1 #ifndef __CS_MATRIX_DEFAULT_H__
2 #define __CS_MATRIX_DEFAULT_H__
Definition: cs_defs.h:528
Definition: cs_defs.h:332
unsigned long cs_gnum_t
global mesh entity number
Definition: cs_defs.h:310
Definition: cs_defs.h:529
Definition: cs_defs.h:325
Definition: cs_matrix.h:110
cs_matrix_fill_type_t
Definition: cs_matrix.h:72
cs_matrix_type_t
Definition: cs_matrix.h:54
cs_matrix_t * cs_matrix_external(const char *type_name, bool symmetric, cs_lnum_t diag_block_size, cs_lnum_t extra_diag_block_size)
Return matrix wrapper for external library for a given fill type.
Definition: cs_matrix_default.c:665
int cs_matrix_get_tuning_runs(void)
Definition: cs_matrix_default.c:863
void cs_matrix_finalize(void)
Definition: cs_matrix_default.c:485
void cs_matrix_update_mesh(void)
Definition: cs_matrix_default.c:535
cs_matrix_t * cs_matrix_native(bool symmetric, cs_lnum_t diag_block_size, cs_lnum_t extra_diag_block_size)
Definition: cs_matrix_default.c:640
void cs_matrix_vector_native_multiply(bool symmetric, cs_lnum_t db_size, cs_lnum_t eb_size, int f_id, const cs_real_t *dam, const cs_real_t *xam, cs_real_t *vx, cs_real_t *vy)
Definition: cs_matrix_default.c:418
cs_matrix_t * cs_matrix_copy_to_external(cs_matrix_t *src, bool symmetric, cs_lnum_t diag_block_size, cs_lnum_t extra_diag_block_size)
Copy base matrix to external library matrix type for given fill type.
Definition: cs_matrix_default.c:769
void cs_matrix_initialize(void)
Definition: cs_matrix_default.c:464
void cs_matrix_default_set_type(cs_matrix_fill_type_t fill_type, cs_matrix_type_t type)
Set default matrix type for a given fill type.
Definition: cs_matrix_default.c:881
void cs_matrix_default_set_tuned(cs_matrix_t *m)
Definition: cs_matrix_default.c:806
cs_matrix_t * cs_matrix_msr(bool symmetric, cs_lnum_t diag_block_size, cs_lnum_t extra_diag_block_size)
Definition: cs_matrix_default.c:612
const cs_gnum_t * cs_matrix_get_block_row_g_id(const cs_matrix_t *m)
Return a (0-based) global block row numbering for a given matrix.
Definition: cs_matrix_default.c:902
cs_matrix_t * cs_matrix_set_coefficients_by_assembler(const cs_field_t *f, cs_matrix_type_t type, bool symmetric, cs_lnum_t diag_block_size, cs_lnum_t extra_diag_block_size, const cs_real_t *da, const cs_real_t *xa)
Assign coefficients to a matrix using a matrix assembler.
Definition: cs_matrix_default.c:942
cs_matrix_t * cs_matrix_default(bool symmetric, cs_lnum_t diag_block_size, cs_lnum_t extra_diag_block_size)
Definition: cs_matrix_default.c:577
void cs_matrix_set_tuning_runs(int n_min_products)
Definition: cs_matrix_default.c:847
Definition: cs_field.h:131
