7.2
cs_rotation.h
1 #ifndef __CS_ROTATION_H__
2 #define __CS_ROTATION_H__
5  * Rotation modeling features.
34 #include "cs_defs.h"
41  * Local Type Definitions
44 /* Rotation structure */
45
46 typedef struct {
48  double omega;
49  double angle;
50  double axis[3];
51  double invariant[3];
52
54
55 /*============================================================================
56  * Global variables
58
60
61 /*============================================================================
62  * Public function prototypes
63  *============================================================================*/
64
65 /*----------------------------------------------------------------------------
66  * Define a global rotation.
67  *
68  * The rotation vector's length determines the angular velocity (in rad/s).
69  *
70  * parameters:
71  * omega_x <-- rotation vector x component
72  * omega_y <-- rotation vector y component
73  * omega_z <-- rotation vector z component
74  * invariant_x <-- invariant point x component
75  * invariant_y <-- invariant point y component
76  * invariant_z <-- invariant point z component
77  *----------------------------------------------------------------------------*/
78
79 void
80 cs_rotation_define(double omega_x,
81  double omega_y,
82  double omega_z,
83  double invariant_x,
84  double invariant_y,
85  double invariant_z);
86
87 /*----------------------------------------------------------------------------
88  * Compute rotation matrix
89  *
90  * parameters:
91  * theta <-- rotation angle, in radians
92  * axis <-- rotation axis direction vector
93  * invariant_point <-- invariant point coordinates
94  * matrix -> resulting rotation matrix
95  *---------------------------------------------------------------------------*/
96
97 void
99  const double axis[3],
100  const double invariant_point[3],
101  double matrix[3][4]);
102
103 /*----------------------------------------------------------------------------
104  * Update coordinates based on a global rotation and time.
105  *
106  * parameters:
107  * n_coords <-- number of coordinates
108  * t_rot <-- time since rotation start
109  * coords <-> coordinates array
110  *----------------------------------------------------------------------------*/
111
112 void
114  double t_rot,
115  cs_real_3_t coords[]);
116
117 /*----------------------------------------------------------------------------
118  * Compute rotation velocity relative to fixed coordinates at a given point.
119  *
120  * parameters:
121  * r <-- pointer to rotation structure
122  * coords <-- coordinates at point
123  * vr --> relative velocity
124  *---------------------------------------------------------------------------*/
125
126 static inline void
128  const cs_real_t coords[3],
129  cs_real_t vr[3])
130 {
131  vr[0] = (- r->axis[2] * (coords[1] - r->invariant[1])
132  + r->axis[1] * (coords[2] - r->invariant[2])) * r->omega;
133  vr[1] = ( r->axis[2] * (coords[0] - r->invariant[0])
134  - r->axis[0] * (coords[2] - r->invariant[2])) * r->omega;
135  vr[2] = (- r->axis[1] * (coords[0] - r->invariant[0])
136  + r->axis[0] * (coords[1] - r->invariant[1])) * r->omega;
137 }
138
139 /*----------------------------------------------------------------------------
140  * Add a Coriolis term to a vector.
141  *
142  * parameters:
143  * r <-- pointer to rotation structure
144  * c <-- multiplicative coefficient
145  * v <-- velocity
146  * vr <-> vector to which Coriolis term is added
147  *---------------------------------------------------------------------------*/
148
149 static inline void
151  cs_real_t c,
152  const cs_real_t v[3],
153  cs_real_t vr[3])
154 {
155  double f = r->omega * c;
156
157  vr[0] += (- r->axis[2]*v[1] + r->axis[1]*v[2]) * f;
158  vr[1] += (- r->axis[0]*v[2] + r->axis[2]*v[0]) * f;
159  vr[2] += (- r->axis[1]*v[0] + r->axis[0]*v[1]) * f;
160 }
161
162 /*----------------------------------------------------------------------------
163  * Compute a vector Coriolis term.
164  *
165  * parameters:
166  * r <-- pointer to rotation structure
167  * c <-- multiplicative coefficient
168  * v <-- velocity
169  * vr --> vector associted to Coriolis term
170  *---------------------------------------------------------------------------*/
171
172 static inline void
174  cs_real_t c,
175  const cs_real_t v[3],
176  cs_real_t vr[3])
177 {
178  double f = r->omega * c;
179
180  vr[0] = (- r->axis[2]*v[1] + r->axis[1]*v[2]) * f;
181  vr[1] = (- r->axis[0]*v[2] + r->axis[2]*v[0]) * f;
182  vr[2] = (- r->axis[1]*v[0] + r->axis[0]*v[1]) * f;
183 }
184
185 /*----------------------------------------------------------------------------
186  * Add the dual tensor of a rotation vector to a tensor
187  * The dual tensor is such that:
188  * tr[i][j] * v[j] = (omage ^ v)_(ij)
189  *
190  * parameters:
191  * r <-- pointer to rotation structure
192  * c <-- multiplicative coefficient
193  * tr <-> tensor to which dual tensor of rotation is added
194  *---------------------------------------------------------------------------*/
195
196 static inline void
198  cs_real_t c,
199  cs_real_t tr[3][3])
200 {
201  double f = r->omega * c;
202
203  tr[0][1] -= r->axis[2]*f;
204  tr[0][2] += r->axis[1]*f;
205
206  tr[1][0] += r->axis[2]*f;
207  tr[1][2] -= r->axis[0]*f;
208
209  tr[2][0] -= r->axis[1]*f;
210  tr[2][1] += r->axis[0]*f;
211 }
212
213 /*----------------------------------------------------------------------------
214  * Compute the dual tensor of a rotation vector
215  * The dual tensor is such that:
216  * tr[i][j] * v[j] = (omage ^ v)_(ij)
217  *
218  * parameters:
219  * r <-- pointer to rotation structure
220  * c <-- multiplicative coefficient
221  * tr --> dual tensor of rotation
222  *---------------------------------------------------------------------------*/
223
224 static inline void
226  cs_real_t c,
227  cs_real_t tr[3][3])
228 {
229  double f = r->omega * c;
230
231  tr[0][0] = 0.;
232  tr[0][1] = - r->axis[2]*f;
233  tr[0][2] = r->axis[1]*f;
234
235  tr[1][0] = r->axis[2]*f;
236  tr[1][1] = 0.;
237  tr[1][2] = - r->axis[0]*f;
238
239  tr[2][0] = - r->axis[1]*f;
240  tr[2][1] = r->axis[0]*f;
241  tr[2][2] = 0.;
242 }
243
244 /*----------------------------------------------------------------------------*/
253 /*----------------------------------------------------------------------------*/
254
255 void
257  const cs_real_t coords[3],
258  const cs_real_t v[3],
259  cs_real_t vc[3]);
260
261 /*----------------------------------------------------------------------------
262  * Copy rotation structure values to an array
263  *
264  * This may be useful to avoid requiring specific type mappings for MPI or
265  * other programming languages.
266  *
267  * parameters:
268  * r_num <-- rotation number (1 to n numbering, 0 for none)
269  * fra --> flat rotation array: axis (0-2), invariant(3-5),
270  * omega (6), angle(7)
271  *---------------------------------------------------------------------------*/
272
273 void
274 cs_rotation_to_array(int r_num,
275  cs_real_t fra[8]);
276
277 /*----------------------------------------------------------------------------*/
278
280
281 #endif /* __CS_ROTATION_H__ */
static void cs_rotation_coriolis_t(const cs_rotation_t *r, cs_real_t c, cs_real_t tr[3][3])
Compute the dual tensor of a rotation vector.
Definition: cs_rotation.h:225
void cs_rotation_matrix(double theta, const double axis[3], const double invariant_point[3], double matrix[3][4])
Compute rotation matrix.
Definition: cs_rotation.c:400
static void cs_rotation_add_coriolis_t(const cs_rotation_t *r, cs_real_t c, cs_real_t tr[3][3])
Add the dual tensor of a rotation vector to a tensor.
Definition: cs_rotation.h:197
Subdomain rotation description.
Definition: cs_rotation.h:46
Definition: cs_defs.h:322
double invariant[3]
Definition: cs_rotation.h:51
double precision, dimension(:,:,:), allocatable v
Definition: atimbr.f90:114
static void cs_rotation_velocity(const cs_rotation_t *r, const cs_real_t coords[3], cs_real_t vr[3])
Compute velocity relative to a fixed frame at a given point.
Definition: cs_rotation.h:127
double axis[3]
Definition: cs_rotation.h:50
static void cs_rotation_coriolis_v(const cs_rotation_t *r, cs_real_t c, const cs_real_t v[3], cs_real_t vr[3])
Definition: cs_rotation.h:173
cs_rotation_t * cs_glob_rotation
double angle
Definition: cs_rotation.h:49
static void cs_rotation_add_coriolis_v(const cs_rotation_t *r, cs_real_t c, const cs_real_t v[3], cs_real_t vr[3])
Definition: cs_rotation.h:150
double precision, dimension(:,:,:), allocatable theta
Definition: atimbr.f90:123
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:335
void cs_rotation_update_coords(cs_lnum_t n_coords, double t_rot, cs_real_3_t coords[])
Definition: cs_rotation.c:490
Definition: cs_defs.h:316
double omega
Definition: cs_rotation.h:48
void cs_rotation_cyl_v(const cs_rotation_t *r, const cs_real_t coords[3], const cs_real_t v[3], cs_real_t vc[3])
Express a vector in the cyclindrical system associated to a rotation.
Definition: cs_rotation.c:520
void cs_rotation_define(double omega_x, double omega_y, double omega_z, double invariant_x, double invariant_y, double invariant_z)
Definition: cs_rotation.c:363
void cs_rotation_to_array(int r_num, cs_real_t fra[8])
Copy rotation structure values to an array.
Definition: cs_rotation.c:575
