#include "base/cs_defs.h"#include <assert.h>#include <math.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include "bft/bft_mem.h"#include "bft/bft_error.h"#include "bft/bft_printf.h"#include "atmo/cs_air_props.h"#include "atmo/cs_atmo.h"#include "base/cs_base.h"#include "base/cs_boundary_conditions.h"#include "base/cs_boundary_zone.h"#include "base/cs_field.h"#include "base/cs_field_default.h"#include "base/cs_field_operator.h"#include "base/cs_field_pointer.h"#include "base/cs_log.h"#include "base/cs_math.h"#include "mesh/cs_mesh.h"#include "mesh/cs_mesh_location.h"#include "mesh/cs_mesh_quantities.h"#include "base/cs_parameters.h"#include "base/cs_parall.h"#include "base/cs_physical_constants.h"#include "pprt/cs_physical_model.h"#include "base/cs_post.h"#include "base/cs_prototypes.h"#include "base/cs_thermal_model.h"#include "base/cs_volume_zone.h"#include "ctwr/cs_ctwr.h"#include "ctwr/cs_ctwr_source_terms.h"Functions | |
| cs_ctwr_option_t * | cs_get_glob_ctwr_option (void) |
| cs_ctwr_zone_t ** | cs_get_glob_ctwr_zone (void) |
| int * | cs_get_glob_ctwr_n_zones (void) |
| void | cs_ctwr_define (const char zone_criteria[], int z_id, cs_ctwr_zone_type_t zone_type, cs_real_t delta_t, cs_real_t relax, cs_real_t t_l_bc, cs_real_t q_l_bc, cs_real_t xap, cs_real_t xnp, cs_real_t surface, cs_real_t xleak_fac) |
| Define a cooling tower exchange zone. | |
| void | cs_ctwr_define_zones (void) |
| Define cooling tower zones. | |
| void | cs_ctwr_build_all (void) |
| Define the cells belonging to the different packing zones. | |
| void | cs_ctwr_all_destroy (void) |
| Destroy cs_ctwr_t structures. | |
| void | cs_ctwr_log_setup (void) |
| Log Packing zone definition setup information. | |
| void | cs_ctwr_log_balance (void) |
| Perform balances in packing zones. | |
| void cs_ctwr_all_destroy | ( | void | ) |
| void cs_ctwr_build_all | ( | void | ) |
| void cs_ctwr_define | ( | const char | zone_criteria[], |
| int | z_id, | ||
| cs_ctwr_zone_type_t | zone_type, | ||
| cs_real_t | delta_t, | ||
| cs_real_t | relax, | ||
| cs_real_t | t_l_bc, | ||
| cs_real_t | q_l_bc, | ||
| cs_real_t | xap, | ||
| cs_real_t | xnp, | ||
| cs_real_t | surface, | ||
| cs_real_t | xleak_fac ) |
| [in] | zone_criteria | zone selection criteria (or nullptr) |
| [in] | z_id | z_id if zone already created (-1 otherwise) |
| [in] | zone_type | exchange zone type |
| [in] | delta_t | imposed delta temperature delta between inlet and outlet of the zone |
| [in] | relax | relaxation of the imposed delta temperature |
| [in] | t_l_bc | liquid water temperature at the inlet |
| [in] | q_l_bc | mass flow rate at the inlet |
| [in] | xap | beta_x_0 of the exchange law |
| [in] | xnp | exponent n of the exchange law |
| [in] | surface | total Surface of ingoing water |
| [in] | xleak_fac | leakage factor (ratio of outlet/inlet flow rate) |
| void cs_ctwr_define_zones | ( | void | ) |
Define zones.
TODO rename this: definition (at setup stage) and build (instanciation on actual mesh are not the same).
| void cs_ctwr_log_balance | ( | void | ) |
| void cs_ctwr_log_setup | ( | void | ) |
| int * cs_get_glob_ctwr_n_zones | ( | void | ) |
| cs_ctwr_option_t * cs_get_glob_ctwr_option | ( | void | ) |
| cs_ctwr_zone_t ** cs_get_glob_ctwr_zone | ( | void | ) |
