7.1
bft_mem.h
1 #ifndef __BFT_MEM_H__
2 #define __BFT_MEM_H__
5  * Base memory allocation wrappers with optional tracing
30 #include "cs_defs.h"
34 /* BFT headers */
36 #include "bft_error.h"
38 /*-----------------------------------------------------------------------------*/
43  * Public types
45
47  * Public macros
49
50 /*
51  * Allocate memory for _ni items of type _type.
52  *
53  * This macro calls bft_mem_malloc(), automatically setting the
54  * allocated variable name and source file name and line arguments.
55  *
56  * parameters:
57  * _ptr --> pointer to allocated memory.
58  * _ni <-- number of items.
59  * _type <-- element type.
60  */
61
62 #define BFT_MALLOC(_ptr, _ni, _type) \
63 _ptr = (_type *) bft_mem_malloc(_ni, sizeof(_type), \
64  #_ptr, __FILE__, __LINE__)
65
66 /*
67  * Reallocate memory for _ni items of type _type.
68  *
69  * This macro calls bft_mem_realloc(), automatically setting the
70  * allocated variable name and source file name and line arguments.
71  *
72  * parameters:
73  * _ptr <-> pointer to allocated memory.
74  * _ni <-- number of items.
75  * _type <-- element type.
76  */
77
78 #define BFT_REALLOC(_ptr, _ni, _type) \
79 _ptr = (_type *) bft_mem_realloc(_ptr, _ni, sizeof(_type), \
80  #_ptr, __FILE__, __LINE__)
81
82 /*
83  * Free allocated memory.
84  *
85  * This macro calls bft_mem_free(), automatically setting the
86  * allocated variable name and source file name and line arguments.
87  *
88  * The freed pointer is set to NULL to avoid accidental reuse.
89  *
90  * parameters:
91  * _ptr <-> pointer to allocated memory.
92  */
93
94 #ifdef __cplusplus /* avoid casting from void for C++ */
95
96 #define BFT_FREE(_ptr) \
97 bft_mem_free(_ptr, #_ptr, __FILE__, __LINE__), _ptr = NULL
98
99 #else
100
101 #define BFT_FREE(_ptr) \
102 _ptr = bft_mem_free(_ptr, #_ptr, __FILE__, __LINE__)
103
104 #endif /* __cplusplus */
105
106 /*
107  * Allocate aligned memory for _ni items of type _type.
108  *
109  * This macro calls bft_mem_memalign(), automatically setting the
110  * allocated variable name and source file name and line arguments.
111  *
112  * parameters:
113  * _ptr --> pointer to allocated memory.
114  * _align <-- alignment.
115  * _ni <-- number of items.
116  * _type <-- element type.
117  */
118
119 #define BFT_MEMALIGN(_ptr, _align, _ni, _type) \
120 _ptr = (_type *) bft_mem_memalign(_align, _ni, sizeof(_type), \
121  #_ptr, __FILE__, __LINE__)
122
123 /*----------------------------------------------------------------------------
124  * Function pointer types
125  *----------------------------------------------------------------------------*/
126
127 typedef size_t
128 (bft_mem_get_size_t)(void *ptr);
129
130 typedef void *
131 (bft_mem_realloc_t)(void *ptr,
132  size_t ni,
133  size_t size,
134  const char *var_name,
135  const char *file_name,
136  int line_num);
137
138 typedef void
139 (bft_mem_free_t)(void *ptr,
140  const char *var_name,
141  const char *file_name,
142  int line_num);
143
144 /*============================================================================
145  * Public function prototypes
146  *============================================================================*/
147
148 /*
149  * Initialize memory handling.
150  *
151  * This function should be called before any other bft_mem_...()
152  * function. To activate memory allocation logging, a logfile
153  * name should be given as an argument. The resulting file will
154  * be a regular, local file. If this file cannot be opened for
155  * some reason, logging is silently de-activated.
156  *
157  * parameter:
158  * log_file_name <-- name of optional log_file (if NULL, no log).
159  */
160
161 void
162 bft_mem_init(const char *log_file_name);
163
164 /*
165  * End memory handling.
166  *
167  * This function should be called after all other bft_mem_...()
168  * functions. In case of memory allocation logging, it
169  * writes final information to the log file and closes is.
170  */
171
172 void
173 bft_mem_end(void);
174
175 /*
176  * Initialize memory handling.
177  *
178  * This function should be called before any other bft_mem_...()
179  * function. To activate memory allocation logging, a logfile
180  * name should be given as an argument. The resulting file will
181  * be a regular, local file. If this file cannot be opened for
182  * some reason, logging is silently de-activated.
183  *
184  * parameter:
185  * log_file_name <-- name of optional log_file (if NULL, no log).
186  */
187
188 /*
189  * Indicates if bft_mem_...() functions are initialized.
190  *
191  * returns:
192  * 1 if bft_mem_init has been called, 0 otherwise.
193  */
194
195 int
196 bft_mem_initialized(void);
197
198 /*
199  * Allocate memory for ni items of size bytes.
200  *
201  * This function calls malloc(), but adds tracing capabilities, and
202  * automatically calls the bft_error() errorhandler if it fails to
203  * allocate the required memory.
204  *
205  * parameters:
206  * ni <-- number of items.
207  * size <-- element size.
208  * var_name <-- allocated variable name string.
209  * file_name <-- name of calling source file.
210  * line_num <-- line number in calling source file.
211  *
212  * returns:
213  * pointer to allocated memory.
214  */
215
216 void *
217 bft_mem_malloc(size_t ni,
218  size_t size,
219  const char *var_name,
220  const char *file_name,
221  int line_num);
222
223 /*
224  * Reallocate memory for ni items of size bytes.
225  *
226  * This function calls realloc(), but adds tracing capabilities, and
227  * automatically calls the bft_error() errorhandler if it fails to
228  * allocate the required memory.
229  *
230  * parameters:
231  * ptr <-> pointer to previous memory location
232  * (if NULL, bft_alloc() called).
233  * ni <-- number of items.
234  * size <-- element size.
235  * var_name <-- allocated variable name string.
236  * file_name <-- name of calling source file.
237  * line_num -> line number in calling source file
238  *
239  * returns:
240  * pointer to allocated memory.
241  */
242
243 void *
244 bft_mem_realloc(void *ptr,
245  size_t ni,
246  size_t size,
247  const char *var_name,
248  const char *file_name,
249  int line_num);
250
251 /*
252  * Free allocated memory.
253  *
254  * This function calls free(), but adds tracing capabilities, and
255  * automatically calls the bft_error() errorhandler if it fails to
256  * free the corresponding memory. In case of a NULL pointer argument,
257  * the function simply returns.
258  *
259  * parameters:
260  * ptr <-> pointer to previous memory location
261  * (if NULL, bft_alloc() called).
262  * var_name <-- allocated variable name string.
263  * file_name <-- name of calling source file.
264  * line_num <-- line number in calling source file.
265  *
266  * returns:
267  * NULL pointer.
268  */
269
270 void *
271 bft_mem_free(void *ptr,
272  const char *var_name,
273  const char *file_name,
274  int line_num);
275
276 /*
277  * Allocate aligned memory for ni elements of size bytes.
278  *
279  * This function calls posix_memalign() if available, but adds tracing
280  * capabilities, and automatically calls the bft_error() errorhandler if
281  * it fails to allocate the required memory.
282  *
283  * The associated function bft_mem_have_memalign() indicates if this
284  * type of allocation may be used on this system.
285  *
286  * parameters:
287  * alignment <-- alignent.
288  * ni <-- number of items.
289  * size <-- element size.
290  * var_name <-- allocated variable name string.
291  * file_name <-- name of calling source file.
292  * line_num <-- line number in calling source file.
293  *
294  * returns:
295  * pointer to allocated memory.
296  */
297
298 void *
299 bft_mem_memalign(size_t alignment,
300  size_t ni,
301  size_t size,
302  const char *var_name,
303  const char *file_name,
304  int line_num);
305
316 size_t
317 bft_mem_get_block_size(void *ptr);
318
325 size_t
327
334 size_t
335 bft_mem_size_max(void);
336
337 /*
338  * Indicate if a memory aligned allocation variant is available.
339  *
340  * If no such function is available, bft_mem_memalign() will always fail.
341  *
342  * returns:
343  * 1 if memory aligned allocation is possible, 0 otherwise.
344  */
345
346 int
348
349 /* Returns the error handler associated with the bft_mem_...() functions.
350  *
351  * returns:
352  * pointer to the error handler function.
353  */
354
357
358 /*
359  * Associates an error handler with the bft_mem_...() functions.
360  *
361  * With the default error handler, an error message is output to stderr,
362  * (after bft_print_flush() is called), and the general error handler used
363  * by bft_error() is then called (which results in the termination of the
364  * current process or process group).
365  *
366  * parameter:
367  * handler <-- pointer to the error handler function.
368  */
369
370 void
372
373 /*
374  * Associates alternative functions with the bft_mem_...() functions.
375  *
376  * When memory allocated with another mechanism is reallocated or
377  * freed using a bft_mem_... function, this allows trying the
378  * matching alternative function rather than throwing an error.
379  *
380  * Though using matching methods is recommended, this allows handling
381  * compatibility between methods which might be used in different parts
382  * of the code.
383  *
384  * parameter:
385  * realloc_func <-- pointer to alternative reallocation function.
386  * realloc_func <-- pointer to alternative reallocation function.
387  * free_func <-- pointer to alternative free function.
388  */
389
390 void
392  bft_mem_realloc_t *realloc_func,
393  bft_mem_free_t *free_func);
394
395 /*----------------------------------------------------------------------------*/
396
398
399 #endif /* __BFT_MEM_H__ */
int bft_mem_have_memalign(void)
Definition: bft_mem.c:1300
size_t bft_mem_size_current(void)
Return current theoretical dynamic memory allocated.
Definition: bft_mem.c:1274
void bft_mem_end(void)
Definition: bft_mem.c:719
size_t() bft_mem_get_size_t(void *ptr)
Definition: bft_mem.h:128
void bft_mem_alternative_set(bft_mem_get_size_t *get_size_func, bft_mem_realloc_t *realloc_func, bft_mem_free_t *free_func)
Definition: bft_mem.c:1355
void * bft_mem_malloc(size_t ni, size_t size, const char *var_name, const char *file_name, int line_num)
Allocate memory for ni elements of size bytes.
Definition: bft_mem.c:815
void() bft_error_handler_t(const char *const file_name, const int line_num, const int sys_error_code, const char *const format, va_list arg_ptr)
Function pointer to opaque error handler.
Definition: bft_error.h:52
void *() bft_mem_realloc_t(void *ptr, size_t ni, size_t size, const char *var_name, const char *file_name, int line_num)
Definition: bft_mem.h:131
void * bft_mem_memalign(size_t alignment, size_t ni, size_t size, const char *var_name, const char *file_name, int line_num)
Definition: bft_mem.c:1145
void() bft_mem_free_t(void *ptr, const char *var_name, const char *file_name, int line_num)
Definition: bft_mem.h:139
void bft_mem_error_handler_set(bft_error_handler_t *handler)
Definition: bft_mem.c:1333
void bft_mem_init(const char *log_file_name)
Definition: bft_mem.c:642
void * bft_mem_free(void *ptr, const char *var_name, const char *file_name, int line_num)
Definition: bft_mem.c:1056
size_t bft_mem_get_block_size(void *ptr)
Return block size associated with a given pointer.
Definition: bft_mem.c:1244
int bft_mem_initialized(void)
Definition: bft_mem.c:793
void * bft_mem_realloc(void *ptr, size_t ni, size_t size, const char *var_name, const char *file_name, int line_num)
Reallocate memory for ni elements of size bytes.
Definition: bft_mem.c:899
bft_error_handler_t * bft_mem_error_handler_get(void)
Definition: bft_mem.c:1316
size_t bft_mem_size_max(void)
Return maximum theoretical dynamic memory allocated.
Definition: bft_mem.c:1286
