1 #ifndef __CS_VELOCITY_PRESSURE_H__ 2 #define __CS_VELOCITY_PRESSURE_H__ int ivisse
Definition: cs_velocity_pressure.h:53
int ipucou
Definition: cs_velocity_pressure.h:124
int icalhy
Definition: cs_velocity_pressure.h:87
int nterup
Definition: cs_velocity_pressure.h:145
double epsup
Definition: cs_velocity_pressure.h:148
int iifren
Definition: cs_velocity_pressure.h:102
int rcfact
Definition: cs_velocity_pressure.h:135
void cs_velocity_pressure_set_n_buoyant_scalars(void)
Definition: cs_velocity_pressure.c:462
double epsdp
Definition: cs_velocity_pressure.h:159
cs_velocity_pressure_model_t * cs_get_glob_velocity_pressure_model(void)
Definition: cs_velocity_pressure.c:434
int n_buoyant_scal
Definition: cs_velocity_pressure.h:71
int igpust
Definition: cs_velocity_pressure.h:118
void cs_velocity_pressure_set_solid(void)
Definition: cs_velocity_pressure.c:486
cs_velocity_pressure_model_t cs_stokes_model_t
Definition: cs_velocity_pressure.h:165
bool fluid_solid
Definition: cs_velocity_pressure.h:67
double xnrmu
Definition: cs_velocity_pressure.h:152
int irevmc
Definition: cs_velocity_pressure.h:98
int irecmf
Definition: cs_velocity_pressure.h:106
int itpcol
Definition: cs_velocity_pressure.h:128
int staggered
Definition: cs_velocity_pressure.h:140
void cs_velocity_pressure_model_log_setup(void)
Print the stokes model parameters to setup.log.
Definition: cs_velocity_pressure.c:507
void cs_velocity_pressure_param_log_setup(void)
Print Velocity-pressure parameters to setup.log.
Definition: cs_velocity_pressure.c:580
Stokes equation model descriptor.
Definition: cs_velocity_pressure.h:51
cs_velocity_pressure_param_t * cs_get_glob_velocity_pressure_param(void)
Provide access to cs_glob_velocity_pressure_param.
Definition: cs_velocity_pressure.c:450
const cs_velocity_pressure_param_t * cs_glob_velocity_pressure_param
double arak
Definition: cs_velocity_pressure.h:132
int iprco
Definition: cs_velocity_pressure.h:93
Inner velocity/pressure iteration options descriptor.
Definition: cs_velocity_pressure.h:80
int igprij
Definition: cs_velocity_pressure.h:113
int idilat
Definition: cs_velocity_pressure.h:58
cs_velocity_pressure_param_t cs_piso_t
Definition: cs_velocity_pressure.h:166
double xnrmu0
Definition: cs_velocity_pressure.h:157
int iphydr
Definition: cs_velocity_pressure.h:82
const cs_velocity_pressure_model_t * cs_glob_velocity_pressure_model
