7.2
cs_turbulence_ke.c File Reference
#include <errno.h>
#include <stdarg.h>
#include <float.h>
#include "cs_array.h"
#include "cs_balance.h"
#include "cs_blas.h"
#include "cs_equation.h"
#include "cs_equation_iterative_solve.h"
#include "cs_face_viscosity.h"
#include "cs_field_default.h"
#include "cs_field_pointer.h"
#include "cs_gradient.h"
#include "cs_lagr.h"
#include "cs_log_iteration.h"
#include "cs_mass_source_terms.h"
#include "cs_math.h"
#include "cs_prototypes.h"
#include "cs_rotation.h"
#include "cs_thermal_model.h"
#include "cs_time_step.h"
#include "cs_turbulence_rotation.h"
#include "cs_velocity_pressure.h"
#include "cs_at_data_assim.h"
#include "cs_atprke.h"
#include "cs_turbulence_ke.h"
+ Include dependency graph for cs_turbulence_ke.c:
void cs_turbulence_ke (cs_lnum_t ncesmp, cs_lnum_t icetsm[], int itypsm[], const cs_real_t dt[], cs_real_t smacel[], cs_real_t *prdv2f)
 Solve the k-epsilon equations. More...
void cs_turbulence_ke_clip (cs_lnum_t n_cells, int iclip)
 Clipping of the turbulent kinetic energy and turbulent dissipation. More...
void cs_turbulence_ke_q_mu_t (void)
 Calculation of turbulent viscosity for the non-linear quadratic K-epsilon from Baglietto et al. (2005) More...
void cs_turbulence_ke_q (cs_real_6_t rij[])
 Calculation of non linear terms of the quadratic k-epsilon model (Baglietto et al.) More...
Solve the $ k - \varepsilon $ for incompressible flows or slightly compressible flows for one time step.
◆ cs_turbulence_ke()
void cs_turbulence_ke ( cs_lnum_t  ncesmp,
cs_lnum_t  icetsm[],
int  itypsm[],
cs_real_t  smacel[],
cs_real_t prdv2f
[in]ncesmpnumber of cells with mass source term
[in]icetsmindex of cells with mass source term
[in]itypsmmass source type for the variables size: [nvar][ncesmp]
[in]dttime step (per cell)
[in]smacelvalues of the variables associated to the mass source (for the pressure variable, smacel is the mass flux) size: [nvar][ncesmp]
[out]prdv2fv2f production term
◆ cs_turbulence_ke_clip()
void cs_turbulence_ke_clip ( cs_lnum_t  n_cells,
int  iclip
[in]n_cellsnumber of cells
[in]iclipindicator = 0 if viscl0 is used otherwise viscl is used.
◆ cs_turbulence_ke_q()
void cs_turbulence_ke_q ( cs_real_6_t  rij[])
[out]rijnon linear terms of quadratic Boussinesq approximation
◆ cs_turbulence_ke_q_mu_t()
void cs_turbulence_ke_q_mu_t ( void  )
