#include "cs_defs.h"#include <stdarg.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include <assert.h>#include <math.h>#include "bft_mem.h"#include "bft_error.h"#include "bft_printf.h"#include "cs_base.h"#include "cs_base_accel.h"#include "cs_blas.h"#include "cs_dispatch.h"#include "cs_file.h"#include "cs_grid.h"#include "cs_halo.h"#include "cs_log.h"#include "cs_matrix.h"#include "cs_matrix_default.h"#include "cs_matrix_spmv_cuda.h"#include "cs_matrix_util.h"#include "cs_mesh.h"#include "cs_mesh_quantities.h"#include "cs_multigrid_smoother.h"#include "cs_post.h"#include "cs_sles.h"#include "cs_sles_it.h"#include "cs_sles_pc.h"#include "cs_timer.h"#include "cs_time_plot.h"#include "cs_time_step.h"#include "cs_multigrid.h"
Include dependency graph for cs_multigrid.cpp:Functions | |
| void | cs_multigrid_initialize (void) |
| Initialize multigrid solver API. More... | |
| void | cs_multigrid_finalize (void) |
| Finalize multigrid solver API. More... | |
| void | cs_multigrid_set_max_grid_level_for_device (int level) |
| Set maximum grid level which should run on device (i.e. GPU). More... | |
| cs_multigrid_t * | cs_multigrid_define (int f_id, const char *name, cs_multigrid_type_t mg_type) |
| Define and associate a multigrid sparse linear system solver for a given field or equation name. More... | |
| cs_multigrid_t * | cs_multigrid_create (cs_multigrid_type_t mg_type) |
| Create multigrid linear system solver info and context. More... | |
| void | cs_multigrid_destroy (void **context) |
| Destroy multigrid linear system solver info and context. More... | |
| void * | cs_multigrid_copy (const void *context) |
| Create multigrid sparse linear system solver info and context based on existing info and context. More... | |
| void | cs_multigrid_log (const void *context, cs_log_t log_type) |
| Log multigrid solver info. More... | |
| void | cs_multigrid_set_coarsening_options (cs_multigrid_t *mg, int aggregation_limit, cs_grid_coarsening_t coarsening_type, int n_max_levels, cs_gnum_t min_g_rows, double p0p1_relax, int postprocess_block_size) |
| Set multigrid coarsening parameters. More... | |
| void | cs_multigrid_set_solver_options (cs_multigrid_t *mg, cs_sles_it_type_t descent_smoother_type, cs_sles_it_type_t ascent_smoother_type, cs_sles_it_type_t coarse_solver_type, int n_max_cycles, int n_max_iter_descent, int n_max_iter_ascent, int n_max_iter_coarse, int poly_degree_descent, int poly_degree_ascent, int poly_degree_coarse, double precision_mult_descent, double precision_mult_ascent, double precision_mult_coarse) |
| Set multigrid parameters for associated iterative solvers. More... | |
| void | cs_multigrid_set_max_cycles (cs_multigrid_t *mg, int n_max_cycles) |
| Set the max. number of cycles for a multigrid. More... | |
| cs_sles_it_type_t | cs_multigrid_get_fine_solver_type (const cs_multigrid_t *mg) |
| Return solver type used on fine mesh. More... | |
| void | cs_multigrid_setup (void *context, const char *name, const cs_matrix_t *a, int verbosity) |
| Setup multigrid sparse linear equation solver. More... | |
| void | cs_multigrid_setup_conv_diff (void *context, const char *name, const cs_matrix_t *a, bool conv_diff, int verbosity) |
| cs_sles_convergence_state_t | cs_multigrid_solve (void *context, const char *name, const cs_matrix_t *a, int verbosity, double precision, double r_norm, int *n_iter, double *residual, const cs_real_t *rhs, cs_real_t *vx_ini, cs_real_t *vx, size_t aux_size, void *aux_vectors) |
| Call multigrid sparse linear equation solver. More... | |
| void | cs_multigrid_free (void *context) |
| Free multigrid sparse linear equation solver setup context. More... | |
| cs_sles_pc_t * | cs_multigrid_pc_create (cs_multigrid_type_t mg_type) |
| Create a multigrid preconditioner. More... | |
| bool | cs_multigrid_error_post_and_abort (cs_sles_t *sles, cs_sles_convergence_state_t state, const cs_matrix_t *a, const cs_real_t rhs[], cs_real_t vx[]) |
| Error handler for multigrid sparse linear equation solver. More... | |
| void | cs_multigrid_set_plot_options (cs_multigrid_t *mg, const char *base_name, bool use_iteration) |
| Set plotting options for multigrid. More... | |
| void | cs_multigrid_get_merge_options (const cs_multigrid_t *mg, int *rank_stride, int *rows_mean_threshold, cs_gnum_t *rows_glob_threshold) |
| Query the global multigrid parameters for parallel grid merging. More... | |
| void | cs_multigrid_set_merge_options (cs_multigrid_t *mg, int rank_stride, int rows_mean_threshold, cs_gnum_t rows_glob_threshold) |
| Set global multigrid parameters for parallel grid merging behavior. More... | |
| const cs_grid_t * | cs_multigrid_get_grid (const cs_multigrid_t *mg, int level) |
| Return a pointer to a grid associated with a given multigrid setup and level. More... | |
| void* cs_multigrid_copy | ( | const void * | context | ) |
| [in] | context | pointer to reference info and context (actual type: cs_multigrid_t *) |
| cs_multigrid_t* cs_multigrid_create | ( | cs_multigrid_type_t | mg_type | ) |
The multigrid variant is an ACM (Additive Corrective Multigrid) method.
| [in] | mg_type | type of multigrid algorithm to use |
| cs_multigrid_t* cs_multigrid_define | ( | int | f_id, |
| const char * | name, | ||
| cs_multigrid_type_t | mg_type | ||
This is a utility function: if finer control is needed, see cs_sles_define and cs_multigrid_create.
Note that this function returns a pointer directly to the multigrid solver management structure. This may be used to set further options, for example calling cs_multigrid_set_coarsening_options and cs_multigrid_set_solver_options. If needed, cs_sles_find may be used to obtain a pointer to the matching cs_sles_t container.
| [in] | name | associated name if f_id < 0, or nullptr |
| void cs_multigrid_destroy | ( | void ** | context | ) |
| [in,out] | context | pointer to multigrid linear solver info (actual type: cs_multigrid_t **) |
| bool cs_multigrid_error_post_and_abort | ( | cs_sles_t * | sles, |
| const cs_real_t | rhs[], | ||
| cs_real_t | vx[] | ||
In case of divergence or breakdown, this error handler outputs postprocessing data to assist debugging, then aborts the run. It does nothing in case the maximum iteration count is reached.
| [in] | a | matrix |
| void cs_multigrid_finalize | ( | void | ) |
| void cs_multigrid_free | ( | void * | context | ) |
This function frees resolution-related data, incuding the current grid hierarchy, but does not free the whole context, as info used for logging (especially performance data) is maintained.
| [in,out] | context | pointer to multigrid solver info and context (actual type: cs_multigrid_t *) |
| cs_sles_it_type_t cs_multigrid_get_fine_solver_type | ( | const cs_multigrid_t * | mg | ) |
| [in] | mg | pointer to multigrid info and context |
| const cs_grid_t* cs_multigrid_get_grid | ( | const cs_multigrid_t * | mg, |
| int | level | ||
If the multigrid hierarchy is not set up, or a level coarser than the coarsest level is requested, nullptr is returned.
| [in] | level | level of the requested grid (or -1 for coarsest) |
| void cs_multigrid_get_merge_options | ( | const cs_multigrid_t * | mg, |
| int * | rank_stride, | ||
| int * | rows_mean_threshold, | ||
| cs_gnum_t * | rows_glob_threshold | ||
| [out] | rank_stride | number of ranks over which merging takes place, or nullptr |
| [out] | rows_mean_threshold | mean number of rows under which merging should be applied, or nullptr |
| [out] | rows_glob_threshold | global number of rows under which merging should be applied, or nullptr |
| void cs_multigrid_initialize | ( | void | ) |
| void cs_multigrid_log | ( | const void * | context, |
| cs_log_t | log_type | ||
| [in] | context | pointer to iterative solver info and context (actual type: cs_multigrid_t *) |
| cs_sles_pc_t* cs_multigrid_pc_create | ( | cs_multigrid_type_t | mg_type | ) |
| void cs_multigrid_set_coarsening_options | ( | cs_multigrid_t * | mg, |
| int | aggregation_limit, | ||
| cs_grid_coarsening_t | coarsening_type, | ||
| int | n_max_levels, | ||
| cs_gnum_t | min_g_rows, | ||
| double | p0p1_relax, | ||
| int | postprocess_block_size | ||
| [in,out] | mg | pointer to multigrid info and context |
| [in] | aggregation_limit | maximum allowed fine rows per coarse row |
| [in] | coarsening_type | coarsening type; see cs_grid_coarsening_t |
| [in] | n_max_levels | maximum number of grid levels |
| [in] | min_g_rows | global number of rows on coarse grids under which no coarsening occurs |
| [in] | p0p1_relax | p0/p1 relaxation_parameter |
| [in] | postprocess | if > 0, postprocess coarsening (uses coarse row numbers modulo this value) |
| void cs_multigrid_set_max_cycles | ( | cs_multigrid_t * | mg, |
| int | n_max_cycles | ||
| [in] | n_max_cycles | maximum number of cycles |
| void cs_multigrid_set_max_grid_level_for_device | ( | int | level | ) |
| void cs_multigrid_set_merge_options | ( | cs_multigrid_t * | mg, |
| int | rank_stride, | ||
| int | rows_mean_threshold, | ||
| cs_gnum_t | rows_glob_threshold | ||
| [in] | rank_stride | number of ranks over which merging takes place |
| [in] | rows_mean_threshold | mean number of rows under which merging should be applied |
| [in] | rows_glob_threshold | global number of rows under which merging should be applied |
| void cs_multigrid_set_plot_options | ( | cs_multigrid_t * | mg, |
| const char * | base_name, | ||
| bool | use_iteration | ||
| [in] | base_name | base plot name to activate, nullptr otherwise |
| [in] | use_iteration | if true, use iteration as time stamp otherwise, use wall clock time |
| void cs_multigrid_set_solver_options | ( | cs_multigrid_t * | mg, |
| cs_sles_it_type_t | descent_smoother_type, | ||
| cs_sles_it_type_t | ascent_smoother_type, | ||
| cs_sles_it_type_t | coarse_solver_type, | ||
| int | n_max_cycles, | ||
| int | n_max_iter_descent, | ||
| int | n_max_iter_ascent, | ||
| int | n_max_iter_coarse, | ||
| int | poly_degree_descent, | ||
| int | poly_degree_ascent, | ||
| int | poly_degree_coarse, | ||
| double | precision_mult_descent, | ||
| double | precision_mult_ascent, | ||
| double | precision_mult_coarse | ||
| [in] | descent_smoother_type | type of smoother for descent |
| [in] | ascent_smoother_type | type of smoother for ascent |
| [in] | coarse_solver_type | type of solver for coarsest grid |
| [in] | n_max_iter_descent | maximum iterations per descent smoothing |
| [in] | n_max_iter_ascent | maximum iterations per ascent smoothing |
| [in] | n_max_iter_coarse | maximum iterations per coarsest solution |
| [in] | poly_degree_descent | preconditioning polynomial degree for descent phases (0: diagonal) |
| [in] | poly_degree_ascent | preconditioning polynomial degree for ascent phases (0: diagonal) |
| [in] | poly_degree_coarse | preconditioning polynomial degree for coarse solver (0: diagonal) |
| [in] | precision_mult_descent | precision multiplier for descent smoothers (levels >= 1) |
| [in] | precision_mult_ascent | precision multiplier for ascent smoothers |
| [in] | precision_mult_coarse | precision multiplier for coarsest grid |
| void cs_multigrid_setup | ( | void * | context, |
| int | verbosity | ||
| [in] | name | pointer to name of linear system |
| void cs_multigrid_setup_conv_diff | ( | void * | context, |
| bool | conv_diff, | ||
| [in] | conv_diff | convection-diffusion mode |
| cs_sles_convergence_state_t cs_multigrid_solve | ( | void * | context, |
| int | verbosity, | ||
| double | precision, | ||
| double | r_norm, | ||
| int * | n_iter, | ||
| double * | residual, | ||
| cs_real_t * | vx_ini, | ||
| cs_real_t * | vx, | ||
| size_t | aux_size, | ||
| void * | aux_vectors | ||
| [in] | a | matrix |
| [in] | aux_size | size of aux_vectors (in bytes) |
| aux_vectors | optional working area (internal allocation if nullptr) |
