7.2
cs_log_iteration.h
1 #ifndef __CS_LOG_ITERATION_H__
2 #define __CS_LOG_ITERATION_H__
5  * Log field and other array statistics at relevant time steps.
35  * Local headers
38 #include "cs_base.h"
39 #include "cs_mesh_location.h"
40 #include "cs_time_step.h"
45
47  * Macro definitions
49
51  * Local type definitions
53
54 /*=============================================================================
55  * Global variables
57
61
62 /*----------------------------------------------------------------------------
63  * Free arrays possible used by logging of array statistics.
64  *----------------------------------------------------------------------------*/
65
66 void
68
69 /*----------------------------------------------------------------------------
70  * Log field and other array statistics for the current time step.
71  *----------------------------------------------------------------------------*/
72
73 void
74 cs_log_iteration(void);
75
76 /*----------------------------------------------------------------------------
77  * Add or update array not saved as permanent field to iteration log.
78  *
79  * parameters:
80  * name <-- array name
81  * category <-- category name
82  * loc_id <-- associated mesh location id
83  * is_intensive <-- are the matching values intensive ?
84  * dim <-- associated dimension (interleaved)
85  * val <-- associated values
86  *----------------------------------------------------------------------------*/
87
88 void
89 cs_log_iteration_add_array(const char *name,
90  const char *category,
91  const cs_mesh_location_type_t loc_id,
92  bool is_intensive,
93  int dim,
94  const cs_real_t val[]);
95
96 /*----------------------------------------------------------------------------
97  * Add or update clipping info for a given array.
98  *
99  * parameters:
100  * name <-- array name
101  * dim <-- associated dimension
102  * n_clip_min <-- number of local clippings to minimum value
103  * n_clip_max <-- number of local clippings to maximum value
104  * min_pre_clip <-- minimum values prior to clipping
105  * max_pre_clip <-- maximum values prior to clipping
106  */
107 /*----------------------------------------------------------------------------*/
108
109 void
110 cs_log_iteration_clipping(const char *name,
111  int dim,
112  cs_lnum_t n_clip_min,
113  cs_lnum_t n_clip_max,
114  const cs_real_t min_pre_clip[],
115  const cs_real_t max_pre_clip[]);
116
117 /*----------------------------------------------------------------------------
118  * Add or update clipping info for a field.
119  *
120  * parameters:
121  * f_id <-- associated field id
122  * n_clip_min <-- number of local clippings to minimum value
123  * n_clip_max <-- number of local clippings to maximum value
124  * min_pre_clip <-- minimum values prior to clipping
125  * max_pre_clip <-- maximum values prior to clipping
126  */
128
129 void
131  cs_lnum_t n_clip_min,
132  cs_lnum_t n_clip_max,
133  const cs_real_t min_pre_clip[],
134  const cs_real_t max_pre_clip[],
135  cs_lnum_t n_clip_min_comp[],
136  cs_lnum_t n_clip_max_comp[]);
137
138 /*----------------------------------------------------------------------------
139  * Log L2 time residual for every variable fields.
140  *----------------------------------------------------------------------------*/
141
142 void
143 cs_log_l2residual(void);
144
145 /*----------------------------------------------------------------------------*/
146
148
149 #endif /* __CS_LOG_ITERATION_H__ */
Definition: cs_mesh_location.h:60
void cs_log_iteration_destroy_all(void)
Definition: cs_log_iteration.c:1378
Definition: cs_defs.h:322
void cs_log_iteration(void)
Definition: cs_log_iteration.c:1418
void cs_log_l2residual(void)
Definition: cs_log_iteration.c:1661
Definition: cs_defs.h:316
void cs_log_iteration_clipping(const char *name, int dim, cs_lnum_t n_clip_min, cs_lnum_t n_clip_max, const cs_real_t min_pre_clip[], const cs_real_t max_pre_clip[])
Definition: cs_log_iteration.c:1605
void cs_log_iteration_clipping_field(int f_id, cs_lnum_t n_clip_min, cs_lnum_t n_clip_max, const cs_real_t min_pre_clip[], const cs_real_t max_pre_clip[], cs_lnum_t n_clip_min_comp[], cs_lnum_t n_clip_max_comp[])
Definition: cs_log_iteration.c:1639
void cs_log_iteration_add_array(const char *name, const char *category, const cs_mesh_location_type_t loc_id, bool is_intensive, int dim, const cs_real_t val[])
Definition: cs_log_iteration.c:1450
