| cs_rank_neighbors_t * | cs_rank_neighbors_create (size_t n_elts, const int elt_rank[]) |
| | Create a rank neighbors structure base on a list of element ranks. More...
| void | cs_rank_neighbors_destroy (cs_rank_neighbors_t **n) |
| | Destroy a rank neighborhood structure. More...
| void | cs_rank_neighbors_to_index (const cs_rank_neighbors_t *n, size_t n_elts, const int elt_rank[], int *elt_rank_index) |
| | Given a list of element ranks, determine the associated element rank indexes in a rank neighborhood structure. More...
| void | cs_rank_neighbors_symmetrize (cs_rank_neighbors_t *n, MPI_Comm comm) |
| | Symmetrize a rank neighborhood structure. More...
| void | cs_rank_neighbors_count (const cs_rank_neighbors_t *n, size_t n_elts, const int *elt_rank_index, cs_lnum_t *elt_rank_count) |
| | Given a list of element rank indexes, count occurences for a rank neighborhood structure. More...
| void | cs_rank_neighbors_sync_count (const cs_rank_neighbors_t *n_send, cs_rank_neighbors_t **n_recv, const cs_lnum_t *send_count, cs_lnum_t **recv_count, MPI_Comm comm) |
| | Exchange send and receive counts for rank neighborhoods. More...
| void | cs_rank_neighbors_sync_count_m (const cs_rank_neighbors_t *n_send, cs_rank_neighbors_t **n_recv, const cs_lnum_t *send_count, cs_lnum_t **recv_count, cs_rank_neighbors_exchange_t exchange_type, MPI_Comm comm) |
| | Exchange send and receive counts for rank neighborhoods, using a given method. More...
| cs_rank_neighbors_exchange_t | cs_rank_neighbors_get_exchange_type (void) |
| | Get current type of rank neighbors collective algorithm choice. More...
| void | cs_rank_neighbors_set_exchange_type (cs_rank_neighbors_exchange_t t) |
| | Set current type of rank neighbors collective algorithm choice. More...
◆ cs_rank_neighbors_exchange_t
| Enumerator |
| CS_RANK_NEIGHBORS_PEX | |
| CS_RANK_NEIGHBORS_NBX | |
| CS_RANK_NEIGHBORS_CRYSTAL_ROUTER | |
◆ cs_rank_neighbors_count()
- Parameters
| [in] | n | pointer to rank neighborhood structure |
| [in] | elt_rank_index | element rank index in neighborhood (size: n_elts) |
| [out] | elt_rank_count | element rank count in neighborhood (size: n->size) |
◆ cs_rank_neighbors_create()
- Parameters
| [in] | elt_rank | element rank |
- Returns
- pointer to new rank neighborhood.
- Parameters
| [in] | elt_rank | element rank in |
- Returns
◆ cs_rank_neighbors_destroy()
- Parameters
| [in,out] | n | pointer to associated rank neighborhood |
◆ cs_rank_neighbors_get_exchange_type()
- Returns
- current type of rank neighbors collective algorithm choice
◆ cs_rank_neighbors_set_exchange_type()
- Parameters
| t | type of rank neighbors collective algorithm choice |
◆ cs_rank_neighbors_symmetrize()
This is a collective operation ,which ensures that if rank i has j among its neighbors, then j will also jave i among its neighbors.
- Parameters
| [in,out] | n | pointer to rank neighborhood structure |
| [in] | comm | associated communicator |
◆ cs_rank_neighbors_sync_count()
This allocates the n_recv ranks neighborhood structure and the recv_count counts array, which the caller is responsible for freeing.
- Parameters
| [in] | n_send | pointer to rank neighborhood used for sending |
| [out] | n_recv | pointer to rank neighborhood used for receiving |
| [in] | send_count | pointer to rank neighborhood used for sending |
| [in] | recv_count | pointer to rank neighborhood used for sending |
◆ cs_rank_neighbors_sync_count_m()
- Parameters
| [in] | exchange_type | exchange type |
◆ cs_rank_neighbors_to_index()
| void cs_rank_neighbors_to_index |
const cs_rank_neighbors_t * |
n, |
size_t |
n_elts, |
const int |
elt_rank[], |
int * |
elt_rank_index |
The elt_rank and elt_rank_index may be identical, in which case it is updated.
- Parameters
| [in] | elt_rank | element rank (size: n_elts) |
| [out] | elt_rank_index | element rank index in neighborhood (size: n_elts) |
◆ cs_rank_neighbors_exchange_name
| const char* cs_rank_neighbors_exchange_name[] |
extern |
