7.2
+ Collaboration diagram for Auxiliary:
integer, save ncepdc
integer, dimension(:), allocatable icepdc
double precision, dimension(:,:), allocatable ckupdc
double precision, dimension(:), allocatable, target b_head_loss
 Head loss factor of the fluid outside the domain, between infinity and the entrance (for ifrent boundary type). The default value is 0, dimensionless factor. The user may give a value in cs_user_boundary_conditions in the array rcodcl(ifac, ipr, 2). More...
integer, save ncetsm
integer, dimension(:), allocatable, target icetsm
integer, dimension(:), allocatable izctsm
 zone where a mass source term is imposed. More...
integer, dimension(:,:), allocatable, target itypsm
double precision, dimension(:,:), allocatable, target smacel
double precision, dimension(:), allocatable, target gamcav
 liquid-vapor mass transfer term for cavitating flows and its derivative with respect to pressure More...
double precision, dimension(:), allocatable, target dgdpca
double precision, dimension(:,:), allocatable xref_cond
 reference point for wall condensation, used in forced and mixed convection regimes More...
integer, save ncmast
 number of the ncmast cells in which a condensation source terms is imposed. See lstmast list and the subroutine cs_user_metal_structures_source_terms More...
integer, dimension(:), allocatable ltmast
 list on the ncmast cells in which a condensation source terms is imposed. See the user subroutine cs_user_metal_structures_source_terms. More...
integer, dimension(:), allocatable izmast
 zone type where a condensation source terms is imposed to model the metal structures condensation on a volumic zone. More...
integer, dimension(:,:), allocatable itypst
 type of condensation source terms for each variable More...
double precision, dimension(:,:), allocatable svcond
 value of the condensation source terms for pressure associated to the metal structures modelling. For the other variables, eventual imposed specific value. See the user subroutine cs_user_metal_structures_source_terms. More...
double precision, dimension(:), allocatable flxmst
 value of the thermal flux for the condensation model associated to the metal structures modelling. See the user subroutine cs_user_metal_structures_source_terms. More...
◆ b_head_loss
◆ ckupdc
value of the coefficients of the pressure drop tensor of the ncepdc cells in which a pressure drop is imposed. Note the 6 values are interleaved as follows: (k11, k22, k33, k12, k23, k13). See ickpdc
◆ dgdpca
◆ flxmst
◆ gamcav
◆ icepdc
number of the ncepdc cells in which a pressure drop is imposed. See {iicepd}
◆ icetsm
number of the ncetsm cells in which a mass source term is imposed. See iicesm and the user subroutine cs_user_mass_source_terms}}
◆ itypsm
type of mass source term for each variable
  • 0 for an injection at ambient value,
  • 1 for an injection at imposed value.
◆ itypst
◆ izctsm
◆ izmast
◆ ltmast
◆ ncepdc
number of cells in which a pressure drop is imposed.
◆ ncetsm
number of the ncetsm cells in which a mass source term is imposed. See iicesm also
◆ ncmast
◆ smacel
value of the mass source term for pressure. For the other variables, eventual imposed injection value. See the user subroutine cs_user_mass_source_terms
◆ svcond
◆ xref_cond
