7.1
bft_printf.h
1 #ifndef __BFT_PRINTF_H__
2 #define __BFT_PRINTF_H__
5  * Base user-definable printf() wrapper or replacement
30 #include "cs_defs.h"
35  * Standard C library headers
38 #include <stdarg.h>
40 /*----------------------------------------------------------------------------
41  * Local headers
42  *----------------------------------------------------------------------------*/
44 /*-----------------------------------------------------------------------------*/
45
49  * Public types
51
52 /* Function pointers for printf() and fflush(stdout) type functions */
53
54 typedef int (bft_printf_proxy_t) (const char *const format,
55  va_list arg_ptr);
56
57 typedef int (bft_printf_flush_proxy_t) (void);
58
59 /*============================================================================
60  * Public function prototypes
62
63 /*
64  * Replacement for printf() with modifiable behavior.
65  *
66  * This function calls vprintf() by default, or a function with similar
67  * arguments indicated by bft_printf_proxy_set().
68  *
69  * parameters:
70  * format: <-- format string, as printf() and family.
71  * ... : <-- variable arguments based on format string.
72  *
73  * returns:
74  * number of characters printed, not counting the trailing '\0' used
75  * to end output strings
76  */
77
78 #if defined(__GNUC__)
79
80 int
81 bft_printf(const char *const format,
82  ...)
83  __attribute__((format(printf, 1, 2)));
84
85 #else
86
87 int
88 bft_printf(const char *const format,
89  ...);
90
91 #endif
92
93 /*
94  * Flush for output of bft_printf() with modifiable behavior.
95  *
96  * This function calls fflush(stdout) if bft_printf()'s default behavior is
97  * used. If bft_printf's behavior is modified with bft_printf_proxy_set(),
98  * bft_printf_flush()'s behavior may have to be also adjusted with
99  * bft_printf_flush_proxy_set().
100  *
101  * returns:
102  * using the default behavior, the return value is that of
103  * fflush(stdout): O upon successful completion, EOF otherwise
104  * (with errno set to indicate the error).
105  */
106
107 int
108 bft_printf_flush(void);
109
110 /*
111  * Returns function associated with the bft_printf() function.
112  *
113  * returns:
114  * pointer to the vprintf() or replacement function.
115  */
116
119
120 /*
121  * Associates a vprintf() type function with the bft_printf() function.
122  *
123  * parameters:
124  * fct: <-- pointer to a vprintf() type function.
125  */
126
127 void
129
130 /*
131  * Returns function associated with bft_printf_flush().
132  *
133  * returns:
134  * pointer to the bft_printf_flush() proxy.
135  */
136
139
140 /*
141  * Associates a proxy function with bft_printf_flush().
142  *
143  * warning:
144  * bft_printf() is called by the default bft_error() error handler
145  * (so as to ensure that the error text appears at the end of the
146  * program output), so a bft_print_flush replacement must not itself
147  * call (directly or indirectly) bft_error() if the default error
148  * handler is used.
149  *
150  * parameter:
151  * fct <-- pointer to a function similar to {return fflush(stdout)}.
152  */
153
154 void
156
157 /*----------------------------------------------------------------------------*/
158
160
161 #endif /* __BFT_PRINTF_H__ */
Definition: bft_printf.c:140
void bft_printf_flush_proxy_set(bft_printf_flush_proxy_t *const fct)
Definition: bft_printf.c:224
int() bft_printf_proxy_t(const char *const format, va_list arg_ptr)
Function pointer for printf() type functions.
Definition: bft_printf.h:54
int() bft_printf_flush_proxy_t(void)
Function pointer for fflush(stdout) type functions.
Definition: bft_printf.h:57
bft_printf_proxy_t * bft_printf_proxy_get(void)
Definition: bft_printf.c:181
int bft_printf_flush(void)
Definition: bft_printf.c:169
void bft_printf_proxy_set(bft_printf_proxy_t *const fct)
Definition: bft_printf.c:193
bft_printf_flush_proxy_t * bft_printf_flush_proxy_get(void)
Definition: bft_printf.c:205
