7.1
cs_sles.h
1 #ifndef __CS_SLES_H__
2 #define __CS_SLES_H__
5  * Sparse Linear Equation Solver driver
31  * Local headers
34 #include "cs_base.h"
35 #include "cs_log.h"
36 #include "cs_halo_perio.h"
37 #include "cs_matrix.h"
38 #include "cs_matrix.h"
45  * Macro definitions
49  * Type definitions
51
52 /*----------------------------------------------------------------------------
53  * Convergence status
54  *----------------------------------------------------------------------------*/
55
56 typedef enum {
57
63
65
66 /* General linear solver context (opaque) */
67
68 typedef struct _cs_sles_t cs_sles_t;
69
70 /*----------------------------------------------------------------------------
71  * Function pointer for pre-resolution setup of a linear system solvers's
72  * context.
73  *
74  * This setup may include building a multigrid hierarchy, or a preconditioner.
75  *
76  * Use of this type of function is optional: the context is expected to
77  * maintain state, so that if a cs_sles_solve_t function is called before a
78  * cs_sles_setup_t function, the latter will be called automatically.
79  *
80  * parameters:
81  * context <-> pointer to solver context
82  * name <-- pointer to name of linear system
83  * a <-- matrix
84  * verbosity <-- associated verbosity
85  *----------------------------------------------------------------------------*/
86
87 typedef void
88 (cs_sles_setup_t) (void *context,
89  const char *name,
90  const cs_matrix_t *a,
91  int verbosity);
92
93 /*----------------------------------------------------------------------------
94  * Function pointer for resolution of a linear system.
95  *
96  * If the associated cs_sles_setup_t function has not been called before
97  * this function, it will be called automatically.
98  *
99  * The solution context setup by this call (or that of the matching setup
100  * function) will be maintained until the matching cs_sles_free_t function
101  * is called.
102  *
103  * The matrix is not expected to change between successive calls, although
104  * the right hand side may. If the matrix changes, the associated
105  * cs_sles_setup_t or cs_sles_free_t function must be called between
106  * solves.
107  *
108  * The system is considered to have converged when
109  * residue/r_norm <= precision, residue being the L2 norm of a.vx-rhs.
110  *
111  * parameters:
112  * context <-> pointer to solver context
113  * name <-- pointer to name of linear system
114  * a <-- matrix
115  * verbosity <-- associated verbosity
116  * precision <-- solver precision
117  * r_norm <-- residue normalization
118  * n_iter --> number of "equivalent" iterations
119  * residue --> residue
120  * rhs <-- right hand side
121  * vx <-- system solution
122  * aux_size <-- number of elements in aux_vectors
123  * aux_vectors <-- optional working area (internal allocation if NULL)
124  *
125  * returns:
126  * convergence status
127  *----------------------------------------------------------------------------*/
128
130 (cs_sles_solve_t) (void *context,
131  const char *name,
132  const cs_matrix_t *a,
133  int verbosity,
134  double precision,
135  double r_norm,
136  int *n_iter,
137  double *residue,
138  const cs_real_t *rhs,
139  cs_real_t *vx,
140  size_t aux_size,
141  void *aux_vectors);
142
143 /*----------------------------------------------------------------------------
144  * Function pointer for freeing of a linear system's context data.
145  *
146  * Note that this function should free resolution-related data, such as
147  * multigrid hierarchy, preconditioning, and any other temporary arrays or
148  * objects required for resolution, but should not free the whole context,
149  * as info used for logging (especially performance data) should be
150  * maintained.
151  *
152  * parameters:
153  * context <-> pointer to solver context
154  *----------------------------------------------------------------------------*/
155
156 typedef void
157 (cs_sles_free_t) (void *context);
158
159 /*----------------------------------------------------------------------------
160  * Function pointer for logging of linear solver setup,
161  * history and performance data.
162  *
163  * This function will be called for each solver when cs_sles_finalize()
164  * is called.
165  *
166  * parameters:
167  * context <-- pointer to solver context
168  * log_type <-- log type
169  *----------------------------------------------------------------------------*/
170
171 typedef void
172 (cs_sles_log_t) (const void *context,
173  cs_log_t log_type);
174
175 /*----------------------------------------------------------------------------
176  * Function pointer for creation of a solver context based on the copy
177  * of another.
178  *
179  * The new context copies the settings of the copied context, but not
180  * its setup data and logged info, such as performance data.
181  *
182  * This type of function is optional, but enables associating different
183  * solvers to related systems (to differentiate logging) while using
184  * the same settings by default.
185  *
186  * parameters:
187  * context <-- source context
188  *
189  * returns:
190  * pointer to newly created context
191  *----------------------------------------------------------------------------*/
192
193 typedef void *
194 (cs_sles_copy_t) (const void *context);
195
196 /*----------------------------------------------------------------------------
197  * Function pointer for destruction of a linear system solver context.
198  *
199  * This function should free all context data, and will be called for each
200  * system when cs_sles_finalize() is called.
201  *
202  * parameters:
203  * context <-> pointer to solver context
204  *----------------------------------------------------------------------------*/
205
206 typedef void
207 (cs_sles_destroy_t) (void **context);
208
209 /*----------------------------------------------------------------------------
210  * Function pointer for handling of non-convegence when solving
211  * a linear system.
212  *
213  * Such a function is optional, and may be used for a variety of purposes,
214  * such as logging, postprocessing, re-trying with different parameters,
215  * aborting the run, or any combination thereof.
216  *
217  * An error handler may be associated with a given solver using
218  * cs_sles_set_error_handler(), in which case it will be called whenever
219  * convergence fails.
220  *
221  * parameters:
222  * sles <-> pointer to solver object
223  * state <-- convergence status
224  * a <-- matrix
225  * rhs <-- Right hand side
226  * vx <-- System solution
227  *
228  * returns:
229  * true if solve should be re-executed, false otherwise
230  *----------------------------------------------------------------------------*/
231
232 typedef bool
235  const cs_matrix_t *a,
236  const cs_real_t *rhs,
237  cs_real_t *vx);
238
239 /*----------------------------------------------------------------------------
240  * Function pointer for the default definition of a sparse
241  * linear equation solver
242  *
243  * The function may be associated using cs_sles_set_default_define(), so
244  * that it may provide a definition that will be used when
245  * cs_sles_setup() or cs_sles_solve() is used for a system for which
246  * no matching call to cs_sles_define() has been done.
247  *
248  * The function should call cs_sles_define() with arguments f_id
249  * and name, and appropriately chosen function pointers.
250  *
251  * A pointer to the matrix of the system to be solved is also provided,
252  * so that the corresponding information may be used to better choose
253  * defaults.
254  *
255  * parameters:
256  * f_id <-- associated field id, or < 0
257  * name <-- associated name if f_id < 0, or NULL
258  * a <-- Matrix
259  *----------------------------------------------------------------------------*/
260
261 typedef void
262 (cs_sles_define_t) (int f_id,
263  const char *name,
264  const cs_matrix_t *a);
265
266 /*----------------------------------------------------------------------------
267  * Function pointer for the default definition of a sparse
268  * linear equation solver's verbosity
269  *
270  * The function may be associated using cs_sles_set_default_verbosity(), so
271  * that it may provide a definition that will be used when
272  * cs_sles_default_verbosity() is called.
273  *
274  * parameters:
275  * f_id <-- associated field id, or < 0
276  * name <-- associated name if f_id < 0, or NULL
277  *
278  * returns:
279  * default verbosity value
280  *----------------------------------------------------------------------------*/
281
282 typedef int
284  const char *name);
285
286 /*============================================================================
287  * Global variables
288  *============================================================================*/
289
290 /*=============================================================================
291  * Public function prototypes for Fortran API
292  *============================================================================*/
293
294 /*=============================================================================
295  * Public function prototypes
296  *============================================================================*/
297
298 /*----------------------------------------------------------------------------
299  * \brief Initialize sparse linear equation solver API.
300  *----------------------------------------------------------------------------*/
301
302 void
303 cs_sles_initialize(void);
304
305 /*----------------------------------------------------------------------------
306  * \brief Finalize sparse linear equation solver API.
307  *----------------------------------------------------------------------------*/
308
309 void
310 cs_sles_finalize(void);
311
312 /*----------------------------------------------------------------------------*/
318 /*----------------------------------------------------------------------------*/
319
320 void
321 cs_sles_log(cs_log_t log_type);
322
323 /*----------------------------------------------------------------------------*/
335 /*----------------------------------------------------------------------------*/
336
337 cs_sles_t *
338 cs_sles_find(int f_id,
339  const char *name);
340
341 /*----------------------------------------------------------------------------*/
358 /*----------------------------------------------------------------------------*/
359
360 cs_sles_t *
361 cs_sles_find_or_add(int f_id,
362  const char *name);
363
364 /*----------------------------------------------------------------------------*/
381 /*----------------------------------------------------------------------------*/
382
383 void
384 cs_sles_push(int f_id,
385  const char *name);
386
387 /*----------------------------------------------------------------------------*/
395 /*----------------------------------------------------------------------------*/
396
397 void
398 cs_sles_pop(int f_id);
399
400 /*----------------------------------------------------------------------------*/
435 /*----------------------------------------------------------------------------*/
436
437 cs_sles_t *
438 cs_sles_define(int f_id,
439  const char *name,
440  void *context,
441  const char *type_name,
442  cs_sles_setup_t *setup_func,
443  cs_sles_solve_t *solve_func,
444  cs_sles_free_t *free_func,
445  cs_sles_log_t *log_func,
446  cs_sles_copy_t *copy_func,
447  cs_sles_destroy_t *destroy_func);
448
449 /*----------------------------------------------------------------------------*/
461 /*----------------------------------------------------------------------------*/
462
463 void
465  int verbosity);
466
467 /*----------------------------------------------------------------------------*/
477 /*----------------------------------------------------------------------------*/
478
479 int
481
482 /*----------------------------------------------------------------------------*/
493 /*----------------------------------------------------------------------------*/
494
495 void
497  int writer_id);
498
499 /*----------------------------------------------------------------------------*/
508 /*----------------------------------------------------------------------------*/
509
510 int
512
513 /*----------------------------------------------------------------------------*/
532 /*----------------------------------------------------------------------------*/
533
534 const char *
536
537 /*----------------------------------------------------------------------------*/
549 /*----------------------------------------------------------------------------*/
550
551 void *
553
554 /*----------------------------------------------------------------------------*/
562 /*----------------------------------------------------------------------------*/
563
564 int
565 cs_sles_get_f_id(const cs_sles_t *sles);
566
567 /*----------------------------------------------------------------------------*/
578 /*----------------------------------------------------------------------------*/
579
580 const char *
581 cs_sles_get_name(const cs_sles_t *sles);
582
583 /*----------------------------------------------------------------------------*/
597 /*----------------------------------------------------------------------------*/
598
599 void
601  const cs_matrix_t *a);
602
603 /*----------------------------------------------------------------------------*/
633 /*----------------------------------------------------------------------------*/
634
637  const cs_matrix_t *a,
638  double precision,
639  double r_norm,
640  int *n_iter,
641  double *residue,
642  const cs_real_t *rhs,
643  cs_real_t *vx,
644  size_t aux_size,
645  void *aux_vectors);
646
647 /*----------------------------------------------------------------------------*/
658 /*----------------------------------------------------------------------------*/
659
660 void
661 cs_sles_free(cs_sles_t *sles);
662
663 /*----------------------------------------------------------------------------*/
683 /*----------------------------------------------------------------------------*/
684
685 int
686 cs_sles_copy(cs_sles_t *dest,
687  const cs_sles_t *src);
688
689 /*----------------------------------------------------------------------------*/
704 /*----------------------------------------------------------------------------*/
705
706 void
708  cs_sles_error_handler_t *error_handler_func);
709
710 /*----------------------------------------------------------------------------*/
720 /*----------------------------------------------------------------------------*/
721
724
725 /*----------------------------------------------------------------------------*/
735 /*----------------------------------------------------------------------------*/
736
737 void
739
740 /*----------------------------------------------------------------------------*/
749 /*----------------------------------------------------------------------------*/
750
751 void
753
754 /*----------------------------------------------------------------------------*/
764 /*----------------------------------------------------------------------------*/
765
766 void
767 cs_sles_post_error_output_def(const char *name,
768  int mesh_id,
769  const cs_matrix_t *a,
770  const cs_real_t *rhs,
771  cs_real_t *vx);
772
773 /*----------------------------------------------------------------------------*/
785 /*----------------------------------------------------------------------------*/
786
787 void
788 cs_sles_post_output_var(const char *name,
789  int mesh_id,
790  int location_id,
791  int writer_id,
792  int diag_block_size,
793  cs_real_t var[]);
794
795 /*----------------------------------------------------------------------------*/
807 /*----------------------------------------------------------------------------*/
808
809 const char *
810 cs_sles_base_name(int f_id,
811  const char *name);
812
813 /*----------------------------------------------------------------------------*/
822 /*----------------------------------------------------------------------------*/
823
824 const char *
825 cs_sles_name(int f_id,
826  const char *name);
827
828 /*----------------------------------------------------------------------------*/
829
831
832 #endif /* __CS_SLES_H__ */
cs_sles_define_t * cs_sles_get_default_define(void)
Return pointer to default sparse linear solver definition function.
Definition: cs_sles.c:1823
cs_sles_t * cs_sles_find_or_add(int f_id, const char *name)
Return pointer to linear system object, based on matching field id or system name.
Definition: cs_sles.c:1166
void cs_sles_log(cs_log_t log_type)
Log sparse linear equation solver info.
Definition: cs_sles.c:943
const char * cs_sles_get_type(cs_sles_t *sles)
Return type name of solver context.
Definition: cs_sles.c:1442
cs_sles_convergence_state_t cs_sles_solve(cs_sles_t *sles, const cs_matrix_t *a, double precision, double r_norm, int *n_iter, double *residue, const cs_real_t *rhs, cs_real_t *vx, size_t aux_size, void *aux_vectors)
General sparse linear system resolution.
Definition: cs_sles.c:1587
void cs_sles_setup(cs_sles_t *sles, const cs_matrix_t *a)
Setup sparse linear equation solver.
Definition: cs_sles.c:1519
void cs_sles_initialize(void)
Definition: cs_sles.c:883
void() cs_sles_define_t(int f_id, const char *name, const cs_matrix_t *a)
Function pointer for the default definition of a sparse linear equation solver.
Definition: cs_sles.h:262
Definition: cs_sles.h:61
const char * cs_sles_get_name(const cs_sles_t *sles)
Return name associated with a given sparse linear equation solver.
Definition: cs_sles.c:1497
const char * cs_sles_name(int f_id, const char *name)
Return name associated to a field id, name couple.
Definition: cs_sles.c:2129
void() cs_sles_free_t(void *context)
Function pointer for freeing of a linear system&#39;s context data.
Definition: cs_sles.h:157
cs_sles_t * cs_sles_find(int f_id, const char *name)
Definition: cs_sles.c:1101
bool() cs_sles_error_handler_t(cs_sles_t *sles, cs_sles_convergence_state_t state, const cs_matrix_t *a, const cs_real_t *rhs, cs_real_t *vx)
Function pointer for handling of non-convergence when solving a linear system.
Definition: cs_sles.h:233
void cs_sles_set_default_verbosity(cs_sles_verbosity_t *verbosity_func)
Set default verbosity definition function.
Definition: cs_sles.c:1858
void cs_sles_push(int f_id, const char *name)
Temporarily replace field id with name for matching calls to cs_sles_setup, cs_sles_solve, cs_sles_free, and other operations involving access through a field id.
Definition: cs_sles.c:1203
Definition: cs_defs.h:322
void cs_sles_free(cs_sles_t *sles)
Free sparse linear equation solver setup.
Definition: cs_sles.c:1715
Definition: cs_matrix.h:93
void * cs_sles_get_context(cs_sles_t *sles)
Return pointer to solver context structure pointer.
Definition: cs_sles.c:1462
void cs_sles_set_error_handler(cs_sles_t *sles, cs_sles_error_handler_t *error_handler_func)
Associate a convergence error handler to a given sparse linear equation solver.
Definition: cs_sles.c:1803
int cs_sles_get_post_output(cs_sles_t *sles)
Return the id of the associated writer if postprocessing output is active for a given linear equation...
Definition: cs_sles.c:1410
void() cs_sles_setup_t(void *context, const char *name, const cs_matrix_t *a, int verbosity)
Function pointer for pre-resolution setup of a linear system&#39;s context.
Definition: cs_sles.h:88
Convergence status indicator.
Definition: cs_sles.h:56
Definition: cs_sles.h:68
Definition: cs_sles.h:60
void cs_sles_finalize(void)
Definition: cs_sles.c:903
int cs_sles_get_f_id(const cs_sles_t *sles)
Return field id associated with a given sparse linear equation solver.
Definition: cs_sles.c:1478
double precision, save a
int cs_sles_get_verbosity(cs_sles_t *sles)
Get the verbosity for a given linear equation solver.
Definition: cs_sles.c:1363
int cs_sles_copy(cs_sles_t *dest, const cs_sles_t *src)
Copy the definition of a sparse linear equation solver to another.
Definition: cs_sles.c:1746
void() cs_sles_destroy_t(void **context)
Definition: cs_sles.h:207
int() cs_sles_verbosity_t(int f_id, const char *name)
Function pointer for the default definition of a sparse linear equation solver&#39;s verbosity.
Definition: cs_sles.h:283
void *() cs_sles_copy_t(const void *context)
Function pointer for creation of a solver context based on the copy of another.
Definition: cs_sles.h:194
cs_log_t
Definition: cs_log.h:48
void cs_sles_set_post_output(cs_sles_t *sles, int writer_id)
Activate postprocessing output for a given linear equation solver.
Definition: cs_sles.c:1382
void() cs_sles_log_t(const void *context, cs_log_t log_type)
Function pointer for logging of linear solver history and performance data.
Definition: cs_sles.h:172
cs_sles_convergence_state_t() cs_sles_solve_t(void *context, const char *name, const cs_matrix_t *a, int verbosity, double precision, double r_norm, int *n_iter, double *residue, const cs_real_t *rhs, cs_real_t *vx, size_t aux_size, void *aux_vectors)
Definition: cs_sles.h:130
Definition: cs_sles.h:62
void cs_sles_post_error_output_def(const char *name, int mesh_id, const cs_matrix_t *a, const cs_real_t *rhs, cs_real_t *vx)
Output default post-processing data for failed system convergence.
Definition: cs_sles.c:1876
const char * cs_sles_base_name(int f_id, const char *name)
Return base name associated to a field id, name couple.
Definition: cs_sles.c:2104
Definition: cs_sles.h:59
void cs_sles_set_default_define(cs_sles_define_t *define_func)
Set default sparse linear solver definition function.
Definition: cs_sles.c:1841
void cs_sles_set_verbosity(cs_sles_t *sles, int verbosity)
Set the verbosity for a given linear equation solver.
Definition: cs_sles.c:1344
cs_sles_t * cs_sles_define(int f_id, const char *name, void *context, const char *type_name, cs_sles_setup_t *setup_func, cs_sles_solve_t *solve_func, cs_sles_free_t *free_func, cs_sles_log_t *log_func, cs_sles_copy_t *copy_func, cs_sles_destroy_t *destroy_func)
Define sparse linear equation solver for a given field or equation name.
Definition: cs_sles.c:1291
void cs_sles_pop(int f_id)
Restore behavior temporarily modified by cs_sles_push.
Definition: cs_sles.c:1239
Definition: cs_sles.h:58
void cs_sles_post_output_var(const char *name, int mesh_id, int location_id, int writer_id, int diag_block_size, cs_real_t var[])
Output post-processing variable related to system convergence.
Definition: cs_sles.c:1988
