1 #ifndef __CS_TURBULENCE_MODEL_H__ 2 #define __CS_TURBULENCE_MODEL_H__ const double cs_turb_csav1
Definition: cs_turbulence_model.c:729
const double cs_turb_ckwsw1
Definition: cs_turbulence_model.c:637
const double cs_turb_cstlog
Definition: cs_turbulence_model.c:407
double cs_turb_csrij
Definition: cs_turbulence_model.c:574
int itytur
Definition: cs_turbulence_model.h:138
const double cs_turb_ckwsw2
Definition: cs_turbulence_model.c:643
const cs_turb_rans_model_t * cs_glob_turb_rans_model
const double cs_turb_cebmr1
Definition: cs_turbulence_model.c:564
const double cs_turb_cnl3
Definition: cs_turbulence_model.c:920
const double cs_turb_cssgr4
Definition: cs_turbulence_model.c:550
Definition: cs_turbulence_model.h:54
Definition: cs_turbulence_model.h:105
const double cs_turb_cnl1
Definition: cs_turbulence_model.c:918
const double cs_turb_cssgr2
Definition: cs_turbulence_model.c:538
void cs_turb_constants_log_setup(void)
Print the turbulent constants to setup.log.
Definition: cs_turbulence_model.c:1857
double cs_turb_ckwgm2
Definition: cs_turbulence_model.c:678
const double cebmr5
Definition: cstphy.f90:446
Definition: cs_turbulence_model.h:79
const double cs_turb_cpalct
Definition: cs_turbulence_model.c:613
double xlomlg
Definition: cs_turbulence_model.h:235
const double cs_turb_c3trit
Definition: cs_turbulence_model.c:952
Definition: cs_turbulence_model.h:68
const double cs_turb_csas
Definition: cs_turbulence_model.c:704
int irijec
Definition: cs_turbulence_model.h:222
const double cs_turb_ccazd
Definition: cs_turbulence_model.c:789
const double cs_turb_crijp2
Definition: cs_turbulence_model.c:508
const double cs_turb_cv2fe2
Definition: cs_turbulence_model.c:882
int order
Definition: cs_turbulence_model.h:151
cs_turb_les_model_t * cs_get_glob_turb_les_model(void)
Provide access to cs_glob_turb_les_model.
Definition: cs_turbulence_model.c:1546
Definition: cs_turbulence_model.h:104
const double cs_turb_ccaze2
Definition: cs_turbulence_model.c:764
Turbulence model general options descriptor.
Definition: cs_turbulence_model.h:114
int idries
Definition: cs_turbulence_model.h:244
int irijrb
Definition: cs_turbulence_model.h:218
double cs_turb_crij2
Definition: cs_turbulence_model.c:485
const double cs_turb_ales
Definition: cs_turbulence_model.c:808
double almax
Definition: cs_turbulence_model.h:164
Definition: cs_turbulence_model.h:82
Definition: cs_turbulence_model.h:107
double cs_turb_crij1
Definition: cs_turbulence_model.c:479
Definition: cs_turbulence_model.h:94
const double cs_turb_cssr3
Definition: cs_turbulence_model.c:759
const double cebmr2
Definition: cs_turbulence_model.h:57
const double cs_turb_xceta
Definition: cs_turbulence_model.c:592
int igrari
Definition: cs_turbulence_model.h:201
int irccor
Definition: cs_turbulence_model.h:175
const double cs_turb_ckwsk2
Definition: cs_turbulence_model.c:631
int itycor
Definition: cs_turbulence_model.h:179
const double cs_turb_cssgr3
Definition: cs_turbulence_model.c:544
int igrake
Definition: cs_turbulence_model.h:198
const double cs_turb_xiafm
Definition: cs_turbulence_model.c:932
const cs_turb_les_model_t * cs_glob_turb_les_model
Definition: cs_turbulence_model.h:162
void cs_set_glob_turb_model(void)
Set global pointer to turbulence model structure.
Definition: cs_turbulence_model.c:1436
const double cs_turb_crijp1
Definition: cs_turbulence_model.c:500
Definition: cs_turbulence_model.h:81
double cs_turb_cdries
Definition: cs_turbulence_model.c:870
const double cs_turb_cpalc2
Definition: cs_turbulence_model.c:610
double cs_turb_cddes
Definition: cs_turbulence_model.c:698
const double cs_turb_cnl4
Definition: cs_turbulence_model.c:921
const double cs_turb_cpale2
Definition: cs_turbulence_model.c:598
int irijnu
Definition: cs_turbulence_model.h:214
const double cs_turb_apow
Definition: cs_turbulence_model.c:432
Definition: cs_turbulence_model.h:56
int reinit_turb
Definition: cs_turbulence_model.h:208
int iclptr
Definition: cs_turbulence_model.h:232
const double cs_turb_cpale3
Definition: cs_turbulence_model.c:601
double cs_turb_ce2
Definition: cs_turbulence_model.c:464
void cs_turb_model_log_setup(void)
Print the turbulence model parameters to setup.log.
Definition: cs_turbulence_model.c:1558
double cs_turb_cwale
Definition: cs_turbulence_model.c:927
const double cs_turb_xa1
Definition: cs_turbulence_model.c:586
const double cs_turb_cebmmu
Definition: cs_turbulence_model.c:580
const double cs_turb_ckwa1
Definition: cs_turbulence_model.c:685
double cs_turb_cmu025
Definition: cs_turbulence_model.c:448
const double cs_turb_cebms2
Definition: cs_turbulence_model.c:562
const double cs_turb_cv2fc1
Definition: cs_turbulence_model.c:888
Definition: cs_turbulence_model.h:59
double cs_turb_csmago_max
Definition: cs_turbulence_model.c:851
Definition: cs_turbulence_model.h:64
int type
Definition: cs_turbulence_model.h:146
const double cs_turb_cv2fa1
Definition: cs_turbulence_model.c:876
void cs_set_type_order_turbulence_model(void)
Initialize type and order members of turbulence model structure.
Definition: cs_turbulence_model.c:1378
Definition: cs_turbulence_model.h:67
const double cs_turb_xlesfl
Definition: cs_turbulence_model.c:799
double cs_turb_crij3
Definition: cs_turbulence_model.c:491
const double cebmr3
const double cs_turb_c1trit
Definition: cs_turbulence_model.c:942
void cs_turb_model_init(void)
Initialize turbulence model structures.
Definition: cs_turbulence_model.c:1364
const double cs_turb_bles
Definition: cs_turbulence_model.c:817
double cs_turb_ce4
Definition: cs_turbulence_model.c:473
Definition: cs_turbulence_model.h:62
RANS turbulence model descriptor.
Definition: cs_turbulence_model.h:173
Definition: cs_turbulence_model.h:65
Definition: cs_turbulence_model.h:69
void cs_turb_compute_constants(void)
Compute turbulence model constants, some of which may depend on the model choice. ...
Definition: cs_turbulence_model.c:1451
const cs_turb_ref_values_t * cs_glob_turb_ref_values
Definition: cs_turbulence_model.h:80
const double cs_turb_csaw3
Definition: cs_turbulence_model.c:744
const double cs_turb_cv2fct
Definition: cs_turbulence_model.c:900
const double cs_turb_cssgs1
Definition: cs_turbulence_model.c:520
cs_turb_model_type_t
Definition: cs_turbulence_model.h:52
const double cs_turb_cv2fet
Definition: cs_turbulence_model.c:912
const double cs_turb_cv2fc2
Definition: cs_turbulence_model.c:894
double cs_turb_ce1
Definition: cs_turbulence_model.c:456
const double cs_turb_cstlog_rough
Definition: cs_turbulence_model.c:418
const double cs_turb_xkappa
Definition: cs_turbulence_model.c:387
double cs_turb_xlesfd
Definition: cs_turbulence_model.c:841
double cs_turb_ckwgm1
Definition: cs_turbulence_model.c:667
Definition: cs_turbulence_model.h:63
const double cs_turb_csab2
Definition: cs_turbulence_model.c:719
const double cs_turb_csab1
Definition: cs_turbulence_model.c:714
const double cs_turb_ccazc
Definition: cs_turbulence_model.c:784
const double cs_turb_ccazsc
Definition: cs_turbulence_model.c:769
int ikecou
Definition: cs_turbulence_model.h:204
Definition: cs_turbulence_model.h:61
const double cs_turb_cssgr5
Definition: cs_turbulence_model.c:556
const double cs_turb_ccazb
Definition: cs_turbulence_model.c:779
const double cs_turb_ckwbt2
Definition: cs_turbulence_model.c:655
const double cs_turb_cpalcl
Definition: cs_turbulence_model.c:616
cs_turb_ref_values_t * cs_get_glob_turb_ref_values(void)
Provide access to cs_glob_turb_ref_values.
Definition: cs_turbulence_model.c:1518
int idifre
Definition: cs_turbulence_model.h:225
int iturb
Definition: cs_turbulence_model.h:116
const double cs_turb_ckwsk1
Definition: cs_turbulence_model.c:625
const double cs_turb_cpalet
Definition: cs_turbulence_model.c:619
LES turbulence model descriptor.
Definition: cs_turbulence_model.h:242
const double cebmr4
const double cs_turb_vdriest
Definition: cs_turbulence_model.c:396
const double cs_turb_cpale1
Definition: cs_turbulence_model.c:595
int hybrid_turb
Definition: cs_turbulence_model.h:140
const double cs_turb_cthafm
Definition: cs_turbulence_model.c:962
cs_turb_model_t * cs_get_glob_turb_model(void)
Provide write access to turbulence model structure.
Definition: cs_turbulence_model.c:1422
const double cs_turb_cnl2
Definition: cs_turbulence_model.c:919
const double cs_turb_csasig
Definition: cs_turbulence_model.c:724
Definition: cs_turbulence_model.h:60
const double cs_turb_c4trit
Definition: cs_turbulence_model.c:957
Definition: cs_turbulence_model.h:93
const double cs_turb_cssgs2
Definition: cs_turbulence_model.c:526
int iclsyr
Definition: cs_turbulence_model.h:229
const double cs_turb_cebme2
Definition: cs_turbulence_model.c:577
double cs_turb_csmago_min
Definition: cs_turbulence_model.c:861
int iclkep
Definition: cs_turbulence_model.h:190
const double cs_turb_cv2fcl
Definition: cs_turbulence_model.c:906
Definition: cs_turbulence_model.c:831
const double cs_turb_ckwbt1
Definition: cs_turbulence_model.c:649
Definition: cs_turbulence_model.h:66
const double cs_turb_xcl
Definition: cs_turbulence_model.c:583
const cs_turb_model_t * cs_glob_turb_model
const double cs_turb_c2trit
Definition: cs_turbulence_model.c:947
double uref
Definition: cs_turbulence_model.h:166
const double cs_turb_csas_eta2
Definition: cs_turbulence_model.c:709
const double cs_turb_cssgr1
Definition: cs_turbulence_model.c:532
const double cs_turb_etaafm
Definition: cs_turbulence_model.c:937
int igrhok
Definition: cs_turbulence_model.h:194
double cs_turb_cmu
Definition: cs_turbulence_model.c:445
const double cs_turb_ccaza
Definition: cs_turbulence_model.c:774
double cs_turb_csaw1
Definition: cs_turbulence_model.c:734
const double cs_turb_cnl5
Definition: cs_turbulence_model.c:922
void cs_clip_turbulent_fluxes(int flux_id, int ivartt)
Clipping for the turbulence flux vector.
Definition: cs_turbulence_model.c:2059
cs_turb_rans_model_t * cs_get_glob_turb_rans_model(void)
Provide access to cs_glob_turb_rans_model.
Definition: cs_turbulence_model.c:1532
int idirsm
Definition: cs_turbulence_model.h:185
const double cs_turb_ckwc1
Definition: cs_turbulence_model.c:692
const double cs_turb_cssge2
Definition: cs_turbulence_model.c:514
double cs_turb_dpow
Definition: cs_turbulence_model.c:438
int irijco
Definition: cs_turbulence_model.h:211
const double cs_turb_cpalc1
Definition: cs_turbulence_model.c:607
Definition: cs_turbulence_model.h:58
const double cs_turb_csaw2
Definition: cs_turbulence_model.c:739
Definition: cs_turbulence_model.h:106
const double cs_turb_cssr1
Definition: cs_turbulence_model.c:749
Definition: cs_turbulence_model.h:92
const double cs_turb_bpow
Definition: cs_turbulence_model.c:435
Definition: cs_turbulence_model.h:55
const double cs_turb_cebms1
Definition: cs_turbulence_model.c:559
const double cs_turb_xct
Definition: cs_turbulence_model.c:589
double cs_turb_cstlog_alpha
Definition: cs_turbulence_model.c:429
const double cs_turb_cthdfm
Definition: cs_turbulence_model.c:967
const double cs_turb_cssr2
Definition: cs_turbulence_model.c:754
const double cs_turb_cpale4
Definition: cs_turbulence_model.c:604
