7.1
bft_mem.h File Reference
+ Include dependency graph for bft_mem.h:
Macros
#define BFT_MALLOC(_ptr, _ni, _type)
 Allocate memory for _ni elements of type _type. More...
#define BFT_REALLOC(_ptr, _ni, _type)
 Reallocate memory for _ni elements of type _type. More...
#define BFT_FREE(_ptr)   _ptr = bft_mem_free(_ptr, #_ptr, __FILE__, __LINE__)
 Free allocated memory. More...
#define BFT_MEMALIGN(_ptr, _align, _ni, _type)
 Allocate aligned memory for _ni elements of type _type. More...
Typedefs
typedef size_t() bft_mem_get_size_t(void *ptr)
typedef void *() bft_mem_realloc_t(void *ptr, size_t ni, size_t size, const char *var_name, const char *file_name, int line_num)
typedef void() bft_mem_free_t(void *ptr, const char *var_name, const char *file_name, int line_num)
void bft_mem_init (const char *log_file_name)
 Initialize memory handling. More...
void bft_mem_end (void)
 End memory handling. More...
int bft_mem_initialized (void)
 Indicates if bft_mem_...() functions are initialized. More...
void * bft_mem_malloc (size_t ni, size_t size, const char *var_name, const char *file_name, int line_num)
 Allocate memory for ni elements of size bytes. More...
void * bft_mem_realloc (void *ptr, size_t ni, size_t size, const char *var_name, const char *file_name, int line_num)
 Reallocate memory for ni elements of size bytes. More...
void * bft_mem_free (void *ptr, const char *var_name, const char *file_name, int line_num)
void * bft_mem_memalign (size_t alignment, size_t ni, size_t size, const char *var_name, const char *file_name, int line_num)
 Allocate aligned memory for ni elements of size bytes. More...
size_t bft_mem_get_block_size (void *ptr)
 Return block size associated with a given pointer. More...
size_t bft_mem_size_current (void)
 Return current theoretical dynamic memory allocated. More...
size_t bft_mem_size_max (void)
 Return maximum theoretical dynamic memory allocated. More...
int bft_mem_have_memalign (void)
 Indicate if a memory aligned allocation variant is available. More...
bft_error_handler_tbft_mem_error_handler_get (void)
 Returns the error handler associated with the bft_mem_...() functions. More...
void bft_mem_error_handler_set (bft_error_handler_t *handler)
 Associates an error handler with the bft_mem_...() functions. More...
void bft_mem_alternative_set (bft_mem_get_size_t *get_size_func, bft_mem_realloc_t *realloc_func, bft_mem_free_t *free_func)
◆ BFT_FREE
BFT_FREE (   _ptr)    _ptr = bft_mem_free(_ptr, #_ptr, __FILE__, __LINE__)
This macro calls bft_mem_free(), automatically setting the allocated variable name and source file name and line arguments.
The freed pointer is set to NULL to avoid accidental reuse.
[in,out]_ptrpointer to allocated memory.
◆ BFT_MALLOC
BFT_MALLOC (   _ptr,
  _ni,
  _type
Value:
_ptr = (_type *) bft_mem_malloc(_ni, sizeof(_type), \
void * bft_mem_malloc(size_t ni, size_t size, const char *var_name, const char *file_name, int line_num)
Definition: bft_mem.c:815
This macro calls bft_mem_malloc(), automatically setting the allocated variable name and source file name and line arguments.
[out]_ptrpointer to allocated memory.
[in]_ninumber of elements.
[in]_typeelement type.
◆ BFT_MEMALIGN
BFT_MEMALIGN (   _ptr,
  _align,
  _ni,
  _type
Value:
_ptr = (_type *) bft_mem_memalign(_align, _ni, sizeof(_type), \
void * bft_mem_memalign(size_t alignment, size_t ni, size_t size, const char *var_name, const char *file_name, int line_num)
Definition: bft_mem.c:1145
This macro calls bft_mem_memalign(), automatically setting the allocated variable name and source file name and line arguments.
[in]_alignalignment.
◆ BFT_REALLOC
BFT_REALLOC (   _ptr,
  _ni,
  _type
Value:
_ptr = (_type *) bft_mem_realloc(_ptr, _ni, sizeof(_type), \
void * bft_mem_realloc(void *ptr, size_t ni, size_t size, const char *var_name, const char *file_name, int line_num)
Definition: bft_mem.c:899
This macro calls bft_mem_realloc(), automatically setting the allocated variable name and source file name and line arguments.
Typedef Documentation
◆ bft_mem_free_t
◆ bft_mem_get_size_t
◆ bft_mem_realloc_t
typedef void*() bft_mem_realloc_t(void *ptr, size_t ni, size_t size, const char *var_name, const char *file_name, int line_num)
◆ bft_mem_alternative_set()
void bft_mem_alternative_set ( bft_mem_get_size_t get_size_func,
bft_mem_realloc_t realloc_func,
bft_mem_free_t free_func
◆ bft_mem_end()
void bft_mem_end ( void  )
This function should be called after all other bft_mem_...() functions. In case of memory allocation logging, it writes final information to the log file and closes is.
◆ bft_mem_error_handler_get()
bft_error_handler_t* bft_mem_error_handler_get ( void  )
pointer to the error handler function.
◆ bft_mem_error_handler_set()
void bft_mem_error_handler_set ( bft_error_handler_t handler)
With the default error handler, an error message is output to stderr, (after bft_print_flush() is called), and the general error handler used by bft_error() is then called (which results in the termination of the current process or process group).
handlerpointer to the error handler function [in].
◆ bft_mem_free()
void* bft_mem_free ( void *  ptr,
const char *  var_name,
const char *  file_name,
int  line_num
This function calls free(), but adds tracing capabilities, and automatically calls the bft_error() errorhandler if it fails to free the corresponding memory. In case of a NULL pointer argument, the function simply returns.
[in]ptrpointer to previous memory location (if NULL, bft_alloc() called).
[in]var_nameallocated variable name string
[in]file_namename of calling source file
[in]line_numline number in calling source file
NULL pointer.
◆ bft_mem_get_block_size()
size_t bft_mem_get_block_size ( void *  ptr)
bft_mem_init() must have beed called before this function can be used.
size of associated memory block.
◆ bft_mem_have_memalign()
int bft_mem_have_memalign ( void  )
If no such function is available, bft_mem_memalign() will always fail.
1 if memory aligned allocation is possible, 0 otherwise.
◆ bft_mem_init()
void bft_mem_init ( const char *  log_file_name)
This function should be called before any other bft_mem_...() function. To activate memory allocation logging, a logfile name should be given as an argument. The resulting file will be a regular, local file. If this file cannot be opened for some reason, logging is silently de-activated.
log_file_namename of optional log_file (if NULL, no log).
◆ bft_mem_initialized()
int bft_mem_initialized ( void  )
1 if bft_mem_init has been called, 0 otherwise.
◆ bft_mem_malloc()
void* bft_mem_malloc ( size_t  ni,
size_t  size,
int  line_num
This function calls malloc(), but adds tracing capabilities, and automatically calls the bft_error() errorhandler if it fails to allocate the required memory.
[in]ninumber of elements.
[in]sizeelement size.
[in]var_nameallocated variable name string.
[in]file_namename of calling source file.
[in]line_numline number in calling source file.
◆ bft_mem_memalign()
void* bft_mem_memalign ( size_t  alignment,
size_t  ni,
size_t  size,
int  line_num
This function calls posix_memalign() if available, but adds tracing capabilities, and automatically calls the bft_error() errorhandler if it fails to allocate the required memory.
The associated function bft_mem_have_memalign() indicates if this type of allocation may be used on this system.
[in]alignmentalignment.
◆ bft_mem_realloc()
void* bft_mem_realloc ( void *  ptr,
size_t  ni,
size_t  size,
int  line_num
This function calls realloc(), but adds tracing capabilities, and automatically calls the bft_error() errorhandler if it fails to allocate the required memory.
pointer to reallocated memory.
◆ bft_mem_size_current()
size_t bft_mem_size_current ( void  )
current memory handled through bft_mem_...() (in kB).
◆ bft_mem_size_max()
size_t bft_mem_size_max ( void  )
maximum memory handled through bft_mem_...() (in kB).
