7.1
cs_base.h File Reference
+ Include dependency graph for cs_base.h:
Macros
#define CS_APP_NAME   "Code_Saturne"
#define CS_APP_VERSION   PACKAGE_VERSION /* PACKAGE_VERSION from autoconf */
#define CS_MEM_ALIGN   0
#define CS_BASE_STRING_LEN   80
Typedefs
typedef void() cs_base_atexit_t(void)
char * cs_base_get_app_name (int argc, const char *argv[])
void cs_base_logfile_head (int argc, char *argv[])
void cs_base_mpi_init (int *argc, char **argv[])
MPI_Comm cs_base_get_rank_step_comm (int rank_step)
 Return a reduced communicator matching a multiple of the total number of ranks. More...
void cs_exit (int status)
void cs_base_error_init (bool signal_defaults)
void cs_base_mem_init (void)
void cs_base_mem_finalize (void)
void cs_base_time_summary (void)
void cs_base_update_status (const char *format,...)
 Update status file. More...
void cs_base_trace_set (bool trace)
void cs_base_bft_printf_init (const char *log_name, bool rn_log_flag)
void cs_base_bft_printf_set (const char *log_name, bool rn_log_flag)
const char * cs_base_bft_printf_name (void)
bool cs_base_bft_printf_suppressed (void)
void cs_base_warn (const char *file_name, int line_num)
void cs_base_atexit_set (cs_base_atexit_t *const fct)
char * cs_base_string_f_to_c_create (const char *f_str, int f_len)
void cs_base_string_f_to_c_free (char **c_str)
void cs_base_option_string_clean (char *s)
const char * cs_base_get_localedir (void)
const char * cs_base_get_pkgdatadir (void)
const char * cs_base_get_pkglibdir (void)
void cs_base_check_bool (bool *b)
FILE * cs_base_open_properties_data_file (const char *base_name)
void * cs_base_dlopen (const char *filename)
 Load a dynamic library. More...
void * cs_base_dlopen_plugin (const char *name)
 Load a plugin's dynamic library. More...
int cs_base_dlopen_get_flags (void)
 Get flags for dlopen. More...
void cs_base_dlopen_set_flags (int flags)
 Set flags for dlopen. More...
void cs_base_dlclose (const char *filename, void *handle)
 Unload a dynamic library. More...
void * cs_base_get_dl_function_pointer (void *handle, const char *name, bool errors_are_fatal)
 Get a shared library function pointer. More...
void cs_base_backtrace_dump (FILE *f, int lv_start)
 Dump a stack trace to a file. More...
void cs_base_get_run_identity (char **run_id, char **case_name, char **study_name)
 Query run-time directory info, using working directory names. More...
◆ CS_APP_NAME
◆ CS_APP_VERSION
◆ CS_BASE_STRING_LEN
◆ CS_MEM_ALIGN
Typedef Documentation
◆ cs_base_atexit_t
◆ cs_base_atexit_set()
void cs_base_atexit_set ( cs_base_atexit_t *const  fct)
◆ cs_base_backtrace_dump()
void cs_base_backtrace_dump ( FILE *  f,
int  lv_start
[in]fpointer to file in which to dump trace
[in]lv_startstart level in stack trace
◆ cs_base_bft_printf_init()
void cs_base_bft_printf_init ( const char *  log_name,
bool  rn_log_flag
◆ cs_base_bft_printf_name()
const char* cs_base_bft_printf_name ( void  )
◆ cs_base_bft_printf_set()
void cs_base_bft_printf_set ( const char *  log_name,
bool  rn_log_flag
◆ cs_base_bft_printf_suppressed()
bool cs_base_bft_printf_suppressed ( void  )
◆ cs_base_check_bool()
void cs_base_check_bool ( bool *  b)
◆ cs_base_dlclose()
void cs_base_dlclose ( const char *  filename,
void *  handle
Note that the dlopen underlying mechanism uses a reference count, so a library is really unloaded only one cs_base_dlclose has been called the same number of times as cs_base_dlopen.
[in]filenameoptional path to shared library file name for error logging, or NULL
[in]handlehandle to shared library
◆ cs_base_dlopen()
void* cs_base_dlopen ( const char *  filename)
[in]filenamepath to shared library file.
◆ cs_base_dlopen_get_flags()
int cs_base_dlopen_get_flags ( void  )
flags used for dlopen.
◆ cs_base_dlopen_plugin()
void* cs_base_dlopen_plugin ( const char *  name)
This function is similar to cs_base_dlopen, except that only the base plugin file name (with no extension) needs to be given. It is assumed the file is available in the code's "pkglibdir" directory,
[in]namepath to shared library file
◆ cs_base_dlopen_set_flags()
void cs_base_dlopen_set_flags ( int  flags)
[in]flagsflags to set
◆ cs_base_error_init()
void cs_base_error_init ( bool  signal_defaults)
◆ cs_base_get_app_name()
char* cs_base_get_app_name ( int  argc,
const char *  argv[]
◆ cs_base_get_dl_function_pointer()
void* cs_base_get_dl_function_pointer ( void *  handle,
const char *  name,
[in]namename of function symbol in library
[in]errors_are_fatalabort if true, silently ignore if false
pointer to function in shared library
◆ cs_base_get_localedir()
const char* cs_base_get_localedir ( void  )
◆ cs_base_get_pkgdatadir()
const char* cs_base_get_pkgdatadir ( void  )
◆ cs_base_get_pkglibdir()
const char* cs_base_get_pkglibdir ( void  )
◆ cs_base_get_rank_step_comm()
MPI_Comm cs_base_get_rank_step_comm ( int  rank_step)
This updates the number of reduced communicators if necessary.
[in]rank_stepassociated multiple of total ranks
◆ cs_base_get_run_identity()
void cs_base_get_run_identity ( char **  run_id,
char **  case_name,
char **  study_name
Returned names are allocated if non-NULL, so should be deallocated by the caller when no longer needed.
Names are extracted from the working directory structure, which is expected to be of the form: <prefix>/study_name/case_name/RESU/run_id
or, in the case o a coupled run: <prefix>/study_name/RESU_COUPLING/run_id/case_name
If some names cannot be queried, NULL is returned.
[out]run_idrun_id, or NULL
[out]case_namecase name, or NULL
[out]study_namestudy name, or NULL
◆ cs_base_logfile_head()
void cs_base_logfile_head ( int  argc,
char *  argv[]
◆ cs_base_mem_finalize()
void cs_base_mem_finalize ( void  )
◆ cs_base_mem_init()
void cs_base_mem_init ( void  )
◆ cs_base_mpi_init()
void cs_base_mpi_init ( int *  argc,
char **  argv[]
◆ cs_base_open_properties_data_file()
FILE* cs_base_open_properties_data_file ( const char *  base_name)
◆ cs_base_option_string_clean()
void cs_base_option_string_clean ( char *  s)
◆ cs_base_string_f_to_c_create()
char* cs_base_string_f_to_c_create ( const char *  f_str,
int  f_len
◆ cs_base_string_f_to_c_free()
void cs_base_string_f_to_c_free ( char **  c_str)
◆ cs_base_time_summary()
void cs_base_time_summary ( void  )
◆ cs_base_trace_set()
void cs_base_trace_set ( bool  trace)
◆ cs_base_update_status()
void cs_base_update_status ( const char *  format,
Update status file.
If the format string is NULL, the file is removed.
[in]formatformat string, or NULL
[in]...format arguments
◆ cs_base_warn()
void cs_base_warn ( const char *  file_name,
int  line_num
◆ cs_exit()
void cs_exit ( int  status)
