol concentration file.
| void cs_atmo_set_chem_conc_file_name | ( | const char * | file_name | ) |
This function set the file name of the chemistry concentration file.
| void cs_atmo_set_meteo_file_name | ( | const char * | file_name | ) |
| void cs_atmo_z_ground_compute | ( | void | ) |
where
read:
Remarks:
