167 #if defined(HAVE_MPI)
231 #if defined(HAVE_MPI)
263 const int elt_rank_id[],
423 #if defined(HAVE_ACCEL)
448 cs_halo_sync_pack_d(
const cs_halo_t *halo,
526 #if defined(HAVE_ACCEL)
cs_alloc_mode_t
Definition: bft_mem.h:50
const size_t cs_datatype_size[]
Definition: cs_defs.c:133
cs_datatype_t
Definition: cs_defs.h:284
Definition: cs_defs.h:528
Definition: cs_defs.h:332
Definition: cs_defs.h:529
Definition: cs_defs.h:325
bool cs_halo_get_use_barrier(void)
Definition: cs_halo.cpp:2111
void cs_halo_sync_pack(const cs_halo_t *halo, cs_halo_type_t sync_mode, cs_datatype_t data_type, int stride, void *val, void *send_buf, cs_halo_state_t *hs)
Pack halo data to send into dense buffer.
Definition: cs_halo.cpp:1490
cs_halo_comm_mode_t
Definition: cs_halo.h:66
@ CS_HALO_COMM_P2P
Definition: cs_halo.h:68
@ CS_HALO_COMM_RMA_GET
Definition: cs_halo.h:69
void cs_halo_state_destroy(cs_halo_state_t **halo_state)
Destroy a halo state structure.
Definition: cs_halo.cpp:1164
void cs_halo_sync_start(const cs_halo_t *halo, void *val, cs_halo_state_t *hs)
Launch update array of values in case of parallelism or periodicity.
Definition: cs_halo.cpp:1703
cs_halo_comm_mode_t cs_halo_get_comm_mode(void)
Get default communication mode for halo exchange.
Definition: cs_halo.cpp:2139
void cs_halo_sync(const cs_halo_t *halo, cs_halo_type_t sync_mode, cs_datatype_t data_type, int stride, void *val)
Update array of values in case of parallelism or periodicity.
Definition: cs_halo.cpp:1939
void cs_halo_set_comm_mode(cs_halo_comm_mode_t mode)
Set default communication mode for halo exchange.
Definition: cs_halo.cpp:2153
cs_alloc_mode_t cs_halo_get_buffer_alloc_mode(void)
Get default host/device allocation mode for message packing arrays.
Definition: cs_halo.cpp:2168
static size_t cs_halo_pack_size(const cs_halo_t *halo, cs_datatype_t data_type, int stride)
Compute required size for packing send data into dense buffer.
Definition: cs_halo.h:326
void cs_halo_renumber_cells(cs_halo_t *halo, const cs_lnum_t new_cell_id[])
Definition: cs_halo.cpp:1213
void cs_halo_dump(const cs_halo_t *halo, int print_level)
Definition: cs_halo.cpp:2197
void cs_halo_sync_wait(const cs_halo_t *halo, void *val, cs_halo_state_t *hs)
Wait for completion of update array of values in case of parallelism or periodicity.
Definition: cs_halo.cpp:1854
cs_halo_state_t * cs_halo_state_create(void)
Create a halo state structure.
Definition: cs_halo.cpp:1121
void cs_halo_set_use_barrier(bool use_barrier)
Definition: cs_halo.cpp:2125
cs_halo_type_t
Definition: cs_halo.h:56
@ CS_HALO_N_TYPES
Definition: cs_halo.h:60
@ CS_HALO_STANDARD
Definition: cs_halo.h:58
@ CS_HALO_EXTENDED
Definition: cs_halo.h:59
void * cs_halo_sync_pack_init_state(const cs_halo_t *halo, cs_halo_type_t sync_mode, cs_datatype_t data_type, int stride, void *send_buf, cs_halo_state_t *hs)
Initialize halo state prior to packing halo data to send.
Definition: cs_halo.cpp:1399
void cs_halo_create_complete(cs_halo_t *halo)
Ready halo for use.
Definition: cs_halo.cpp:642
cs_halo_t * cs_halo_create_from_ref(const cs_halo_t *ref)
Create a halo structure, given a reference halo.
Definition: cs_halo.cpp:750
void cs_halo_sync_untyped(const cs_halo_t *halo, cs_halo_type_t sync_mode, size_t size, void *val)
Definition: cs_halo.cpp:2027
void cs_halo_set_buffer_alloc_mode(cs_alloc_mode_t mode)
Set default host/device allocation mode for message packing arrays.
Definition: cs_halo.cpp:2182
void cs_halo_sync_var(const cs_halo_t *halo, cs_halo_type_t sync_mode, cs_real_t var[])
Definition: cs_halo.cpp:2071
void cs_halo_sync_num(const cs_halo_t *halo, cs_halo_type_t sync_mode, cs_lnum_t num[])
Definition: cs_halo.cpp:2049
void cs_halo_renumber_ghost_cells(cs_halo_t *halo, const cs_lnum_t old_cell_id[])
Definition: cs_halo.cpp:1237
cs_halo_t * cs_halo_create(const cs_interface_set_t *ifs)
Create a halo structure given an interface set.
Definition: cs_halo.cpp:497
void cs_halo_sync_var_strided(const cs_halo_t *halo, cs_halo_type_t sync_mode, cs_real_t var[], int stride)
Definition: cs_halo.cpp:2094
cs_halo_state_t * cs_halo_state_get_default(void)
Get pointer to default halo state structure.
Definition: cs_halo.cpp:1199
cs_halo_t * cs_halo_create_from_rank_neighbors(const cs_rank_neighbors_t *rn, cs_lnum_t n_local_elts, cs_lnum_t n_distant_elts, const int elt_rank_id[], const cs_lnum_t elt_id[])
Create a halo structure from distant element distant ranks and ids.
Definition: cs_halo.cpp:846
void cs_halo_destroy(cs_halo_t **halo)
Definition: cs_halo.cpp:1074
struct _cs_halo_state_t cs_halo_state_t
Definition: cs_halo.h:178
Definition: cs_interface.h:61
struct _fvm_periodicity_t fvm_periodicity_t
Definition: fvm_periodicity.h:67
int n_transforms
Definition: cs_halo.h:80
cs_lnum_t * index
Definition: cs_halo.h:124
cs_lnum_t * send_list
Definition: cs_halo.h:98
cs_lnum_t * send_index
Definition: cs_halo.h:101
int n_rotations
Definition: cs_halo.h:87
cs_lnum_t * std_send_blocks
Definition: cs_halo.h:115
Definition: cs_halo.h:90
cs_lnum_t n_std_send_blocks
Definition: cs_halo.h:113
int n_c_domains
Definition: cs_halo.h:79
int * c_domain_rank
Definition: cs_halo.h:82
cs_lnum_t * perio_lst
Definition: cs_halo.h:129
cs_lnum_t std_send_block_size
Definition: cs_halo.h:112
cs_lnum_t * send_perio_lst
Definition: cs_halo.h:106
const fvm_periodicity_t * periodicity
Definition: cs_halo.h:84
MPI_Group c_domain_group
Definition: cs_halo.h:169
cs_lnum_t * c_domain_s_shift
Definition: cs_halo.h:170
cs_lnum_t n_send_elts[2]
Definition: cs_halo.h:94
Definition: cs_rank_neighbors.h:67
