7.1
cs_defs.h
1 #ifndef __CS_DEFS_H__
2 #define __CS_DEFS_H__
5  * Base macro and typedef definitions for system portability
30 /*============================================================================
31  * Autoconf-defined macros
32  *============================================================================*/
34 #if defined(HAVE_CONFIG_H)
35 # include "cs_config.h"
36 #endif
38 /*============================================================================
39  * Internationalization
40  *============================================================================*/
42 #ifdef __cplusplus
43 extern "C" {
44 #if 0
45 } /* Fake brace to force Emacs auto-indentation back to column 0 */
46 #endif
47 #endif /* __cplusplus */
48
49 #if defined(ENABLE_NLS) && defined(HAVE_GETTEXT)
50
51 # include <libintl.h>
52 # define _(String) dgettext(PACKAGE, String)
53 # ifdef gettext_noop
54 # define N_(String) gettext_noop(String)
55 # else
56 # define N_(String) String
57 # endif /* gettext_noop */
58
59 #else
60
61 # define _LIBINTL_H /* Prevent inclusion of <libintl.h> by other files
62  with incorrect or missing checks;
63  TODO locate files causing issues to avoid
64  requiring this workaround */
65
66 # define _(String) (String)
67 # define N_(String) String
68 # define textdomain(String) (String)
69 # define gettext(String) (String)
70 # define dgettext(Domain,String) (String)
71 # define dcgettext(Domain,String,Type) (String)
72 # define bindtextdomain(Domain, Directory) (Domain)
73
74 #endif /* ENABLE_NLS && HAVE_GETTEXT */
75
76 #ifdef __cplusplus
77 }
78 #endif /* __cplusplus */
79
80 /*============================================================================
81  * Parallelism
82  *============================================================================*/
83
84 #if defined(HAVE_MPI) && !defined(CS_IGNORE_MPI)
85
86 # include <mpi.h>
87
88 # if !defined(MPI_VERSION) /* Defined in up-to-date MPI versions */
89 # define MPI_VERSION 1
90 # endif
91
92 # if MPI_VERSION == 1
93 # define MPI_Info int
94 # define MPI_INFO_NULL 0
95 # endif
96
97 #endif
98
99 #if defined(HAVE_OPENMP)
100
101 # include <omp.h>
102
103 #if _OPENMP >= 201307 /* simd construct available from OpenMP 4.0 */
104 #undef HAVE_OPENMP_SIMD
105 #define HAVE_OPENMP_SIMD 1
106 #endif
107
108 #endif
109
110 /* Do we have accelerator support ? */
111
112 #if defined(HAVE_CUDA)
113 #define HAVE_ACCEL 1
114 #elif defined(HAVE_OPENMP_TARGET)
115 #define HAVE_ACCEL 1
116 #endif
117
118 /*============================================================================
119  * C99 Qualifiers
120  *============================================================================*/
121
122 #ifndef __cplusplus /* C */
123
124 /* inline provided by cs_config.h if necessary */
125
126 #if !defined(__STDC_VERSION__)
127 # define __STDC_VERSION__ 1989
128 #endif
129
130 /*
131  * Redefinition of "inline" et "restrict" qualifiers incompatible with
132  * some C89 compilers (standard in C99)
133  */
134
135 #if (__STDC_VERSION__ < 199901L)
136
137 # if defined(__GNUC__)
138 # define inline __inline__
139 # define restrict __restrict__
140 # else
141 # define inline
142 # define restrict
143 # endif
144
145 #endif
146
147 #else /* C++ */
148
149 # ifndef HAVE_RESTRICT /* Must be provided by caller */
150 # define restrict
151 # endif
152
153 #endif /* __cplusplus */
154
155 /*============================================================================
156  * Definitions that may not always be provided directly by the system
157  *============================================================================*/
158
159 /*
160  * Obtain definitions such as that of size_t through stddef.h (C99 standard)
161  * if available (preferred method), or through stdlib.h (which defines
162  * malloc() and family and so must define size_t some way) otherwise.
163  */
164
165 #if HAVE_STDDEF_H
166 # include <stddef.h>
167 #else
168 # include <stdlib.h>
169 #endif
170
171 /*
172  * Usually stdint.h is included by inttypes.h, but only inttypes.h exists
173  * on certain systems, such as Tru64Unix.
174  */
175
176 #if HAVE_STDINT_H
177 # include <stdint.h>
178 #elif HAVE_INTTYPES_H
179 # include <inttypes.h>
180 #endif
181
182 /*
183  * Obtain the definition of off_t.
184  */
185
186 #if defined(HAVE_SYS_TYPES_H)
187 #include <sys/types.h>
188 #endif
189
190 /* C99 _Bool type */
191
192 #if HAVE_STDBOOL_H
193 # include <stdbool.h>
194 #else
195 # ifndef __cplusplus
196 # ifndef HAVE__BOOL
197 # define _Bool signed char;
198 # endif
199 # define bool _Bool
200 # define false 0
201 # define true 1
202 # else
203 # define _Bool bool;
204 # endif
205 # define __bool_true_false_are_defined 1
206 #endif
207
208 /* int32_t type */
209
210 #if !defined(HAVE_INT32_T)
211 # if (SIZEOF_INT == 4)
212 typedef int int32_t;
213 # elif (SIZEOF_SHORT == 4)
214 typedef short int32_t;
215 # else
216 # error
217 # endif
218 #endif
219
220 /* int64_t type */
221
222 #if !defined(HAVE_INT64_T)
223 # if (SIZEOF_INT == 8)
224 typedef int int64_t;
225 # elif (SIZEOF_LONG == 8)
226 typedef long int64_t;
227 # elif (HAVE_LONG_LONG == 8) /* SIZEOF_LONG_LONG not generally available */
228 typedef long long int64_t;
229 # else
230 # error
231 # endif
232 #endif
233
234 /* uint32_t type */
235
236 #if !defined(HAVE_UINT32_T)
237 # if (SIZEOF_INT == 4)
238 typedef unsigned uint32_t;
239 # elif (SIZEOF_SHORT == 4)
240 typedef unsigned short uint32_t;
241 # else
242 # error
243 # endif
244 #endif
245
246 /* uint64_t type */
247
248 #if !defined(HAVE_UINT64_T)
249 # if (SIZEOF_INT == 8)
250 typedef unsigned uint64_t;
251 # elif (SIZEOF_LONG == 8)
252 typedef unsigned long uint64_t;
253 # elif (HAVE_LONG_LONG) /* SIZEOF_LONG_LONG not generally available */
254 typedef unsigned long long uint64_t;
255 # else
256 # error
257 # endif
258 #endif
259
260 /*============================================================================
261  * General types and macros used throughout Code_Saturne
262  *============================================================================*/
263
264 #ifdef __cplusplus
265 extern "C" {
266 #if 0
267 } /* Fake brace to force Emacs auto-indentation back to column 0 */
268 #endif
269 #endif /* __cplusplus */
270
271 /*----------------------------------------------------------------------------
272  * Variable value type.
273  *----------------------------------------------------------------------------*/
274
275 typedef enum {
276
277  CS_DATATYPE_NULL, /* empty datatype */
278  CS_CHAR, /* character values */
279  CS_FLOAT, /* 4-byte floating point values */
280  CS_DOUBLE, /* 8-byte floating point values */
281  CS_UINT16, /* 2-byte unsigned integer values */
282  CS_INT32, /* 4-byte signed integer values */
283  CS_INT64, /* 8-byte signed integer values */
284  CS_UINT32, /* 4-byte unsigned integer values */
285  CS_UINT64 /* 8-byte unsigned integer values */
286
287 } cs_datatype_t;
288
289 /*----------------------------------------------------------------------------
290  * Basic types used by Code_Saturne
291  * They may be modified here to better map to a given library, with the
292  * following constraints:
293  * - cs_lnum_t must be signed
294  * - cs_gnum_t may be signed or unsigned
295  *----------------------------------------------------------------------------*/
296
297 /* Global integer index or number */
298
299 #if defined(HAVE_LONG_GNUM)
300  #if (SIZEOF_LONG == 8)
301  typedef unsigned long cs_gnum_t;
302  #elif (SIZEOF_LONG_LONG == 8)
303  typedef unsigned long long cs_gnum_t;
304  #else
305  #error
306  #endif
307 #else
308  typedef unsigned cs_gnum_t;
309 #endif
310
311 /* Local integer index or number */
312
313 #if defined(HAVE_LONG_LNUM)
314  typedef long cs_lnum_t;
315 #else
316  typedef int cs_lnum_t;
317 #endif
318
319 /* Other types */
320 typedef double cs_coord_t; /* Real number (coordinate value) */
321
322 typedef double cs_real_t; /* Fortran double precision */
323 typedef char cs_byte_t; /* Byte (untyped memory unit) */
324 typedef unsigned short int cs_flag_t; /* Flag storing metadata */
325
326 /* Vector or array block types */
327
328 typedef cs_lnum_t cs_lnum_2_t[2]; /* Vector of 2 local numbers */
329 typedef cs_lnum_t cs_lnum_3_t[3]; /* Vector of 3 local numbers */
330
331 typedef cs_coord_t cs_coord_3_t[3]; /* Vector of 3 real (coordinate)
332  values */
333
334 typedef cs_real_t cs_real_2_t[2]; /* Vector of 2 real values */
335 typedef cs_real_t cs_real_3_t[3]; /* Vector of 3 real values */
336 typedef cs_real_t cs_real_4_t[4]; /* Vector of 4 real values */
337 typedef cs_real_t cs_real_6_t[6]; /* Vector of 6 real values
338  (for symmetric tensor) */
339 typedef cs_real_t cs_real_9_t[9]; /* Vector of 9 real values */
340 typedef cs_real_t cs_real_10_t[10]; /* Vector of 10 real values */
341
342 typedef cs_real_t cs_real_33_t[3][3]; /* Matrix of 3x3 real values */
343 typedef cs_real_t cs_real_66_t[6][6]; /* Matrix of 6x6 real values */
344 typedef cs_real_t cs_real_99_t[9][9]; /* Matrix of 9x9 real values */
345
346 typedef cs_real_t cs_real_333_t[3][3][3]; /* tensor of 3x3x3 real values */
347
348 typedef cs_real_t cs_real_34_t[3][4]; /* Matrix of 3x4 real values */
349
350 typedef cs_real_t cs_real_63_t[6][3]; /* Matrix of 6x3 real values */
351
352 typedef cs_real_t cs_real_69_t[6][9]; /* Matrix of 6x9 real values */
353
354 typedef cs_real_33_t cs_real_332_t[2]; /* vector of 2 3x3 matrices
355  of real values */
356 typedef cs_real_66_t cs_real_662_t[2]; /* vector of 2 6x6 matrices
357  of real values */
358
359 typedef struct {
360
361  double val; /* Value */
362  int id; /* Id related to value */
363
365
366 /* Vector-valued quantity stored using its measure (i.e. length) and
367  its direction given by a unitary vector */
368 typedef struct {
369
370  double meas;
371  double unitv[3];
372
373 } cs_nvec3_t;
374
375 /* Mappings to MPI datatypes */
376 /*---------------------------*/
377
378 #if defined(HAVE_MPI) && !defined(CS_IGNORE_MPI)
379
380 # define CS_MPI_REAL MPI_DOUBLE /* If cs_real_t is a double */
381
382 /* MPI type for cs_gnum_t integer type (depends on configuration) */
383
384 # if defined(HAVE_LONG_GNUM)
385 # if (SIZEOF_LONG == 8)
386 # define CS_MPI_GNUM MPI_UNSIGNED_LONG
387 # elif (SIZEOF_LONG_LONG == 8)
388 # if defined(MPI_UNSIGNED_LONG_LONG)
389 # define CS_MPI_GNUM MPI_UNSIGNED_LONG_LONG
390 # elif defined(MPI_LONG_LONG)
391 # define CS_MPI_GNUM MPI_LONG_LONG
392 # endif
393 # endif
394 # if !defined(CS_MPI_GNUM)
395 # error
396 # endif
397 # else
398 # define CS_MPI_GNUM MPI_UNSIGNED
399 # endif
400
401 /* MPI type for cs_lnum_t type */
402
403 # if defined(HAVE_LONG_LNUM)
404 # define CS_MPI_LNUM MPI_LONG
405 # else
406 # define CS_MPI_LNUM MPI_INT
407 # endif
408
409 # define CS_MPI_EFLAG MPI_UNSIGNED /* MPI type for cs_mflag_t type */
410 # define CS_MPI_FLAG MPI_UNSIGNED_SHORT /* MPI type for cs_flag_t type */
411 # define CS_MPI_COORD MPI_DOUBLE /* MPI type for cs_coord_t type */
412
413 #endif /* defined(HAVE_MPI) && !defined(CS_IGNORE_MPI) */
414
415 /* Mappings to Code_Saturne datatypes */
416 /*------------------------------------*/
417
418 #if defined(HAVE_LONG_GNUM)
419 # define CS_GNUM_TYPE CS_UINT64
420 #elif (SIZEOF_INT == 8)
421 # define CS_GNUM_TYPE CS_UINT64
422 #else
423 # define CS_GNUM_TYPE CS_UINT32
424 #endif
425
426 #if defined(HAVE_LONG_LNUM)
427 # if (SIZEOF_LONG == 8)
428 # define CS_LNUM_TYPE CS_INT64
429 # else
430 # define CS_LNUM_TYPE CS_INT32
431 # endif
432 #else
433 # if (SIZEOF_INT == 8)
434 # define CS_LNUM_TYPE CS_INT64
435 # else
436 # define CS_LNUM_TYPE CS_INT32
437 # endif
438 #endif
439
440 #if (SIZEOF_INT == 8)
441 # define CS_INT_TYPE CS_INT64
442 #else
443 # define CS_INT_TYPE CS_INT32
444 #endif
445
446 #if (SIZEOF_INT == 8)
447 # define CS_UINT_TYPE CS_UINT64
448 #else
449 # define CS_UINT_TYPE CS_UINT32
450 #endif
451
452 #define CS_FLAG_TYPE CS_UINT16
453 #define CS_EFLAG_TYPE CS_UINT_TYPE
454 #define CS_REAL_TYPE CS_DOUBLE
455 #define CS_COORD_TYPE CS_DOUBLE
456
457 /* Minimum size for OpenMP loops
458  * (will need benchmarking and tuning for various systems)
459  *---------------------------------------------------------*/
460
461 #define CS_THR_MIN 128
462
463 /* Cache line size, or multiple thereof */
464 /*--------------------------------------*/
465
466 #define CS_CL_SIZE 64
467
468 /*----------------------------------------------------------------------------
469  * Type independent min an max (caution: the argument is evaluated)
470  *----------------------------------------------------------------------------*/
471
472 #define CS_ABS(a) ((a) < 0 ? -(a) : (a))
473 #define CS_MIN(a,b) ((a) < (b) ? (a) : (b))
474 #define CS_MAX(a,b) ((a) > (b) ? (a) : (b))
476 /*----------------------------------------------------------------------------
477  * Variable interlace type:
478  * {x1, y1, z1, x2, y2, z2, ...,xn, yn, zn} if interlaced
479  * {x1, x2, ..., xn, y1, y2, ..., yn, z1, z2, ..., zn} if non interlaced
480  *----------------------------------------------------------------------------*/
481
482 typedef enum {
483
484  CS_INTERLACE, /* Variable is interlaced */
485  CS_NO_INTERLACE /* Variable is not interlaced */
486
488
489 /*----------------------------------------------------------------------------
490  * Macro used to silence "unused argument" warnings.
491  *
492  * This is useful when a function must match a given function pointer
493  * type, but does not use all possible arguments.
494  *----------------------------------------------------------------------------*/
495
496 #define CS_UNUSED(x) (void)(x)
497 #define CS_NO_WARN_IF_UNUSED(x) (void)(x)
498
499 /*----------------------------------------------------------------------------
500  * Macros for compilation with a C++ compiler
501  *----------------------------------------------------------------------------*/
502
503 #undef BEGIN_C_DECLS
504 #undef END_C_DECLS
505
506 #if defined(__cplusplus)
507 # define BEGIN_C_DECLS extern "C" {
508 # define END_C_DECLS }
509 #else
510 # define BEGIN_C_DECLS
511 # define END_C_DECLS
512 #endif
513
514 /*----------------------------------------------------------------------------
515  * Macros for Fortran interoperability
516  *----------------------------------------------------------------------------*/
517
518 /*
519  * Macro for handling of different symbol names (underscored or not,
520  * lowercase or uppercase) between C and Fortran, for link resolution.
521  */
522
523 #if !defined (__hpux)
524 #define CS_PROCF(x, y) x##_
525 #else
526 #define CS_PROCF(x, y) x
527 #endif
528
529 /*
530  * Macro used to handle automatic "Fortran string length" arguments
531  * (not used by code_saturne calls, but set by many compilers).
532  * Some compilers may not
533  * support the variable length lists in mixed C/Fortran calls.
534  */
535
536 #define CS_ARGF_SUPP_CHAINE , ...
537
538 /*=============================================================================
539  * Global variables
540  *============================================================================*/
541
542 /* Empty but non-NULL string */
543
544 extern const char cs_empty_string[];
545
546 /* Sizes and names associated with datatypes */
547
548 extern const size_t cs_datatype_size[];
549 extern const char *cs_datatype_name[];
550
551 /* MPI Datatypes associated with Code_Saturne datatypes */
552
553 #if defined(HAVE_MPI) && !defined(CS_IGNORE_MPI)
554
555 extern MPI_Datatype cs_datatype_to_mpi[];
556
557 #endif
558
559 /* Global variables indicating task state */
560
561 extern int cs_glob_n_threads; /* Number of threads */
562
563 extern int cs_glob_rank_id; /* Rank in main MPI communicator */
564 extern int cs_glob_n_ranks; /* Size of main MPI communicator */
565
566 extern int cs_glob_node_rank_id; /* Rank on node in main MPI communicator */
567 extern int cs_glob_node_n_ranks; /* Number of ranks on node of main
568  MPI communicator */
569
570 #if defined(HAVE_MPI) && !defined(CS_IGNORE_MPI)
571
572 extern MPI_Comm cs_glob_mpi_comm; /* Main MPI intra-communicator */
573
574 #endif
575
576 /*=============================================================================
577  * Public functions
578  *============================================================================*/
579
580 /*----------------------------------------------------------------------------*/
589 /*----------------------------------------------------------------------------*/
590
591 inline static cs_lnum_t
592 cs_align(cs_lnum_t i,
593  cs_lnum_t m)
594 {
595  return ((i > 0) ? ((i-1)/m+1)*m : 0);
596 }
597
598 /*----------------------------------------------------------------------------*/
599
600 #ifdef __cplusplus
601 }
602 #endif /* __cplusplus */
603
604 #endif /* __CS_DEFS_H__ */
Definition: cs_defs.c:183
cs_datatype_t
Definition: cs_defs.h:275
global mesh entity number
Definition: cs_defs.h:301
Definition: cs_defs.h:329
Definition: cs_defs.h:346
Definition: cs_defs.h:283
Definition: cs_defs.h:334
Definition: cs_defs.h:282
Definition: cs_defs.h:337
Definition: cs_defs.h:484
Definition: cs_defs.h:348
6x6 matrix of floating-point values
Definition: cs_defs.h:343
char cs_byte_t
Definition: cs_defs.h:323
cs_interlace_t
Definition: cs_defs.h:482
Definition: cs_defs.h:277
Definition: cs_defs.h:331
Definition: cs_defs.h:344
int cs_glob_n_ranks
Definition: cs_defs.c:175
Definition: cs_defs.h:356
Definition: cs_defs.h:285
double cs_coord_t
Definition: cs_defs.h:320
vector of 4 floating-point values
Definition: cs_defs.h:336
Definition: cs_defs.h:322
Definition: cs_defs.h:368
Definition: cs_defs.h:485
Definition: cs_defs.h:359
Definition: cs_defs.h:339
Definition: cs_defs.h:279
Definition: cs_defs.h:340
double meas
Definition: cs_defs.h:370
Definition: cs_defs.c:172
Definition: cs_defs.c:157
Definition: cs_defs.c:129
vector of 2 3x3 matrices of floating-point values
Definition: cs_defs.h:354
Definition: cs_defs.h:328
Definition: cs_defs.h:284
Definition: cs_defs.h:335
Definition: cs_defs.c:133
Definition: cs_defs.h:316
Definition: cs_defs.h:352
Definition: cs_defs.c:178
Definition: cs_defs.h:278
Definition: cs_defs.h:324
Definition: cs_defs.c:177
Definition: cs_defs.h:342
const char * cs_datatype_name[]
Definition: cs_defs.c:143
Definition: cs_defs.h:350
int id
Definition: cs_defs.h:362
Definition: cs_defs.h:281
Definition: cs_defs.h:280
int cs_glob_rank_id
Definition: cs_defs.c:174
double val
Definition: cs_defs.h:361
