48 #define CS_APP_NAME "Code_Saturne" 49 #define CS_APP_VERSION PACKAGE_VERSION 53 #if defined(__linux__) || defined(__linux) || defined(linux) 54 #define _CS_ARCH_Linux 62 #define CS_MEM_ALIGN 0 64 #define CS_BASE_STRING_LEN 80 97 static inline const char *
98 cs_base_strtf(
bool boolean)
138 #if defined(HAVE_MPI) 437 #if defined(HAVE_DLOPEN) 524 bool errors_are_fatal);
void cs_base_trace_set(bool trace)
Definition: cs_base.c:1886
void cs_base_string_f_to_c_free(char **c_str)
Definition: cs_base.c:2171
void cs_base_mem_finalize(void)
Definition: cs_base.c:1583
void() cs_base_atexit_t(void)
Definition: cs_base.h:77
void * cs_base_dlopen_plugin(const char *name)
Load a plugin's dynamic library.
Definition: cs_base.c:2393
char * cs_base_string_f_to_c_create(const char *f_str, int f_len)
Definition: cs_base.c:2114
void * cs_base_dlopen(const char *filename)
Load a dynamic library.
Definition: cs_base.c:2353
const char * cs_base_get_localedir(void)
Definition: cs_base.c:2229
const char * cs_base_get_pkglibdir(void)
Definition: cs_base.c:2262
void cs_base_warn(const char *file_name, int line_num)
Definition: cs_base.c:2076
void cs_base_option_string_clean(char *s)
Definition: cs_base.c:2199
void cs_base_mem_init(void)
Definition: cs_base.c:1512
void cs_base_mpi_init(int *argc, char **argv[])
Definition: cs_base.c:1240
void cs_base_bft_printf_init(const char *log_name, bool rn_log_flag)
Definition: cs_base.c:1905
bool cs_base_bft_printf_suppressed(void)
Definition: cs_base.c:2062
int cs_base_dlopen_get_flags(void)
Get flags for dlopen.
Definition: cs_base.c:2424
void cs_exit(int status)
Definition: cs_base.c:1427
void cs_base_logfile_head(int argc, char *argv[])
Definition: cs_base.c:1144
void * cs_base_get_dl_function_pointer(void *handle, const char *name, bool errors_are_fatal)
Get a shared library function pointer.
Definition: cs_base.c:2491
char * cs_base_get_app_name(int argc, const char *argv[])
Definition: cs_base.c:1085
void cs_base_backtrace_dump(FILE *f, int lv_start)
Dump a stack trace to a file.
Definition: cs_base.c:2522
void cs_base_check_bool(bool *b)
Definition: cs_base.c:2280
void cs_base_update_status(const char *format,...)
Update status file.
Definition: cs_base.c:1809
void cs_base_dlopen_set_flags(int flags)
Set flags for dlopen.
Definition: cs_base.c:2438
FILE * cs_base_open_properties_data_file(const char *base_name)
Definition: cs_base.c:2310
void cs_base_get_run_identity(char **run_id, char **case_name, char **study_name)
Query run-time directory info, using working directory names.
Definition: cs_base.c:2599
MPI_Comm cs_base_get_rank_step_comm(int rank_step)
Return a reduced communicator matching a multiple of the total number of ranks.
Definition: cs_base.c:1349
const char * cs_base_get_pkgdatadir(void)
Definition: cs_base.c:2244
void cs_base_bft_printf_set(const char *log_name, bool rn_log_flag)
Definition: cs_base.c:1983
void cs_base_error_init(bool signal_defaults)
Definition: cs_base.c:1469
void cs_base_time_summary(void)
Definition: cs_base.c:1729
void cs_base_dlclose(const char *filename, void *handle)
Unload a dynamic library.
Definition: cs_base.c:2458
void cs_base_atexit_set(cs_base_atexit_t *const fct)
Definition: cs_base.c:2095
double precision, save b
const char * cs_base_bft_printf_name(void)
Definition: cs_base.c:2046
