1 #ifndef __CS_PARAMETERS_H__ 2 #define __CS_PARAMETERS_H__ 222 int iscvr = 0, f_id = 0;
312 const char *variable_name);
Definition: cs_parameters.h:107
void cs_parameters_eqp_complete(void)
Complete general equation parameter definitions.
Definition: cs_parameters.c:1491
Definition: cs_parameters.h:87
cs_field_t * cs_parameters_add_boundary_values(cs_field_t *f)
Define a boundary values field for a variable field.
Definition: cs_parameters.c:1303
Definition: cs_parameters.h:114
Definition: cs_parameters.h:68
Definition: cs_parameters.h:108
int read_auxiliary
Definition: cs_parameters.h:173
double thetst
Definition: cs_parameters.h:160
int imrgra
Definition: cs_parameters.h:128
const cs_space_disc_t * cs_glob_space_disc
Definition: cs_parameters.h:112
Definition: cs_parameters.h:84
void cs_parameters_create_added_variables(void)
Create previously added user variables.
Definition: cs_parameters.c:1178
Definition: cs_parameters.h:115
int iflxmw
Definition: cs_parameters.h:138
Definition: cs_field.h:125
Definition: cs_equation_param.h:177
Definition: cs_parameters.h:96
Definition: cs_field.c:2314
cs_time_scheme_t * cs_get_glob_time_scheme(void)
Provide access to cs_glob_time_scheme.
Definition: cs_parameters.c:863
void cs_parameters_add_variable(const char *name, int dim)
Definition: cs_parameters.c:1039
void cs_parameters_read_restart_info(void)
Read general restart info.
Definition: cs_parameters.c:1017
void cs_space_disc_log_setup(void)
Print the space discretization structure to setup.log.
Definition: cs_parameters.c:1606
cs_tree_node_t * cs_glob_tree
Definition: cs_parameters.h:111
void cs_parameters_add_variable_variance(const char *name, const char *variable_name)
Define a user variable which is a variance of another variable.
Definition: cs_parameters.c:1080
cs_restart_auxiliary_t * cs_glob_restart_auxiliary
Definition: cs_parameters.h:86
void cs_parameters_add_property(const char *name, int dim, int location_id)
Define a user property.
Definition: cs_parameters.c:1117
Additional checkpoint/restart files.
Definition: cs_parameters.h:171
Definition: cs_parameters.h:95
int time_order
Definition: cs_parameters.h:155
cs_space_disc_t * cs_get_glob_space_disc(void)
Provide access to cs_glob_space_disc.
Definition: cs_parameters.c:847
Definition: cs_parameters.h:110
void cs_parameters_create_added_properties(void)
Create previously added user properties.
Definition: cs_parameters.c:1253
Definition: cs_field.c:2991
Definition: cs_parameters.h:81
Definition: cs_field.c:2497
Definition: cs_parameters.h:82
int iccvfg
Definition: cs_parameters.h:162
int itbrrb
Definition: cs_parameters.h:143
Definition: cs_parameters.h:94
Definition: cs_parameters.h:113
int cs_parameters_n_added_variables(void)
Return the number of defined user variables not added yet.
Definition: cs_parameters.c:1152
Time scheme descriptor.
Definition: cs_parameters.h:153
Definition: cs_parameters.h:85
int n_it
Definition: cs_parameters.h:69
cs_equation_param_t cs_var_cal_opt_t
Definition: cs_parameters.h:62
const cs_time_scheme_t * cs_glob_time_scheme
double l2residual
Definition: cs_parameters.h:73
Definition: cs_parameters.h:109
void cs_time_scheme_log_setup(void)
Print the time scheme structure to setup.log.
Definition: cs_parameters.c:1580
Definition: cs_parameters.h:88
Space discretisation options descriptor.
Definition: cs_parameters.h:122
Definition: cs_parameters.h:93
int cs_parameters_n_added_properties(void)
Return the number of defined user properties not added yet.
Definition: cs_parameters.c:1166
int isto2t
Definition: cs_parameters.h:157
Definition: cs_parameters.h:89
Definition: cs_parameters.h:90
double rhs_norm
Definition: cs_parameters.h:70
void cs_parameters_define_field_keys(void)
Define general field keys.
Definition: cs_parameters.c:878
Definition: cs_parameters.h:91
int write_auxiliary
Definition: cs_parameters.h:174
Definition: cs_parameters.h:92
Definition: cs_parameters.h:83
int imvisf
Definition: cs_parameters.h:124
double derive
Definition: cs_parameters.h:72
cs_var_cal_opt_t cs_parameters_var_cal_opt_default(void)
Return a local variable calculation options structure, with default options.
Definition: cs_parameters.c:1568
void cs_parameters_output_complete(void)
Complete general output options definitions.
Definition: cs_parameters.c:1518
cs_field_t * cs_parameters_add_boundary_temperature(void)
Define a boundary values field for temperature, if applicable.
Definition: cs_parameters.c:1408
double res_norm
Definition: cs_parameters.h:71
