1 #ifndef __CS_TURBULENCE_KE_H__ 2 #define __CS_TURBULENCE_KE_H__ double precision, dimension(:,:), allocatable, target smacel
Definition: pointe.f90:199
cs_real_t cs_real_6_t[6]
Definition: cs_defs.h:337
void cs_turbulence_ke_q(cs_real_6_t rij[])
Calculation of non linear terms of the quadratic k-epsilon model (Baglietto et al.)
Definition: cs_turbulence_ke.c:2314
void cs_turbulence_ke_clip(cs_lnum_t n_cells, int iclip)
Clipping of the turbulent kinetic energy and turbulent dissipation.
Definition: cs_turbulence_ke.c:1999
void cs_turbulence_ke(cs_lnum_t ncesmp, cs_lnum_t icetsm[], int itypsm[], const cs_real_t *dt, cs_real_t smacel[], cs_real_t *prdv2f)
Solve the k-epsilon equations.
Definition: cs_field_pointer.h:73
integer, dimension(:,:), allocatable, target itypsm
Definition: pointe.f90:193
Definition: cs_defs.h:322
void cs_turbulence_ke_q_mu_t(void)
Calculation of turbulent viscosity for the non-linear quadratic K-epsilon from Baglietto et al...
Definition: cs_turbulence_ke.c:2225
integer, dimension(:), allocatable, target icetsm
Definition: pointe.f90:184
Definition: cs_defs.h:316
